View Full Version : Honda CRX / EF Civic (1988 - 1991)
- type r red honda sign on steering wheel
- sunroof swap help
- zc dohc water pump inlet pipe
- Timing woes
- b16 sedan bogging need help
- POSER ALERT
- b20 swap? mount
- trying to go from 4 speed to 5 ls helllllp
- need some help....
- injector size question
- TACH...
- What shiftlinkage do I need for a b18 into a crx?
- Need suport for a special edition 91
- 91 CRX Si help plz
- Kicking the carb.... please please help
- Help! why am I still a trial member?
- d16z6 swap in a 90 si
- aem ems question
- 1988 Honda Civic Hatch DX Auto 1.5L Dual Point
- changed Master Cylinder and Bleed brakes, now car dies when I press pedal
- motor ideas for my crx
- front crossmember.auto diff than manual?
- fuel leak
- gsr cluster
- B16A2 Emissions
- hesitant motor
- Another won't start Question....
- WTB b16 for 1990 CRX HF!
- What knuckles for 11inch conversion for 1991 EF CRX?
- Why are Tokico Illuminas Knocking aroung in the top hat??!!
- zc in si
- Tie rod scraping wheel on full lock.
- Need help With SMOG plz.
- b18 swap in 88crx throttle/idle problem
- first time engine swap
- Cams fo zc (d16a9)
- Want to clear motor mount issue
- please help
- Any one recognize these clips? Where are they from?
- B18 Wiring harness question
- LHD Conversion
- fresh build, cranks but no start
- CRX Door swapping: No belt doors on door belt CRX
- doing motor swap and need help
- DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs
- thrust washers?
- just bought a 91 civic with wiring probs need help
- cost of k swap?
- EF9 Suspension Tear down!
- B16a obd1 td-44 vs td-42
- water in my oil (could my block still be good)
- honda civic indonesian brochure
- Honda Techs are stumped. Car stalls, and won't start
- Holy %$#& I have a CRX in the garage o.O
- MY TYPE R MOTOR
- crx SI
- Fuel press. reg. through purge valve. Cause leaning???
- im putting my b18 from my ef in my eg. what parts can i use?
- CRX Thermosensor Question...
- putting eg bumper on a ef hatch
- conversion questions
- I'm stumped...Need major help..
- 4 door auto to manual,front tranny mount probs
- EF wiper help..
- Quarter panels for a CRX???
- 1991 dx sedan speaker ??
- burning out fuel pump relays
- dashboard swap help
- How do i adjust ZEX 59300 cam
- crx 1990 si
- 1990 crx
- RHD conversion
- CRX Help!
- Leaking Head
- transmission
- what band timing belt for 1989 crx si 1.6
- Rear hatch window molding end
- New to swapping.
- HeelToe Auto EF8 Honda Access Foglights.
- Car starts then dies, no prove out circuit
- need help with wiring
- How can i install a rear strut bar ?
- 90 civic car wont start
- 88 CRX WONT HOLD IDLE? CANT HEAR FUEL PUMP? PLEASE HELP!!!!
- crx engine removal question
- MPFI into a 90 hatch HELP!
- crx/hatch front reinforcement bar
- baterry fuze blows ?
- JDM Doorrssss
- Clutch pedal sticks (or stays on the floor for a moment)
- Seats Fitment for the CRX
- crx wiring problems
- Thinking about this swap.. Help?
- integra seats vs del sol seats
- B16 ?????
- idel at 300rps??
- Best SS Brake Lines???
- My $300 1990 STD Thread
- Question About Internals
- 88' si crx seat into 91' crx hf? w/diagram
- turbo timer install where do the wires go
- HELP LOST MY KEY !!!!!!!!
- idle
- type r in crx
- tach install, lights up no rpms?
- hytech replica header
- crx si dash harness
- 88-89 and 90-91 crx exterior moldings exchangable?
- Why swaps instead of reuilds???
- RHD
- Strange stumble at high RPM
- vacuum line diagram anyone????
- Wanted to say hi.
- 1990 civic no power to fuel pump
- Idle problem for '89 CRX SI
- aswell as dash boa91 crx si dash&cluster change wat else fits
- i got a 98 honda civic im selling for part contact me if your interested
- HelP: steering wheel column
- What is this plug?
- quetion on iacv's
- 91 Si Tranny Has Shaftplay.
- SB RACING'S EF'S
- speed sensor location for 90 civic
- B16A in a CRX?
- just put cams in b16a1 check engine light flashing no CELs
- Drop springs+16's?
- which oem rear seats...
- wet floor problem on 91' crx
- HKS LES-H05 SPORT EXHAUST
- CRX noise elimination hatch squeak dash rattle
- milkshakey oil
- Steering Knuckle/spindle
- Front brake pads ...Ceramic or Semi-Metalic?
- ecu pin out
- if anyone has installed a viper 5900 in their ef8 chasis, please take a look...thanks!
- clutch problem
- Stolen CRX Alert - Austin TX
- civic/crx parts question
- Fuel system issues
- noob saying hello , with a question
- need pics of roll cage in a ef hatch. searched
- blown engine question ?
- 90 CRX wont start...
- key stuck in ignition
- Crx Sunroof problem
- rear disk conversion control arm question. help please
- 88 civic auto tranny question
- oil pressure question
- control arms
- help finding this part
- Help me out light problem
- ignition kill switch has anyone done this?
- JDM EF9 ecu adapter
- L15A VTEC swap from Fit/Jazz?
- burning oil?
- will i pass smog
- 91 dx hatch
- my b16 sputters
- crx,ef jdm front/rear end conversion?
- Replacing Foglight from 1991 Si CRX
- Crx swap???
- overheating !?
- zc idling very high!!!
- Can i fit a 98 front end on my crx
- Help!!! How to remove ignition switch
- Questions about NRG quick release for EF
- Fuel sending unit?
- Turn signal help
- crx b16 full throttle issue
- I need a rear wiper arm for my DX, what fits? (No, tegs dont fit)
- Need some fuel, and idle help...
- good buy???
- help with ignition kill switch
- eg swap vs ef swap?
- 90-93 integra axel back fit on ef's?
- one final mpfi swap question
- Which intake manifold fits?
- b16a hesitates under full throttle
- EF hatch questions
- 89 civic LX front and rear speaker replacement?
- Brake Question
- 88 crx doors fit a 90?
- Question about Exedy Clutch Kit....
- S80 in an EF, speed sensor issue?
- Injector problem
- Question about taking off my bumper
- what should I go with???
- Engine Codes Need Help Identifying
- going obd1 b16 Quick ?
- D16Z6 swap help
- CRX B16 Idles High
- wheres the dent go?
- The New EF Innovative Traction Bar review !!
- crx cluster
- QUESTIONS for the EFers
- 89 CRX Si With B18b1 swap. Need help with wiring harness & ECU
- transmission is shifting hard and rough need help!!!
- 1990 CRX DX D15B2
- vtec wiring and second 02 sensor
- Innovative B-Series Cable-Hyrdro Clutch/Flywheel Question-
- Coolant is not flowing, car is overheating
- JDM tails + USDM center?
- mpfi swap now bad vacuum problem
- Swap help please
- looking for a good full coilover kit
- Winter tire size
- Reverse binds, any ideas?
- Mini me head gasket thickness?
- tenrai
- 98 gsr motor. cable or hydrolic
- will it fit in my ef?
- dx to si harness question and yes i searched
- 88 Civic harness ?
- koni yellows w/ ground control springs
- still no spark....tried everything, please help!!
- EF9 FITMENT QUESTION
- motor mounts
- Fitment question
- Alternator problem
- Ignition Timing Service Connector Q's
- Pictures of people's 1991 Civic EX
- DPFI to MPFI conversion and automatic transmission
- Evil water dripping!
- CRX needs a tune up for cross-country trip!
- CRX motor and transmission swap???
- Apexi WS2 vs Tanabe Super Medallion Hyper spec
- HELP - Main Relay Clicking
- how to check injectors
- OBD1 conversion.. NEED Help
- Hood will NOT open, got it open before with a knife, now it won't work
- Pr3 ecu pinouts
- I need the wire diagram for a 98 civic dx cluster can anyone help me....
- Just out of curiosity...K swap MPG?
- crx intercooler fit behind BC
- Tach Freakin out
- dohc zc pcv valve location and possibly pics?
- need some help finding something
- HELP optional tranny fill????
- Radiator question for a 91 crx si
- iam a noob with a crx
- rebuild ????
- problems with hood
- 99/00 Si Cluster into ED hatch. *SEARCHED*!!!
- JDM CRX Si-R Seats
- which fuel injector o rings
- interior light project. (NOT RICE) tell me what u think!
- do p28 ecu look for knock sensor
- How to retrofit one of USDM crx 90-91 reverse lights tobe a rear fog light just like EDM crx
- making a build thread
