View Full Version : Honda CRX / EF Civic (1988 - 1991)
- b16 vtec is cutting out around 7200 rpms
- Are 2.5in CRX/EF Ebay Exhaust truly 2.5in ID? I need just the piping.
- b18 crx skunk2 intake mani problems
- zc head question
- blower motor brushes
- 1991 Civic Si Hood Insulation Question
- head gasket 1990 civic 1.5L
- crx b16 obd0 header
- CRX STRUT replacements
- 1/2 radiator fit in EF9?
- D15b/d15b7 mini me. Will not start.
- Bumper Support
- headgasket help? searched
- Rear crx lip help!!!!
- My LS/VTEC has a weird idle
- CRX seat question
- SIR power mirror on USDM door?
- youll never guess what i managed to wrap my claws around!! ((:
- crx miracle cross bar question
- quick dizzy question
- Looking for CRX...
- sooo
- 1991 civic si seats will bolt right into my dx hatch correct?
- Firewall heater inlet nipple smashed but not all the way, help
- sohc zc with no spark
- 89 crx si with axles issues
- d15b1 running running irradically once warm at idle
- zc vtec dizzy ?
- p29 rods
- swapping 4 speed tranny for 5
- head swap question
- no spark help asap! SEARCHED
- seemingly challenging problem. 1990 CRX wont turn over.. please help!
- rpm and speedo don't work...
- crx with d16z6 major problem...
- jdm front end, insurance questions
- my new project... not bad for $500
- blocked off iacv and fitv, any downfalls?
- HORRIBLE gas mileage.
- P29s in D15
- rusted valves in a perfectly good head
- SEACHED. cant findGsr swap woes!
- D15b7 Engine Wire Harness And D16y8 Intake Manifold..
- G-man's '89 4dr ef pt.2
- 91 ef wire tuck
- Cage? No Cage?
- Need help asap my hatch no like start
- Injector Question...
- Heater will not work
- Best bang for the buck swap to boost
- Hatch wont start?
- help please ...dizzy help
- EF 8 or EF 9?
- Need help, 90 Si with b16a, died every time car stops. Dunno why...
- New sedan owner soon!
- speed limiter on jdm b16a?????
- 90 crx si "reving" issues
- NEED HELP WITH B18B IN A CRX
- d15b7/d15b VTEC Mini-me swap questions
- 1991 Honda Civic won't start
- jdm ef9 visors on 91 hatch
- What ecu?
- sohc zc head gasket question
- EF Civic Si Seat Upholstery
- Odyssey PC680 Battery Question
- 88-91 civic
- emergency z6 swap... a few questions
- Throttle Position Sensor???
- SAFC II question
- Bumper question...
- 1990 CRX - battery keeps draining
- New here
- injectors????
- chipped ecu
- b16a idle problems
- 1991 CRX SI Passing Smog Test Problem
- Lx sedan, manual conversion, d16 head?
- D15b6 bottom end rebuild and mini me. worth it?
- DoubleDirtyC's project 1990 crx si
- vtec
- Car key question
- Power Window Kit.... Good Deal???
- Crx B20 swapped has no SPARK?!?!
- b16 redline at 7200?? wtf?
- Leak
- How to ID a transmission??
- stuck on Highway! Help!?
- DIY/HOW TO: EG half radiator in an EF
- how to remove old head gasket & copper spray?
- ford focus exhaust on b16 swap??
- 88 dx multi point help
- CRX LS wont crank over .. help
- interior noise
- Ouch ... Is this repariable?
- 88-89 civic bumper
- Update & Questions D16A6
- jdm ef9 front end vs USDM front end ????
- how do i time a crx si
- 91 Hatch Si Jumping Tach and slight stutter
- Need Info ... Want To Put Hood Dampers On
- Electrical Issues, Help me!! 91 crx si
- CRX driver side fender
- CRX engine change
- looking for 88 ef front seats...????
- SI AND DX DASH?
- ef2 Front End Conversion
- CRX High Fuel Economy trim?
- I have a few questions...
- i need help still? with my boggling
- HELP I LOST my only pair of car keys!!!!!!!!!!!
- car sputters for 15 seconds from a hot start
- JDM part question
- 88 civic wont start
- Need tranny help from the H.T. Gods...lol
- 89 crx speedo help!
- 89 Sedan B16a starter issues
- Ef Wiring questions
- CRX SIR HEADLIGHT WIRING
- Part # for rear wiper plug..
- reading engine code
- CX in an EF generation?
- tire size help with 14 in wheels!
- should I get rid of my CIVIC and get a CRX ?look at my story / pics
- quick jrsc ?
- 91 si d16a6 hatch cooling temp issue
- head studs!
- vacuum/thred request
- aem ems diy?
- obdo mini me swap question
- purpose of 150 mph spedo??
- Just picked this like steriod monster up
- S2K Start button installed..
- header and vtec controller
- axle problems d16a1
- CRX si 1/4 mile drag
- one of a kind crx, k20 itb complete restoration, got a link??
- oregon area needs a swap
- Heat blowing question
- D15B2 cranks, no start
- how to put a 90-93 integra front on a 91 honda civic
- doing a swap and need some wiring help
- So my gf hit a curb and.....
- New battery, good starter and alternator, but car won't start
- 91 si tranny mount question??????
- would 88 prelude lowering springs for my 90 hatch?
- Quick suspension question
- Whats wrong with my EF9?
- 1991 Honda Civic LX Sedan FS/FT
- ap1/ap2 cluster
- ef hb/sedan catback question
- CRX won't start after changing headgasket
- 91 ex,should i?
- where can i find crx quarters rust free
- code 3 , 14, 17 on a d16z6swap - ran awesome , randomly dead.
- need help wit 1990 civic hatch back
- wagovan dash
- Leaky windshield WHAT TO USE?
- MY 91 CRX SI. PROJECT BUDGET!
- Will this exhaust set up work?
- Vitara piston help
- my rex is still boggling... need HELP?
- full hydro conversion on crx help!!
- need help with harness conversion obd0-obd1
- Wheel Weight? HFP EP-R5 16x6.5
- 92 gsr tranny problem. Help?
- CRX Interior parts
- fender flares???
- Spudder while driving.
- Mannual Conversion
- TURBO OR ALL MOTOR
- what kinda paint do you use to paint clear corners smoked amber?
- $5 Homeade Hatch Prop ( Easy to make)
- wire harness question please help
- car cuting off need help!
- Need Help on 91 SI Hatch
- D15B7 in 91 DX
- Swapping a B16A (1st Gen) into a stock 91 Civic HB
- simple yes or no
- who makes aftermarket parts for the ef?
- Ball Joint removal? help
- Failed CA Emissions.. need help.
- crx steering wheel loose.
- Mini-Me swap questions...
- axle
- Pre Fabbed Corbeau Seat Brackets 89 Civic Hatch
- Teaching a old dog new tricks!
- new crx owner, need help
- STOLEN :1990 Honda CRX- Nashville TN
- Si vs. DX seat differences
- ??? is a po8 vtec head the same as a d16z6 head ???
- Full Front End Conversions?? Any look decent??
- Part out, or sell as whole?
- Water Pump replacement
- Help!! Please!
- emmisions question?
- IACV question?
- ARP 208-4301 ? what engine d16a6/z6?
- car bogs when throttle
- b20b swapped crx compression test results, any good?
- stuck.... fuel pump
- 90 Si hatch brights dont work
- 1990 si ef axle problem??
- Dome light issue...
- crx delsol brakes failed
- Head swapping question.
- crx b16a codes
- Trying to find out if i can use 90-91 part on my 88 Crx Dx
- starting issues
- The Wrath of the Crank Bolt
- accord side marker lights on 91 civic?
- about to buy ef sedan
- CRX-HF B16 conversion
- bobbing idle bad
- 88 Civic DX Hatch Wire Tuck HELP!!!
- Crx Sir Bumper with USDM BUMPER SUPPORT?
- Crashed my crx on sunday :( pic...
- why when it rains my carpet is soked
- mini me swap help please help pleaseeeee!!!asap
- 88 D15B2 Help Needed
- 90 ef9 ls vtech?
- Crx bumper on my Ef sedan?
- fuel idle problems
- You havent seen this before. Lol
- been out of the game for years, got a few questions
- 91 hatch b18a1 idle problems
- 91 civic dx wont start!
- CRX with b16a a fing on nuber 3
- 92 rear civic seats fit in 91 civic?
- ideas for my sleeper hatch
- crx fuel pump problem
- octane,compression and elevation question
- Corner light wires burned up! Need help with wiring!!
- MPFI swap problem!
- quarter window screws/bolts
- recommended header?
- How to tell if a block d15 or d16?
- hatch side moldings on crx ????
- ef hatch no spark
- need head bolt tourqe specs d16z6
- 90 civic steering rack install...
- quick question.....
- D16 Rod/Crank Specs
- need help with my alignment on lowered crx si
- need help with Vtec?!
- b series dizzy
- having distributor trouble...
- b18b1 venting
- MACHINE SHOP WORK questions
- anyone have rear bumper bar removal pictures ?
- da motor mounts?.....
