View Full Version : Honda CRX / EF Civic (1988 - 1991)
- mini me or dr. evil?
- fuel system takes a turn for the worst.
- good online trusty place to buy some EF parts?
- PIC REQUEST ON RED STICHING RACORO'S OR ANY BUCKETS
- Cusco Type St
- what would you guys do?
- need help with headgasket and studs for b18a
- ***The New Official EF Exhaust Thread***
- mpfi swap
- effin motorworks
- "free mods"
- Running issues
- b18 obd0-obd1 conversion not getting spart help
- check engine light and throttle delay
- What type of suspension should i use?
- CODE 4- CKP Sensor good- Wiring is good
- crx hf b18a1 swap obd2 distributor
- EF bumpers 89-91. any help??
- Push button start and i blew somthin up
- motor swap question
- cel could you help plz??
- flipping a swapped ef?
- Help Please, Problem after obd1 conversion
- axals
- wiring question need help
- ZC head Code
- Rear LCA's for '88 crx or ITR style shock???????????
- NEW TO crX's......help identify motor
- converting ecu from auto to manuel
- Need HELP
- Posted in wrong forum....please help.
- lower rear strut brace
- smaller crank pulley on h22/ef
- dual point to multi-injection swap 88 CRX DX
- just recieved hayame intake...can't find any info though?
- CRX suddenly smokes. Ideas?
- my 1991 hatch build
- how much oil in my trans
- Spoon mirrors
- in-cabin mbc install (crx)
- are 90"crx hf brakes that bad?
- Help with SI Seats
- Wiring question!!!
- Car Wont Start !!!NEED HELP!!! Dizzy just replaced.
- CROWER STAGE 2/3 CAMSHAFT AND CAM GEARS.
- pulled my b16....
- mushy gear box
- b16 transmission question
- What Will I Run?
- Shaving doors handles, acctuators and jimmy locks (question)
- i need help plz
- p05 ecu work on a d16???
- gsr head on my b16 block??
- 246k motor, time for major maintenance?
- suspension question? da nuckles stock struts?
- Swapping engines, do I have to pull the tranny?
- no idle, run w/ throttle open
- control idle valve
- d15b in dx question?
- Thermal exhaust on CRX?
- 88-91 CRX WITH ACCORD OEM SKIRT LIP KIT??
- Weird sound when slowing down in 2nd
- OEM or OEM style exhaust for 89-91 Si hatch
- ..dpfi to mpfi..new guy here so
- 0bd-1 b18a1 into 88 crx si
- Car Boggs down but now CEL???
- B16B OBD conversion
- D16 Si motor + GSR Throttle Body?
- SOHC d16a1??
- Need Help! car wont start. no spark or fuel cant figure it out!
- quick question.
- b18c CRX fuel problem??
- connectors
- front bumpers
- ef lip for 88-89 usdm front- need help?
- Help dis-assembling CRX si seats...
- removing&replacing wheel bearing
- obd0--> 0bd1 Dizzy Wiring!!! (mini-me)
- need some help on dashboard
- ZC swap, what ecu?
- need help on 90 dx
- CRX Catalytic Converters
- throttle body question
- Looking for a C pillar bar for a EF 4dr!!!
- 88-89 cluster in a 90-91
- Steering Wheel Info needed
- tunerz image
- ys1 want go in gear.
- crx 88 si with b16a2 wiring help needed!
- HELP
- HF/SI harness
- 89 CRX electrical problem, lights don't work, won't crank, no click... nothing.
- Rear brake drum clicking
- anyone have any experience with Suspension Techniques Coil Springs???
- 90 crx dx mpfi conversion wont start
- help with swap
- Which bracket to use for rear?
- Help on 91 crx
- Need some help! Integra parts on 90 std
- 88 Civic Hatchback Some questions..New Guy here..
- speedometer question
- My 91 hatch witb b18 swap (hood problem)
- Da lip on Ef hatch?
- Inner tie rod and rack end bushing removal/install
- JDM front end...
- ?Help traction bars?
- GRINDING
- Draining Old Gas
- [Help] What are the best COILOVERS for stock crx struts
- NEED HELP ASAP WILL THIS WORK
- New owner/member here...
- Another one of those Vacuum Questions
- eg radiator in an ef???
- Need some help ASAP...New clutch now it will not engage.
- Rear sway bar ST24 mm and exhaust??
- how to read code
- what kind of engine can i put in 91 crx
- shifter, bushings, and linkage questions pics (searched)
- new engine
- Electrical Problem
- Searched through the FAQ's, still need to clarify an axle question.
- trying to order parts.. what car is my engine from?
- B-series VSS interchangeable?
- Washed engine bay today, now Map sensor code?
- timing marks wont line up.
- oil on the spark plugs
- SO i whent threw a puddle..
- Gauge cluster Question
- Motor mounts needed for 91 STD hatch with d15b7 motor?
- should i save this crx?
- write up for doing a head gasket?
- NEED HELP!!!!!!!!!!!!!!!!!
- weird problem on crx, need help
- map sensor
- just bought an ef
- looking for a throttle body
- quick ? bout b18b head assembly
- clanging noise on acceleration low rpms
- f/s two front mud flaps and a rear strut bar
- hello every one
- ZC swap Question?
- B-Series Swap Some Basic Questions
- mpfi swap need help with vaccums
- Blown Head Gasket
- tach not working
- CRX DONT START, PLEASE HELP
- extrange dust on the intake manifold
- b series prob....
- Help fuel problem, sputtering, I think its..........
- Wiring Harness ?
- How do I disconnect the clutch cable?
- 97 EX Brakes on RT4WD wagon
- crx Hf's IACV
- zc tranny vs si tranny?
- aftermarket fan not working.
- What axles half-shafts do I use.
- 1990 CRX Same Old Idle Issue
- Quaife Quick Ratio Rack
- running lsd in 88 civic with b16a1 tranny
- obd0 ls harness into 89 civic
- Question about DSS Axles Level 2.9
- itb clearances?
- AC Evaporator Duct Delete Part Number
- Ef front lip ?
- clutch dont feel right, please help!!!!
- Where the hell is all my coolant going??
- quick help
- NOW WHAT?
- 91 Civic Hatch Re-Build Thread
- rear roof spoiler
- CRX Swap Q...
- New Clutch
- lexan
- best street clutch for b16a EF?
- Oil pressure on a D16Z6. Please I'm begging you for some help. about to rip my hair out!!!
- Heat temp gauge/sensor problem
- Standalone ECU on OBD0
- quarter window removal- 89 CRX
- Where can i find a carbonfiber front and/or rear lip for my 91 civic hatchback??
- Engine Problem that i cant figure out, help please!
- injector issues after mpfi conversion
- new to honda, already overheating
- 91 4wd wagon overheating
- Emblem adhesive
- Skipping... sputtering any help?
- new to the crx...please help
- 91 hatch b18... idle problem...
- obd0 injector wiring turbo/emanage
- WTF NOW?!
- Clutch problems!
- sputter
- car wont start
- usdm GSR ys1 final drive ring gear tooth count?? somebody help please
- transmission question
- Camshaft Swap
- Water Pump
- crx help
- HELP!!! Code 4 Crank Angle Sensor HELP!!!
- 89 si hatchback needin some TLC
- 90 civic hatchback with b16a2 swap please help
- crx wire tuck
- crx wire tuck (pics)
- obd1 conversion diagnostic plug
- a couple of my EF's
- Crx losing power after ~15 miles
- 91 CrX Si D15B Swap OBD0 to OBD1
- Floor Mats
- the strangest CAmber issue ever !!!!!!!!!!
- ecu problem
- throttle body? year???
- Which Throttle body gasket?
- broken retainers
- PS9 1 wire vtec
- Weird idle and closed throttle popping??
- quick question serched but cant find
- Hasport CRX front air dam
- my 91 si build
- What are these Two "Wires" for?
- CRX obd-0 b16 headers (hasport style)
- Quick obd0 ECU question
- feedback on catback INVIDIA exhaust???
- MPFI AGAIN!
- skunk2 front camber kit how good is it? What other alternatives?
- 91 crx si - 91 std hatch seat swap
- thermostat, low or high temp
- Upgrading Front SpinDels
- 88 crx si wiring harness question
- What should I offer ($) this dude for all these parts?
- ebay gaskets
- code 16 on b16
- obd-0 to obd-1 conv. S2 IM install
- Fuel Pressure when starting ?
- TPS question
- V8 supercharged Honda CRX.
- 89 CRX brake upgrade
- Headlight Problems
- Doing a b16 swap into EF, Need guidance!
- zc dohc clutch/flywheel
- dizzy help
- Radiator Wiring, Thermo Switch, ECT, etc.
- radatior help please 90 ef
- Parts to fix a sloppy shifter, pic inside
- Stumped: Won't start, clicks hard
- anyone know how to hook up the lighter
- d15b8 what pistons do i get? and what head do i have? pm3-6 ?
- rear bracket for itr engine
- p72 ecu for poor mans r
- ?? mini me swap !
- EF si tranny code/vin
- clutch pilot bearing not fitting
