View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ebay obd1 conversion harness code 4 fix!!!
- Weird problems, need some help.
- NEED help! EF code 3
- 91 civic z6 swap knocking noise from clutch/trany/dizzy area
- 91 Civic hatch engine problems!
- need diagram of pic 88si c210
- 89 DX hatch - D15B2 with P2J-2 head - Engine help!
- please help with ef shell
- 1991 civic wagon rt4wd tranny upgrade
- what camshaft do you guys know will produce more?
- what's uo ppl
- My first Civic!!
- Video: CRX SI - Music to the Ears
- Trans swap
- need insight on jdm d15 non v
- 89 Si clutch pedal spring??
- MPFI intake question
- B16a mild build help
- How To:Lower Ball Joint
- 88-91 Honda CRX 1.5L DUAL CARBS - Anyone Have one?
- 91 civic wagon clutch cable question.
- code 4
- 91 civic hb bseries and 91 civic sedan swap
- The feel of the car
- Overflow bubbling car overheating
- Hazards/ Signals
- mixing clutch flywheel and pressure plates
- starting issues...
- wire diagram for 89 trunk glass heater
- Adding INTERMITTENT WIPERS to a 1990 Civic EF 3 dr. Std.
- 89 CRX car wanted to die after jumping battery
- intake manifold identication pm6 hf-5
- 1989 Sedan HID help!
- 1989 CRX Build/Restore Thread
- 1989 and 1990 CRX
- Code 5 and 16. Horrible MPG!! please help!!
- New wagon!! small issue looking for some help!
- does SH4 interior fit in SH3 hatch?
- Can someone identify these two connectors?
- crx/si rear disc set up
- EF Knuckle Queston
- Help! How to Seperate Drive shaft from Knuckle
- Best suspension under 2500
- Questions about Hubs , Interchageability Rear Hubs with Axles
- EF Sedan Auto to Manual (Gearbox Mounts ?)
- OBD1 shocktower plugs on EF
- difference between b16a SIR1 and b16a1 ?
- Looking for 1991 torque values for the front suspension
- Will a Integra dual bend shifter fit in Innovative Mounts Shift Linkage?
- replacing drivers side door, couple questions?
- 91 Civic Dash
- CALLING ALL OLD CRX / EF Civic (1988-1991) Members! no tech, please dont delete!
- shift linkage/cable park is reverse. and d4 works in N
- question for the ef sedan owners
- HF TPS Low volts at WOT even with new TPS
- Seat mounting
- increased cr in d15
- need to know which wires for each sensor
- Crx itr interior?
- Importing a '90 EUDM CRX VT in 2015
- 1989 honda civic / bypass ign.
- car not starting : changed the starter and battery,
- coil melted
- Hood Cable disconnected
- lag on take off
- Squeaking sound from driver side wheel
- Distributor cap??
- car turns on but turns off
- JDM fenders
- moisture in trunk/ seats
- Fast Idle 2000RPM causes Check Engine = Failed Emmisions Test
- Quiet but light exhaust???
- Clutch problems with z6 block and 1990 lx tranny after rebuild
- JDM 96-97 B18C A/C compressor into CRX
- 91 si motor options
- mini me question
- 2 questions: Wipers & Oil leak
- engine wont crank by hand when i install transmission
- 96 B18C-R into 88 CRX SI w/ Chipped obd1 ECU Wiring Q's - Please review
- obd0 ef b20v knock sensor
- Hush Performance Hydro Conversion - Who is running one????
- D15B2 weird oil pressure issue
- Idle problem
- Cable to Hydro options?
- smells like exhaust in my car after accident
- b18a1 code 1 help.
- DOHC ZC clutch option
- b18a1 in 91 civic si hatch no crank
- oil keeps showing up?
- B16A Swap or a D16 turbo?
- Hasport vs Innovative mounts for B series engines
- B-Series Swap Parts Shopping List?
- how does top of door panel go on door ?
- 91 civic auto trans shift problems and surging idle
- 91 Civic ED3 built thread
- D-series clutch compatibility question for swap
- Ultra Carbon Fiber sunroof delete install
- Rear Fog light install on USDM hatch bumper
- Length of clutch cable?
- D15b1, Misfire on cyl #1
- Clarification on Hf vs Si/DX rear bumper supports
- coolent leak - Starting to get agitated.
- 89 Civic SI - Right Transmission mount bracket, Where do I get one?
- Help! just did a new timing belt and the car has no compression!
- D16y7 wont budge
- Y1 to Hydro conversion?
- Turns over but won't run
- Ls swap into crx ecu and power steering help
- GSR idle
- hf or dx
- D16y7 build
- 91 civic wagon wire tuck help
- b16/ef sedan
- Should these 2 connect?
- 91 crx si - alternator problems
- b16a2 swap
- steering wheel ignition lock bolts?
- crx head swap
- D16A6 into '90 CRX HF, questions
- spoon sport cluster - ?
- 89 ED6 Project
- anyone bother to rebuild power steering rack?
- whos running half radiator
- Installing Radio Antenna
- Vacuum lines
- need opinions about oil pans
- Need info. an Specs on a D16Z1 plz help
- is there a difference between clutch alignment tools
- 1991 Civic Hatchback Windshield Molding Clips?
- Disc brake conversion ef hatch
- 89 Hatch seat pan swap
- wiring harness
- Generation sub names?
- 88 Civic LX - Setting idle
- 89 civic si clutch change question
- 1989 Si won't start anymore
- Manual transmission car dies in reverse?
- Idle Issue
- What are the best tires for a 1990 Honda crx si?
- high idle and bogging when accelerating
- where can i find 2" axle back exhaust pipes?
- 90 CRX - What is the gauge of wires coming out of the ecu?
- 89 Hatch Passenger Wiper Not Wiping
- snapring lower ball joint
- code 4 help
- Brightness/Illumination Controller 90-91
- ef hatch problems with blower.
- 89 CRX No Start Other options beyond Main Relay?
- Crossmember and hub question
- steering rack question
- Ride height problems
- aftermarket rta bushings worth?
- Temp Gauge Fuckery
- EF5 Shuttle rear bumper on EF2
- Will 1991 speedo fit in 1988?
- Civic Hatch starts an shuts off. NEED HELP!
- Suspension bushings
- 89 Civic - Need opinions on engine swap
- exhaust help on my 90 1.5 DX hatch
- extra bump stop with aftermarket struts?
- DX automatic transmission same as EX?
- any places still sell sunroof plug for crx?
- 91 Civic Dx manual/obd1 b18a1 - Wires hacked
- I need some help with my first engine replacement. (ZC in RT wagon)
- OBD0 - D16A6 Setting Code 1 - not O2 sensor ?
- Bargain/universal mufflers?
- '97 Integra LS brakes on '91 CRX Si
- Cxracing full width aluminum radiator problems
- mechanic said i need adjustable radius rods?
- STUMBLED ACROSS THIS
- Ef b series questions
- fuel pump kicking out
- b16a maximum engine temp ?
- issues starting and running while cold.
- 91 Crx loud squeling noise?!
- 90 Si minime swap
- can headlight frame area be removed?
- Rotor comes loose
- Fastener for rear triangular pieces - P/N?
- Spotting Fake Floor Mats
- Back In the Honda Game! 1989 Civic Si Restoration/Project
- CV axle washers?
- Check engine light
- 91 EF/B18a1 swap - no spark after DPFI to MPFI conversion
- Crx o2 sensor wiring and colors
- auto zc questions in an 88
- 90 ef hatch turn key and just brake light comes on (solved)
- Need to write about a rex.
- Parts List for a B-Series Swap?
- b16a1 where is the fan replay located ?
- 91 EF civic hatchback randomly dies while driving but turns back on
- How would I bypass the VTEC oil pressure switch
- Suspension work
- Need help with my EF sedan
- 89 ef sedan fuel pump not priming
- oem replacement plug for stock radiator?
- Tien SS + GC tophats = possible?
- coilover suspension: not finding what im looking for
- D16a6/d15b7 puzzle
- 91 civic hatch si not starting
- tokico illuminas- one side shorter
- 89 lx sedan injector issues
- Electrical drain
- indiglo rear garnish question.
- Catback rattle
- HELP Changed HG And Wont Start
- $For Sale/Want to Buy$ - 88-91 CRX/Civic Parts Only (NO COMMENTS ALLOWED)
- I fxkcj up my speedo
- compression
- Correct LED Cluster/Climate Update?
- 1991 civic si help me please
- civic ek convert to si??
- cable transmissions
- 91 Civic Si, Wont start after running
- 1991 Civic Si Need help!!!
- Help Can't figure it out 91 civic si
- will this cap D1 Spec Thermostatic will fit ?
- 91crx si - D16Z6 Cutting out/bogging problem
- '91 CRX Crossmember Bolts
- jdm obd0 b16 head plug
- Dpfi T/B coolant bypasss
- Will 88 interior fit in 89?
- Vtec won't engage help please
- Part name/Honda catalog help
- How can I make my doors close a little better?
- New smog results..need more help please
- new to me auto 91 rt4wd
- Coolant leak at heater hose?
- 91 LX Sedan build
- Pacesetter ceramic header
- 1988 Honda Crx Intake options
- 88-91 Crx Corner lights
- 1990 SI starts, runs, then sputters to a stop
- How much coolant for the D16A?
- Dpfi mounting plate o'ring
- WHAT TYPE OF ENGINE
- 1991 Hatch
- door/belt light indicator
- fuel system question
- Floormats
- fuel pump
- Si/Manual Steering Rack Bushing
- Clanging sound by right side wheel
- what the best head for my D15B2 ????!
- TPS
- OBD1 Conversion, CEL code 4, help?
- Rhd conversion question
- 89 hatchback no start 1.5L
- D15b2 intake manifold gasket keeps splitting
- squeaky sound when turning steering wheel to the left ?
