View Full Version : Honda CRX / EF Civic (1988 - 1991)
- another question si d series disty same as b18a wiring wise and everything?
- starts runs and stalls.....DOHC ZC swap.....
- ????Will an 01 GSR Center Console fit in my 88 CRX????
- B18b swap in a 90 crx si help?
- GSR Brakes and knuckle on 4dr EF?
- Just picked up a rex for new daily driver
- b16a question
- d15 motor question
- am i asking to much for my crx?
- 91 civic gauge question
- upper a arm stripped
- supercharged d series
- I just got this ef with a b18a swap and I need to know where to get some stuff
- best suspension?
- ignition?
- what parts needed for street tune of d16z6 honda crx
- tranny tranny, wont u shut up...
- lights comes on!
- error 15 on a honda Civic hatchback SI 1991
- timing belt tensioner
- i want powerlocks and windows can anyone help
- CRX B18 Axles issues. Please help!
- Can you use the stock fuel pump on a fuel cell?
- my ecu light doesnt flash- it normally flashes once when i turn on the ignition
- (i searched) How hard is it to install a fuel pump on a 91 crx?
- whats the ECU's job in making the A/C work ??
- upper control arm hitting frame
- 89 b16a hb running problems
- 89 dx interior questions
- blowing fuse to a/c condensor, opinions would help
- main fuel relay
- Urgent, can I put DX calipers on a Si?
- B16A problems
- Running terrible
- any one used explicit speedperformance motor mounts ??? LMK
- I finally did the integra cluster swap into my REX
- help me identify this cluster
- what do i need..
- Best intake diameter for B16A NA...
- Hi Flow Cat...... Texas emisssions????
- Can i use 90-91 crx fenders on a 88-89 crx, help asap :)
- J's lips - What companies made direct copies?
- Won't start after swap/CEL Code 41
- Mugen LSD for D tranny
- d16a6 distributor sounds like a pepper grinder?
- main relay location??
- Want To Build A CRX Stock Car. Need Some Help With Rules/Regulations.
- SWAP
- distributor problems
- What full swap should I get for my CRX?
- Manual Conversion?
- Transmission Question. please help!
- HCP cast mounts
- strut bars
- A/C Recharge Question
- Idle Question Guys?
- jdm b16a spark plugs and wires question
- Code 8 with one distrib, then code 9 with a known good distirb...
- fuel cell in daily driven car?
- JDM or what????????
- high idle? searched....done everything
- full DOHC ZC head help/question
- fire wall map sensor problem
- troubles with wires
- i wanna get rims but hav no idea wut im lookin at...offset bolt patterns?
- engine clicking sound
- MINI-ME TURBO BUILD
- CHANGING FROM AUTO TO MANUAL
- ignition module question
- How much Toe in should I have?
- braided brake lines
- CRX starting problems
- Car won't start, sparking from valve cover...
- civic charging problems
- possible miss fire after mpfi need help
- Oil Seal QUICK QUESTION!!!!
- h2d swap
- 88 CRX si w d15b swap,problem with left blinker and coolant temp gauage
- civic sedan 1990 help
- Recaro Seats
- help with rust
- does anyone have inline pros number
- brake lines bolt to the strut help
- I own 91 honda civic 4dr have few questions
- Help. NO BRAKES!
- b16a swap plug left over. need help
- CBR 600 tb's too small for ls motor?
- B series swap in to my 91 Si
- Picked up a set of ef9 front seats, need help with install
- surging idle question i have searched
- 91 si sohc zc
- b16 axle wont fit into halfshaft - Searched, but found no help
- door panels!!! need help finding door panels for my hatch!!
- 89 Civic Sedan no power to the fuel pump HELP!
- Okay need some help................Please
- WTB:ef9 radiator t bar
- chipped ecu question
- 92-95 Civic HB Suspension Fit 89 Civic Sedan
- HELP! b16 swap wont fit!!
- B16a1 clutch
- 91 civic blue smoke.
- My civic B16A1 Turbo inside
- ex brake swap question
- wire tuck help
- Is this turbo kit legit?
- Air filter box on a CRX B series engine swap?
- carbon fiber lip
- no nothing
- distributor question
- goin to build a ls/vtec guestion
- breaking up at 5500
- Pw0 ecu with Spoon Sports chip
- 1990 to 1991 USDM CRX factory Fog Lights.
- Which driveshaft? Teg 90-93 or Sir
- another mpfi conversion question
- Does the IACV need the coolant lines running to them??
- mini me: z6 or y8
- a few problems with my crx
- is there any crx meeting in socal ?
- lcon traction bar..
- WATER PUMP Replacement for 90 CRX HELP
- 89 Civic SI Dizzy Prob!!?
- hydro d transmission
- no problem or problem?
- help with wheels
- no spark...
- stolen in Las Vegas 89 civic dx hatchback
- stolen in las vegas my nephews 89 honda civic
- How do I get my HATCH to stop leaking?
- D15B Vtec Question about timing (SEARCHED) HELP ASAP!!!!
- CODE # 9 PLEASE HELP ME
- need help with code 6......
- My two cents on this forum.
- knock sensor issue canot fin answer. ive been searching for 3 days now!!!!!
- No power to ecu B16
- this prolly sounds old but.....
- Where to buy: Corner light for 85 CRX
- Body Panel Gauge
- got a turbo zc question in reguards to timing
- cruise control removal.
- In need of HELP. Somebody please
- B16 OBD 0 Swap Problem
- HELP with diciphering engine code....
- Oil pressure sensor wire
- question about z6 swap in an 88 crx hf
- sunroof bubbles (inside car)
- boosting mini me
- What Exhaust Manifold yeilds best mid-high power?
- Need help ASAP?
- Battery draining problem.
- obd1 LS swap/left over plugs?
- Mini-me problem d16a6 d16y8 bogging
- weird pause?
- little modifications
- what kind of head on a b16 bottom?
- a conversion
- what where the extra USDM options on the 1990 model civic ef hatch
- overheating please heLP!
- should i try and targa top my crx??? thumbs up or down
- p72 or p28 ?!?!?!?!?!?!?!?
- help blinkers
- Broken links on H-T?
- tails just stopped working
- cross member problem...
- goin to rebuild
- I JUST BOUGHT AN EF I HAVE QUESTIONS
- engine balance question on D16a6 pulley.
- Another battery question
- timing belt help
- quick help please, ordering brake parts
- HELP .....SMOKE !!!!
- 1989 crx c pillar ?!?!?!?!?!?!?!?
- 88 D15B1 C/R different?
- Power Windows Upgrade
- dizzy swap
- 91 crx ?
- Quick crossmember question....
- 88 crx si no start
- JDM B18C
- b18 shift linkage
- some dizzy help ....
- Neuspeed Race Springs
- Dizzy Concerns
- good bye honda
- Intake Manifold (Skunk2) Question
- got two problems
- looking for someone to tune my car
- 91 ef sedan motor swap
- What injectors can you use for the D16Y8 manifold swap????
- my car die when i step on the brake HELP!!!!
- Turbo b18 with ac....is it possible?
- ugh stupid fan question
- b18a crx vs 99 si
- omeone eyeball this radiator and tell me if it's single or dual core
- ecu trouble codes
- 1989 honda civic LX
- B16a swap questions. i searched but apparently i suck
- NEED HELP crazy boggig
- Fastbrakes 11 inch kit
- piece of crap civic is hesitating like its a freakin virgin!!
- I need help on tuning my B 16A
- Cigarette lighter question
- D16A6 rebuild, by a Newb.
- is 2.5 inch exhaust good for a lightly modded na b16??
- When it gits hot out the car won't start
- replaced head gasket now wont start (88crx si)
- harmonic balancer clearance problems
- Which Radiator
- EF
- Tranny from a 86 work in my 88?
- AEM Big brake kit
- transmisson
- easy horsepower?
- The day the D died...
- suspension mod
- 89 honda civic Dx
- Need 91 CRX Si gauge cluster wiring diagram asap..please look.
- Baltimore/DC/NOVA
- Elite Summer Nationals.
- CRX - Changed starter and new starter turns too many times
- Keeper interchage? Help ASAP
- Omni power coilovers
- CRX- value
- No Start, Odd Symptoms, tested and searched, require help please
- loose shifter..
- Can anyone tell me what this is??? I believe it came off my D16Y8 Intake Manifold??
- where can i find the cheapest rota rims w/tires?
- Black hose under IM
- 94 Integra ls complete harness into 91 CRX Si...need help..please look.
- Attempting the D16Y8 manifold swap-Where is the IACV plug????
- 90 honda crx si coolant temp sensor local????
- what is the max boost on a garret t3t4 turbo?
- tranny Question
- need some zc advise please
- new to the honda game...NEED HELP PLEASE!!!
- no spark crx with a b18c1
- code problem? help
- crx si or civic si axles any difference
- buddy club exhaust
- block A cams
- No Injector Pulse
- DPFI to MPFI! help please
- when is the D2B kit coming out? or it is
- Surging Idle.
- what head gasket for sohc zc
- CODE 9 / 41 Cannot FIGURE THIS OUT
- Are there any other gaskets with your distributor other than the O-ring on a D16Z6????
- D16a6 crankpulley help
- ive searched please help!!!
- wrecked ef
