Questions about EF B Series Mounts
Old Aug 11, 2015 | 08:21 AM
WhatThe_EF91's Avatar
Default Questions about EF B Series Mounts
Hi, I'm Jes and I own a 1991 Civic Hatchback SI with a B16A swap (including the Y1 LSD Cable Trans).
I've had the swap for many years now, and it is well past time to replace the haggard urethane inserts. I have all Hasport Mounts and just purchased the 70A (race) from Hasport.
I'm looking for info on the smartest way to dive into this project... Meaning, which mount do I start with first? Any advice on tackling the rear mount? ETC...
Mostly just looking for a simple write up for the process of changing out my mount inserts. Any help would be great. Thanks!
Old Aug 11, 2015 | 08:32 AM
.Manny.'s Avatar
Touching My Member
Default Re: Questions about EF B Series Mounts
I've always done rear first, then trans, then driver's side.
It's pretty straight forward. Just dive in. Make sure you have a hydraulic jack, jack stands, a good set of hand tools, a few extensions, and a swivel adapter.
have fun.
Old Aug 11, 2015 | 10:26 AM
VegaS10's Avatar
The rear one is a huge pain in the *** to get to.
Old Aug 11, 2015 | 10:35 AM
Freemananana's Avatar
I had some issues with my rear mount and when I replaced it, I essentially just picked up the whole motor (removing all the motor mounts) and replaced it first. Then I lined up the others. With the side mounts in place, I find it difficult to get the motor in position for the rear mount.
Old Aug 12, 2015 | 09:07 AM
Thanks for all of the replies.
Rear mount was definitely the biggest pain, but mission was a success.
Old Aug 12, 2015 | 11:21 AM
whited's Avatar
CRX God
You don't have to lift the engine if you don't want to. I have successfully done it without lifting the engine even though I thought I might have to. I remember removing the rear intake support, oil filter, but not sure if I removed the alternator and/or the axle.
I was aiming to get the rear support bracket out not the mount though. You need a good flex head gear wrench for that back bolt though.
acmoc
Mar 29, 2017 05:36 PM
ef yu
Mar 23, 2011 10:58 PM
B18C5-EH2
Aug 22, 2008 03:57 PM
Maengelito
16
Dec 5, 2004 07:07 AM
