89' Crx si build thread
Old Jun 16, 2015 | 11:00 AM
Jdm256's Avatar
Default 89' Crx si build thread
I meant to start this awhile ago but here it goes, I bought an 89 Honda Crx si from Indiana for 1400$ with plans to swap and build it.
Here's what it looked like once I got it home
My first agenda was to fix the rust, and try to do something about the awful paint fade it has! I started by sanding down the areas very thoroughly then cut out the areas that the rust had gone completely through. I welded in some metal in and bondo'd and sanded till it looked and felt good at this point I had decided for a temporary fix and plasti-dip that car until I eventually paint it.
It came out looking pretty good and I scored a set of gsr blades for 125$ with tires on them!
Old Jun 16, 2015 | 11:08 AM
Jdm256's Avatar
Default Re: 89' Crx si build thread
Well I made another good find today I ended up getting a crx hf with a b16a sir & lsd trans it also has a 16g td05h, how ever it's not in good shape it took some front end damage during an accident in the winter. It got hit in the front bulk head on the drivers side it didn't hit the engine besides the valve cover and slightly cracked it, Im going to pull it do all the gaskets timing belt water pump etc, rebuild the turbo and hopefully have it in my crx this summer. Will post pictures of it soon, I got the car for 1600 and got it towed home for 70$! :D
Old Jun 17, 2015 | 05:58 AM
CrxChicken's Avatar
first thing i would do is scrape that 1320 sticker off it
Automotive Paint, Car Paint, Auto Paint - PaintForCars.com has good deals on urethane and clear check their ebay auctions and you can often get a can for a bit cheaper than the website.
Old Jun 17, 2015 | 12:25 PM
Jdm256's Avatar
Haha I recently did take the sticker off, thanks for the heads up about the paint! I took some pictures of the crx with the b16a I bought it's missing parts front bumper rear bumper and the hood but all I wanted the car for was the engine and trans.
You can see the front end damage to the bulkhead here
I almost immediately got to work on it once I got it home pulled out the seats and carpet, boy was it gross underneath there the car smells like a giant ashtray .
After that I decided the next thing to do was getting the engine out of there It was pretty easy work with the help of a friend it was out in a few hours.
Old Jun 17, 2015 | 05:32 PM
Slenderman's Avatar
Dang, $1600 is a pretty good price for that donor car.
Do you know what kinda engine management they were using for the "boost"?
Old Jun 17, 2015 | 06:54 PM
Jdm256's Avatar
I'm not completely sure I knew the previous owner of the car it had a good tune but I unfortunately don't know where from , he bought it from the guy who had built it so I'm trying to get ahold of him and see what all went into it. When the car was running it was on 13 pounds of boost launch control at around 3200 rev limiter was set at 7500 and was said to be around 230 hp, I'm hoping to be able to do a full rebuild on it before it i put it in.
Old Jun 17, 2015 | 08:55 PM
Slenderman's Avatar
Hmm, you really think a rebuild is necessary?
Just saying, if the engine was running when it crashed, and it's still good now, I'd just run the **** outta that boosted B.
If/when it pops, then I'd do work with rebuilding it.
That's just me...
Old Jun 19, 2015 | 12:44 PM
Jdm256's Avatar
Yeah that's where I'm kinda leaning towards right now because I'd love to get it going soon! I got the valve cover and new hardware all i need is valve cover nuts, here's the new valve coverName:  lImYbd7.jpg
I also got the wiring harness and shift linkage out of the donor car
I'm starting working on my car tonight should have everything out over the weekend, well hopefully!
Old Jun 19, 2015 | 05:25 PM
Evo9GSR's Avatar
Your build has a lot of potential!! Keep it up
Old Jun 21, 2015 | 11:22 AM
Jdm256's Avatar
Saturday I ended up getting the engine out of my car with the help of my good friend Josh who's been working on this with me.
I'm gonna start getting this engine in tonight or Monday!
Old Jun 21, 2015 | 02:49 PM
Slenderman's Avatar
Do you still have the factory front crossmember in your car?
If you do, I believe you will run into clearance issues with the engine because of the turbo bits hanging off the front of it.
Old Jun 21, 2015 | 07:31 PM
Jdm256's Avatar
Yeah I do have the stock one on still, I'm going to see if the one from the donor car will work but if it doesn't do you have any suggestions on a nice one?
Old Jun 22, 2015 | 06:41 AM
Slenderman's Avatar
Well just judging by the crash damage on the donor car, I'd say that the one on that yellow car is fucked.
I was planning to buy the Innovative one when I go turbo. It's compatible with the half width radiatiors.
Affordably priced, too.
Old Jun 22, 2015 | 07:25 AM
Jdm256's Avatar
Yeah the one on the yellow car is actually ok but it's not just bolted, but welded on so I ordered an Innovative off amazon for 242 cant wait for it.
Old Jun 25, 2015 | 12:57 PM
Jdm256's Avatar
Well I got a great package in the mail yesterday that included new tie rods, ball joints, and my crossmember! Not all of it is in the picture
Here's my crossmember fully installed I had some slight fitment issues getting it lined up but in the end I got it all bolted up, sits at a really nice height not nearly as low as imagined.
Old Jul 1, 2015 | 12:03 PM
Jdm256's Avatar
I have the engine in my car now I'm farther then the picture I've put below is, I'm just held up on getting some more 2.5 ic piping probably going to order some if I cant find any local. I'm hoping a a couple more weeks till she's on the road !
Old Jul 25, 2015 | 10:38 AM
Jdm256's Avatar
Haven't posted in awhile I've been really busy but I have everything hooked up but I'm throwing a (CKP)Crank shaft position sensor cel, I was thinking buying a new dizzy and resetting the ecu. Anyone else have any ideas??
Old Jul 27, 2015 | 06:34 AM
Freemananana's Avatar
It is likely a bad distributor. I had the same issue with my B16 and some random distributors I had.
amus0102
99
Dec 20, 2011 12:16 PM
gospeed81
14
Mar 22, 2011 09:06 AM
scottmog
11
Jan 14, 2008 04:47 PM
h22_crx
Nov 11, 2005 11:22 AM
CRXstress
34
Jul 2, 2005 11:48 PM
