View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Look what "really" happens result of hydro-lock!
- Crx restoration project Updae
- Need help with older Honda
- new to honda-tech
- da dash in a 91 dx hatch?
- CRX Starting problem. Starter maybe?
- Exhaust Header for 1990 with b16a1 engine Suggestions
- how can I make my signal lights work as running lights AND signal lights
- so close
- Quick brake question.
- i want the 94 integra center console
- dash swap
- Looking 4 Wiring Help. Swapted 1.5 to 1.6Si. Main Wire Threw Firewall does not Match up?
- New swap. No headlights or alarm? Checked fuses, dont know whats wrong!
- no more code 9, but car is hard to start & doesnt hold idle
- could use a little advice...
- engine swap ?
- crx cv axel prblems
- After the tranny swap my car runs horrible..ECU codes 10 and 14
- B16a1
- help car wont start
- Possible radiator leak? help!
- check out this honda ad
- New Topic
- Can disconected/broken VSS cause CEL......?
- F20C in CRX FWD/RWD Question
- Can i use these tranny, and clutch bolts?.
- cluster swapped
- d16y8 oil pan fit on d16a6?
- OH my Dizzy
- just put my crx on the bottle (setup questions)
- H22 mounts
- battery/wiring/car not starting questions
- code 19?
- Fuel Pump replacement in a 85 CRX...difficult?
- 89 Prelude Fog Lamps... Anyone know how!?!
- sunroof question, help...
- code 20
- ef front end
- Laguna Gold... Anyone else got it??
- ebay timing kit. is it a deal, or nicely packaged crap?
- B16 Swap, Car won't run at low rpms
- hatch got broken into yesterday
- wiring diagram for obd0 to obd1 o2 sensor
- Wierd Starting problem?!?!?!?!
- EACV?
- CRX carbon fibre sunroof. *PICS*
- 1992 civic cx
- Hook-ups REX that was stolen in 951 AREA: IS THE OWNER ON HERE?
- Legend brakes on CRX Sir VTEC??
- clutch worries
- another mpfi question, i searched i swear
- crx tie rod help
- battery relocation
- stock or not?
- RMF header w/ stock X-member, reference pics for anyone.
- Who makes a coilover kit for an 1986 crx or a good spring and strut combo?
- BRAKES
- I can't figure out what wrong with my car
- i wonder what motor can i put in my ef so it can get B.A.R ????
- F20C into 88-91CRX
- Rear Seats in a 1990 Honda CRX any body have any for ideas????
- my new wagovan with my hatch
- Is There Any....
- How do i fix this?
- Gas Mileage....
- y8 swap problem with tranny
- What should i get for my birthday?
- 95 GSR gauge cluster into a rex (91)?
- Just completed mpfi, rywired! Miss at idle no cel.
- I need a 12+ power source...
- Coverting to OBD1
- high fuel tank pressure
- Cleaning Transmission
- heater doesnt work
- My 1989 CRX Si
- Is an H22 really worth it in a crx.
- CRX engine code
- please help! high idle then car dies.
- help wiring universal bosch 02
- clicking noise coming from rear suspension or brakes?????
- B16a Idling low under 500 RPM
- 88 Hatch with LS swap Dies while driving
- why my noiser dont sound good do you no
- B16 AXLES: are they side specific?
- change 89 hf gauges to 91 hf gauges.
- b18a1 swap, orig parts--do i still need this?
- battery boxes in stripped hatches, lets see some pics.
- YS1 tranny w/ helical LSD, what type of fluid
- i thought our gas tanks were 10 gallons????
- are all SOHC spark plug wires the same
- NEW PISTONS???
- swapping an LS, harness question...
- EF HONDA CRX POWER
- XSi axles different from 1992 GSR?
- CRX sunroof replacement in an SI...not a plug.
- CAR DOES NOT GO INTO THIRD AT HIGH RPM
- low rpm misfire, stutter, bogs, etc.... idle jumps also
- 89 sedan front sway bar thickness?
- Speedhut gauges... Quality or a waste of Money?
- Differential: Removal and Replacement. Who Has a Guide?
- looking to JDM out my ladys g ride need help finding some products
- zc vtec swap won't start
- fuel injectors
- HOOKING UP SHIFT LIGHT
- disc brakes
- Best Turbo Manifold
- 4 door front on a hatch
- Question About What kind of oil i should use in my B20/Type R head????
- Oil smell after VTEC
- fuel presure gauge leaking. searched. tried evreything
- won't stay on!
- brake help
- 1990 Civic Engine Swap Question
- FPR?
- taking head off, any advice?
- 90 dx swap
- crashed my crx today, suspension question
- b16 wont start helpzzz!
- sneak peak
- Not getting fuel to the fuel filter......
- car is running but rpm guage idle at 0
- spray into Ls hatch
- H22 CRX 4Sale
- ALL MOTOR CRX!
- Need Brake Pad Clips what other models?
- Wich tie rod end for SIR ?
- Steering Wheel shaking.
- Buying b16 tranny need some input
- Buying a CRX...it's throwing codes and running funny...should i buy it?
- Gas Smell Within Car
- EF civic front driver side window/glass same as CRX???? need help asap!
- Tweaker Blinker Left turn only.
- zc timing belt HELP
- race header
- quuick question
- d15b2 head on d16y7 block
- z6 help, error 4
- 4th gen civic body kit?
- CRX HF vs GSXR-750...Video inside
- 88-89 vs 90-91 CRX tails pics, what the hecks the difference
- Installing OBD 1 GSR into 90 CRX Si w B16
- start up problem...its different i searched
- dizzy wiring
- NON CRX SEATS IN 91 CRX?
- OBX turbo manifold, same as SS auto crap?
- 84 civic cold air intake?
- OBD2 in EF NEED HELP
- big brake question
- IAT position question
- wtb HF exhaust manifold
- Problem with Axle ! Help !
- what axles???
- b16 fuel spark no start
- <WTB> EF OR CRX SHELL!!!!!!!!!!!! IN SO CAL
- Where to but aftermarket sunroof for SI? NOT A PLUG!
- Good Price?
- mpfi oxygen senser
- negative camber
- doing a lil shopping.
- okie
- first time to the track i need some tips on what good to do and not to do
- swap setup
- Can you somebody give me a step by step procedure on how to swap a B18A1 in a 91 civic hatch
- Can I Get Some Help Putting On My Tachometer?
- Which Crossmember To Get ???
- Intro and question
- Potentially buying a CRX, need advice.
- car starts but?
- Skunk 2 stage 1 inquiry & cam caps compatibility.
- need help with a b20 swap in a 91 si hatch
- Couple questions
- ecu
- still won't start.
- How many head bolts do I have?
- Help!!! My car died!!
- Won't shift!!
- same shit different day
- Idle problem...
- D16Z6 help and a little info
- fuel filter and distributor question
- will 93 civic shifter work with s1 integra shift linkage?
- d16y8 wiring
- Exhaust Parts
- quick question
- Engine swap
- question ?????????
- Intake Question??
- need help..cluster problem
- Making 89-91 Rear LCA bushings fit on an 88?
- another "wont start" thread
- won't start...
- pink slip??
- crx consol in civic????
- sir conversion?
- 1g crx motor in a 2 g crx
- annoying vibration
- OIL JET "O" RING ON D15B2 BLOCK????
- rear disc from a eg fit 88 crx?
- car wont start! need help!
- any special tools needed for replacing axles?
- Anyone ever get their o2 sensors crossed?
- b18c1 into 97 civic cx hb help
- Where is my "Value of a 95 Civic thread"
- oil jet o-ring - Q about reinstalling head
- Build ls/vtec or GSR for 350+ WHP??
- HELP!!!!! 1991 civic si hatch
- my b16 wont start help
- ecu questions
- Need help for CRX chassis parts for autocross
- Best exhaust header for CRX EF8 B16A1 engine
- Help question
- 91 civic sedan, need info if "auto B-series" will fit...
- brake question
- what kind of paint?
- where to get 1989 Civic hatchback used parts?
- cable adjusted right for a CRX si
- Farewell to the hatch..... On to better things
- staining taillights
- Why so hot?
- Overheating
- What USDM cars fit the plugs needed for the sir cluster?????
- Will a '90 integra cluster fit in a '89 hatch?
- Crx troubles
- Best cable tranny??
- b18 crx wont start
- synchromesh ?
- ZC ( SOHC ) block/ Y8 head. What timing belt?
- Messed up Steering rack!
- dumb questions **searched**
- front bumber for 89 si hatch
- B16A1 - Whats going wrong with it?
- question about cluster connections
- who's getting ready for the Puerto Rican parade?
- god price? (update)
- Need help identifying transmission
- Dumb question...
- where to get corners
- best prices??
- help obd0 ls in a crx si
- Is the PR3-J00 OBD1?
- Alternator - NipponDenso (ND) vs. Mitsubishi
- Do they make a Wide Body kit for 1991 Civic HB dx????
- mini me swap
- My ecu's throwin codes...
- What are thing u need to do to put a b16a1 ten second
- My CRX Times at BOTI Chicago
- EF swamper
- a/c question on b16 swap
- EF SEDAN for sale make offer MANY NEW PARTS!!!!!!!!!!
