View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 24 PSi Boost?
- 89-91 SI tranny needed ASAP
- B16A1 Head!!!!
- 89 si motor
- So.Cal Paintshop
- Guys i got this CM stage 2 clutch but i cant get it to fit
- rear disc, 94 integra e-brake cable work??
- d16z6 driver's side mount - just mount, or mount and bracket?
- 4th gen tranny question
- Help me find my sister a car!!
- Lots of stuff to get rid of still...
- Dynomax super turbo muffler
- Will a 88 Si Head Fit and 88 DX Engine?
- Multi-Port Change Over Anyone ????
- red hot catalytic convertor, smoking
- Wireing Diagram help
- Installed a fuel pump without the low filter...
- First time at the track
- got a question on my new project.
- what clutch & flywheel.
- CRX manual to power door locks
- B18 CRX wont start
- does anyone know
- Sold The Crx
- need a distributor? can anyone help?!?
- code 4, crank position sensor help
- EF Squad Stickers
- 89 crx with 92 civic radiator?
- Distributor ?
- Stock Radio harness...what wires do what?
- b16 turbo dependable?
- I suguest everyone reads this thread
- 88 crx to z6 Q:
- My Rex
- Manual to Auto Conversion
- Type-R suspension on ef's
- Where have you attached your racing harnesses?
- Dashes in 91 CRX si
- What dash/console swaps can I do in my 91 EF9?
- good source for switched power in engine bay?
- Will the SI padding and cloth fit on a HF metal seat structure?
- Looking for center console
- WTF should I do?
- Help with smog issues please!
- B18A in to a CRX DX axel problem.
- Will 205 60 R14 Rub????
- Tanabe Suspension?
- blower motor installation troubles...
- What muffler for JDM type-R in 91 hatch? Let's debate!
- does the hf wire harness work on the si motor?
- brake upgrade questions...after search
- 87 CRX Engine Swaps
- hatch si rear sway bar?
- Sport muffler
- What engine is best for me?
- where is the best place to look for intructions crx hf to z6?
- wiring harness??
- Do you need hub rings with Rota C8's?
- vtec controller question??
- ZC Intake
- running code 10??
- Do It Yourself - Exhaust Mod / Repair (*56K Warning Lots-o-Pics*)
- have some suspension questions.
- brake lights stuck on
- JDM HB Power windows?
- b16a1 vs B18a/b
- heater core replacement
- si manifold..
- 88-89 vs. 90-91
- WTB Asap!
- Really odd D15 hybrind motor, will it work?
- Integra dash in a CRX?
- CRX CAT on a 90 civic hb dx - Please let me know as soon as possible
- Si the same as HF?
- integra ecu in 89 crx
- Sign up sheet is up for 3rd Annual 88-91 Civic/CRX Meet in PA
- Single vtec
- tranny problem
- tranny questions???help!!!
- florida H-T members
- Mugen AGBS
- cold air intake
- Reasonable price for a Civic SI or a CRX SI?
- FPR off a 91 prelude....
- Help me pleace..................
- dist question
- ecu plugs
- electronic vss wiring for my gsr cluster... HELP!!!!!!!!!!!!!!!!!!!!!!
- can someone tell me.......
- B18c manifold on b16a1??
- rpm's on my friends civic are bouncing
- check engine code 20
- looking for jdm ef rocker covers.
- MPFI swap that gets CRAPPY mileage...
- 90-91 climate control in a 88 dx yea or nea?
- where can i get bushing cheap?
- Flywheel Questions...
- Does a 4th gen auto trans have a VSS?
- Got Camber?
- Custom Spring Rates Ground Control 91 Hatchback????
- i need this asap
- k gusy i need help please
- CRX Shift Light Modable?
- ok, this is what I need
- Its alive!!!...again.
- What are my brakes?
- CRX/Civic
- greddy turbo kit on d16a6
- Anybody have a dead pedal in an EF?
- 1st gen b16 on crx. what kinda 02 sensor should i get?
- Fourth Gen Militia meet (milwaukee)
- CRX HF vs CRX DX?? How to strip out a CRX?
- Can't find headers for my car! HELp!!!!
- crx tire size
- EF motor wanted
- thermostat for b16? quick
- Just installed new clutch
- 87 integra RS ECU in 89 crx si
- I already have a 96 b16 turbo hatch, I want a sohc turbo crx, How much boost to run 14.00 ish?
- what clutch for a ZC.
- Oil light comes on and off?
- 91 crx si seats and 14" alloys w/tires for sale
- Diff B16A and B18A cranks
- Toronto EF's
- ZC pistons and rods...
- Getting Rid Of CRX!! Please Read!!
- Wheel stud Q?
- ZC sputtering/surging
- b16 wont rev
- DOHC ZC intake manifold Q's
- help with a 4-point harness
- 1.5L ZC ?s
- CRX questions... silly maybe...
- That was a close one!
- bogging in 3rd?
- will DA teg sliders bolt into an EF???
- Brighter 194 wedge bulbs?
- Who has the link to the 500+ HP D16A6 SOHC turbo????
- It is Alive .........
- for sale 88crx hf
- 89 Hatch Launch...
- Possible to put ABS in an EF?
- 90 D16A6 parts for sale
- where did u buy your motor mounts and how much?
- hybrid rear brakes ?????????
- so cal EFs where you at?!
- Power Mirrors From an EX Sedan to a DX Hatch?
- d16z6 in a 88 hf crx what do i do ?
- ECU question
- Help
- OBD 0 TO OBD 1 Question!! Again pls...
- What makes this sound?
- 1989 civic si hb tranny question
- hcp adjustable shift linkage sucks!
- 90 CRX Si Seats into 91 hb?
- Zc axles and tranny problems.
- Civic Fenders fit CRX? *did search
- Question!?!?!
- noticeable difference from a .0040 over piston?
- popping sound out of exhaust.
- New Project
- CRX door coversion
- What D series header Applications work on D16a6?
- correct timing for crx w/ b16
- ZC + turbo
- B16 Tuning
- KONI yellows pricing
- Maybe i'll sell it...
- Hondata question
- Just priced my mini-me build.
- SOHC Vtec swap w/pr3 ECU
- anyone heard about airmass performance products?
- damn i hate rust
- Zc valve adjustment
- Civic/Integra Attack!
- Anyone attempt to put 4WS from a 91 lude on a CRX?
- What color is wire is for ckp sensor on obd1/obd2 distributors?
- 88 CRX Si rear speakers?
- rear camber kit for CRX w/ washers???
- Z6 swap- tech question
- Difference in 88-89, 90-91 doors??
- CRX Manual, Remote start
- 03' CRV I picked it up on Saturday Morning..............
- what do i need??
- testing for an electrical load that drains your battery?
- Whats the cheapest way to make brakes more effective...
- Which ecu to use.
- JRSC Resistors
- Rattling problems
- is it worth to get this stuff? And what do you think of my vision of the CRX i'll be getting when fi
- Jdm ef cluster owners.
- What to choose?
- looking for a Mugen Si-R front bumper
- Where can you put bars?
- Can anyone post pics of a B20 in a CRX please?
- Car won't start after head gasket/timing belt replacement...HELP!!!
- V-Tech Problems
- need help
- Lovely pics of my crx...
- where can I find a new crx si motor. not too expensive?
- jdm front
- ???'s on kosie's
- Want to learn to rebuild and engine...
- what AEM CAI for b16a1 CRX?
- Your EF=Wanted :)
- JDM SIR cluster install questions
- Just got my 91 crx si, Have few options, Need Opinions
- where can I find A JDM....???
- Project CRX floormats (pics...56K ok?)
- EF Mount Question!
- Project Audi holder below radio (part 1)
- 99 civic conversion
- B18A swap in a 90 DX HB(wiring questions)
- best head gasket
- White smoke is good right?
- CRX SiR jdm cluster 90-91
- One last T&T for us Ohio guys... Come!!
- Motor mount problem
- sputtering
- how much?
- Error codes, 14, 3 and 4? Please help
- What to do?
- I need a camshaft
- Dist Question
- I need help with my swap!!!!!!!!!!
- Cutting out spare tire well.
- Whats a 4th gen 4dr worth?
- what block should i get?????
- Should i trade?!?!?
- Changing MC
- CRX Suspension / brakes SWAP!
- Drag Gen 3 Turbo Kit
- This thing is blowing my mind: Please help me!
- wet dizzy... god i hate pigs!!
- b16 (or b17) in ef swap pictures
- Hasport dx to SiR wiring
- A little help please
- gimme a price estimate
- Power mirrors on CRX? How to?
- argh, problem after problem....
- mini-me on 1987 crx si??
- I need the lowdown on Skunk2
- Jacking point for front of my civic...where?
- Anyone ever heard of using mustang 5.0 injectors on a b-series (pre obd)
- B18 swap
- oil squiters?
- crx in the new grand theft auto!
- where is the fast idle sensor (or is it valve) on the d16a6?
- Going to the track tonight
- ZC Head knocking
