View Full Version : Honda CRX / EF Civic (1988 - 1991)
- CRX rear trunk triangle panels
- Exhaust Question. Ef wit a Ls?
- carbon fiber ef/crx pics?
- HELP ON Starting problem
- got a b16a to get rid of
- Speedometer cable or cluster?
- b16 to b18 help
- EF SQUAD
- What front/rear strut bar and rear lower tie bar will fit 88CRX Si
- help and YES i searched obd1 to obd2
- 88 DX Hatch w/ B16
- Overheating EF hatch
- eyelids
- EE wagon owners, how old are you?
- Fast ass crx!!!!!!!
- FS: WET NOS KIT
- ys1 tranny...axles help...
- alternator thru bolt.
- Driver side axle will not go in
- Early Christmas Present for my EF
- Look at this funny picture i made.
- which tranny would be best
- does a d16z6 and d16y8 use the same wire harness, ecu, and distributor as the 88 honda civic dx hatc
- please help. someone?
- removing rear seat
- new si dash... plugs?
- check engine light and vtec wont work?
- license plate relocator?
- Rear Suspension and Brakes
- suggestions on muffler
- New to forum need help with wiring swap for b16a
- when i want to buy an engine can i just ask for a d16z6 or a d16y8? or do i have to say the year of
- jdm b16 with bigg a$$ vtec solenoid
- 90' Civic Si HEATING and STARTING problems
- z6 head d16y7 block???
- motor shaking when at low RPM
- Jumping 89 4-door Civic!
- will it fit?
- ef mini me swap
- my speedometer is way below 0 and i took a closer look and its the spring. how does the spring go?
- is there a way to take off the glass housing on a headlight to clean the inside?
- EF engine swaps
- Changed cap & rotor.... distributor now makes loud ticking noise?
- Question. Brake pedal goes to floor. I think I need to adjust brake drums.
- Missfire or stumble during idle
- Which vehicle's bushing set should I get for my shifter?
- No power to ecu (searched)
- Project EF pickup
- zx6r throttle bodies on b16
- need help with a6 block and pistons
- what kind of head
- Flowmaster on a SOHC?
- question on parts for rear disc convertion on a 90 4dr
- Cooling fan barely runs.
- 8 valves?
- ED3 won't start when HOT (after driving around for a while)
- non v tec vs v tec
- Red EF9 with SiR emblem???
- where is the vss located on a 88 civic dx?
- CRX Side Moldings!
- Do you know how to use photoshop? if so i need your help.
- bumper for 89 hatch
- clueless.... b16 ef
- nitrous idea. lmk what you think
- d15 to b18 b1 help
- Greddy SP2 Exhaust
- i need a 91 dx harness wire color diagram
- sunroof question
- throttle body help
- crx dash instrument cluster cover, Any mounting differences from 88-89 to 90-91?
- New bulbs for HEADLIGHT! Bright!
- Todays Tech Tip... and Fram Oil Filters
- 91 SI won't start
- rear mount removal
- hiccups at idle
- Help identify this interior pieces...where can i find them???
- half size fluidyne radiator on 89 crx (hf)
- what is this part???
- whats wrong with this picture
- selling a Obd 1 pr4 distrubitor
- Buddy Club Spec II Exhaust on EF9
- I'm mostly a lurker but I need to post this, possible ebay scam?
- Clean 91 Ef Hatch!
- Anyone tried the Borg-Warner "Brute Power" clutch kit?
- HELP! Rad fan switch quick question
- is anyone running ZYDNE?
- crx parts - interchangeable with other chassis codes?
- Bumper/lights swap between 88-89 and 90-91
- 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ?
- wondering if thisll fit
- knock/idle
- Exedy Clutch Kits: Differences between '89 and '90?
- D16Z6 into an '88 CRX HF
- Will a 90 civic dx fit a ls vtec engine?!?!
- buying a crx
- b16 into a crx si , wiring harnes???
- 90 civic cx with 1.6l wiring issues (post engine swap)
- quick crx questions
- 1991 HONDA CRX HF RADIATOR REPLACEMENT TURORIAL?
- !!HELP!! with 1991 HONDA CRX HF RADIATOR
- how do you find out if you got a b16 tranny on a cable
- nuub here got my first handa git some questions
- engine swap wiring question
- Purchasing Crx
- Integra center console in my 91 civic hatch (ed6)
- Towing a dirtbike single trailer with a dx hatch?
- B16 in 88 Hatch
- wall mounted and throttle body map sensor question
- Crx Stolen in Menefee. (Inland Empire)
- anyone used BBP exhaust??
- b16 head gasket tutorial?
- 88 Front camber kit/control arm
- 89 crx hf rack and pinion in 89 si civic hatch?
- What is this connector?
- D16A6 mini me dizzy questions
- My CRX is on ebay but I'm not selling it.
- Car wont start after replaceing blower motor...help!! this is my DD
- I GOT TO READ THE RULES!
- SEAT PAN problem, 89 crx si seats-> 90 civic dx
- Severe Tie Rod - Steering Rack Problem
- will ba o2 sensor cause the car to not run?
- '88 CRX Si tranny into my '91 STD
- any one here from san jose bay area HT users selling any ef parts?
- AC Compressor Bracket
- Looking for a rear wing/spolier
- single zc with vtec head (mini me)
- b16 vs b18 timing belt covers. same or not?
- help weird cutting out when cruising
- adjustable cam gear
- muffler
- 94-00 intgera knuckles on 89 civic si ?? TYSON chime in!!!
- anyone know the compression?
- b18 ef help
- finally got it.
- Car turns OFF!!
- torque specs
- !!HELP!!! WHAT IS THIS PART CALLED CAUSE IM MISSING IT
- FEW PIC OF MY CRX FOR THE STARTER
- SEE what you guys thing about this problem??
- 90-91 CRX Front Bumper Fitment
- quick question.........
- AVID SHIFT LINKAGE
- RSX-S Leather Seats into 91 CRX-Si
- fuse box tuck
- Does this work?
- getting b16 head resurfaced
- need help with wheel????
- Coolant leaking into cylinder 4 through head cooling port
- my swap into my 88 crx si
- 92-00 Catback on 91 Civic?
- !seat question!
- how can i convert obdo to obd1
- need help ASAP. how to take out the alternator?
- h22 crx
- jdm B16a Tranny
- walbro 255 bracket bending help
- HELP!!DID HEAD GASKET NOW I HAVE 3 CODES(7,10,14)
- Input shaft in and out on 90 CRX si tranny?
- obd 0 gsr q's
- mpfi swap with z6 manifold?
- Help vtec!
- 1991 Suspension compatible in a 1988?
- more pics of my stripped to da bone hatch project
- 91 civic 4d getting ready to swap motor b18 a1
- 88 crx pillar mounted seat belts fit a 1990 crx?
- Suspension Problem Please Help???
- ecu noob
- B18C1 burning oil?
- electrical mystery - scary stuff
- just need to make sure
- what kind of mods can i do with a budget of $200 dollars?
- installed new starter, i hear starter rotate/turnover when i connect negative battery clamp ???????
- Dohc Zc crank pulley
- Bad vibrations
- help again
- camber kit for 91 crx dx
- injectors?
- check engine light and loss of power. help.
- something let go, i need some help!
- Temperature sensor plug broke at wires any ideas?
- cluster question
- peakboost kit
- gsr rear brakes on 90 hatch? possible?
- running to rich and check engine light.. Please help??
- d16a6 swap, now nothing happens
- cel code 17 VSS - speed sensor!!!!!! need help
- How to install the rear divider in a CRX
- strange question?
- has anyone ever straight Wire a OBD2 dizzy connector into a OBD0 crx si harness??
- MPFI Conversion done and now codes
- NEED HELP CRX CODE 9 and pop in idle
- Need some teg brake rotor dimensions
- post all ef's with ls mesh rims
- Quick Clutch Question
- PR3 chipped....wat chip do i have?
- Vtec head...?
- JDM EF9 INTERIOR ?????
- Traction Bar Questions (ground clearance issue)
- 1991 CRX Auto throttle control cable
- HELP!.how much is this crx worth?
- Wire Tucking- coming up short?
- Gsr Turbo
- bigger rims and your speedo
- 1991 Honda CRX DX Idle problems
- ef hatch please help???
- Ugh, major tank leakage. Help!
- CRX seat rails...
- PCV System
- How big can you go?
- master cylinder
- ZC Help needed
- please help
- EF Pix
- dx to si cluster
- My Ef
- Transmission dipstick popping out
- z6 block, y8 head--- in 91 crx Si need help.
- YS1 tranny
- obd1 dizzy with obd0 ecu?
- 90 honda civic crx
- Calling All Civics!!!!!!!!!!!!!!!!!!!!!!!!
- Transmission longevity...how many miles?
- code 17 vss(vehicle speed sensor)?
- will this steering wheel fit my 91 civic
- hood pins lockable which are the best. theft prevention
- Put a 92 Civic Engine in CRX HF NO Start
- swap shop in san diego/south cali area
- Help with remote start, can't find my answer anywhere
- motor not reving up help plz
- Aftermarket Tilt for EF
- wat could it be ??????
- anyone know what this says?
- anybody have ghettodyne?
- what has more horse power a d16 or a zc dohc?
- My engine is acting up and my check engine light is on can u help me?
- 5 pin connector on Si? and 6 pin connector?
- should be a quick an easy question ,
- Civic hood interchange
- What ECU?
- PISTONS
- quick question
- 94 integra dash into a crx
- I was driving and came to a stop and My CRX wouldn't move.L@@K
- No Heat when at idle
- Big Tube Hytech
- CRX DX and some SI parts
- Rear Disk Conversion
