View Full Version : Honda CRX / EF Civic (1988 - 1991)
- MIDWEST MEET, march 21st, be there or be SQUARE
- Think itll hit 12's?
- 89 D16a6 Pricing and Some other questions
- How to find a leak
- Weird sorry Jdm b15b (non vtec in my car ) 91 civic si no d16a6 just trying to figure things out ?
- D15B6
- 92 cx hub compatible with ef?
- 90-97 accord rear struts on rear of 88 dx.
- what can i get for it?
- Sent the wrong IACV valve, will this one work? Pics inside.
- how hard to get 14's with d15b2 mini-me (d16z6 head or d16a6)?
- how much does a fully gutted 91 hatch wheigh?
- does gsr throttle fit d series intake manifold?
- are hcp mounts worth $245 shipped?
- newb question about strut bars....
- Body Kit Rear Bumper
- I just got the beauty! Now for a couple of q's
- my hatch was stolen last night.....
- Has anyone heard of this???????
- 1990 dx hb steering wheel removal
- J's Racing group buy on EF front lips
- 1st gen CRXs
- B or Z?
- Cleaning engine question
- Guys with Jimfab cross member, please look
- civic si with automatic seatbelts with cage???
- what DC headers for b18c?
- How much oil in the ZC?
- J1 tranny.
- Yet another DPFI-MPFI Question..
- 90-93 integra calipers & 90-91 ex calipers
- Tranny Noises.....pls help want to prevent!
- lightest seats that will bolt in a 2G rex?
- need help asap!
- Spring Tech struts are they any good at all?
- EK seats in an EF
- my friends axles fo rhis standard hb to b16a
- putting in 4 point sparco bolt in harnessin my ef, somebody tell me how and where?
- b16a in crx question
- can u use si axles and hf nuckles?
- Which is the best tranny(Y1, S1, J1)?
- Distributor woes
- ZC parts question. Please help...
- Question about FPRs... [Mini-Me]
- Kumho 711 and 712....??
- body is leaning?
- Which FUEL INJECTOR Cleaner do you use?
- Just double checking-Code 23 (knock sensor)
- B16 Vacuum lines...do these look right?
- Quick question please help...
- Question, on 88 crx hf to si engine swap
- Question on crx hf, to si engine swap????
- b16 throttle body problem help pleeeez
- code 9 on mini-me
- Removing valvese
- US/JDM Clock in 91 Civic Hatch STD
- Has anyone ever had this problem??!?!?!
- Right side exhaust....
- vision corner lights?
- 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver
- ??engine code for 91 CRX si....
- Need side pic
- 6 speed tranny with 90 si motor
- DOHC ZC engine rebuild parts list
- to p/p intake manifold, how much n where in san diego
- does my car have an ew1?
- Put a new climate control in and heater doesnt work WHAT IS IT?
- ef power window motors (did the search)
- 3-2-1 header? wtf?
- d15 specs please!
- Nor Cal Dyno Day #2
- ITR front UCA on crx?
- How much would a glass (moon roof) for a CRX sell in the US + shippin from the UK?
- I need some advice
- 91 hf zc swap
- Oil Leak at the Vtech Cylinder (1991 B16A)
- time belt question? slowly moves
- timing on 75 shot of nawz?
- selling my car
- delta camshaft???
- Where can I get a B16 head?
- b16a upgrade questions
- ZC leakdown #s / should i buy it?
- crx disk brakes
- motor poll...which one???
- b16 oil filter oil type thermostat type basic tune up questions FIRST TIME~!
- Car will not start, just cranks - problem resolved
- Adjustable cam sprocket on D16?
- ok i have ? swap ? i have been told so many things. ANY1??
- There are a lot of badass cars on this board
- What camber kits will work with my EF?
- B17A EF's...What octane do u use?
- cooling fan relay connector
- D16A6 tranny bolt on D16Z6?
- help on next project?
- uuuhhh someone broke my drivers side window in front of my house.....
- pr3 vtec crossover!!!
- Question about my motor?
- How-To on moving battery to the trunk?
- re-upholstering seats? How hard? Links?
- zc swap Q's hf crx
- Distributor Problem
- Automatic Transmission Shift Point Problem...
- HF to Si swap: Can I reuse these? ( Dizzy,Intake,TB)
- Are these 2 engine harnesses the same??
- check out my muffler idea
- 89 crx hf-ls swap axle info
- does hondata make ecus for this
- pics of my header guard (skidplate)
- BISIMOTO Engineering header for D series are coming soon.
- quick question about stock d16a6 valvesprings
- crx(B16) running really lean??
- Cool 1stgen CRX
- HELP 88 CRX owners!!!
- AN-R D-Series headers now available
- Bad front wheel bearing symptoms?
- MPFI INFO aka errors in SCC, Hasport, and Honda Tuning printed info...
- changing the cluster
- Can extended wheel studs be put on without removing the hub?
- How to take off IM bolts?? QUICK HELP PLEASE!!
- valves are getting loud
- Y8 intake manifold for mini-me?
- 91 CRX Si engine help
- Where to get RSR springs for ef
- b18 motor mount?
- Grrr, MPFI not going well at all
- where to mount IAT sensor for the Y8 manifold swap
- Trim Paint from Autozone
- miss at idle
- Saying so long to the ZC
- Valve respacing (already did a search)
- b16 obd0 and 0bd1 question
- Attention to all 2001+ Civic Owners.
- looking to do a turbo on a zc
- trying to sell my 89 CRX- fully gutted b16a etc
- CRX HF swap help...
- what's needed to get a dohc zc into the 14's
- motor question "noob question"
- where can I get this b16 motor mount?
- coverting drum brakes to disc?
- S1 tranny
- 90 SI HB civic suspension
- Anyone have pics of a Apex'i N1 exhaust on a CRX?
- FREE interior paneling...(norcal)
- 566WHP Street Civic with 412ft of torque!
- dpfi to mpfi. looking for diagram??
- cam gear?
- Need help converting 88' dx gauge cluster over to that of 90' si.
- non obd B16 Q's
- what axsles do i use?
- what does a 88 gutted si run w/ 55 shot of zex in a 1/4?
- Lighting problems
- LS Turbo
- 88 crx - ls/vtec
- chech valves?
- Compression Test....check this out.
- Rebuilded SIR won't start, very hard to figure what's wrong, input needed ASAP.
- ImPoRtAnt
- question about rear disks...please help me as much as you can
- 1991 crx brake rotor size?? 9.5inch right
- speed blinkers
- Need help with swap!!!
- crx carpet
- b20 vs b18 ?
- SUN ROOF!!! fillers or ideas?
- looking for tranny
- Crower 403's
- Cracked Sunroof Help!!!!
- ZC Noise
- Tranmission Question
- what tranny should I get?
- Mini-Me parts list??? Anything else?
- 90-93 teg axle, dust seal removal?
- any one used integra type R suspension on a crx?
- MD Snow storm
- Rebuild of a DOHC ZC.
- Where can I find struts for a 88' DX?
- kyb gr2 or tokiko blues?
- what should i expect? sohc+vtec+turbo=????
- Leaking oil??
- Compression
- FPR need a vacumn hose location for a B16
- 4-1 header questions
- B16A or B18A with J1 tranny?
- '91 CRX Si Exhaust Manifold Removal
- best overbore pistons
- Quick Question?
- relible b20 vtec swap?
- Good Setting for adjustable cam gears?
- does this sound good? 400.00 shipped crx?
- Factory ITR struts?
- won't start when warmed up
- What Alternator?
- A few random pics from Homemadeturbo.com
- windsheild?
- One fast REX coming your way!!
- What size are crush washers
- Possible Orange county meet/ideas welcome
- Is this bolt ok to fill up the trans ?
- i have a 89 crx si having problems wit the pasenger door!?!?!?!
- naturally aspirated vs turbo (sorry if re-post)
- Need everyones help!!!!!!
- Engine code on your CRX Si
- Extended wheel studs?
- seats what fit
- axles for b20b swap
- I need help with what axles to use?????????ASAP
- Rebuilding a B18A too put in my 88 hatch
- swap help!!!
- Question about jdm pwo ecu...
- body work estimate? $$$ experts/experienced please reply
- let see ur b16 turbo set ups mainly for fitment issues
- Check engine light NO MORE!!!!!
- Catch can q along with PCV valve
- Integra console into a DX
- 91 dx clutch in a 85 crx si?
- DPFI to MPFI for u guys that need info
- SiR front crossmember? Will it fit?
- FYI My 98 DX starter fit my 89 DX!
- need pic of stripped interiors
- Gude sohc vtec cam - HCCS14
- Ground Control Install Question??
- My buddie's CRX went crazy yesterday
- here's the pics of my polished crack!
- which plug wires for mini-me
- got my 3" thermal muffler now i got one q's....
- can i use any crx axles with hf
- 90 crx and sohc vtec
- ?Red Springs & Blue Shocks?
- Some questions i wonder about....
- ZC Stats
- Problems with my new motor. Have any ideas?
- B16 Vacumn Dash Pot q
- zc swap pain in the rear coad 8 and code 10
- cool videos...but need help!
- crx 1988 good buy or no
- how much does it cost to rebuild an engine?
- interior help
- interchangablity between struts
- intermediate shaft?
- Will 89, 90, 91 hatch interior fit my 88 hatch?
- any diffence between 88 dx and si steering rack(manual)
- CRX • 88 Headlights/Corners to 90-91 Headlights/Corners
- ACT 88 Upgrade
- HELPP!! SMC Install=- car wont crank now-10$ to whoever can figure it out
- B18b throttle body on my 1st gen b16a
- tail light question
- skunk2 camber kits for eg fit ef??
- any glove boxes w/a lock?
- ITR Manifold in CRX
