View Full Version : Honda CRX / EF Civic (1988 - 1991)
- will 88-91 civic hatchback front doors fit on 88-91 CRX?
- is a VSS required for a non vtec car to run right?
- Which sway bar are the best
- how to tell if....
- Want other crx owners opinions...
- dpfi to mpfi conversion, car wont start
- whats better b16a or a d16yb in my 89 dx crx?
- aftermarket lightweight crx hatch?
- any 91 si trannys for sale???
- please help with rywire harness swap (extra wires).
- fuel upgrade with swap?
- Selling my 90si B16...
- ecu
- fiberglass frontend for a crx
- new head put on top dead center put number 1 cyclender at top dead center wont start
- H22A in an 87 CRX
- im ordering everything today - need everyones help on where/what parts to get
- VSS WIRING help please
- crx transmission spline question
- B16 CLUTCH problems
- the crx is coming back for 2008
- o2 sensor issues
- Wiring harness plugs
- Just bought an extreamly clean Ef and got a few questions..
- Tranny mounts for dropping tranny, do i take out all 3 ?
- is this an si crx ?
- jdm b16a1 ??????
- Center Console Fitting
- um...did i buy a ex/si tranny?
- EF Modification HELP
- aftermarket "high intensity" light bulbs
- crx 84 ls (1.5 i was told) Wont idle after it has warmed up.
- Pretty funny
- JDM TAIL LIGHTS??
- Hmotorsonline.com problem
- can an a/c from a eg go into a ef?
- CKP sensor wired backwards?
- Need help with alternator belt
- B now, K later? Opinions please.
- another dpfi-mpfi swap problem
- FC3S top feed injectors?
- d15 question
- 90 SEDAN EXHAUST QUESTION
- another sizzy question
- Hatch wont pop
- SOHC Vtec Project
- CEl 41 wont go away
- flywheel bolts?
- rebuilding transmission
- what's it's potential (crx)
- Quick question: will 88 prelude wheels have the right offset for an EF?
- Stock Injector and FMU setup safe?
- h22 axles
- yes ive searched but i have a sunroof question
- 1989 crx Hf Tps sensor
- Rear Fog Light - Right side or Left side?
- Just to check...auto and manual zxles the same?
- Stuff I have for sale...
- D16Y7 and D16Y8 dizzy
- Paking Lights always on...
- help using turboedit
- CRX dpfi idle adjust?
- crx race clips
- Hf to SI hub swap
- tourqye specs for head bolts on a d16a6
- h
- Seems to be the alternator. Need some input please!
- how to remove 90 crx rear bumper
- Car is running like a BAG! *video*
- What do you guys use for a EF9 Pin stripe! (searched)
- Seat belts broken?
- finally setting the timing on my mini-me
- obd1 conversion...is it even worth it?
- Question about A/C fan switch.
- Exhaust Muffler
- header too long?
- Getting a crease out?
- Engine Management??
- The 3 grounds, where are they?
- armrest swap from a 86 -89 integra
- grounds
- instalin a head on a d16a6 how to
- another ls swap question
- HELP!!! should I get these?
- Dpfi wire hwarness differences
- 88 CRX ECU (PM6) upgrade question... PG7?????
- B16 FLYWHEEL ?????
- Does this fit right? PLEASE LOOK!
- ls tranny question
- HELP!!! Oil in the sparkplug hole, what do i do
- Need advice on POWER
- crank pulley removal
- more parts for turbo setup
- Heres the rest of the problems
- 12 pc. spyder kit
- Installed Rage Header...
- yo guys i need help!!
- Map sensor removal...
- automatic swap?
- conversation parts for b18c to crx
- e-brake line swap
- d15b2 Q
- stage 3 cams
- B18B1 and B18A1 differences... Please help... OBD0 and OBD2 ???'s
- Stupid question, hose hook up!
- SCORE!!!!!
- Dizzy Problem, Please Help!
- remove axles just from tranny
- Piston rod question...
- CRX fuel issue PLEASE HELP!!
- Sellin some coilovers for 88-00 civic on e-bay. Never Used
- lookin for
- Final drive gearing?
- Tappered Throttled Body??
- OBD 0 to OBD 1 Questions
- Steering rack problem? Wheel shakes like crazy...
- CRX FIBERGLASS ONEPIECE FRONTEND!!!!
- check engine light
- Tranny Fluid
- D16Z6 head and MPFI conversion onto an STD, some tech questions.
- is this a bad distributor? pics
- ball jonits!!!!!!
- wiring issues
- 89 HF----->89 Civic Si seat pan swap????
- converting
- getting b18 for my 1991 civic hb , what would i need
- I Need Basemap Help - 2.5 Bar Install OBD0 - Never Tuned Before
- My new project 88 crx dx
- Just figured out my car has been in an accident
- OBD0-OBD2 on crx
- Kakimoto Catback
- tps sensor
- Door won't open
- Where do people get plugs for teg cluster swaps?
- stuck in gear, bet you can't figure out -searched-
- FPR and injectors
- Possible electrical problem...Headlight bulbs keep blowing...
- Need help on '91 CRX HF
- SUSPENSION?
- flat black civic pics
- d16z6 flywheel on a d15b2?
- can i swap my stock 88 si 1.6 into an 84 rex?
- Any Tips On Filling Transmission Fluid? 91 Civic Si
- removing head lights
- D16Y8 camshaft
- 92-95 Radiator
- my battery is done
- built gsr for sale (so Cal)
- Is the true or not!!!!
- No vtec - Help, I need bOost!!
- Converting a B18B1 OBD1 to OBD0
- CEL code nine (9)... How to get rid of it?
- How to tell the differences between Hatch/CRX bumpers.
- HELP - Advice - Broken engine mount (on motor)
- what do you think is better?
- difference between 88-89 rear bumper and 90-91 rear bumper
- which obd-1 t.b's will bolt up to a obd-0 dohc zc?
- new springs for crx, which ones go in front or back??????HELP!!!!!
- p54
- Light bulbs help. Please.
- Anhybody using this front crossmember?
- Rear speaker location for 1989 Civic DX hatchback
- 1990 HB parts
- flywheel i think
- whats the best front disc brake upgrade and rear disc conversion for my 91 hatch si???
- dohc zc,,,,now overheating
- 88-89 versus 90-91 hatch bumper question
- i need a timing belt for my b16a1 can a 99 civic si fit?
- p28 cel code in a EF hb
- Lowering my NO for smog??? any help/input?
- questions about h22 in a ef
- what is expected from this build??
- Well it had to happen to me ^%#*&^ Drunks
- d15b2 runs weird than wont start? help please
- How much do u think my crx is worth?
- hyperduck tuning
- Prep for paint
- Is this TRUE????
- Del Sol seats in a 88-89 EF Hatch write-up...ghetto welded but effective. Lots of pix!
- how to remove rear bumper and install
- How do i GET A SPONSOR???
- how do I make this SI cluster fit my DX?
- New seat for the rex
- How Can I make IT FAST?????
- Is it possible??????
- idea... crx rhino liner?
- i need help ASAP plz
- loose shifter, energy suspension bushings already installed
- New and uneducated
- body work estimate
- Please help!! JDM b16 tranny help!!
- worth building a6?
- need help
- EXPERT OPINION NEEDED
- wires
- where can I find this
- HELP!!! Axel broke+ motor blew up
- 88 CRX DX LCA question
- SEAT ISSUES NEED ADVICE!!!!!!!!!
- 89 dx rex ?'s
- euro spec ef gauge cluster into usdm ef civic
- Del Sol seats in a 90-91 EF Hatch write-up...ghetto but effective. Lots of pix!
- 89 crx si bought from a hack with a problem
- Bseries motor mount question
- got my brakes...
- intake manifold
- rebuilding trans
- anybody using jdm headlight and wiper switch
- Which? Sohc Zc, Dohc Zc, or a d15bvtec?
- Is this right? Wiring Question
- alternator belt keeps snapping.
- Something wrong with my cassete player
- Where to buy a d16y8 complete in So Cal.
- rails for my buddy club seat? where can i find them?
- help with swap???
- ls/vtec
- car is acting funny?
- Throwing code 20, help.
- wiring mess
- hello iam new and i need help!
- any one know what kind of wheels?
- Pricing Down A Civic Hatch
- DA sway bars.
- should i???
- CRX back seat?????
- How does this come apart?- Installing camber kit. help needed!
- i want to boost my crx
- alternator removal
- car is shaking when i stop.
- intake
- Anyone selling '89-91 Civic in MD/DC/VA area?
- Rear Lower Control Arm (LCA) Question
- Hood poping cable came undone at the hood (help)
- 93 fuel rail
- 91 4door automatic (dpfi -> mpfi)+(d16a6 motor only) swap questions
- So I turn to my real friends for advice..
- decided to go b-series
- Coolant overflow tank
- thing above the oil filter
- Welded up All of my Piping, almost ready to BOOST!
- clutch clutch clutch clutch
- My CR-Xcel Drag Car
- Vis Mugen bumper availability?
- CRANE CAPACITIVE DISCHARGE IGNITION WITH AUTO-SEQUENCE REV LIMITER
- 86 crx for 90 si hatch?
- what type of rim is this
- which brand of clutch do u recomend
- unricing painted plastic panels
- b16a and header...who makes one that fits?
- Will 15x7s with 205/50s rub?
