- EF9 RHD conversion log (56K warning)
- Fan on Fluidyne radiator?
- no spark or fuel pump wtf
- throw out bearing
- problems with my EF hatch
- Launched at the strip and....
- map sensor vacuum lines???
- god i hope i know what i am doing
- pics of the hatch
- 2 injectors to 4 injectors conversion
- b16a swap to hf rex
- Do B Series Swaps come with automatic trans???
- need some expert advice
- rough idle???
- wires on thermoswitch. which is which?
- b16a water pump
- IDLE QUESTION
- Sleeve strength?
- ITR 5 lug conversion axles???
- tranny fluid how to?????
- Need advice
- what the hell is this?
- Car running very rich!
- Is CRX Dash interchangeable?
- Clutch cable length
- It wont turn off !!!!!
- Part needed
- What Swaps Can I Do?
- rad fan not comming on
- cranks, won't start
- help i need somebody
- d15 tranny
- need camber help
- Axle question
- CTR cams in b16a1
- d series lsd HELP!!
- engine pics ls-vtec nitrous 91 civic
- heater core???
- traction bar help
- 91 stock hb help
- Front mount intercooler intake
- where are my rear discs?
- Which headers with 2.5" collector fits EF with stock crossmember ?
- Very odd vibration...(1991 Crx)
- help with my crx
- Cam gear adjustment
- need help asap............ F$%^
- F20B in a 1990 Civic (gen 4)
- Did I mistake buying a CRX?
- d16a6 and dohc ZC ?guestion
- EF-9 loses power and then stalls after 20 minutes
- Walbro 190 or 255
- Ways to tell 88-91 Civics apart.
- 88 dx 4 door w/ b16a HELP* searched
- Cry02 vs. Nitrous Oxide
- mini me setup....will my budget build be fast enough to run 14's? inputs appreciated.
- do obd0 ecus throw codes?
- 89-91 Civic Hatch floor mats
- 90 civic swap
- door locks
- engine swap questions
- what are the benefits of a balanced and polished crank?
- crx zc swap
- Gronuys d HELP
- JDM ZC SOHC Non-Vtec cam specs
- Rear Bumper ' filler ' piece removal (91 hatch)
- SICK, first tranny swap ever!
- cluster swap?
- d16z6 in 89 dx----issues! someone who knows their stuff help me out!
- Can i bench bleed a master cylinder with bolted onto the car?
- z6 v y8 head
- Will putting the original cat back on my car kill my acceleration?
- b16 crx dx wiring help
- my car title doesnt make any sense...
- will zc distributor fit on a d16y8 head?
- heated oxygen sensor
- ITR Gauge Cluster wiring
- WHERE TO BUY MOUNTS
- need a B16 head to finish mah project
- DASH INFO HELP!!!!!!
- Need help on Dizzy wiring for B18B1 into the EF si???
- how do I b&m pressure change
- tranny mount ?
- IACV valve *worse* after cleaning
- Ignition cylinder lock, anyone replace before, got a ?
- Charging/Battery light on dash flickering ?
- car is very smoky-looks white to me others say its blue
- Z6 ZC head or D16Y8
- some help needed asap
- vtec oil pressure switch problem
- Climate control conversion...
- Tranny Rebuild?
- bought CRX Si, has factory oil cooler on back of D16A6 motor ???
- I'm NEW!
- Trans
- WHo here has successfully installed a 99-00 cluster in their hatch?
- problems installing one piece header on b16. bracket doesn't line up.
- 87 Crx Si. MPFI or DPFI?
- Wire help, ASAP!
- building bottom block for jdm single
- Replacing fuel pump...can it be done on the street?
- Light bulbs on my car?
- Need Help!!!! No.2 spark plug is not firing
- 91 CRX SI WIRING PROBLEM
- got car back from shop now horn is activated by my fog light button
- d16z6 code 3&4
- Fan switch relay?
- problems with starter and/or battery
- 90 hatch w/ no A/C but wanna put a/c in it question
- HELP with half-sized radiator and FMIC in 88CRX.
- CRX: LS/VTEC & CRV/VTEC versus GSR B18C Which is better? Round 1 Fight!
- d16y8 with ac???
- 1.5l motor probs
- searched......fan is broken
- crx roof
- Camber Kits?
- Fuel Line Differences
- cluster just stopped working! HELP!
- OBD0 hondata
- Suggestions for CRX Engine Swap
- car wont start HEEELLLLPPPP!!!!!!!
- Crx won't start...dead fuel pump.
- How to hook up oil catch can
- place racing front cross member...if you have one post here
- i have some questions.....
- Pseudo Type R motor - Hybrid
- whats do u guys think of these rims on a 89 hatch
- will a 89 si clutch work in a 92-95 sohc vtec tranny
- PM6 Code 17: VSS?
- Clutch help
- wtb mpfi swap for my dx
- '90 Hatch DX Not Starting SEARCH WAS DONE
- so finally my seat is begining to rip...what did you guys do to repair it?
- exhaust
- Help Altenator advice please!
- Is all B-series axles the same? and do they fit all b-series motor:?
- Super Easy Crank Pulley Bolt removal (pics inside)
- back fireing through intake!!!!
- still having zc porbs?????
- crx parts
- cf hood clearance
- what needs to be done to ref a zc(into a ef) in CA.
- OBD 0 to OBD 1 worth it?
- B18B1 into the EF si questions?
- crx is burning oil
- firing order 1990 civic dx
- problem... gas guage -- help please.
- Anyone know what exhaust this is?
- Body wire harness issue, anyone that knows wiring help me out TIA!
- trying to figure out problem. stumbles when given gas
- AWD 4DR civic
- I Need doorcards ASAP
- Need help !!!!!
- F1 motorsports
- Mini me drives!
- 89 CRX Cluster in a 90 CRX.
- after swap car has 5 different rev limiters????
- DA headlights on a EF
- rhd civic
- Good place to buy YS1 LSD Tranny?
- Auto to stick need help!!!
- Mini-me swap parts list ??
- infinite motorsports
- Oil Filter relocation?
- How do you like my wheels?
- two o2 sensors?
- d15b or ZC into 1990 civic h/b?
- Help On Which B16a Swap Components To get
- my head is gonna explode!!!!!!!!1
- My RIDE freshly painted!
- Easy swap? (D15B2 to JDM D15B)
- crx ef speedo cable help
- 1981 Honda Civic Parts
- crx zc hood
- seats
- Valve job... Now clatter
- stock 88 crx hf with gsr swap 1/4 mile time......?
- help starting problem 88/HF
- D16Z2
- does crx have power steering?
- 90 dx starting problem
- New Coilovers. Will they fit?
- crx's/hatchbacks common problem? window trim right under window broken?
- just painted my car!!!
- passenger highbeam wont work. 88 civic dx hatch
- SEARCHED: D15B7 into ED hatch Motor Mount ?
- how hard is it to put a gsr in a 88 dx crx
- my carr wett............wink wink
- cut valve cover for cam gears??
- how long will my mini-me last?
- Resistor power
- IAVC Problems
- front seats bolt sizes?
- what the flip is a mini-me
- high rpm at 60 mph...?
- CRX Mini-Me track times
- Is it just me?
- need help vaccume lines
- shift linkage help
- lookin for a b16 tranny
- Pr3-2
- short thrown question
- Need help telling the idiots at autozone which axle I need......
- Climate Control *NEED HELP*
- getting a free a6 engine..
- flywhell/tranny combo for a d-series(need info)
- crx brake question
- need help d16a6
- WTB JDM b16
- Rebuilt Starter?
- Another brake question help me out guys...
- can you put a h22a type s in a rex?
- ls turbo
- My Clutch Pedal Is Done For. Help!!!
- b16 help asap!!
- radio whip
- sorry to be ignorant...
- Y1 question?
- Ef crx part out Link to classifieds
- AWD Civic Wagon......my wagon needs to be fixed!
- The right harness???
- Getting a New CRX :)
- Electrical Woes... Need some help from you pro's!!
- B18c5 or K20 type s
- I need a complete swap....anyone selling one??
- Mini me timing/ valves
- 3 weird noises after motor swap
- Just did The big brake swap.
- throttle bodies
- simple green?
- civic hatchback owners with apex world sport exhaust questions gaskets where to order?/exhuast hitti
- crx...ls motor jackson racing / vortech
- jdm d15b non vtec? exsist?
- b16a header
- code 21 vtec solenoid help!!!
- HONDA EPC SERIAL NUMBER
- bogging @ 10% throttle
- rex si brakes.....help
- whats this wire for???
- how to remove CEL code 21?
- crx hood on hatch
- suspension set up
- Wimpy starts, sporadic power...
- dohc zc valve rocker arm sequence? Searched
- Omnipower coilovers for EF pics?
- need help on crx...
- tokico's and brembo rotor will they fit my crx???
- LS/Vtec Swap For '88 EF 4 door
- Good muffler for B16
- Fuel Delivery Problem
