View Full Version : Honda CRX / EF Civic (1988 - 1991)
- OVER HEATING???
- could my Injectors be the problem???!!!!!!!???????
- What yall think of my choice of colors?
- APEX'i SAFC...
- rods
- oil leak ????? from zc crx
- ZC Head
- b&m bad for trans
- 1.8 build
- EF Chassis Questions!?
- Just A Problem
- crx fenders
- Crx b18a1 swap wiring
- ruthless801
- what clutch for mini me
- Will a hb catback fit on a 4 door?
- Stock Distributor Install - Which Direction Does Groove Go? How Do I get Rotor on Cyl #1
- SOHC zc 1/4 times post urs
- I AM NEW GUYS. NEW HELP FINDING JDM D15b2 CAM
- IT STILL WON'T START
- ZC wiring
- late model civic linkage fit in 91 crx?
- why a 1/2 radiator?
- Timing Belt... HELP!!! Reply please...
- Hood that replaces header panel for 1st gen crx
- still having problems with my sohc zc
- tail lights
- ZC turbo thoughts
- Check engine light after filln'n up gas??
- For Sale: '88 Honda CRX
- ECU Code 13?
- help...
- dpfi to mpfi what do u add to the si chassis harmens
- radiator help
- What size rims are best for the CRX 15 or 16
- Crx choice
- pm5 for a dpfi auto to manual swap?
- 91 Civic Fenders : Price Query
- igniton switch wire diagram crx
- ecu questions
- nokia data cable
- do you need boost retard?..
- what 15" 5x114.3 rims are
- vtec light wiring - searched -
- 07 CRX?
- are these parts interchangable
- Tires for 15"
- IAT Resistance Levels
- Will DA upper arms work?
- B16A2 sawp
- my b16 crx
- Where and How do i install HID's on my EF9
- injectors??
- very unusual electrical issue
- What does an exhaust leak sound like?
- b16 problem
- can u use d16a6 Distributor on a zc the d16 Distributor is off my 89 crx si
- Update To my Previous Problem
- short shifter problem
- b18a1 swap in 90civic dx
- Crazy torque steer!
- brake pedal travel
- Fuel control wire
- d15 with d16a6 head wiring
- moister in headlights?
- TEST
- my newest member of my family
- exhaust choices?
- exhaust ?
- Instrument light and tail light problem. Pls I need help FAST!
- ??question??
- Ebay power door actuators
- suspension, axle, and or steering rack problem?
- d16y8 and y7 piston-to-deck height difference?
- selling my 90 civic with jrsc, recaro seats, crane cam and much more
- nice little site by nice guy
- To buy a cable or hydraulic b16
- 98 Civic Hatch Rear brake Conversion
- friends selling 85 CRX for 75.00...good deal?
- FOR SALE!!!!!!!!! 91 Honda Crx
- turbo trouble
- Help me please.... car won't start
- 91 DX hatch - need some seat swap suggestions
- 4 door EF Forum
- Please help!!! ZC swap
- How much is my car worth?
- motor question
- whats the max rpm i can run with a stock jdm gsr exhaust manifold???
- b16a boggs @ 5200rpm
- battery or alternator dead?
- **Request** how to shim up stock wing 90 Civic HB
- Different pulleys and crankshafts
- How much coolant do I use?
- my car
- Hatchback needed for test fitment (SF BayArea)
- 91 hatch ?'s
- PICK N PULL PRICE for distributor
- crx shell anyone got one for.....
- need a part # on master cylinder??
- spark problems with b16a in 88 rex si
- 90 civic/91 ls swap runs rich
- ef9 ef8 replacement bumper cover question.
- Somethings Draining my battery. NEED HELP!
- Intermittent ticking when idling on b16a1
- how to clean pistons?
- Which Idle Air Control Valve to Use??????? HELP!
- How does a integra gauge cluster fit in a 89 civic si?
- bear with me please
- swap obd1 b16a wont start!!!
- Steering rack...Damn Lock washer!!!...
- 91 civic D15B (JDM) swap?
- CA smog questions
- did full race change the design of their traction bars?
- seatbelt question
- prelude cluster
- code 8 TDC
- CLUTCH NO RESISTANCE ALL THE SUDDEN
- Need Si Bumpers Front and Rear for my EF9
- What OEM seats will bold into a 86 CRX?
- Pros And Cons Of The CRX
- How do you take off the front bumper 1991 civic wagon?
- CRX auto to 5speed conversion, help needed
- JDM Y1 LSD "rebuild" (lsd clutch pack resurfacing or replacement)
- where to order jdm b series trannys?
- OH NOZORZ I need an exhaust!
- not running right
- b16 crx?
- crx turns on then shuts off?
- Couple CRX Questions.........
- Anyone did a swap in their crx/ef around San Jose, CA??
- Crx Radio Wire Diagram??
- rear discs under 13" wheels?
- rear disc brake swap (sedan) problem
- Need Major Help!!!! Need car for the morning :(
- Leak from the starter??
- Headlights keep burning out, wtf?!?!?!
- Will B18A fuel injectors fit on my d16 ZC motor???
- OEM foglight, factory Honda installation instructions, where are they??
- My SI
- CRX cliamte control in civic
- Tach works but shift light does not help
- 94 CIVIC EX & 95 INTEGRA GSR OBD1 ECU WIRING HARNESS CONNECTOR
- Is it possible to run a hydro tranny in a EF?
- pic request: clutch cable bracket for d series
- My Ef F**king Hates Me (HELP!!!!!!)
- eg radiator fan
- What model of steering wheel is this and will it fit in my CRX
- crx with jdm b16a
- oil catch can ??????
- Next best Tranny for my Dseties Block DOHC ZC
- Are the CRX/Sedan/HB Climate controls the same??
- A/C fan on Radiator....?
- Car sputtering under heavy load
- Installing wheel studs/camber kit noticed something...
- gauge clusters?
- 1990 master cyclinder on HF
- DX CRX with HF Transmission
- 13" Mugen CF48s fitment
- vtec is not working
- Dohc Zc Double power adder????
- CAN I PUT A EG OR EK LIP ON A EF HATCH ---POST SOME PICS
- 89 std hatch front end noise
- Intercooler question to go with piping....
- Got the Z6 running
- tdo5h turbo crx help
- throttle body question
- researching for swap: Post your timeslip, hp/tq - motor swaps with power adders please post
- Wrench Size for Ignitor replacement
- Throttle Vibration? Need advice/pics
- EF8 side markers can anyone w/ an actual EF8 tell me what blinks and what doesnt?
- pete's rex updated
- d16y7 buildup with zc pistons?
- lowering car question
- B16 swap into 90 civic dx same as crx?
- which obd is best
- fs 1994 gsr rear disc brakes complete.
- Ebrake lever & handle replacement
- No Heat 88 CRX
- Jim Fab traction bar and JDM ITR header...
- Clean REX! CHEAP!!!
- Do the pressure plate bolts use washers?
- airbags?
- EF9 Civic SiR sterring knuckle question.
- Will d16a6 bolt in?
- Power gains from ebay Short Ram Intake
- EX knee assemble
- Need some help, negative coil wire?
- LS swap into an STD hatch
- Hubcaps
- Gas leakage and tranny problems
- crx 1.6L - how many miles do you guys get out of a tank of gas
- My a6 dyno
- Window regulator compatibility?? Hatch -> CRX??
- 96-98 Civic Honda Type R Headlights
- what size fittings for my oil catch can?
- Best Turbo Exhaust for EF>???????
- BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (91 Civic)
- MAP Code 3 - need serious help
- Are CRX'es Stolen As Much As EG/EK's?
- F/S 1991 CRX Si
- Steering Problem
- Tranny Problem....
- car wont start
- motor mount?
- Need help with B18C!
- Which cluster fits in 89 CRX?
- I Got A Question About Headers
- jdm pwr folding mirror, mirror replacetment
- 2nd Gen b16, cable trans?
- wiring help with d16z6 in crx dx
- bought a EF the other day
- Anyone running omnipowers? (91 civic si)
- problems with fuel guage.....help w/ troubleshooting
- any one know where to get a 88-91 civic sedan jdm hood
- Car runs too rich
- ZC pic request.
- parts
- newbie here... pics of my current project
- Rust; Why I hate Wisconsin.
- password cf intake on d16a6
- hello, newbie
- NEED HELP!!! MPFI swap wont start
- Picture Request
- exhaust leak, what gasket to buy?
- *I need a pic* EF with the porsche lip
- ctr pistons or stock b16 pistons?
- engine swap problems
- Confused....
- will accord rear handles fit a crx?
- new swap new problems
- Me and my EF9: New to Honda-Tech
- Cermaic Headers vs. Steel Headers
- I want your opinion
- Error 4 code
- www.rywire.com
- Short ram install
- Quickie: Si brake booster on my dx?
- Need to know how the throttle cables go on a cruise control car
- New steering rack or what?
- ok im confufused on what tranny this is i baught a b16a off sum kid an check this out
- Some fucker try to steal my car!!!
- dx harness for ls swap?
- Auto retarding during rev... any ideas why?
- jdm b16 throttle body?
- Wiring problem??? Brake light switch, any help would be appreciated.
- Review my setup
- Help with zc swap, not starting 91 crx si
- Turn signal fuse blows when fuel pump is on
- CRX project
- Sir Civic (90-91) Cluster question
