View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Which engine?
- motor for 98 civic
- need help asap please help
- is it true??
- pics of any 88-91 civic hatch?
- Mpfi swap (dizzy wires) Shearched!
- not tech but brought smile to my face.
- Tranny question
- Car bogging, cel on giving me code 1
- First Time At The Track With 91 Crx Si B16a
- Online Crx Service Manual. Want a Engine OverHaul Guide. WHO GOT IT
- What would you pay?
- Axle and Hub question on DOHC ZC swap, I screwed up and need help!!!!!
- worst luck in the world
- im new, clue me in.
- xtd clutch any good?
- d16a6 alternator/d16z6 alternator..same??
- alternator question
- Ignition Short
- PR3 or PW0?
- si seat re-upholster question
- after market PULLEYS are they worth it?
- Dont you love it when your wheel falls off?
- weight redux
- CTK: New Exhaust "DeVito"
- trans swap 90 civic hb 4 to 5 speed
- Help question
- Tire size on crx help---should i get these?
- ATTN: all EF'ers check out my FS thread I'M done with OBD0
- code 20 and 7 idle at 3k WTF? anyone?
- squeaking problem
- Where do you guys reccomend buying SPC UCAs from?
- please help! how can
- corners
- transmission problem. not going in gears
- Need pics of d16a1 from 86-87 and 88-89 Integra need before this weekend help!!!!
- Bday cake (CRX)
- Sohc vtec or Mini-me
- my new toy b18a1 90 crx si
- 1989 seatbelt question
- need CTR spec:
- need some help
- Does anyone make coil-overs for a 87 CRX Si?
- D16z6 into EF and auto to manual conversion?
- cluster help
- DA exhaust on EFs?
- Rear Parking Lights not working! Help please!
- fuse map for the crx?
- 89 CRX Coil Input Voltage
- b16a 1st gen ecu codes
- what to buy for b16 a1 88-91 SIR1
- distributer
- Finally got to run my b16 hatch at the track
- car started now need help!!!
- How much do 2 gen (95) b16 heads go for
- Pic of my b16 powered 87 CRX Si
- need help guys
- Can of Supercharged Bee's
- Gsr guage cluster wiring problem ....
- Si and HF
- si vs. hf
- Clutch Chaos
- Love your fellow EFer
- Which harness do I use??
- Did swap NO SPARK MIGHT PAY IF SOMEONE CAN COME OVER AND START MY CAR In POMONA
- having trouble with swap choice
- ZC DOHC <~> D16A6
- D16A6 cam in a a D15b2 without the MPFI uipgrade.
- wiring question reg. obd to obd1 conv.
- bucking when cold
- dist change equates to timing probs?
- TOP B16 ECU
- door trim
- so i wanted something a little different
- best turbo
- How much is a d15 port and polished head $
- 2006 crx?
- Fuel rail machining question
- NEED TUNING DONE FOR A GOOD PRICE
- I need an electrcian
- wiring problems?????
- Help Buying New Springs....
- wubblescump
- gasket set
- Rear Speaker Option and Deck lid w/seatbelts for 90-91 EF hatch
- Any other sway bar options?
- can i re use the head gasket from integra?
- Motor question
- Main Relay clicks like a Semi Auto SHOTGUN
- Finished my system in my CRX what do you guys think???
- My ED6 unveiling: Build Stage 1 and Photo Journal
- Y8 IM on a Z6 head
- wiring info
- B20 question
- Part # -Tw sensor
- More problems with my 89 civic
- ZC Misfire HELP PLEASE!!!!!
- b16a swap tips and tricks
- Centerforce clutch & flywheel out of a D16 into a B18 can it be done
- turbo help
- best price on wings west kit???
- CRX HYBRID
- computer help
- what honda did my b16 come in ?
- 1990 blk CRX si MA
- anyone coming with me?
- Concern! Crx Master key released!
- window clips
- project 89 Si for $100
- Is this a Mugen header?
- VSS Broken. How Are These Fixed?
- transmission
- gas needle help
- 90 Civic STD hatch project
- 91 integ LS ecu
- Nitrous help
- tires for the steelies
- Newbie here, HELP
- lookin to do my brakes
- Engine swap???????
- Rota sub's
- can i use crx shift linkage with a b16
- B16 shift linkage
- 90 civic- hs crx 1991 i want to put parts from a crx 2 a civic???
- to anybody with a 500whp b16 civic
- Shift Linkage horror!
- need a nice turbo ready motor
- Help me bypass FITV on AEBS manifold
- d16y8
- E BRAKE LIGHT
- Upper control arm problem
- Would the bra for the hood from a 90-91 fit a 88-89?
- New to the Forum (not the game) here with Q 4 U :
- My new 1988 Honda CRX HF!
- crx with rust
- evo seats in crx
- Missing FITV
- where is the oil jet on the z6 head?
- 91 Civic Failed NOx and high HC
- 90 crx running bad
- Axles for 91 CRX
- 7000-7200 red line PR3 B16 ECU??????
- crx engine swap
- can door trim off a 90 fit a 88 door?
- where is the thermostat and what does it do?
- Where to buy Ball joint Boot?
- i need help guys asap
- The love for crx.
- looking for some info...please dont give me the "use the search" response
- swapping bodies:88dx to a 90cx
- Pssssssh Noise!
- anybody know if they sell skunk 2 axlebacks?
- hey need a little help :D
- d16y7 into a CRX
- From Trash To Treasure PLEASE HELP
- I need a longer fuel line
- b16a into 91hf converted to obd1 PROBLEMS!!!!
- wheel wont turn, did i mess up my ball joint??
- 91si with b16...strange electrical problem..help plz
- B16, no VTEC??????
- Will these Ebay Mudflaps fit my 88 CRX?
- intermediate shaft question
- looking for pics and details of SMIC mounted up front
- 88 CRX SI Valve Adjustment specs?
- What kinda wiring harness do i need for my EF
- CRX SWAP Questions
- HOW MUCH OIL DOES MY 1.6l SI MOTOR NEED??? i HAVE A 90 SI HATCH...
- Whos done H22A swap
- WTF size spindle nut on 88 HF ??
- Clutch Question
- boost
- widest tires on crx si wheels?
- any way to smog d16z6 in ef?
- what wou;d be the best site???
- b18b pistons
- HELP ON MY SUPRA TAIL LIGHT CONVERSION-CRX.
- 1990 hf turbo crx with a b18 motor for sale
- in need of parts from a 91 hatch
- Engine Mounts-Who makes a Good Set???
- What mounts to use for ZC in 89 DX?
- crx heater problem, please help
- ZC Dohc Flywheel? clutch?
- What motor now.!?
- b16a swap into a 1989 CRX HF
- motor building
- is this muffler going to work?
- skunk 2 piping to a spoon N1?
- energy shift linkage stablizer bushing for b16
- 89 crx dx with zc motor
- Finished my build crx b16
- tractor puller CRX
- Omni Power full coilovers not low?
- vids
- quick question for knowledgeable efers!
- Ebay xenon headlight bulbs
- Any stock ride height springs that are made stiffer than the factor OEM springs?
- Easy answer question I'm sure..
- spoon motor help
- Where can i get a SPC Camber kit
- Did my beater crx come with a rare Mugen LSD??
- Where to buy 88-89 Bras and mudflaps?
- B series crank pulley rubs
- What intake manifold did I find? SOHC,DOHC,B,D,?
- Water Temp Troubles
- where can i buy a rear crossmember
- (Off Topic) H-T nation states game...
- Should I use the D15 or D16 crankpulley on my ZC?
- Pinging with correct ignition timing?
- How to adjust luminas?
- Oil spots are showing on valve cover
- BARing a B16?
- Auto ECU, manual tranny?
- what year jrsc?
- HEEEEEEEEEEELLP !! radius rod wont blot on to lca (can only get one blot in)
- sell me a hatch 88-91
- mugen lip for usdm front ef/crx
- 99 GSR in EF wire harness help
- Insight into Zc
- 19 Automatic transmission lockup control valve
- 90-91 Civic/JDM Civic Taillights
- Slow Crank.
- door sagging
- Clunking sound when I brake and accelerate...
- are these 5zigen? black racing wheels..
- Speed odometer dont work
- Puffing noise in engine
- Installing a GSR Head
- hey any one rock'in these
- ANOTHER Brake Post
- racing seat material?
- How I put a DA rear sway bar on my DX hatch,pics galore
- searched: 88 crx lowering spring
- What the heck is this!?
- what do yall think about the D16Y7
- Motor Video. 13.5MB quicktime
- Strange idle problem
- engine rebuild
- WTB: CRX HF...
- Best camshaft
- obd0 injector question, i want bigger
- Someone please tell me what this is!? B-series cable tranny
- What length resonators are you running for Bseries CRX
- DOHC ZC Throttlebody questions
- wich distributor and ecu
- questions about "HX" rims and SI hub caps
- please help
- b16 ecu help 3 beep 4 beep 5 beep
- plugs and wires?
- First swap ! Took 7 days.
- spotlight on 4g civic
