distributor problem
Old Jul 14, 2015 | 10:43 AM
BOBCOLE's Avatar
Default distributor problem
I BOUGHT A DURALAST DISTRIBUTOR FOR 1991 HONDA CIVIC HATCHBACK, 1.5.. would not work, I checked it and the rotor pin pointed at plug pin at tdc and after, was the time it was lined up so as to send spark to plug, my distributor lined up with plug pin from 20degrees to tdc, , the duralast will not worl, does anyone seen this problem, what can I do??
Old Jul 14, 2015 | 01:08 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: distributor problem
Can you post pictures of what you are talking about? Or maybe describe it a bit more carefully? I'm pretty sure I'm not going to be the only one who says I'm not following what you're describing.
Old Jul 15, 2015 | 10:55 AM
tamboo's Avatar
10 Year Member
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
EsCo_EsCo
Sep 29, 2008 08:25 AM
SunkistRex
Mar 14, 2004 08:06 AM
Kg cm2
Jan 28, 2003 09:08 PM
