View Full Version : Honda CRX / EF Civic (1988 - 1991)
- v-afc and injectors?
- 90 civic hb - need a helms pdf
- i need a lot of help
- 148whp on a SOHC and more tq then a b16 :)
- poor ls-vtec CRX
- Inline walbro, now have code 16
- biggest you can go with gsr block
- removed head
- D16Y8 turbo or K20A2/A3 hatch
- USDM Gsr Head on a B16a ?
- 91 civics have rear disc?
- Favorite sohc engine? straight up or hybrid.
- AWD Conversion??
- List
- Speedometer drive after swap?
- CRX Rally car update...WRX = BAD :(
- Fuel injector
- Head Comparison A6 (PM3) vs. Z6 (P08) vs. Y8 (P2J)
- automatic Pr3?
- Rota Auto X (SSR Type X Replicas?)
- Can I use a B-16 VTEC Computer to control a B-20 VTEC
- How to post Pics from Cardomain.com
- single cam LSD?
- Add one more to the list. Lots of pics
- what hose is this? were is heater hose?
- Base Pressure?
- PR3/PW0 pinouts ? VAFC help
- ZC motor Failing Emissions Please help
- tranny problems
- Yet, a new B16A is born
- Pr3 throwing code 2??
- HELP ME Please :(
- WTB VAFC
- cant get my F'in altenator out. 90 civic hb
- Aftermarket fusebox.....?
- 94 clutch and PP on 91
- BEST CAMS TO GET???
- Seat rails question
- I need Opinion please
- problem with hubcaps and lugnuts
- 96 CIVIC SUSPENSION ON 91 HATCH
- B18C1 swap finally begins!
- Valve cover oil leak...
- Fusebox relocation...
- si tranny fu<ked? stuck in 2nd
- mini me, always off by 1/2 tooth?
- b16 swap help with VSS and some other plug
- Need some advise from the Honda guys.
- 92-95 DX head onto 90 HF?
- blown motor...help!!!!!!!!!!!!!!
- 1990 Civic Losing Compression
- Stolen!
- ctr cams b16...fuel delivery
- did swap, need help...********
- How often do you change you ef/crx oil?
- REMOVING DIZZY
- romoving bumper cover
- MINI ME GASKETS??
- h23 in a 91 hb?
- sloppy stick.
- what stock honda throttle body fits b16a1?
- jim fab crossmember sucks, wont clear my header
- 88 CRX Si what clutch should I buy?
- honda Fuel Injectors
- My 88 CRX Project Log
- USDM front lip spoiler on JDM front bumper for EF8 CRX conv.
- Head Transplant B7 to B2 ye or nay
- Trade 2 w6v2's 10 inch Jl audio and 2 500/1 JL audio amps for D series Turbo! // NOS
- I have a DX and a Si Tranny..can I make a hybrid......Also SOHC ZC question.
- moved to CO idle seems to have problems?
- New Big Brakes for the car...teaser
- b18a1 swap into 91 crx
- WTB: 88 crx front and rear tranny mounts
- attention motor building gurus...
- looking for parts for EC-3 crx
- tranny ? need help with right axels
- how do you p a jdm cluster in a usa crx and the sir rear seat
- How hard is it to put a vtec head on a non vtec motor?
- dohc zc cams
- Would anyone be interested in H22 EF mounts????
- does it Fit?
- EMERGENCY!!!!!!!!!
- aftermarket sunroof into 88 SE
- JDM Links for EF9s
- damn exhaust manifold
- 12.1:1 obd1 d16z6 leaning out at top end??
- Anybody with Edelbrock or Skunk2 SOHC I/M in their EF???
- Gsr Manifold Sensors will B16 fit
- 16x7 rims on a 1.5"-2" lowered 88 honda CRX
- New
- Best place to buy fenders
- How hot do these motors get?
- checking CEL's (searched) HELP!!!!
- 1st gen crx rust problems...HELP
- new member
- Exhaust?
- CRV crank pulley the same as other B-series pulleys?
- I just bought a mint 91 si for $500
- 91 crx si front bumper onto 91 civic hatch?
- Original Door Mouldings Color
- throttle cuts out at full temp on B16A1
- need front and rear tranny mounts for 88crx
- sohc zc tranny
- Need Mugen Sides and Door Caps
- distributor or wiring problems
- Need help finding an exhaust!!!
- B16 civic is SLOW
- zex cam in 1.5L block mini me swap
- Connection Scheme for electronic belt - Civic '91
- weight loss
- new crx si
- Post Pics of your OBDI Conversion!
- power vs weight?
- Auto to manual , need to know which wires to jump for safety switch
- d16y8 exhaust manifold on crx si?
- DOHC ZC head conversion to LS Head?
- help removing ac from crx
- Front brake swap w/ B-series motor
- Skunk 2 manifold
- Valve Adjustment tool
- How many K-series EFs are really out there?
- Instrument/tail/parking lights won't turn off?!
- Q's about clutch set applications
- speedometer switch
- wiring removal??
- hotwiring my fuel pump
- Throwing Codes. Anyone help?
- HKS A/F ratio controller
- vtec solenoid
- are there people wanting glass roofs??
- SWAPPIN CYLINDER HEADS
- Bad Valve Guides, seals, bent valves??? HELP Searched
- THROWING CODES?
- RSX Type S Bose Subwoofer install on EF Hatchback
- restless...need a starcraft CD key anyone?
- NEED HELP! Calling all D-Series tranny guru's!
- ecu chipping question
- Vacuum diagram(searched)B18A
- ? for a D16Y7
- Civic Si seat id please help! 88? 89? 90? 91?
- Just wondering what 1/4 times these cars have
- b16 ?
- sold the lude - now a ef'er , few questions.
- Intake manifold
- Type R lsd in b16 tranny?
- B18B1 into 88 crx si??? searched but every one go somethin different to say!
- WTB '89 CRX HF oil pan
- EXHAUST RESONATORS
- HELP! Problems removing oil pan on '88 CRX DX
- Diameter of rear trailing arm bushing on 90/91 CRX Si?
- Looking for CF hood
- suspension question?
- Anyone want front OEM mudflaps for a '88-91 EF Civic hatch???
- Stupid CEL
- Valve Clearence specs??
- JDM EF9 Front Corner Lights...
- crx factory upgraded audio options
- 1992 Civic LX Auto Transmission Problems
- Removing windshield trim
- Pictures of your relocated fuel pump post here...
- wtb 90 civic si seat rails
- Custom b18 header & system
- Steering Easier???
- Where to buy aftermarkt tie rod ends/bushings?
- Doing a minor swap just want some thoughts
- b16 problems
- Does my B18a make the right power?
- help with 88 crx dx
- Is it safe to drive on a burnt intake valve car
- I want to see...
- FS.... 88-91 CIVIC SI REAR SEATS
- You guys that can weld...take a look at this for me!
- ECU is throwing code 1 or code 10, how to tell?
- Side trim moldings (rubber protectors)
- Hidden Intercooler Pic
- ecu wiring
- i'm confused about b16 axles, someone help
- how loud are N/A thermal catbacks?
- HELP PLEASE
- Where do i get power for Fan?
- doing a obd0 to obd1 conversion.... whats my options??
- Someone tell me what this is!
- Don't have the money for new OEM signal... need help
- i'm thinking about importing ef8 crx sir for parts need some help
- A.C. and a DC 421 does it work?
- How to remove crankshaft pulley?.......
- CRX wheel space problem....
- oil on all spark plugs?!HELP
- bent valves?
- ZC DOHC question?
- wat car is this?
- did search but found nothing gear box oil??
- Ran into a problem DA GSR ABS MC + BOOSTER swap on 89 crx si HELP!
- My newest Toy(56k get comfortable)
- Alternator Problems?
- 89 si motor-tranny for sale or trade for b series tranny and mounts
- I got Her! Finally.
- Which axle spline teeth should I get?
- HF transmission
- need help!!! Brake master cylinder
- Modifications available for DOHC ZC
- POST valve adjustment concerns....
- $500 for a 88 crx si
- God damn ecu did a difference!!
- Type R cams, you'll need LMA's in yer' 10+ year engine....
- Brembo Slotted Rotors
- Caster Adjustment on 88-91 Civic Hatches
- Fuel Pump Issues with a STD hatch back Motor swap RRRRRRRR
- B16A1 tranny hookup
- ENGINE RUNS IF U HIT GAS RIGHT AFTER START, YOU CAN REDLINE IT , THEN U LET IT GO OT IDLE THEN U HIT
- Fly wheel bolts?
- Compression ratio on a CX block D15 Vtec head?
- Wiring 02 Sensor questions
- D16a6 oil pan...
- CRX front end flexes
- How do i get EG seats into my EF???
- is my car backfiring???
- 88 crx dx missfire problem
- Really weird electrical problem. Please help.
- FS: '91 CRX Si
- what parts made out of CF would u buy for your efs
- SPARCO Evo Seat Install Dilemma!
- wtb REAL mugen crx spoiler
- are these mats from a crx
- Seat Belts Dont Work
- How bad is my camber? I have a pic
- Corner lights
- Free Crx Shell.
- intake manifold, need to indentify sensor
- honda tech noob
- 1987/1988 Compatibility issue
- what map sensor do i use?? one on firewall or one with motor?
- Another ZC - DX hatch wiring question...
- GSR dash
- CRX SPRING RATES, WHAT ARE THEY???
- Anyone read the article on the CRX's in this months Midified Magazine?
- hf front sway
- Change of plans??
- FUCKING THEIVES!
- HELPPPPPP Integra rear seat can i fit it in my 91 hatch
- 88' CRX B16 SWAP What else do i need?
- Can i fit a 97 rear seat on my 91 hatch
- 5Spd Transmission differences from 88-91
- Value of Glass Top from EF8
- prelude to crx compatibility
- looking for new crx frame or chassis
- Can you Buy a full Da Teg b18swap from a company? where and how much?
- Hit a big bump, air vents quit working!
- Anyone have a diagram of the underhood fuse box?
- ST sway bar differences
