View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Brake Pads installation problem
- will SIR 4door 1 pieces fit?
- my hatch pic!!!
- idle surge!!! help me!!!!
- J's Racing CR-X: who has pics?
- camber adjustments NEED HELP!!!
- i tried
- brakes take too much force to "bite"...need help pls
- new tires for my HX rims
- what 1/4 mile time should i be looking for??
- WANTED WANTED I HAVE CASH
- 1g b16a questions
- F@&kin crank bolt!!!???
- Distributor problem?
- 3rd gear grindin' Y-1 tranny
- how often do you have to smog in cali? in other states? propane conversion2pass
- WHAT TIRES TO USE?????
- e-brake
- dpfi to mpfi Distributor connector problem??
- obdo-obd1 any converted harnesses?
- Suspension questions
- Front spring rates for 91 civic with B-serie swap
- Got a quick question....
- HF or DX?
- please help
- 88-91jdm b16a distributor
- Holset Turbo Need Help Now
- need help with friends alternator problems
- D15B VTEC engine swap
- b16a timing?
- Need help to put EG seat into my EF
- Cylinder wall scratches...HONE? / BORE?
- 91 hatch with 95 integra front
- Type-R LSD in S1 Tranny?
- map sensor issues Help~~~
- who's got or where can I find the 89 crx HELMS manual in .pdf ?
- car dies on me
- Brakepad Opinions
- does anybody have a pic of pr3 wiring to the ecu and out in a hatch/crx?
- sunpro tachometer wiring?
- 91 crx si ????????????????
- My setup?
- ls/vtec question
- 1 1/2" of rubber at the top of the hatch window
- OBD0/OBD1 conversion in 91 crx si
- Is a fuel pump necessary?
- OBD1 transmission on a non OBD engine?
- help please, cluster problems
- How to get the rear shock/spring out of a 91 crx si????
- take off A/C............
- WTB:Crx or Civic with B series swap in or around Iowa.
- Car pulls hard to the right
- Need some help with MPFi swap...
- Broken wheel studs HELP ASAP!
- crx vtec for sale
- what would you pay for shell?
- Aftermarket Lip?
- yO what kind of mid wing is this?
- leaking tranny fluid
- 1982 honda civic
- D16 VTEC HEAD PRICING RANGE
- ef questions
- My B18 swap in CRX 1.6iVT - Question
- z6 cam on sohc zc
- JDM Crx Conversion
- Is there a difference between DX auto and Si/HF instrument cluster wiring?
- 3
- Sometimes I just get a click when I first turn the ign. key...
- anyone have 96spec ITR wheels on their EF hatch?
- stock engine 90 dx hatch...........
- battery light AGAIN
- put LSD in today, now NO reverse
- Valve clearance with A6/Z6 mini-me, 2 layer HG and milled head
- b16 in cali??
- Anyone in the market for a clean B16A powered 91 civic Si?
- Gear setting on a SOHC Vtec and compression?
- turbo information
- simple question about 2nd gen crx wiring
- OBD0-OBD1 VTEC Wiring
- Some crx questions, see if you guys can help.
- What color is honda MTF???
- shift linkage removal
- CRX conversion?
- SOHC non-vtec ZC timing belt? (tried searching)
- wtb turbo!!!
- CRX and HB windows and window regulators?
- stock 14 inch crx si wheels 4 -sale
- exospeed race A6 or sr909...decisions decisions...
- hydro conversion
- Installing alarm where is Door Trigger and Dome light relay?
- wanting some 15 or 16 inch wheels for crx
- Brake Stumper ?
- do you think its rod knock??
- si or dx transmission? need info indetifying
- To take the rear lower control arm of do i.....
- Where to ge B16 stroker kits
- wondering about motor swap idea
- chassis vibrating on corning... LEFT and RIGHT
- hatch and sedans fender interchangable?
- D16Y7 in a 91LX?
- TYPE R CAMS
- New here
- looking for high-flow cat...should i get 12inch or 14inch one??
- slip on muffler?
- MINI ME SWAP
- Help with throw out bearing got old one out can't get new one in
- intake-air-temperature (IAT) sensor wire harness
- Another silly CRX conversion, found in Quebec, CN
- aout the awd.
- Any oem style side skirt for 89 civic si?
- post all canister cat back exhaust that can be bought...not custom
- EG Radiator in a CRX...Quick Question...
- good night for the stock 89 hf......
- brake lights?
- 7th gen civic problem
- scale Ef hatch pics
- MPFI COST??
- check engine light=loss of power, oil light battery light, click from relay?
- installing clutch cable
- Spark plug wires?
- sohcZC owners! post your mods/times/dynos or any helpful infos here!
- I need help with my crx w/b16
- B18C swap w/ billet hasport mount fitment issues: alternator pulley, lower crossmember...
- JDM front end
- Gutted my interior..want some sound deadening.
- Need legal replacement for stock cat cov...
- pressing clutch the letting go hearing grinding sound?
- Jumping o2 sensor...is ti bad?
- does ac really use that much power?
- HELP!!!
- ZC swap times?
- What cams/ cam gears for ZC?
- cluster not lighting up
- HF upshift light questions
- Fuel Kill Switch Reliability, would like your input for those who have installed
- Code 10 and 14 after Swap.. EACV and IAT.. NEED HELP
- PLEASE READ!!! I NEED HELP WITH COOLING FAN
- Help I cant shift !
- Where is this thing 'supposed' to seperate (VSS GEAR)
- code 17:VSS...89 hf w\D16A6
- POST PICS of your METAL battery relocation box install!
- need help with some specs on the d15b
- B16 won't start, main relay?
- Sounds like a bad ignition switch to you?
- headlight problems
- CRX- sohc ZC vtec dyno! you're going to be surprised :P
- CRX smoke
- crossing into the dark side
- ? for people who have installed H&R springs, PLEASE HELP!
- Testpipe Question
- charging system?
- AWD B20 crx.. what do u think ????
- obd1 to obd0 distributer??
- DC Header Rattle?
- Gunna try this again: Car runs fine, but stalls randomly when idling.
- need help wiring apexi turbo timer
- 88 DX won't start, fuel system issue, any ideas?
- AWD Civic
- Da Skunk2 springs yada yada rates? fit? just a couple questions
- Is this a bad thing???
- CRX si rev limit?
- Check this out!!!! Who does this, they should be shot.
- wont start, took out main relay. starts again.
- Quick question........
- need zc distributor asap
- Code (20) after swap, some help please
- Which Battery for a B16 hatch?
- safc hooked up wrong?? HELP
- Zc with dx tranny
- BAD CAT??
- Couplers, hump hoses and reducers
- Rare ZC race ECU
- Best D-series (stock) for turbo 8psi???
- d16a6 in dx smog?
- jess bout right?
- mpfi swap injector position
- blown 87 civic motor. what to get now?
- turbo,sc psi
- Windshield leak--remove trim and fix or just apply sealant?
- how do i remove...crx hatch glass strip bar thingie
- Need thoughts
- can i use a 87 pg7 ecu?
- What diameter are b16 manifolds?
- 91 crx si...-b16a1 need help...
- Can someone decipher my problem (ECU code)
- what is code 7 on my 91 civic si with single vtec motor in it
- does any1 know about the top feul coilovers
- cheap carfax reports - get em while you can
- aem intake question??
- CRX FOR SALE IN MIDWEST
- too much fuel going in to engine!!!!
- flow master exhaust?
- need help!!!!
- OBD0 PR4 ecu.... does it read two o2 sensors??
- Best suspension setup for ED3
- pcv valve breather filter,
- Shop Vouch
- WTB AC air condition tubing
- intercooler piping on a 90 si??????????
- Can you rewire an OBD1 B series distrubuter to work w/ an OBD0 ECU?
- post ur Ls setup!!!!
- Hasport shift linkage Question
- HELP code 17
- intake manifold
- arospeed coil overs...which springs do i use for front?
- is this is my starter?
- Dual Point Problem
- Window crank broken. Will EF crank work on EG?
- d15b2 cylinder head swap
- sandblasting exhaust manifold
- ? On Brakes - Problems
- 1995 HONDA CIVIC DX COUPE BLACK - FOR SALE - PHILLY, PA - 4450/OBO - GREAT SHAPE!
- Possible to overbore b16 by .2-.4 liters?
- 95 Civic Coupe F/S in Philly area
- Price on Russells SS lines
- What Vacume line to use for the z6's only vacume line in back of intake mani??
- I NEED A 91 CIVIC DASH WIRING DIAGRAM!
- stereo wiring pinouts? which wires are these for?
- E-Brake Light stays on Even with E-Brake lever down
- Honda/Acura ECU list reference
- Rotors came with metal clip inside vents???
- ok electircal problem still...
- What brake lines for crx with rear disc swap.
- ECU HELP!!
- Throttle body---AEBS INTAKE--QUESTION ? B16a
- D15 w/ Z6 head timing (adjustable cam gear)
- DC 4-1 HEADER
- d15b5
- Just got my es oval muffler from Inlinefour.com
- PG7 ecu
- OBD0 PR3 ECU??????
- Is lexon legal?
- RE-JETTING CARB ON 85 CRX hf?
- can a b16 head fit on a zc
- Wheel Locked...
- dseries Fuel rail all the same??z6 and y8?
- HI FLOW CAT
- best carpet
- Brake Setup
- which aem cai for 91 crx vtec
- any one selling a sohc v-tech motors if so let me know?
- EXHAUST SMELLS
- ls/vtec or ls/turbo
- wtb ef9 parts
- OBD0 ZDYNE users running an OBD1 motor?
- WHERE TO FIND CLEAN JDM HATCH BUMPERS????
- My crx is too loud...
- y8 vs skunk2 intake manifold
- What engine
- Those with Alum Radiator knowledge . I need your help! Learn from my mistake?
