View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Rear speaker installs
- dsm smic mounted in front.. anyone done it?
- MEGAN rear LCAs??
- turbo build decision....buy new block or sleeve current block
- homemade air intakes?
- Newer Apexi SAFC II on Ef OBD-0 cars?
- aeromotive fitting?
- Motor Swap????
- ECU and Wiring problems
- New gauge cluster. what do you recomend?
- AN-R mount kit?
- hood question
- Radiator Cap Selection for Koyo.
- manifold
- I THINK I FOUND THE 2005 CRX?(Honda Fit)
- b16a1 block with 2000 gsr head?
- wheel size
- Valve cover colors??????
- b16 transmission fluid help
- someone here talked to my dad at Courtesy Honda today...
- need wire diagram for 88-89 civic gauge cluster
- 91 CRX bigger brake master cylindar
- Brake Pads *quick reply appreciated*
- Race Fuel Use Help!
- CV's are toast.
- obd1 engine wiring harness into a obd0...
- ZC question??
- suspension ?
- hellllllllllp
- Swapped Master Cylinder, bled brakes, still have problems...
- hiring help b16A in crx !!!!!!!!!!!!
- b16a1 wiring problems
- need some opinions
- OBD-0 cable transmission on OBD-1 D15B vtec?
- B16a Water pump 94 del sol vtec doesnt fit
- Progress pics of my hybrid Civic/GSR cluster into my sedan. Mini how-to, y0
- Picture request (EF hatch Specific)
- Im putting a GSR motor into my 90 HF WHAT AXLES DO I NEED??
- im sure this has been covered but i cant find it in archieves.
- some help please
- beefing up the suspension
- 88 hf
- Great Fitting OEM/Aftermarket OEM Parts
- crx clutch
- ZC Swap questions
- dash light problem? help!
- How much would you pay for a mint CRX?
- ive tryed searching for the pr3 code no such luck
- Rumor has it someone here can sell me koni yellows for 475
- 91 civic si cluster into 91 civic dx
- Conflicting responses
- body kit parts..
- B16a to B17a project log. not a big build....
- P70 ecu
- FS: DRAG gen 3 turbo kit For B-series in EF
- headlights and angel eyes
- B18c5 Integra TypeR Motor Into A CRX?
- Do i need to modify?? b16 swap...
- 87 CRX
- suspension problems..HELP
- JDM dash question
- Timing mark questions and what # do put the knob to on the timing gun
- I believe that the money saved on the price of the R can be used to make the gsr faster than the R
- car is broke down please help
- CRX H22 swap?
- motor
- Working Pictures of 88 DX and a Lesson in Uploading...
- DPFI to MPFI
- Turbo b16 problems
- idle speed plm
- what ecu should i use in my91 hatch si a pm7 or a pr4
- Turboedit / datalogging / palm question
- Super Chargers....
- ZC timing belt question
- 88 DX Pics! Opinions? Need Input...
- Question about the JDM 4 door one piece headlights
- Blue smoke when taking off from a stop...why?
- prices
- 88 CRX Si/ Ef Hatch Fitment Questions
- Best ecu for car, differences?
- full-race traction bar/ crossmember for 90 CRX
- code 4 help
- paint is finished...pics to come, now NEXT
- Racing seats?
- cross member removal
- Just back from the track..times posted inside
- the Radiator again....
- droppin tranny tonight help
- did y8 head, mani swap with b16 tb, where should i relocate the IAT?
- weird squeeling noise
- Rare HF catalytic converter please help
- crossmember help!
- Any info?...disconnect the clutch switch for start up?
- for sale... 91 ls
- Can I Swap in Cruise Control from an EX Sedan?
- new on the forum
- sunroof fitment between 85-87 and 90-91 si
- B16 question
- help with wiring B16a
- Cracking sound at 3000 rpms
- WTB: Civic Si or CRX in Ontario
- ANY BOBY NOW WEARI COULD FIND A RHD CRX
- wiring b16a
- D16Z6 into my 88Si.....
- tranny for a b16a1
- Mini Me Y8 head or Z6 head
- my radiator fan doesnt work.. i think...
- AMBER BUMPER LIGHT PICS
- Mini Me Z6 or Y8?
- Starter Solenoid Wire Mixup
- Pressing gas makes the car kill
- Clicking and ignition
- Are EF 89-91 Rear LCA same as 92+ Civic LCA?
- I want your guys opinion on my work i did to these wheels
- speedo HELP!
- A/C wiring troubles
- Crx Si seats
- benefit of aftermarket crossmember
- ef8 jdm front end conversion.
- 14b or rhb2?
- TRANNY CLEANING
- anybody have a picture of a .... i searched
- Si harness question
- im thinking about getting the crower stroker kit
- who has an SIR front end on the east coast?
- Fuel injector problem?
- EG Seats into 91 SI??
- mini me Q?
- e manage yea i searched
- Dumbass people... (Buying a CRX)
- 1988 CRX - Code 16 = fuel injection
- Rear JDM head rests on a hatch...
- Battery light is on, dash lights are dim...
- IDLING a little too high
- 91 Civic HB Help
- Test Pipe Worth It???????
- what are the computer codes for an 88 si
- Engine Compression
- Crx Sub harness??
- need a crx shell desperately
- Climate control problem...maybe you can help?
- Stripped alternator bolt
- Fuel Smell from CRX when I get out after a drive.
- REX injectors
- HELP, did a mini me swap now car idles wrong, and wont go over 5000 rpms
- Rs-r GT-ll Exhaust
- Tow Hooks....?
- Build My SOHC ZC **OR** Buy Pre Built DOHC ZC
- Few questions about B18C/CRX DX swap (fuel feed, vacuum lines, etc)
- Tachometer red wire connection
- Swap Help
- Spring chioce dilema
- NO FUEL?????? NO FUEL?????? NO FUEL?????? please help!!!!!
- cheap motor swap?
- cel code 23
- new swap, ZC DOHC throwing codes 8 and 9 need help
- Tranny fill problem!!
- 87 crx h23 mounts? possible?
- Car runs with no O2?
- will 91 Dizzy work in 89?
- b16a Qs
- I've rediscovered the joys of driving.
- trying to install kill switch, and no, i couldn't find the answer from the serach menu.
- b18b swap help cel 3 and 14!!
- JDM EF Body Parts
- 88-89 corner lights to 90-91 corner lights
- ef8 and ef9?
- corner lenses, 89 civic hatch
- obd1 block /car(95 civic w/d15) w/ obd2 (d16y8) top end???
- wtb jdm bumper pole
- Radiator question...
- JDM CRX rear speaker brackets ??
- zc help
- ecu codes
- New lightweight underdrive pully, needs new alternator belt?
- dual point to multi point
- New CRX Bodywork
- B16a question
- Help on suspension.
- help with master cylinder, possible upgrade too
- D16Z6/D16Y8 into mpfi CRX ----- WHAT DIZZY DO I USE????
- LOOK!!!
- Replace Syncro(2-3) or get a New tranny???B Series
- my car worries me too much
- How much were CRX's Brand new back in the day
- i can't get my speedo cable to work!!
- CHECK ENGINE LIGHT & CODES WILL NOT STOP
- How many Crx's have you owned?
- HELP, starter signal fuse not getting any power...
- roarring noise ony my rear tires
- Removing rear bumper support on crx..
- sir front?
- crx si b17 swap, what wiring do I need?
- Differences between Si and HF harness
- New Jersey engine swaps
- i got a Honda Crx HF 91' any ideas that can help?
- Swap Sir 00 in civic 91
- installing a new dizzy HELLLLP
- D15B1 power??
- 1991 Honda CRX si (should i get it)
- window
- Anybody have a ZDYNE tune for JRSC B18c?
- JDM Freaks, start bidding! (not my auction)
- did the obd0-obd1 conversion and this is my problem
- Tranny story and question.....please help
- Front hub has LOTS of play?!!
- LS/VTEC swap wiring questions?
- are e-bay lowering springs any good?
- vss issue
- to all you Civic and CRX owners
- HKS Exhaust/Mushroom for a 1991 Civic GL 1.4 16V
- Things to Make My Dirt Track 88 CRX Si a Bit Faster, need suggestions w/pics
- CRX Dash Instructins
- Vtec Solenoid
- RHD Crx SiR. Opinions/Points/Prices/Info Please
- D15 Timing issue(s)
- would the water sensor have something to do with the vtec not kicking in on the single vtec motor
- where is my water sensor on my single vtec motor
- CRX HF/B16 swap question/problem
- whats the best engine for...
- in your opinion......poll
- Not another SRI vs CAI
- MPG display?
- Non honda gauge cluster
- 1991 Honda CRX
- What valve lash are you using with your SOHC aftermarket cam?
- nitrous jets question
- askin for input on cams
- tach installed but not detecting rpm.. why??
- wiring help
- what has to be done to put a h22 in 90 ef hatch
- Radiator help!
- how do i install integra seats into a crx???????
- Replaced driver side axle now car makes grinding noise while driving
- dohc zc intermediate shaft question
- ecu chipping
- no power to starter signal fuse...
- does anybody see this but me?
- b series motor what tranny?
- Pics of my Rexbie.
- what do you call the sockets that goes in here..
- do the crx camber kits inlcude upper ball joints?
- how low can a towed car be
- anyone selling a Zdyne?
- indigo guage install this one is a tricky one
- can't find this torque spec anywhere.
- 88 Hatch DX, Z6 OBD1 Swap, Tach reads too high and too fast?????
- egr valves
- anyone near psl- South Florida w/ chip burner
