View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how should i go about this rust :(
- 2.25 vs 3in catback exhaust thermal reseach all motor
- 91 Civic DX/OBD1 jdm b18c swap - Fuel pump won't prime
- D15 distributors
- 91 civic dx, takes forever for headlights to come on in winter
- 91 Si D16 randomly won't start
- Jumpy Acceleration and Light issues: 91 Crx
- Help! Can I do a a valve job only? - 253,000 Miles
- Alternator or Battery?
- What weight oil should i run in a new D15B2 engine?
- 91 hatchback - the rear quarter body panel is rusted
- DIY Request: How to Remove Door on EF Hatch
- delayed start up between ignition switch and main relay
- 90 CRX DX - A/C Clutch noise?
- y7 head on a6 block?
- EF9 ROUND FOG LIGHTS INSTALL
- Would smaller Honda displacement engines get better gas mileage than the HF engine?
- headlight faulty help
- 91 civic d15b ecu HELP!
- Help! Which Harness OR combination of Harness' to use???
- Alex_S - Honda Civic ED7 88' Build
- 88-91 civic door cards interchangeability
- 2 step problem
- extreme dimensions b2 full body kit for crx
- dizzy coil resistance spec b16a 91 crx
- glove boxx question
- Eg D2 one peices will they fit on a 91 crx
- What is interchangeable between the Wagovans and other Hondas/Acuras?
- d16a6 cam question.
- A6 Head Rebuild. What do I need to buy from honda? *PICS*
- Where the shift rod goes in the tranny is very loose and just flops around
- 1991 Honda Civic DX Sedan Rack and Pinion bolts
- i got problems with my spindles
- b16a stock with stock p28 ecu starts crappy when its cold
- Civic D15B2 PGM FI ECU wiring diagram in need
- Dizzy adjustment question
- Stock D16A6 PCV Valve Rubber Grommet ... Help please!
- Help with knocking noise coming from passenger side (Not Axle)
- metal cam seal for d15b?
- Plug pin-out help
- d16 z6 idle
- d16a6 throttle connection help
- Climate control fan speed selector breaking
- New owner!!
- CA, failed smog, high NO!
- How much axle play is normal?
- 1989 Wagovan RT4WD O2 sensor code, running funny
- z6 head on a6 bottom
- crank bolt a pia? solution
- worth going to premium?
- Cel and battery light same time... limp mode
- What d series engines will bolt up to a wagovans awd drivetrain? Will a zc work?
- Rough Idle at Startup
- Rebuilding a D16A6, what parts am I missing?
- what is the correct valve clearance for a b15?
- Door indicator wiring on ef2 gauge cluster please help
- dizzy maybe going bad?
- 3rd Head Gasket??
- how to check if speedo cable is working or broken?
- 1989 CRX G23 swap Axle length
- just got a jdm front
- 91 CIVC DX HATCH with blown head gasket - need input on replacing head
- Car stalled
- Cable Tranmission Questions
- CEL 7 & 17 but speedometer is funtioning
- Which prop brake valve for Hybrid brakes for EF civic
- Rules, Thread Titles, Car Information, Searching, and Picture Posting
- 90 civic si - cranks but won't start
- MiniMe Questions
- A/C Suction & Discharge hose interchangability
- d15b1/z6 mini me
- 89 civic si Throttle Body?
- D16y8 OBD0 questions
- Fuel pump question
- 9006 Headlight bulbs
- Crx b16 problems reinstalling transmission rear mount k bracket
- chasebays harness problem
- 91 honda civic ls low compression
- Head Bolts?
- Crx rear defroster doesnt work, and winter is coming!!!
- 1991 DX swap from D15b2 to D16a6 help!
- Engine swap D16a8 sluggish..
- 91 Civic Wagon RT4WD Vibration
- Crx 98 type-r swap digital vs cable speedo obd2a issue
- Need help- MPFI swap throttle bogs and surges
- Civic Sedan Special Edition?
- Fuel Gauge Wont Work Plz Help Me
- Fuel line leak - Line replacement suggestion?
- Slight Clicking in R turns
- OBD2 motor TDC sensor problem.
- is honda dw-1 the best atf to use?
- 99 civic coupe Strut/Spring(tein) Fitment
- Coil on plug B16a1 using standard ECU
- Apexi V-AFC controller install
- eg front upper camber arm fit ec?
- Axle headache
- 88-91 CRX/EF Civic Picture & Video Thread (NO COMMENTS)
- $For Sale/Want to Buy$ - 88-91 CRX/Civic Parts Only (NO COMMENTS ALLOWED)
- removing rocker assembly
- car randomly loses alll power-- maybe fuel pump?
- Anchor bolt for rear boot gas strut
- blink code 4 on a ef hatch
- shifter question
- Need help with my 91 CRX D15B2
- Difference between SOHC ZC and D16A6...
- need help!!! ef9 power window wiring for lhd switches
- NON adjustable racing shock/spring combo
- tie rods gave me he!!
- lower tube seals avail sep?
- fuel cutting at 5500 rpm 91 crx help?
- Thinking about running only one fan
- 91 Si Map Sensor Wiring Colors?
- 90 si high idle problem
- Newbie 90 civic hb what internal upgrades (pistons and ?) for horse power
- Window tint
- slammin a 91 hatch
- crx ac condensor noise filter connector
- 89 Civic Si w/ 96 B18b1 won't start!! OMGWTFBBQ
- crx camshaft?
- 89 Civic starting/cranking Help
- Hard time shifting into any gear
- Need some help from the pees in Miami
- Will 99-00 si gearing fit in my 91 ls cable trans?
- 90' Civic Pedal Assembly
- OBD0 Warning Lights Issue
- Anybody know a similar exhaust to this one??
- Alternator removal on swapped CRX
- TPS adjustment issues.
- oil burner here
- B16a2 on carburators?
- 91 civic si conversion???
- Alternator question mini me with conversion harness
- B16 Header fitment
- how to do a wire tuck?
- zc crank?
- 1991 Prelude fogs on EF?
- Check out my Rex
- horn botton wont work HELP
- no spark
- car stalled & got jumpstarted, then i had no headlights, signals, gauge lights ?
- 1988 Civic
- diff between ef and da uca's?
- core support replacement
- Found seller of super rare CRX parts - anybody need anything?
- quick question - 88-89 / 90-91 part - ac condenser fan
- CRX Seat cover replacements
- after idling lastnite, it overheated & coolant leaked all over front of car ?
- Five lug conversion for my 1991 civic seden
- Shift linkage binding with b series swap
- what kind of gas milage do you get
- CRX/B16 swap - slow dripping coolant leak
- first honda/future project
- headers
- Motor mount AVID
- my L3 tranny wont go into gear when motor is running. please help..
- rex on diamond steelies,post yours
- Low Idle troubleshooting
- CRX SI STARTING PROBLEM
- new to me 91 si
- NO POWER TO FUSE #8 4th gen civic EX why?!
- Crx core support?
- seating cam and crank seals?
- hatch smokes on start up
- 1991 Honda Civic DX Help
- help on color
- Help with a crx build....
- JDM d15b HELP
- Civic si only sparking once.
- where do i find this sticker
- Got bit by the Honda bug again haha
- b18 vs h22
- how to get my car out of safe mode
- difficulty and cost of replacing rear engine mount?
- I can not start my 1991 Honda CRX Si (manual)
- Kill Switch Help!
- My SMF build : from a 91 si to an 88 std
- Can anyone check my vin free?
- crx injector problem
- 1989 Civic Full Rebuild to K series
- Alternator Problems
- JDM power door panels
- Yet another fuel issue -__-
- steering wheel clunk
- Transmission rebuild problems
- 2 questions please help need car out ASAP
- rattling sound from intake manifold d16a6
- fan only covers half of rad, this normal?
- b16a swap help
- 88DX CRX TPS code, replaced still throwing code
- Boot Lower Gas Strut Bolt
- Rear backup lights Stay on 24/7? please help :)
- valve cover bolts.. help please
- 91 Si No power to the injectors...help.
- civic running rich
- brake pads
- a6 downpipe same as b2?
- ys1 transmission part question
- [DIY] How to tint headlights [PICS]
- obd0 obd1 whats the benifits?
- what is the best way to rebuild a car?
- 1/4 tank and run out of gas?
- chasebays harness
- d16a6 block d16z6 head studs
- Suggested/Recommended Front Camber Kit?
- 91 Civic - 2 Bad Cats - 5000 miles!
- cf-48s
- ef swap
- Uhoh
- B18C1 GSR Swap into 90' CRX Si
- front camber kits needed?
- d16a6 problems: has spark and fuel, but won't run
- 91 Civic DX Brake Problems
- Hatchback weather strip for 91 crx?
- Gear oil for 89 Civic manual trans
- ef lips
- Ignition Problems
- Diy: CR-X to BB6 cluster swap
- 91 civic b18b1 swap no injector pulse
- a little miss
- ef cluster swap
- issue with running stock ecu
- D16z6 swap, CEL 43 running rich
- 91 CRX W/B18A1, ECU In LIMP, Possibly TOAST...
- need help with jdm EF cluster lights explantion
- B series transfer
- 88-89/ 90-91 ef door cabin harness swap
- Cluster hactch light stuck on?
- What's the damage caused by driven with no harmonic balancer
- pull Transmission
- Dam Seattle has alot of EF's
- harness
- replacing b16a1 with b16a2 ef7 crx
- Fuse 10a slot 1 (turn-signals, back up light) keeps popping!!!
- Getting a crx? Maybe..
- b18 swap not starting with key
- bumper removal.
- 90 CRX LS Smoking
- Crank bolt removal 101...
- D16A6 + DC Sport Header + Chipped ECU =?HP
- 90 civic ecu prob
- whats the best way to make a sohc non-vtec fast without turbos
- Dead Pedal removal on 89 crx
- Honda CRX 88 in Perth, WA -- Headlight and TPS code questions
- Trailing arm problem!!!
- 91 ef wagon - stalling, hesitation, and smog issues
- swapping b20 into ef need advice!!!
- idle up control solinoid
- D16a6 head
- JDM Bronze glass help
- STD Civic under Wrap
