View Full Version : Honda CRX / EF Civic (1988 - 1991)
- brake questions. . .
- NEED HELP W/ OVERHEATING/ CLOGGED COOLING SYSTEM
- thoughts on cf / fiberglass roof
- RHD Front CLip Installation question
- '89 CRX DX.... Code 17 and 21.... questions
- kiss my CRX goodbye
- Help, Clutch will not disengauge??
- serive connector
- d15b2 turbo or b16a
- Little rust, is this fixable ?
- h22 injectors?
- Help With Turbo
- d15b help
- Installed DA master and brake booster..front brakes seize
- short shifter
- I need your imput, 178whp 130tq (dynojet)
- My new shooooes *oldskool lovers enter*
- 88 hf crx with 91 d16a6 problems
- EF to eg or ek radiator conversion!
- 26 spline axle wont go into 26 spline tranny
- got some problems
- Upgrading/fixing brakes. any opinions/help?
- buying a 1990 EF Civic Hatch....
- 90-91 d series clutch fit fit in 95 d series tranny
- throttle body help
- should i buy it?
- B16a code 4
- Need HELP ecu not geting power.
- ive searched and cant find it
- EG DX d15b motor into EF civic....
- Bulletproof 90-91 Teg Tranny???
- 88 HF b16 JRSC complete
- Decision/Question on swap
- I got questions about my motor...i need a little help too...
- Difference between 88-91 DX vs EX auto tranny?
- (vtec won`t work) speedometer problem
- CR with B18B with ITR head/cams
- hi flow oil and hi flow water pumps?
- nobody believes me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WTF!!!!!!!!!!!!!!
- waterpump swap?
- help please
- ef roll caged
- Not sure what is wrong.
- del sol master cylinder in a crx Help!!
- How to replace speed sensor cable
- please help ASAP
- anybody with integra clutch cable please help me
- 1st gen b16 TB gasket HELP....
- 86 CXRsi sheetmetal changes
- Brake bleeding order
- Biggest MC into an '88 CRX SI?
- Best CAI for EF Hatch?
- nononononono
- pr3 tunning help
- pics of my 24.5's on my ef...
- power lock questions
- best NGK plug for d16a6
- Jdm EF8
- body parts of hf on my si
- Which DC sports header do i buy?
- crx obd0 to obd1 conversion ?????
- Is the obx intake manifolds any good? someone is selling one for only$160!
- Bad clutch = not getting in gear?
- what the best way to get paint off from the dash board?
- Greddy Emanage for obd-0?
- CAM not turning
- ebay chips for p28
- mini-me question
- Red Civic Standard -- pics of my allmotor setup 2005
- wagon swap
- does this make a difference..............
- fs or trade d series act clutch fidanza flywheel and axles almost new
- Rear disc brakes help?
- Code trouble
- Em i in tha right place?
- buying a CRX with 300,000km?
- crx lowering springs problems
- This is gay and I need opinions...
- My CRX destroyed :( (ugly pics inside) :(
- hood wont shut all the way?
- Flywheel Cover Interchangeable??? Help Please
- Will CRX Si front brakes fit on a DX?
- new motor
- Diff between 88-91 Civic Si Hatch?
- Need Help plz..
- hi,im new can any1 help
- b20z swap problem
- JDM B16a Crankshaft, connecting rod, and connecting rod bearing
- clutch pulley removal in 2 minutes
- 94+ JDM HID Integra headlights in a CRX? Is it possible?
- my seat stinks
- D16y7 or ZC?
- air conditioning questions.
- Distributor Swaps
- ? For all CRX Owners
- installing windshield trim with out removing windshield?
- Wats up with my tranny or clutch now
- Should i buy this crx
- want to swap in d16a6 into 91 crx with b16a
- B18A1 question
- Wiring diagram for distributor
- torque specs on z6 n/ distro timing
- exhaust?
- 1991 Honda Civic SI Hatchback F/S Washington/Oregon/B.C.
- ZC NO start....help
- ARP studs
- 91 crx for sale 3000 OBO
- 89 CRX won't start up!
- CRX Starter Relay Location
- spark plugs and wire
- Fuel pump/ECU Relay?
- this is for blown90 hatch
- d15z6 mini me
- need hellp with axle
- apexi question
- which minime?
- Anyone living in SPRINGFIELD IL OR ST LOUS
- Were to but mugen wing or sideskirts or anything for my 1986 Civic SI?
- b16a vs. b18c1
- what do i have to do to get a hatchback buddy club front bumper to fit on my 4 door?
- people using ground control
- Keep your head on a swivel in Las Vegas
- How low is to low
- cluster question...
- Will a 1990 Honda Civic DX EACV fit a 1988 CRX DX with a ZC Swap?
- 88-89 HF CRX FRONT BUMPER REINFORCEMENT ON A 91 HF?
- need pics of what fuses for what on the SIR modle...
- Question about a JDM product for a 90' honda civic hatch
- ok..I need help picking an easily swapped and smoggable engine in Nor cal
- Need help ASAP - Y8 head valves compatible with Z6?
- Can i use my stock dizzy?
- rear disc brakes question help!!
- Field vtec controller??
- Stuck fuel injector
- CRX HF / Si front fenders
- Oh no Clutch help
- For all those w/ 88-91 crx w/LS-v-tec pls send information and swap guide if possible, thank you muc
- 90 hatch dpfi-mpfi
- 90 prelude si motor
- Keyless entry, and Instrumental Pannel
- 1/4 times for b 18 ls
- gsr cloths in a crx
- Failing FPR...NEED HELP QUICK??????
- will a comptec gsr header fit my b18b????????????
- Getting a new key made + a funny story!
- what tranny do i have.
- How do i get the speed sensor out??? Trying to change clutch.
- Is it bent?
- how to remove emblem
- CRX B16 1/4 mile run
- WTB: P30 ECU!
- another Hatch bites the dust **stolen EF**
- anyone ever broken clutch pedal
- ANYONE DO ENGINE SWAPS IN D.C.?
- Engine mount JDM DA Integra (B16A) do they fit EF chassis?
- Crx DX question
- CRX Double Din Info JDM vs CDN Si SE
- anybody here have a pict or link for EF Motor SOHC non vtec wich using singgle carb
- Pimp My Ride this Sunday......Civic Hatch!
- Just happy to be alive...
- mpfi with dpfi dizzy...can it be done?
- d16 g2t25 (recomendations)
- PWO ECU for a B16a?
- Tech ; knocking caming from the suspension at low speeds
- NEED HELP! 91 civic no start d16a6
- alternator trouble again
- VAFC Harness for OBD 0
- aftermarket lsd worth it??
- Z6 swapped CRX Si....Couple questions.
- anyone use obx headers ??
- WTB: 97 GSR rims blades
- D2 Coilover fitment wtf mofo
- How much would you pay for a SOHC ZC cam?
- itr ctr cam combo
- JDM fog light install need help with some wiring Q's (pics and diagram included)
- Time to do a little boasting
- $$$ Help me with a mini-me swap and earn 200$
- found sumthin on ebay
- FS: dizzy Ouestion
- b16a knock sensor
- A6/B8 QUESTIONS...?
- All you hondata people i need your opinion
- The last straw !!!!
- Say hi & VSS question
- SPEEDO CABLE QUESTION!!!! NEED HELP ASAP
- I KNOW U LIKE MY HOOPTIE(link inside)
- I weighed my CRX last weekend! Is this normal?
- too much fluid keep VSS from workin?
- finally started painting my car ...
- What is the size of a CRX's header? Need info for a Kteller cat
- intercooler on crx
- newby here, simple guestion.
- d15b or DOHC Zc?
- quick question
- My introduction and plans...chime in with your help
- My radiator is cold yet the top hose is hot
- North Cal?
- spoon type r pistons and connecting rods
- d15b7 throttle body on d16a6?
- Shaking while turning right/ going straight?
- looking for 1 peice race front end
- my crx
- Horn Problem, HELP!!!
- Hmmmmmmm
- HOW U LIKE MY HOOPTIE???????????????pics
- Clicking noise when going at a certain RPM
- 90'civic mods
- Engine Bogging. I need HELP!!!
- bumper question help please
- NEWS FOR 89-91 CIVIC LOVERS!!!
- d16 distributor
- tranny fluid
- i think we need a "JDM front end" sticky
- need some help !
- alternator fitment
- omni power coilovers?
- Can anyone tell me were to find a jdm honda hatchback sir front end bumper?
- BEWARE OF EREBUNI CORP/WICKEDBODIES.COM!!!
- my car wont start, dash board related.
- Cluster
- Brake swap information
- Mini-Me ????
- Throttle Body issue
- will 88-91 civic/crx projectors fit my sedan?
- small civic radiator in a ef9??????????
- really bad vibration
- egr location on 91 si
- Mini Me PM6 and OBD0 question
- CRX carbonfiber dash or fiberglass dash
- Carbon Fiber trunk
- newly purchased engine???
- an exhaust question
- how fast have u gone on ur honda hatchback?
- help to fix dash vents
- EG radiator/ Totem Traction bar system REinstall . *pics*
- Help with 91 hatch problems
- how much power will i get out of this set up
- What is my CRX worth?
- TURBO
- What to do next
- center console radio mount??
- 91 CRX Si with GSR, won't start, need help!!!!
- vacuum help please! search no help
- ls swap questions
- cut springs!!?? what??~!!
- Anyone here of the store Speedworks?
- need HELP ASAP: 90 crx Si died!
- Vafc wiring obdo?
- d16y8 question
- Rotor Screws
