View Full Version : Honda CRX / EF Civic (1988 - 1991)
- GSR header
- gsr ef
- headers on ebay ?!
- What brake caliper to run with big brakes in rear?
- shaking car at 35mph
- battery light, i am very lost
- 90 crx
- Won't start, Backfires when turning over. HELP!
- I HAVE A QUESTION ABOUT A SWAPPP
- Burned Ignition...
- a few b16 swap questions (belts, and manifold)
- Car won't start (searched)
- problem with my crx
- D17A2 swap in my hatch. a little help please!!!
- can it be done? 94 EG swap in 88 REX
- crx dpfi fuel pressure
- I just watched the bmi america togue!!!!
- Light Buzzer
- k sport suspension
- I need a clutch pedal!! Help
- difference in v-tec and non v-tec i need help!
- msd 6al help
- ID this IM shaft?
- Darton Sleeves
- Need Swap Info
- Blown headgasket or cracked sleeve?
- Will wagon rear seats fit in my EF?
- What suspension are you running?
- Anything i can use from an STD motor to make an Si motor more powerful?
- removing badge from rear light
- Proper V-AFC tune for a stock Y8 in my rex?
- Integra coilovers on an ef
- LF: dash kit
- harness plug pinouts for dash cluster harness 90-91 Civic Si
- crx climate control
- CV joint/body work
- Noob needs help to sending message to Civic seller
- Need Help Trying to Swap 00 Type R Cluster in my 91 Civic STD
- Oil pump for an OBD0 B16?
- New to obd-1
- mpfi swap 4 sale
- high idle on b16a
- battery relocation wiring diagram?
- questions about agressive cam for d16a6 and more!
- k series swap
- Distributor final clarification
- IF YOU HAVE A SWAP CLICK HERE!
- hondata cel
- Weird idle issue
- 88 si for free(thats right) for free
- should i get go all motor or turbo? need input
- is this a distirbutor problem?
- what's an ef
- Help with cam timing
- Sometimes does... Sometimes doesnt....
- I hate people
- JDM Whale spoiler mod
- alternator took a shit :(
- oil in motor
- Dimmer switch discontinued
- Install VAFC on B16 Crx with pr3
- Hwo do i i tell apart the us s1 and jdm s1 tranny besides swaping them in the car
- what is this mean (newbie)
- more frustrating tranny problems
- car vibrates at 2000 rpm
- tie rod end thread size?
- S2000 push start button
- I HAVE A QUESTION NEED HELP ASAP ABOUT MY EF HATCH
- intake swap
- Honda Car Care Days, April 1 - April 30, 2006.
- not holding fuel pressure
- dohc zc in civic hatchback???
- will 90 ef fenders fit on 90 crx
- is this steering wheel worth it?
- What's up? New to the board
- carbon fiber wrap?
- hub removal , confused bc everyone is saying diff ways
- CRX ECM
- umm What an EF?
- zc mini-me turbo!!!!!!!
- crank pulley help
- What is this??
- Distributor Gasket
- difference in b18a and b18b
- ksport coilovers with pillow mounts
- I HAVE A QUESTION ABOUT MY 91 EF
- Timming belt.
- Battery Question?
- Bulbs for top of Gauge cluster...What do I need?
- axle fitment
- seats what can be made to fit easiest?
- does anyone know if door panels from a 89 civic dx will fit a 91 crx?
- jrsc fit in crx with b16a?
- how to reupholster CRX seats?
- Turbo b18a?!
- Block Guards
- Pulled tach needle off to clean...Now it doesn't work?
- 88 si, rear discs conversion = 89+ shocks?
- Axle instal tips?
- smoking out tail lights?
- car idling up and down
- lookin at motors and...
- brakes
- Just got my Hasport mounts. H22 into a CRX. Questions!!
- FS Sparco Speed Seats w/ rails and brackets SEATTLE AREA
- dont know how fast im going.
- takin off the butterfly...
- can electrical vss be interchangeable with mechanical vss?
- Alignment problems due to CASTER
- obd-1 conversion harnesses on ebay
- Clutch/Tranny Issues
- FS: jdm ef8/ef9 SiR headlights & climate control $$ 125 shipped each!!
- Making the paint shine again?
- Most powerful CRX 3v4r and i mean EVER
- hahah these are some tight ass songs about hondas
- sir front end question?
- a 85 crx sunroof on a 1991 crx si
- CAR IDLING REALLY BAD
- Will any parts work off an 89 prelude
- electrical problem?
- Help with ECU Codes and Hesitation
- High output alternator,cant find one
- how well does ur all motor d-series run
- Quick A/C guestion after motor swap
- 89 Ef Hatch
- PLZ some one tell me if im wrong about this?!
- Does this sound like a spun bearing?
- r134a ac compressor
- * PLEASE HELP * question about crank pulley
- PIC REQUEST~~CRX w/ 04 Civic EX wheels!!
- CAI question
- CRANK TDC Markings - Can I repaint them? Cant see them
- b16a swap vacuum routing
- installing 1990 - 1991 driver side window
- 85 Si PGM-FI
- High Output Alternator.
- B16A 3-4 Synchros
- std w/ si cluster direct swap
- MINNESOTA HELP!
- Crx keeps dieing.
- tein pillow ball mounts question
- Quick release short hub question
- Shortest EF shifter
- where to get carpet
- 88 hf & b16 swap
- Does the Z6 need a injector resistor box?
- bad TPS??
- T-belt has nicks on it
- Project: 88 Crx LS...
- speaker question
- A little plug ID please...Thanks!
- Problems after clutch swap
- cluster for crx/civic?
- ZC SOHC non vtec cam install
- First Gen Civic 1200cc turbo kit, what cha' think...
- crx tach intsall help ASAP
- obd0-obd1/dpfi-mpfi: 4 wires left?
- Need to replace exhaust from the header back
- where is a good site for b-series
- 88 crx si starting problems
- EF8 Conversion, Type-R Swap done. Thanks Honda-Tech!
- I have oil leaking from my axel...
- More Newbieness- Check Engine Light Showing O2 Sensor...fixing it question
- Turboing my B18A
- crx si w/b16 tranny issue??? NEED ADVICE
- Please help with my brake problems!
- 92 Civic Dx Injectors
- any idea where i can find
- rear hatch weatherstrip
- d61a6 basically same as d61a1
- fuel pressure reg
- My Project EF3 almost completed
- Signal light stalling
- DPFI to MPFI, can i use the b18 OBD0 wiring harness for the spare plugs?
- CRX 5 Lug conversion
- 2nd o2 sensor
- the integra disc conversion
- Car wont start after sitting for 2 weeks
- Idk if this is a nooby question or not.
- ls/vtec turbo ?
- what gears will work on a B16 cable S1 tranny? (small spline)
- Need a quick answer - How to *know* if HF vs. DX
- what do i need for an turbo LS in my 89 civic sedan
- drift button, anyone know how to install one?
- Car Just Won't Start!
- fpr advice
- ECU CODE
- zc swap feels like a go cart
- Cold bottom rad hose...Problems...need help???
- axles
- crx seats
- d16z6 in my 91 crx
- Need help with dx to obd1 dizzy wires dohc ZC
- Would these seats fit?
- Injector Resistor????
- spoon sport sw388 wheels, WERE?
- just did auto to manual swap, linkage question!
- help identifying ef trannys
- i need this dpfi to mpfi
- dual carb zc sohc
- What timing belt for my for my poor man’s non-mini me head swap and who’s taking my oil?
- 90 Civic Hatch Si Trade/Sale
- obd1 help
- gas gauge problem, maybe?
- what is my wheel offset/bolt pattern?
- Battery Relocation.
- Can u guys please recommend what to get for a sway bar?
- lookin for an diff alternator...what is good.
- new project
- Just bought this, what do you think?....It's going to be framed
- HELP!!! EF WIRING HELP!!!
- need help...motor revs instantly
- ebay strut bars
- from a dx to a mini-me, do I still need the injector resistor box?
- FOR SALE THREAD!
- Turbo or Supercharged B16
- Picking up 88CRX HF - What to do first?
- oh joy! my clutch pedal assembly bolt just snapped!
- aftermarket crossmember
- 91 teg rear disc conversion on my 91 civic si questions
- LOOKING FOR JDM SIR PARTS
- my spring break- motor and interior swap. bunch of and questions inside
- b16 rear bracket for ef PLEASE HELP>>>>>>>>>?
- B-serie Transmission problems !!!
- oil
- mini me swap
- rpm is off...
- dash lighting
- Fully built JDM D15b vtec vs. b16
- 91 crx for parts
- does a 90 or 91 civic 4door ex exist? if so pics?
- Steer Wheel Opinion
- 88 si Hub
- ?????diference between 88-89 and 90-91 crx front bumpers??????
- replaced timing belt and water pump tonight...
- HELP.......
- part of wheel bearing stuck on hub-side. (88 si)
- Wagon clutch pedal stiff and trans woes
- what sunroofs for the crx
- tranmission question...help me out*********
- Need some help figuring out manufacturing location
- i went on a jdm shopping spree
- i cant find a 89 teggie helms around here so thats why im asking i just want to see whats all invole
- intake gasket
- anyplaces online to buy rebuilt crx trannies?
- So here is my plan...
- Has anyone ever seen this rear hatch??
- Ebay clutches??
- Car died today, need a sanity check.
- 1991 CRX W/JDM D15B VTEC
