View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Mugen parts
- teg seats in crx
- Flywheels
- those with mini-me swaps.....
- amber side markers?
- do a couple of ls swap q's...
- alternator belt
- Getting ready to do my clutch...(pics)....+ some ?'s....
- any one ever convert crx into OBD1
- rear 1/4 panels -rusted, dented, replacement?
- rollcage
- My RPM gauge and engine are going crazy!!! HELP
- Is a zc even fawking worth it?
- 89 Civic DX swap
- 88 crx si stock cam
- destoyed my motor mount today
- HELP!! Clutch is going BONKERS!!!
- What kind of plug wires for b16a?????????
- North east bbq in Ct this weekend. sat 27
- 88-91 CRX DX seat into 91 Civic DX
- WTF!?!?!?!? what u think? give me some input, and dont go to edgewater!
- d15b2 block and z6 head ?
- Inconsistent engine tick??
- Car won't rev past 6800 RPMS (Zdyne ECU)
- buddy club exhuast
- Clutch for zc tranny
- A-Support bars?
- What rotor button for my b16a ??
- Help rex is SLOOOW
- If you did a zc swap read this.
- Weird hesitation...
- 90 crx si motor into a 91 civic dx hatch?
- zc wont start any suggestions?
- 1988 CRX HF race project
- check this swap out
- zc won't start any suggestions
- help. need a a good engine supplier in southern california.
- problems with the wheel hub
- 91 hatch si fuel pump rating?
- What "toe-in" settings for 87 CRX with Ground control and Tokicos?
- 88/89 and 90/91 crx front pads different?
- 91 civic interior
- what is it called?
- engine stalls
- what is the difference in gearing in b trannys
- *anyone ever try to mod a spoon mirror or those fake spoon mirrors for our cars?*
- Im new to the board and am very pleased.
- help with turbo on b16a
- zc tranny?
- can 91 crx brakes fit a 91 civic hatch dx??
- b series Question
- EF Picture & Video Thread (NO COMMENTS)
- B16a in a 90 dx, the Temp gauge no longer workin?
- Itr gauge cluster in a crxsi
- Tein Coilovers....Problem?
- h22 injectors in b16a
- What color is your carpet in your 90-91 si hatch?
- Y1, S1 Tranny Question
- b16 into hf clarification
- First year for rear disc brakes on CRX Si???
- Which shifter bushings with SiR shift linkage and short shifter?
- Now it's a CEL code 5! help!
- Has anybody ordered a rollbar online?
- h22 swap into ef hatchback.....
- Um, help????
- 88-91 Civic STD manifold
- what can i do?
- swap motors?
- will si axles fit on the zc tranny?
- JDM B16A emissions(for a friend)
- Catalytic Converter
- Tired of everyone complaining
- mini-me: where do I start?
- jumper from obd0-obd1
- 86CRX-si i need a good base motor i wana go all out TURBO i have 15k to spend right now on it
- GSR rear seats?
- everyone APC vote!!!!!!!!!!
- Please help CRX guru's
- short shifter
- OBD0 to OBD1
- b-series to d-series tranny changability!!
- 88 HF, but 89 on the title?
- 86CRX si i wana go all out turbo what base motor should i go with? allso i am going all out so plas
- My $300 CRX Project (56k beware)
- shift bushing/stabalizing, which kit for a B16a 89 CRX?
- new in the old or not at all?
- swapped my fields ecu for a stock one on my b16 an now CEL,wtf?
- Upper Control Arm Options
- What Distribs. Can i use with my JDM B16A ??
- My '91 D16A6...
- Missing B16a......But its running better!
- 89CRX + B16a1 = ?CA legal how?
- B16a reference guide (What parts from what cars to use)
- B16a+n2o Spark Plugs, NGK BKR61IX-11's? and wires?
- Automatic Gauge Cluster
- pin hole leak in bypass hose
- Fuel pump + tank install
- homemade shift light?
- TRANSMISSION TECH: ZC 5th gear in a Y1 tranny?
- Greddy Turbo *Blue Box* Need wiring
- Shift Light
- power windows?
- PR3??? PWO????
- got my rex lowered today...
- Anyone have any springs they want to get rid of??
- Manual Conversion in 4dr
- I got my Rex back...kinda upset.
- Smog ref today (last tips?)
- car stumbling.....
- Quick Pic for my CRX Pals.....
- what are the reasons for locking a thread?
- problems starting
- Need Bolts and nuts?
- crx rt4wd?
- Differnece between LS/Vtec and B16?
- VTEC rod bearings on my d16a6
- opinions on exhuast
- wheel rubbing problems
- how difficult is it to re-build a si tranny?
- paying insurance is a Bitch!
- Questions on the JDM CRX SiR
- Idle help
- d16a6 sohc non-vtec with sovc vtec head
- b18c1 swap question
- I need some help!!!!!!!
- b18 questions
- new swap
- bay area peeps
- Injector flow rates?
- b16a with cai?
- APC 88-91 crx short shifter in a 1gen
- who runs ground control coilovers
- crx sunroof rattle...
- z10 buy
- Exhaust/Fuel/Ignition problem? Car runs like garbage! Help please
- What starter to can I use on my hybrid?
- Best header for ls/v-tec in crx
- need timing belt for b16a1
- timing
- A/C in B16a CRX, need help, compressor combos, bracket info, etc...
- alarm?
- need some help removing coolant drain bolt on block of b16
- What seat should I get?
- I fixed snapped timing belt...now tach needle bouncing !!
- Is Carbon Fiber considered JDM??
- Car wont start....HELP please!
- b16a swappers looky here
- 1st gen b16 pwo ecu $200 and b16 distributor $125 or both for 275
- Identifying Tranny
- East Coast Meet!
- 370 injectors
- 94 up integra dash swap
- Are automatic camshafts and 5 speed camshafts the same???
- What is wrong with my ZC?
- Battle of the Imports!!
- Simple motor swap
- who has fit a skyline sized intercooler(24x10.8x3) in a stock ef bumper?
- how good are hasports mounts??
- anybody have a built all motor ZC?
- Yes!! I am buying this Hyundai CRX. Link inside!
- 90-93 Teg springs on a CRX????
- stupid emissions
- Name This Steering Wheel
- need to know torque spec for front motor mount
- Need rebuild kit for 91 Si motor
- changes from 88 to 91yrs civic/crx's??
- might be selling d16y7?how much?
- What do you think? My first car? Need to drive it daily? Still want to play with it...
- 87 CRX Engine Grounds/Chassis Grounds
- What radiators can i use for a 89 CRX Si?? broke mine and need new one now..
- Adding air conditioning to 89 CRX si - Help please?
- Old school wheels...
- Failed smog inspection
- ECU found...
- ITR seats fit a 2001 Civic???
- pics of my ride . flame on ?!
- 85 civic ??????is thereany thing ican do
- What does CRX stand for?
- My ZC turbo 1/4 mile times....
- FS: CRX SiR Headlights, SiR hood more...
- mini me question and .std ?
- Volk TE 37 vs. RacingHart CP-035
- D/B Series questions...
- CRX battery relocation
- Just had a B16A dropped into '89 CRX and now it's not working...need help!!!
- vafc and 440 dsm injectors?????
- Weight of stock Honda rims.
- fs. hondata equiped pwo
- crx hf trunk area????
- Mini-Me swap in dx
- 4 Wire O2 install
- whining noise on alternator on b16
- Is there a way to take the lenses out of CRX Tail Lights?
- starting parts car w/ no key
- Extra sensor on ZC?
- Zc dizzy wiring, not normal?
- will this head fit my engine?
- What are the differences between the JDM and USDM CRX headlights?
- Making a 88 dx fast?
- b16a EGR valve?
- any of you guys just have the ww front bumper on your rex?
- shocks
- d power
- Why is my b16a so fuckin slow!!
- moisture in headlights
- DIST.?????
- I just got excepted for a 5,000 dollar credit limit.....
- Rear Disc Brake Conversion on 89 Hatch DX
- Need help adding air conditioning to 89 CRX si
- new tim/belt now a code 9
- crx exhaust fit on a hb?
- a/c - heater controls
- 89 HF questions and advice?
- b16a ecu help
- I need susp set up for 87 hb
- spark plugs for b16
- Please Read!!!! DOHC 1.6l into 91crx Starter Problem!!!
- Engine troubles, car wont start or run...
- CEL #13
- Are you happy with your "mini-me?"
- d15 vs d16
- b16a tranny syncros
- What is needed?????
- shocks quick need help
- gap between my siR headlights an corner lights?
- New here. NEED HELP
- First race with b16a....plz read and help!
- crx amber corners
- D16Z6 giving me hell....
- Question about rear trunk/interior panels on 88-91 CRX Si
- anyone in NJ or NY go to Nanuet on wed & sun nights?
- Squeeking from front end...getting aggrivating after putting $200 into it already...
- Help! I need A new main relay for my 90 crxsi !
- Got a Final Drive?
- what is the weight of a STOCK 1990 CIVIC SI?????????????????????????????
- slicks for a 91 crx?
- ZC swap gone bad any suggestions??
- Neuspeed coilovers(not sleeve)
- can someone help me w/ idel problems (pics to show)
- valve adjusting
- Are alternators all the same for 88-91 CRX Si/DX/HF?
- for your viewing pleasure, HIN pics..
- help i lost my zc parts list
- Yeah, so did you move?
- help
- where to find cheap rotors?
- Anyone need an A6 head?
- wiring gurus?
- need help asap rev limiter prob
