View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Heater/Air Conditioner
- 89 civic with mpfi (b18a map question searched!!)
- Rim Size
- 91 Civic Hatchback SE Error Code
- conversion
- help need ur guys honda experties
- gsr into 90 si
- gauge cluster differences? ef si vs. ex or lx
- after ractive header
- Did I blow my head gasket???
- Has anyone shaved the tiny letters off of their tail-lights?
- best engine under $1000
- need tip for cams for B16A1
- 88 through to 91 ef weight differences
- Custom CRX door pannels
- can you fit these tires on a crx?
- 2001-05 si cluster in a rex
- ls crx?
- Rear Bumper Support
- !!! Clutch problem: master/slave cylinder failure
- LS YS1 won't START!!!
- anyone install the jdm turnsignal bumper lights on usdm harness?
- ls hatch problems
- interior lights...
- DX To ZC SOHC
- what all is needed for a rear disc brake conversion???
- Help get my pulleys off!
- exhaust question for a friend(Hf crx have a deeper spare tire well???
- modifying lip to fit crx help
- CRX will not be a collectible car...
- Brake Upgrade?
- Quick question on JDM Front bumber on USDM Car.
- What fogs are these? How do I mount them?
- Tire pressure?
- why does my car die?!
- B16 EngineSwap
- Crx Si Exhaust dimension questions
- Quick Injector question
- will the this part work on the ef wagon?
- EF8 Warning Light?
- Help guys
- No need to paint 90-91 Crx clear bumper lights amber anymore. Ebay finally caught on!
- please help ive searched header question?
- mini-me to z6 swap question
- Momo Steering Wheel Question?
- confirmation of neuspeed race spring rates
- crx dash in civic
- Some pics of the new paint
- It still wont start!!!!!!!!!
- rex wont start, please help
- a/f Gauge
- Z6 Head On D15????Possible????
- Gettin' a DOHC ZC - What distributor works?
- Harmonic Balancer.....
- b16 1/4 mile times
- need your opinion (new paint)
- Need help with head bolts.
- heavy or lighter?
- WILL A D16A1 FIT????
- Ignition Lock cylinder question....
- one pice frount ends
- good place to buy suspenshion for 90 hatch?????
- Need your guy's opinion on a crx im looking at
- 88 hf crx spline count
- Getting my CRX painted soon, need help on which color to get, pics would help!
- oxygen sensor
- dizzy
- axel nut stuck
- Best CRX Service Manual?
- Installing foglights?
- 91 Civic DX Hatchback Problems PLEASE HELP!!!
- WHO OWNS THIS CRX?
- Check out this CRX
- power steering & a/c?
- clutch cable Q
- help needed! ecu swap
- Sealing rear sprayer nozzle
- DOHC ZC crank on SOHC ZC motor
- leaky hatch
- Crx rear disk question....
- Clutch cable install?
- Flywheel\Pressure plate bolts
- what would my compression be??? (pistons)
- Quick axle queastion
- Lighting issues...Need Help
- integra font end convertion
- pic request: EF's on egay 'coilover conversions'
- injectors
- D15B2 coolant hoses on a B16 Si motor...SAME?????(88-91Civic)
- Battery light on = alternator done?
- I'M GETTING CODE 2 WHEN I RACE THE CAR
- My CRX is a DOHC ZC w/ZC tranny, its a DX, what was replaced to fit it?(hubs, ect?)
- CRX Brake Upgrade
- OBX LSD ??
- Wheels on CRX SI
- help!
- suspension sound??
- B16 OBD 0 question
- What else do i need to install ITR tranny into my ef?
- Do they make Ef crx Air ducts applications??
- Weird mushy brake? new MC
- Code 7 problem
- No power to Ecu????
- TEG brakes on my wagon and now I have no peddle
- SOHC Oil Pan baffles...where to find more info????
- New Member - Stumped about steering
- PCV Vavle for a 91 CRX
- Update Video Of My Turbo DOHC ZC *Track Video 12sec Pass*
- Was power steering an option
- CRX exh options? post em up
- Which is the best strut/tie bar for a crx 89
- what can it do or will it show that when the dizzy go bad?
- Massive Failure
- b16 crx si vaccum diagram
- Which is better for racing springs or coilover
- Need help with obd0-obd1 distributor...harness side
- CRX stuttering bad from 0-25mph...?
- how to hook up my vtec?
- Quick Questions for a 88 HF Rex with clutch issues, tranny, clutch/flywheel, and axle questions
- jdm crx back seat
- STRANGE PROBLEM
- Cable>>Hydro tranny conversion...
- Fuel rail
- 1988 Honda Civic Fuel Injectors
- b16a sirII w/hydro tranny into a '87 crx?
- TSW VX1s and my recent "wreck"
- CRANK BOLT WAY TOO TIGHT!!!!!!
- looking for lower rear tie bar
- 1989 crx si with b16b motor swap. (how much do you think this is worh???)
- new to imports
- CRANK PULLY>>>88-91 1.6 and 1.5 the same?
- rpm output from pm6
- How much would it cost for door poppers
- clutch cable
- Window off track
- Problem after the crash?
- V-tec wheels or Rota
- Intake manifold clearence with a GSR Swap
- Any feedback on skunk2 coilovers..?
- bumper support
- Lexan windows kit for EF9
- Auto Trans Question...
- Who uses projectors?.. lets see the setup
- need to decide on some new shoes looking for input..
- barrel catback?
- b16a specs
- EF JDM Sohc ZC Swap W/Si Tranny After Swap weird Axle noise passenger SIde !!!!
- where to find window molding...
- Oxygen senSorrrss =[
- 4040 Prop Valve Install?
- Good Socal respectable shop
- civic vx wheels
- dohc zc motor upgrades?
- How much would u pay for this 88 4dr?
- 87 CRX si tranny question...
- B18a1
- pictures of front lips
- RADIATOR HELP
- 91 Civic Si
- carbon fiber doors
- **Calling all CRXs with aftermarket rear Lower control Arms-help needed**
- short tranny? SOmeone has to know
- d series LSD tranny?
- s stumbling question...
- anybody know what a pw0 redline at?
- AEM V2 Intake
- SOHC Turbos what manifold / traction bar / radiator arrangement do you have?
- My rex project. (56k killer)
- ***HELP MY POOR CRX*** code 9 code 9 crx in trouble
- civic lip
- where can i get the ef manual for interior
- Do these traction bars/crossmember for ef look any good???
- Hunting steering rack
- I found me a car
- deciding on engines
- parts compatibility with a dc?
- puttin in my A1 auto carpet....
- Clicking Noise when I try to start my car
- rear windshield whiper
- Si-R spoiler?
- odd ecu code ? what does this mean ?
- cheaptrixracing.com revamped again
- b18c1 vs b18c5
- CRX OR MR2
- My crx...
- question about jdm crx front ends..........
- wiring problem..
- my pg7 hits limiter at around 7100. is this right? I thought they redline @7500?!
- Idle vibrate, No vtec, Flood when starting
- crx sunroof question???????
- *pic request*hatch slamed on panasports
- engine?
- CRX HF B16 SWAP WONT START CODE 6 HELP!!!!!!!
- 4 wire o2 install
- CA Smog Legal JDM GSR Swap
- Cannister on back of Block leaking and smoking
- B16A CRX Exhaust
- *Pic wanted* black crx, mugen kit, spoon wheels, lowered
- want a lil more power no turbo or expensive parts
- Axle problems with a zc
- all Honda injectors the same?
- Door Mirror Replacement
- HELP: Is problem my fuel pump?
- regarding JDM EF bumper assembly
- Under Dash fuse box options
- zc motor question i've searched...
- Power Bulge hood
- Trying to put in my CRX ... JDM D16 ZC or USDM D16Z6 pros and cons?
- 1/8 Mile times
- drag rex
- Si door panals
- effinitup.com - for the ef enthusiast
- What do i need before i get tunned
- mpg on d16a6?? help me out please
- stock spring rates si,dx,hf
- I got a new lip
- Teg sway bar on 91Si?
- Is your gas gauge crazy?
- Seat Swaps--Civc Si/CRX
- pics of my ef !!!!! let me know watcha think
- What pistons/rods/valve to use
- starting 91 hatch with damaged ignition
- no power at all
- Need Fast Help Please, Got An Easy Question Here : How Do You Take Off Your Rear Bumber For 90 Hatch
- what all do i have to do for this swap?
- 91 black civic hb with 5 differnt sets of honda stock wheels
- exhaust search
- Engine Harness Help!!!
- Carbon Fiber Strut and Sway bars
- prepping my 1991 Honda Civic for paint...
- URGENT! Vss Install, Clip Wont Hold, Will Mechanic Wire Wrapped Work???
- What seats will fit directly in a 88-91 crx direct Bolt up no Mods???
- WHICH WIRE IS THE VEHICAL SPEED AMPLIFIER
- Need some Electrical help with 89 CRX..
- rpm activation switch help
- Ground wire kit worth it???
- Code 4 NEED HELP PLEASE GUYS!!!!!!!
- 87 crx si ported throttle body...
- general question
- Custom Exhaust
- code 22 on pw0, could it be oil pressure
- Good info...
- SOHC ZC passing CA smog?!
- RHDwhor3s EF9 Euro edition..
- Coil Voltage
- I just bought a 88 CRX shell! Just a few questions...
- ls swap question
- b16 timing belt
- oil sensor?
- crx 89 1.6 16v , idle problem Please help tried everything
