View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 88-89 usdm teg tranny w/ Si F/D??
- good deal for 2200?
- y1, s1, lsd, cable tranny questions!
- side skirts
- clutch cable
- Single cam head question!
- Heel/ Toe shifting question...
- wtb88-91 HATCHBACK, im in delaware. Looking for something cheap in any condition
- CRX b16a swap..car runs like ass
- 4wd acura integra
- Income Tax
- Currently Modifing a 1985 carbuerated CRX...
- The lowest coilovers??? I need to go lower then this...
- axles
- Street D16Z6 - California Emissions?
- PLEASE HELP....IN A BIND
- CEL Codes - How to fix?
- What is WTB?
- CRX/EF meet, Kingston Ny
- 1point5 crx
- zc header please help
- Crx Hf O2 Sensor?
- 1/4 mile d16 stck + Boost
- Si Transmission for sale
- I HAVE BEEN SCAMMED!!!!!!!!!!!!!!!!!!!(GoCivicGo)
- Disaster strikes, never got to drive my B18C5 hatch...
- crx-strip interior or keep on????????
- Sway Bars for an EE8?
- Wiring diagrams
- crx model
- carbon fiber spoiler
- need help with window crx
- the h22 CRX is running again!!!!
- Funny squeaking noise... JDM B16A. Help?
- B16 help
- 91 EF hatch swap
- *PIC REQUEST** Crx Rear Interior Seat Flip Up Thingy
- vss to speedo
- for all you guys w/ recaro SRDs....
- EF with DC2 HID?
- 91 hatch rear disc...need parts? HELP!
- Foglights? Here's my install! (used Talon driving lights)
- vin check for crx
- Comp Ratio Question
- What should I do?
- Final update with the douche bag known as mastakilla.
- Spark plug tube seals
- does anyone have a itr header or jdm dc 4-1 for sale
- power steering....help
- Mellow Yellow
- B16 Si - axle is going to break, what part do I need?
- side mirror visors?
- STUMPED: The Beater Is Actin Up, any suggestions???
- b16 in ef anyone else have leaky lower radiator hose?
- 89 integra camshaft versus zc camshaft
- 92-95 bumper on a 90 civic????
- 88 CRX Si ZC got a prob. with engine surging on full throttle???
- home made intake/factory airbox?
- Post pics of your tweeters
- listem to this
- Gude Performance Heads ........anyone have one on their civic ?
- searched but cant find info on map sensor+boost
- DOT Standards in order to bring in a JDM car
- HOw much do stock SI seats wiegh?
- 4 lug type R suspension on a ef8???
- Third alternator...
- whats a code #1 on a pg7 ecu
- b16 mysterious plug wire problem
- CRX GURUs: How do you remove steering from rear crossmember????
- Quick question.. y8 headgasket on d16a6
- CIVIC TURBO TROUBLE WITH MAP
- prelude foglights on crx
- b16 swap help
- Ls/vtec into a crx
- looking 4 a ITR header or a dc jdm 4-1 for my rex
- Does anyone know verseone?
- does someone can confirm that its the same thing or that it will fit??
- testing spark
- please help me up load my pics!!!!!!!!!!!!!!
- Autometer RPM hookup
- I Need Some Help Buying A Car
- pic request, please look inside
- pedal options for crx
- 3rd brake light problem in 90 si hatch
- crx rear sway bar pic???
- looking for rear interior parts for a 1990 crx hf and do i need to change ?
- whats the best bushing kit for a crx 88 w/ b16
- Won't start, weird sound coming from underdash
- Help I need a wiring harness for my b16a !!!!!!!
- What pistons???
- Difference in motors(Can't search)
- help please!!!!!!!!!!!! brake problems in the garage right now
- need to know what year the clutch cable and throttle cable for a b16swap on a crx88
- ITB's ... are they legal?
- Anyone besides Hasport? f22 h22
- How many people use Polyurathan bushings?
- DOHC ZC question
- Tranmission ground
- How hard is it to find an older Si? Like 2000ish?
- WHAT AXLES?
- Will a b16 TB fit on a d16a6 mani?
- Do 88-89 crx's have the same clutch as 90-91's??
- Need Help ASAP: Brakes stuck on 88 EF Hb!
- crx suspension quston
- B16 swap questions
- What axels for B17A w/ YS1....?????
- CRX w/ b18c1 CARB/BAR question!
- Camber Problem!
- d series stroker kit
- B16a reliability
- need help!!!!front crossmember!!!!!
- Supercharged D16A6-what else to add on?
- Body Work
- Rear storage compartment!
- electrical wires?
- Can't turn off car when in Reverse
- headers for b16---did a search
- did the crx HF have a lever to adjust the steering wheel height?
- 88 honda crx dx, rear suspesion is making me crazy, need help!
- SOHC GURU'S NEEDED -- Do obd0 Distributors fit on obd1 heads? what about obd2?
- speedo to vss
- frankenstein swap??!!
- car dies when i turn on the lights..what am i missing?
- Need Rings? You tell me...
- b17 in a ef8???
- Help ....Turn signal Problem
- speaker mount
- Place Racing crossmember with D16
- starting my new all race project crx....
- So this is what i have been up to lately.......
- help me out guys,double check- mpfi
- Getting sent to smog ref need advice. Please help!
- Thermal exhaust pics??? anybody??
- On a y8 head gasket, if you just use the middle of gasket will you get a little more compression?
- ek side skirts on ef sedan??? and how hard is a b20 motor swap on a sedan??
- my 1991 civic si hatch
- D16 ZC
- rear wiper problem
- Rear windshield washer not working...please help
- Pics of my new 89 SI
- ex vs si
- ITR TEIN flex fit on an EF?
- Just installed I/H/E and WOW what a difference!
- 91 civic hatch worth 500$?
- >>>88 STD Hatch bumper question<<<
- help me figure this out
- T-Top job possible?
- B18c5 into a 3rd gen civic si
- Newbie here have some Q's
- Intercooler Piping!
- crx 84-87...where can i find clear bumper lens
- Electrical Problem HELP !#@$!
- front mount on b16 crx
- should i buy this crx
- WTB CHEAP 88-91 Hatch in any condition, Located in Delaware looking for beater!
- FS: JDM/EDM CRX Spoilers
- How much do brand new rear bumpers go for from honda?
- Crank Angle Sensor
- options on JDM D15 VTEC ecu's
- 89 CRX Spring size
- how to fix a code 4!!!!
- Mid pipe for CRX???
- canadian hatch
- which intake---did search
- idle problem for b16a
- ef9 cluster problem
- STD 4SPEED TRANS
- Car won't shut off.
- ww sideskirts..i know this should be in appearance but
- timing is jumping
- What could cause this?
- FS: D16A motor
- B-series wiring guys, I have no vtec
- is this possible?? 89 si trans, 89 flywheel, 90 clutch disc, 90PP
- Wheel Bolt Pattern
- NO HEAT, help me please
- New pictures of my project CRX pt3
- valve adjustment
- steering and suspension problem
- questions about recaro srd...
- ** Post Pics Of Your Racing Seats ** Questions Also.!!
- Whats a better swap, Teg mani with b16a TB, or y8 mani with y8 TB on my d16a6 with y8 head?
- Project b20Vtec Hatch: Part 1-Remeoval of the Old Setup
- Anyone know what the Black canister looking thing thats mounted on a 98 y8 std mani is?
- people with gsr swaps in crxs
- High idle
- Where is the temperature sending unit located on a 1990 DX?
- Thinking about ZC DOHC into my '91 DX hatch.
- Upper Rad. hose bulging, coolant draining out of bottom of radiator...
- 4th Gen Civic HB ZC D16 Swap - New Motor Mounts?
- Thieves got me 2 Times this Week. (56K Warning)
- D16A6 HEADER vs AFTERMARKET HEADER
- please help me with my newest problem????
- crx seats
- where are the forum rules
- ecu's for zc
- Got new CRX stuff is this rare?
- Check Engine Light Mod
- Motor mount inserts for 1st Gen CRX?
- Mini Me swap info needed!!!
- Same intake for d16a6 & ZC?
- Can you make a y8 Auto mani work on a standard civic?
- Full coilovers for 90 civic?
- Putting in 90-91 Si-R cluster?
- Carsound cat fitment and questions
- Wiring A\C Controls. Help!
- Look what I got, need a bit of help.
- crx traction and handling
- stuck sunroof!!!
- EF/ZC stuff for sale
- Who knows how to make those VTEC lights?
- crx blown motor. how much expected $ to peice d series together
- anyone wanna trade?
- 91 si stock exhaust
- anyone know the xenon homepage address?
- anybody know where i can find a cowl hood
- What to do with my CRX?
- ECU auto to manual question.
- Crx what should i do?
- Climate control question.
- Pics of EF drag engine bays....
- clifford alarm
- What is the maximum drop to be covered under warranty for AGX's and Illuminas?
- V2 intake
- Skunk2 rear spring rates
- OBD conversion?
- crx si vs dx
- Pics wanted of Crx's with 99-00 SI rims please!!
- quick Q: do VX wheels fit on 88-89 CRX Si's
- 4-Speed (std) to 5-Speed (DX) Shifter ?
- CRX SiR gauges
- CRX Gauge cluster bezel!
- A/C
- my shifter has too much play!!
- Where to buy HID Bulb???
- Speedometer problem! HELP!!!!!!!!!!!!!!!
- AEM V2 in my 90Si hatch???
- what set up should i have?
- driver's side window problem
- Apexi turbo fit an EF
- dc jdm 4-1 header with jimfab bar clearance issue!
- Ghetto paint?
- LOOKING FOR PASSEGER SIDE 88-91 CIVIC HATCH DX SEAT (GREY VYNAL) LOCALS NYC.??
- half shafts
- 96 pin outs
- d16 build up
- Driveshaftshop.com axels or OEM axels?
- My crx!
- wtb 89 civic predator cf hood
- CEL on
