- The Most Power Quick
- hasport sucks
- Dropping the gas tank..
- Clunking.... Transmission...?!
- EVER BOUGHT A BAD....................................?
- Lower radiator hose cold...?
- obd conversion question
- turbo sohc or go b16?
- CRX a sports car?
- Civic Concept from Honda UK (please delete if repost)
- Dual porportioning valve for crx dx help
- JDM ZC DOHC swap question
- Transmission Bolts
- vetec controler
- Tranny conversion.
- gap between bumper and hood on EF's! PICS
- what bumper fits a 89 civic hatch
- motor swap quick questions
- Zc swap help
- EF AC into EG civic
- obd1 conv
- fixing cel error code 5
- Question about rotor wear on integra 10.3" brakes
- NEED HELP!!! Looking for a wiring diagram for my cluster (NOT EF8/9---> IT'S FOR AN EF 4door)
- b18c1 swap into ef
- Messed up Studs
- Shitty Vacation
- Hitch Available??
- weird tranny/clutch problem....
- ef9 rear lip
- zc cams
- d 15 trans on d 16 y series block can i?
- low budget
- HELP! Problem with speedmeter
- b16-b18-or b20 vtec
- JDM front CONVERSION For Crx
- Ebay turbo kits?
- Online (d series) motor dealers
- boosted zohc zc or mini me?
- Revised plan for my 91 DX
- outside door handle swap?
- where is hmo?
- 5th gear problem
- carfax please
- MSD ignition? AEM tru power pulley kit?
- 3 gauge din panel
- need help guys dizzy problem
- CRV-TEC cam opinion
- have exedy racing clutch now, looking for something closer to stock on b16a
- Help Help!!
- Difference between USDM corners and JDM corners?
- A little engine bay clean-up...
- Auto Brakes EF!?
- ef civic front control arm fit in 92 eg hatch?
- Does the speedo need power to move the gauge?
- 89 rear koni yellows Vs. 89 rear civic wagon shocks
- no power help!!!!
- Toughts on Wind Deflector
- Fs: Crx w/B16
- Question about VTEC engagement in B16
- hid in a 90 hatch?
- Adjusting Milage on Gauge Cluster
- starter problem
- newbie help
- minime ?
- Can i cut my radiator in half ??
- Possible problem with A/C b16a 89CRX
- Jdm d15b vtec?
- help plz
- 1989 honda hatchback vs 1990 honda hatchback
- Ansa Axleback exhaust... anyone heard of this?
- How to, L-con traction bars install on EF crx w/pics...
- j1 transmission wiring
- trans mount bolt size?
- d15b vtec swap trouble PLZ HELP!!!!!!!!
- Shortening cluch travel?
- wheel tilts
- dizzy problem
- any recomendations.
- Engine Bay Pics That ya Guys asked for look!!!!
- shift light
- Will this oil pan work????
- 87 CRX si Orphan
- 1 gear 2k rpm I lose power why?
- Boosted B16A1 or GSR swap?
- mini me head gasket Q
- HELP
- ls v-tech???????????
- what would I need to do to swap a D16y7 into my 89 Si??? i just need a newer motor
- crx clutch
- what will fit?
- did all 89 hatchbacks have rear window defoggers
- iPOD holder in CRX/EF anyone?
- Temperature Guage Crazy!
- idle at 5krpm and cel 5?
- gas tank 1/4 full engine getting no gas
- Bogging problem B16A .....
- Would 91 Integra momo hub fit into 89 Civic?
- best clutch?????
- Rear wiper stops on the spot when its turned off...
- FS:Red 88 CRX Si $4000 Utah
- CIVIC doors on CRX
- Password Jdm c/f Sideskirts?
- EG+ clusters into EF's.
- what kind of header should i buy for my d series motor
- D series CVT tranny from an EK HX into a EF using existing mounts?
- How do I change the power master brake cylinder to mechanical... Non power brakes in an EF SI 91 HAT
- is this bad?
- Clutch Install
- Radius Rod Bolt Size??? Anyone know?
- F20 in EF Hatch?
- idle problems??need help
- tach install
- in the middle of a MPFI swap. How do I depin the ecu?
- HELP....96 vtec head on my crx si....???
- energy suspension installation kit.
- is this a good wide band afr
- side marker position????
- where can I get the whole exhaust system for my hatch>?
- Trunk/rear hatch rattle solution...
- ideas for EF9 rear lips.....anybody?
- DX to GSR
- Civic ECU interchange ?
- axles for b16a swap into 91 civic dx
- b20 swap helpp!
- I'm a Newb
- crx cupholder...
- Hi new to the site
- Need opinions with Autometer Gauges and my CRX!!
- B16 auto tranny help
- short shifter question
- Is civic ex a sport?
- What ECU to use?
- car wont start after swap
- Omnipower coilovers-how low can u go?
- plug for rear wiper removal
- what wires do i tap on my dimmer switch for my gauge lights ?
- WTB: interior...88-91 si
- Project: Busty Brakes..
- b16a Si tranny problem
- Comments on B Series rear L-Bracket
- how to wire vtec
- One fan or two? Blows toward engine?
- Is a b16 tranny vs b18 tranny the same size?
- when filling tranny with oil do i fill it up until i see oil comes out?
- Whats better gm synchromesh or honda mtf?
- Best oil for tranny? Recommendations
- Integra Brakes on an EF civic.
- si brake question
- Should i get a HB or a Coupe????????????????????
- Anyone know where i can get the pipe between the cat and the muffler in 2.5" for crx
- need help with ecu codes!
- b16 short shifter question
- worth it?
- another one lost to the theives dfw rexers be on the look out
- Looking for 3" catback choices
- Integra seats?? in ef??
- What axles for 86 EA with B-Series?
- obx
- Need a few pages out of the Helms Manual, can anyone help?
- Dang tranny...
- Tein Suspension Q
- PIC request ! The back of D-series D16A6 block complete with all hoses
- VIS Replica Pro2
- Whats a good price for my crx?
- Any EF's rockin Nippons?
- VTEC wired, but no VTEC
- electrical problem miss fire when current draw
- 2 lonely HF's :( project log 2.0
- abandoned black si hatch in Bowie Md.
- u guys ever seen headlights like these before?
- glass moonroof that doesn't open...
- clutch or tranny
- shaved door handels...door opens when you push on the side mirror, possible?
- transmission swap
- will a jdm ef steering wheel work on my dc?
- 1st gen jdm injector noise?
- shift linkage question
- Who has a Spec clutch???
- changing Input shaft of transmission.
- b16a1
- i could hear the chain when i shift
- d15b2/d16z6 bastard child
- oops... dropped razor inside my fender... need help
- does anybody know if there is a difference in d series valves
- 88-91 Civic/CRX Alternators
- few ?'s
- HELP Idle is high and iratic
- Rims galore
- Difference between hatchback and crx mirrors
- what motor should i go with?
- wrecked si trying to fix
- broke the lower control arm bolt!!!
- Board related. Tell me why: Google ads
- Doesnt Crank Over??
- a6 injectors in JDM D15B sohc vtec rail?
- d16y7 in a 90 si
- jumper harness for a d16z to a 93integra gsr
- MK1 1.6-16v - CRX 1986
- New Product Help!!!(need your opinion)
- Video Downloading
- how much for a CAN. hb
- Summit Racing vtec controller
- thoughts on using DA A arms
- How to put the heater/AC control in the glove box???
- Need help deciding on my set-up
- rear fog light set EF civic
- Idle Jumping no CEL
- wiring
- GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself
- b18c5 block with b16a head or a k20 type s motor in an ef
- b16,b18, or H22 swap?
- b16 distributor gone crazy!!!!!! PLEASE HELP
- how can i tell what tranny i have?
- Vaccum lines in on ZC swap in a Std
- intake
- brake upgrade (mc/bb related)
- rex or egg?
- Door hinge is broken... any suggestions?
- Sohc ZC vs. Dohc ZC - which is better?
- fuel injector clean before or after fill up
- vacuum leak?
- car is cutting out help
- 390cc injectors?
- 215's on a ef
- Does it sound like my master cylinder is toast?
- 96-00 conversion on 92-95 civic
- 1/2 Radiator / Traction system install pics
- I got my Zc swaped!!!!
- few questions from a newbie
- a-sport fender braces?
- ef with eg front end conversion
- So many questions today :D how much is my stock 91 si motor worth?
- Short Ram Intake VS. Cold Air Intake (AEM)
- im new
- hondata s200
- how can i hook up my cig lighter?
- parts off of a 91 teg..
- turbo question ?
- wtb misc sol parts
- JDM Fog Lamps. Where can i get a good price on some of these...
- motor swap
- d16a6+ y8 DC Header +Kteller 2.25catback= What Cat and Muffler?
- anybody have a crx si for sell
- 02 sensor
- Overheats with Thermostat, Doesnt overheat without Thermostat
- 96 Civic Xenon Body Kit
- clutch question
- HOW IS YOU FPR HOOKED UP ON YOUR SWAP?????????????????
- Beefy D Series motor mounts?
