View Full Version : Honda CRX / EF Civic (1988 - 1991)
- jackson racing / hasport supercharger for b series crx / civic !!
- need help with eabc
- need help with tune up!!
- anyone have an unsalvagable CRX sunroof assembly?
- willing to take a HUGE loss here
- Will axles fit new tranny
- Car will pull to the right under hard braking.. then "pop" when accel. (HELP)
- j's racing front lip
- D16z6 in 89 Hatchback??
- Dilemma
- IAC
- will '88 or '89 tail lights fit a '91 CRX?
- thats goodStock b16 1/4 mile
- 89 Civic Si Revlimit problem...
- Stock b16 1/4 mile
- Clutch Problem PLz help (ceramic) 4 paddle
- b series swap + jrsc? Any fitment issues?
- B16a to---->B18c Swap in crx finally has started!!! Heres the deal...
- O2 SENSOR GOING BAD AGAIN
- ZC starting problems?
- Car overheating, got code 6 (coolant temp) and smoke, timing related?
- where to buy amber corners?
- Finally boosted.....finally im a d series turbo ninja
- Which Wire To Tap In Rear For Spoiler Light??
- sh blue crx
- weird niose from rear passanger side when i corner hard
- code 16
- for sale intakemanifold
- For all you SOHC soliders out there....
- question on price for my crx no pix yet
- removing rear windows - 90 hatch
- CRX Sunroof motor location
- My swapped and terbowed '91 Si hatchie took a trip to the dyno...
- How much should i ask for this??
- ruff Idle. Any suggestions??????????
- Si Engine harness help
- Need help identifying a CRX year/trim level
- Temp Prob...Need help asap!
- 4G Video's?
- tune up b16
- dohc zc tranny, where do i buy one?
- Question about D16A8
- will EG H&R race springs work in an EF ?
- engine needed
- Taboo: B16a turbo with a/c
- help b18a swap into a 91 HB Si
- rotas clear coated or powder coated
- Exhaust...I HAVE DONE A SEARCH!
- power moonroof problems
- Doing a SOHC VTEC swap w/ the crx si tranny..what clutch should i use?
- How much of a problem is it to do forced induction with a Mini-me?
- Best place for water temp sending unit??
- Making thread of my 91 Si-R
- DX Hatch Transmission
- b18 axles
- value of my ef9!!!!
- B series final drive ratio swapping.....cable & hydraulic interchangeablility?
- Bog on WOT. OBD0 ---> OBD1
- Supra TT Fuel Pump Install Fuel Pump Priming Car not starting!!!
- too low?
- si tranny question
- FiBIGGER throttle body
- i/h/e questions.
- 1/4 mile time
- sparkplug gapping
- crx si not startting and have weird symptoms!!!
- what rotors for EF hatch with teg spindles
- b16 header 4-2-1 or 4-1
- anyone have carfax right now??? 1HGED3559KA043640
- Help me install my glow gauges...
- nitrous
- SPARCO Evo Installed....Head hitting roof
- DOHC ZC Head
- Die-Laughing's Updated Auto Pics...
- EF3 ZC
- 5 pt Harness + Rear Strut Bar Q's!
- Harness Bar Only. Is this possible?
- idel problem
- lookin for ls cable tranny
- help with code 21
- anyone have the new z10 traction bars? If so got some questions?
- Light out in climate control
- b18c1 crx hf update!!!
- Automatic Tranny Removal
- Ineed a 90-93 integra 5spd tranny for like $300 email me if ur selling one
- Hf upper control arm with integra knuckles? please help!
- Looking for thread about HX wheels
- Comment request: Goldline Springs
- misfire after warmup (obd0 b16 in 88 crx si)
- european d16 honda motor specs?
- speedometer not working
- lower timing cover
- Can someone help me with posting pics of my crx?
- 90 crx dx motor swap?
- '90 crx dx brakes?
- wagovan wont start!! help me please!!!
- 1990 crx dx brakes
- **b16 question**
- power windows or manual windows?
- eg sideskirts on a ef
- JDM EF9 Side Skirts
- What timing belt
- wheel packages
- momo steering wheel horn hook up installation.please help
- JDM front hatches in dark blue? any out there?
- z6 swap
- Fuel Pump Kill Switch
- Custom Shift Linkage
- Grass roots car...
- Rev. LiMiTer Problems.....
- ZC TPS question
- overheating
- 91 crx hf rear sway bar
- JDM Sidemarkers
- Where can i get new syncros?
- please help me!!
- how to remove 90-91 door panels?
- F/S front Koni yellows
- brake up grade...
- min me problems! help me out pls.
- BUTTERFLY ?
- b16 swap. using teg spindles...what UCA? how?
- Now this is a blown motor!
- Aftermarket Lower control arms
- DOHC ZC redline? rev limit?
- Need Help Did Engine Swap Starts But Has Not Trottle Response
- Any bigger OEM rea sway bar that will fit a 2g CRX Si?
- changing timing belt.
- S-afc D16A6 wiring
- Question about c-pillar bar....
- 13s all motor crx/hatchbacks. What kind of gas mileage you getting?
- alternater only?
- b16 engine swap info?
- Please help identify my problem.... CRX HF ZC
- D-Series Turbo Ninja?
- Was there ever a civic Se-i???
- QUARTER MILE TIMES CRX B18C5/B18C1/B16A N/A OR FORCED IND.
- Big disc or gsr 4 disc conv
- New here. Doing a swap. Dist Question
- CRX SMELLS LIKE DIRT BIKE WHEN GET OUT
- HELP! Engine related, b18c1, starter, missing part.
- speed sensor for civic
- b16 thermostat
- 93 b18 into 90 civic dx. Do i need obd-0 parts instead of obd-1?
- Front Brake Swaps?
- need a picture
- LS/Vtec
- Most powerfull d15?
- my new hatch
- Power Steering Question
- my hood was stolen
- Intake Air Temperature sensor in an 89 HF?
- P28 in a 90 HB
- Smoking Problem
- JDM front end w/out radiator support? A good idea to try and mod USDM one?
- Ground control spring rate question?
- What is the largest size intercooler a stock crx can fit? 90-91
- high idel
- Doing my swap tomorrow
- bay area swap/tuning shop
- Wanted: Crx Si 88-91
- WTb Sunroof glass 88-91 Civic Si HB
- need help QUICK!
- my car, im new here!
- auto to manual Starter question
- Quick question
- code 23 don't know
- JIM FAB?
- accord front lip and CRX rear si lip. what years?
- master cylinder is starting to go out. integra swapability?
- still grinding gears and have no idea why! all b16a gurus please help
- window tinting, DIY?
- MPG?
- crx problem
- Pt6 CRX pics, it should run this weekend!
- erratic idle on PGI injection
- lexan sunroof?
- DA rear tranny mount...... which hole to enlarge (b swap)
- NEWBIE QUESTIONS.......
- Intake manifold swap!
- aftermarket header weights - which is lightest?
- dont drink and drive haha
- Alright to change only 1 side of my brakes?
- B16 PR3 ECU TROUBLE
- need quik help - trans fluid
- Good deal on swap?
- Crx upper strut bar..which one is good ?
- CRX Suspension Suggestions
- DOHC VTEC Wiring EF
- 91 crx Si seats in a 91 Std hatch?
- Alternator problems
- CRX won't rev past 3,250 after ZC install, I'm lost.
- Which airbox after swap?
- kinda poor - want to do swap
- Single turbo
- SOMEONE HELP ME PLEASE, ASAP
- odd fix for squealing brakes
- SOMEONE HELP ME!!!!!
- bout to replace axel - special tools?
- Honda newbie
- need help :(
- Need help finding engine D15, in texas
- how cold is your a/c with r134a?
- what CRX engine did i buy
- boost a duel carb?
- Hey guys
- i have 91 rex si need some input
- best tuner and builder in philly, south jersey area or close to it?
- just venting ...god i hate code four
- need help buying parts with 95civic, plz help
- header question
- Help: Suspension on 88 hatch
- Decarbinizing Your Pistons
- Axels and Half Shaft
- I have continuity at my battery leads, what to do from here?
- removing bumper/ replace strip 90 dx hb
- turbo questions and needs!!
- Blitz Bodykit & Rear Fender flairs
- Rear Hub Nut Size? 88 CRX Si
- koni yellow
- CANT START MY REX HELP...PLZ FOR THE LOVE OF BUDDHA
- b16 swap done. battery fuse keeps blowing
- Speedo works but mileage doesnt.
- check out this CRX Si with 41k!!
- Found a good lil junkyard today :)
- 90 EF hatch with B18C1 or B16A2, anyone?
- southern cali shops H22>>>CRX
- Brake proporting valve (bpv)
- Selling 89 CRX DOHC VTEC B16a in Vehicle classifieds
- Car smells like gas help!
- 13x8 wheels on a street 90 hatch?
- HALF SHAFT
- Would you buy an older Honda if you couldn't modify it's performance? (a poll)
- funked up clutch.
- question about a part (rearviewmirror)
- oil problem
- b16 with a6 ecu
- zc swap
- thermostat
- Need Help With Car Trouble Mini-me Problem
- car smells and idles rough..
- WTB OBD0 -> OBD1 conversion kit
- 91 Civic Si Smokes bad!
- need help first civic hatchie 91...want to go all motor need some suggestions
- Wiring Questions???? 88-91 hatch
- few questions
- ls vtec
- Wiring nightmare question!
- what are the differences in seats between 88-89 and 90-91?
