View Full Version : Honda CRX / EF Civic (1988 - 1991)
- stupid idle problem
- superhatches car got stolen
- anyone know how to get a factory honda LSD?
- car is having problems starting....any suggestions?
- b16 swap.....keep original wiring harness with hasport subharness?
- What do you guys think of this brace?
- coolant temp sensor???
- Performance Cats... Please help...
- Help, climate control question!
- what car is better
- Anybody have a front lip they want to sale?
- Installing springs...NEED HELP!!!
- Stop light doesn't light up anymore.....
- Transmission Problems (3rd and Reverse)
- Anyone has a B17 gsr in a CRX. what's your 1/4 TIME?
- Help, I lost my book, what's code 7?
- headlight removal?
- AC w/ B16A swap?
- Swap w/ AC
- AEM cold air
- timing belt/water pump the same for d15 and d16?
- B16a ED9 vs 92-95 GSR Civic HB, what kind of chance do I have?
- Climate Control....check it
- What is wrong with my ac?
- Clutch Questions
- 89 Civic Help Needed
- 90 integra lights into 90 civic hatch?
- It runs!
- 89 CRX Si supossed to have front lip?
- help ASAP!
- Shops for a ZC swap in the bay area?
- Help Speedometer isnt workng???
- ecu for zc
- Brakes lines!! HELP!
- true bolt-ons.....
- My car WAS stolen, got it back, selling it.
- what is wrong with my car????
- Engine is in and the car is quick!
- Pictures of my new Kirk Racing roll cage for the ITA CRX! (large pics)
- Si front lip
- B18B1 in 91 CRX - Timing???
- Body Damage - where to go?
- p28 ecu
- Here are the specs for my car....
- crx/civic with d16z6....anybody have drag times?
- anyone in south jersey/philly area?
- Show me what you got photoshoppers!!!
- Which color wire is the tach wire for 90 CIVIC DX??
- Torn between EF and EK...
- <<PLEASE HELP>> Seatbelts are important!
- What is your first gen b16 set at...?
- DX to ZC wiring conversion question....
- do i go to midas or meineke?
- What happened to CRX Resource Classifieds....?
- who makes a fiberglass SiR style hood?
- help!! electrical problem...i think
- Which CRX should I get for my LS/VTEC?
- Need help on figuring out Milleage on this Si.
- how to rev higher in my d16a6???????
- which is the best brake master cylinder?
- I'm torn.... Photoshop guru's please help...
- I need some 1st Gen. CRX info please...
- spring rates on jdm sir?
- Cooling fan problem.......
- Need carfax help please!
- Wiring Harness Conversion
- si seats
- acura integra center console
- Speed Garage Motor Mounts?
- higher compression safe?
- NEED D16A6 Cylinder Head
- What is the STOCK fuel pressure for a ZC?
- Help me with this FPR ((((how to install)))
- Milwaukee ppl!! need help
- tranny problem?
- wtb light flywheel
- nos setup, not sure if i want to keep
- I need a pic...
- 1990 honda cicic center console
- coilover question
- DC power..
- Does anyone need automotive refinish paint?
- Block Girdle-How important?
- Rear subframe damage?
- my car is lopsided. what i need to fix it?
- CRX for comfort?
- door pillar
- How important is the resonator?
- One MORE dumbass disc swap question...
- best CF hood?
- boosting my crx...have a guestion
- wtt: full greddy catback for a camcorder
- 1st time w/zex kit(review)
- what would your best offer be for my car?
- you guys all say b16 engine tranny and mounts are only 1000 but where?
- advice on wheel choice!
- can you guys help me out?
- I recovered my CRX, now I need help catching this biotch!
- Should I buy this?
- wheres the jumper? changing my timing!
- Suspension Techniques rear sway bar with thermal 3in?
- SUPERHATCHs 1991 BLACK CIVIC SI HATCHBACK STOLEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Car Problem Need Help
- Compatibility question (civic/crx)
- whats considered *high milege* for a 12 year old CRX??
- Me vs. S2000s x 5 vs. C5 vs Track w/ pics
- Anyone have the Buddy Club exhaust for the EF hatch?
- Overheating after much cooling system work, cracked block/head?
- WTB: I need a SiR front bumper
- 88 dx crx to 92-95 sohc vtec wiring problem EMERGENCY!!
- High Cost of parts, who know's a cheaper place for parts?
- catback or custom
- jdm front end q's
- o2 sensor
- *** newest pics of my EF***
- distributor
- ZC head swap????????????
- WTB: HX rims
- Vision corner lamp wanabee *pic*... lol
- Can't find that one web page where someone strips out their rex and makes a list of everything he to
- anyone looking for one of these?
- ecu code
- half assed reverse
- 89 dx hb
- pic request
- fiberglass body panels
- 5 Zigen exaust, good?
- is a 1stgen b16a dizzy compatible with.......
- Carbon fiber Mugen style wing for CRX/Civic
- Want to change my 17'' and get sir. Need advice.
- Will the Y8 intake manifold fit on a D16a6 head?
- Pics of fiberglass crx rear hatch???
- Anyone wanna help a sistah??
- AC with b16 in EF?
- Del Sol radiator in CRX, anyone done this B4? Hassles, fitting?
- new ideas help
- DX Wiring!!!!
- Air fuel gauge installation
- Houseman Autosport Custom F/D's
- what engine?!
- ZC = Not reving past 2000
- re building a block
- kansas area import dragS anyone going!
- Anybody Solo II B16 Crx/Civic
- HELP: vtec keeps turning off
- nobody to race =(
- Lexus IS300 Yellow please help
- Why Don't People Know How To Break In To Cars Without Fu**ing Them Up?!?!!!
- Exhaust - Help Needed!
- Trade cat-back systems
- new tires..??
- better performance
- a shout out to all 4th gen four doors
- b16a with skunk 2 manifold
- CODE 14 on B18A swapped CRX?
- Bottom radiator neck f*ked...Fix? Want small radiator, what cars they out of?
- advice on CRX drag car
- Low beam bulb replacement 1989 Civic LX
- easiest way to get rear int. out without trashing it ???
- Si intake manifold on a DX hatch
- WTB: B16A header or manifold!!!
- battery shutoff switch
- what happened to my post?
- Any of you 4th gen four door owners have this problem?
- GDa*n Radiator Problems, anyone? (Long story)
- jdm 1 piece head lights??
- anyone in the northeast lookin for a d16a6?
- Are the CD hoods that are fiberglass and a layer of fiber good or no?
- Teg rear discs use same brake lines as 91 crx si??
- B cable trannys...
- 1990 CRX Si tranny value?
- **pics of my car**a couple more soon**
- Intake fit
- side view mirrors
- Looking For A CHEAP Right Front Fender For 1990 CRX - HELP!!
- what does this mean?
- my crx broke down and will not start
- Help! EF Si fuel/ecu/electrical problems
- I'm looking to buy a CRX...How much?
- what parts are needed for y8 head conversion.
- y8 head
- Brake Rotors: Cross-drilled or slotted
- Where does the tacho wire go?
- A b16 VTEC head on a b20 block.. help??
- Code 10 IAC PLease Need Help!
- MAACO paint...
- Sway Bar Installation/Bushing Help!! Q's need to be answered
- what axle to use?
- Inline fuel pump question?
- I need a header would you buy this
- rear view mirror?
- Where to cut Wiring Harness for MPFI Swap
- Carbon fiber upper door molding (sash) available...
- ABS on 88 Si?
- Water in hatch(CRX Si)!!!
- projectior head lights.. ??
- what you guys think?
- code 12?
- how much is a turbo for ZC?
- ecu code
- Hood release latch
- mpfi swap
- can somone carfax this for me
- temp. gage not working
- Best place to Buy Carpet
- Will this fit?
- Paint decisions...
- just installed headers on 99 Civic SI, NEED HELP!!
- can my motor handle???
- rear body panel on crx - what is it?
- Headers to close to A/C Lines?
- HELP! Which bumper support to use with I/C and stock bumper cover on '91 HB?
- If you could do it again?
- question on a b18 swap in a 90 crx hf
- Which exhaust to buy?? Drag kit better than GReddy?? VOTE..
- D16 crank pulley
- What is my ED9/B16a worth?
- Rear disc brake conversion?
- distributor is fucked, on my b16a
- 86-89 integ head on a sohc d-series block
- Car is primed...worried about leaving it that way
- Has anyone tried this?
- What Turbo Would Everyone Recommend for a ZC Motor?
- whats a good suspension kit for a 94 hatch with an h22
- Urethane bushings, what to get???
- where is there an easy 12 V to tap into for my tach?
- hey CR-X i need your help!!!
- Taking out corner markers???
- West Michigan Honda Meet 2 announced
- One piece for EF sedan?
- Hi im new on this board
- Clutch sqeek..........
- Does anyone have
- anyone running around on 205/45's?
- paint stripper on bumper and mouldings..safe??
- Engine RPM when cruising seems high....
- Fuel gauge not working on Si cluster
- Stock engine ?'s
- OK, where is the Idle Air Control valve ........
- ZC hesitation
- oil in 3 and 4 spark plug...
- Passenger Side Axle question.....
- Throwing a code and sputtering on and off ........ need help identifying it ......
- How to make the windows easier to roll/unroll?
- lexan window for the roof you got a pix???
- HELP???!! D16Y8 SOHC VTEC mounts for 89 DX HB ????
- My Picture link turbozcrx.
- what do you guys think about this?
- exhaust collector flange
- Prepping my car for paint...what you all think?
