View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1 long blink and 14 quick blinks?
- Steering Wheel Shimmy During takes Ok at High Speeds
- ok code 1 what????
- LS swap in 88 crx HF
- Post Your EF Pictures here!! (Commenting is allowed)
- Power windows in 88 crx hf
- DC Integra cluster into 91 CRX
- CRX buyers guid
- 88 crx hf suspension
- Cluster lights don't work anymore. wtf!!
- Looking for jdm ef sedan parts
- rear disc brakes
- headlights
- Code 20 - Load Detector issue, changed 4 fuse boxes
- JDM Civic J's Racing Style Front Lip
- starting/running problem
- prelude fog light wiring
- EF9 wheel bearing help
- EF (89 DX Hatch) B16a2 Swap
- C pillar bar hardware
- buying an EF project car
- NEED HELP WITH SUNROOF MOTOR CANT FIND ANY
- Car Suddenly won't Crank at all
- d15b2
- EF9 harnest
- shimming a flywheel? help
- bout to boost
- cdm crx si cluster
- 91 civic d15b
- camber and lots of it!!!!!
- what have you guys done to adapt the FITV on to an aftermarket intake mani?
- AWD WAGON need advice on tune up
- intercooler fitment on ef hatch need help
- crx calipers
- help with zc starter!! what to use
- project and daily crx si
- ZC won't catch
- low idle bad throttle responce
- civic won't start!!!
- 91SI/DOHC ZC - cranks then dies
- help with finding the right bolt
- Rio Red Aftermarket Paint Matches?
- Looking For Motor
- Seat Belt Buckle
- suggestions for my ef!
- I think my car is dead.
- Fuel Pressure Regulator Question
- 91 Hatch Base Model B16 or ZC Swap?
- Entering the Honda World
- DOHC ZC OBD0, need igniter ohm levels.
- Custom fitted armrest for CRX
- jdm shift linkage
- aem bypass valve?
- seat belt question
- Code 15
- cc stg4
- need help finding hydro tranny conversion kit
- white smoke.
- need help asap!!!! d16z8 [HEAD CODES]
- Strut bar?
- good pittsburgh pa junkyards?
- this is getting annoying
- Dist Cap Wiring Question (PIC inside)
- CRX hatch wont close
- i got a cel code 7 tps sensor
- Those who have done the 99-00 Si cluster swap.
- OBD0 Integra Harness
- enjine transplant problems(please help)
- black hoods
- crx si differential
- steering wheel on EF
- door trim clips (ARGHHH!)
- 1990 HONDA CRX SI TRADE OR SELL 2000
- Ef color help
- 86 civic hatch (rebuild)
- need your help please...
- clock doesn't work, sort of
- Header ?'s
- Transmission issue, need help quickly
- CRX car cover
- HELP! My EF died this morning...
- 89 crx with b18a1 startng problems
- alignment ? dead shock ? tires eating quick
- Need help converting dpfi to mpfi!!!
- Best header B16 road clearance
- 88 civic wagon turn the key to on position nothing happens.
- Bolt Broke on Break Caliper
- Speedometer and Mileage stopped working.
- temp guage broken
- White CRX - dramatic photo
- 91 CRX Seat cover swap from passenger to driver side
- B20b Good for Boost??
- New guy
- crx si underdash harness ?
- Difference between hatch's in 91?
- 88-89 EF Hatch Front Seats - Aftermarket
- starter signal problem *CRX*
- b16 timing cover
- Z6 not revin pass 2k
- plz help, im new to hondas
- Climate Control
- replacing my steering wheel?
- Seat Swap
- o2 sensor obd0 to obd1
- problem with lights
- Just replace my starter bout 1 month ago!
- D16A1 head on D16A6 Block?
- crx seats into my hatch(help)
- Mirrior Fitment
- oil pressure light flickers at idle
- hood wont line up
- Help - Replacing OEM radiator with AC
- EF Sedan <3. My SLOW build.
- PCV removal instructions?
- mini me swap help
- Electronic VSS WTF!??
- sir swap
- Spak Plug Gap size?
- 2005 1.7 sohc i vtec engine
- quick GC coilover question
- boosted b16a ef no start
- rear disk conversion trailing arm bushing??
- DX exhasut help.
- gsr swap into 89 hatch what you think
- Spring/Shock combo??
- simple problem 89 civic si PLEASE HELP
- b16a swap question
- b16 vs ls question
- d15b pre swap info
- 91 civic lx died, replaced fuel pump, still no start
- PLS HELP Cranking but no start
- Help with a 1990 Civic
- Need help - Skunk2 exhaust system installation
- Instrument panel problem
- Seat-Belt Warrenty Issue
- control arm help
- y80 trans
- Instructions on setting timing, 90 civic EX
- sway bars
- Wastegate question Cant post in "Forced Induction"
- Intake Pipes.
- 1990 Civic (BLUPY) Track Car Build
- radio wiring
- civic taillights
- Cooling fan fuse always burns out in my crx.
- CRX not getting power 20 dollars on paypal to whoever can figure it out.
- power mirrors install?
- what are these side things called and where can i get new ones?
- Cold idle help
- If you had an Si Hatch w/ a B18C....
- CRX Spindle swap
- want to buy this off 4G civic!!!
- are the 92 and 91 aicv the compatible?
- huge problem?
- JDM DOHC ZC.
- help with lowering spring questions
- hybrid dynamics
- doing a mini me swap.help!!!
- Looking for an good brand name.
- need help figuring out problem with friends car
- Chassing starting prob...HELP!!
- emmisions help 1991 EF SI
- what intake to use for b18a1 swap.....state ref soon..
- replacement carpet for crx
- Z6 head on A6 block
- Another "will it fit" thread... sorry ;-)
- Is this normal??? (transmission rebuild)
- OBD0-OBD1, making my own harnesses?
- question about oil pump on d16a6
- My new car
- New to Honda-Tech
- help with fuel asap please!!!
- single cam build.
- under hood bolts
- A/C help!
- Will hatchback tail lights fit?
- D17a1 swap
- Got one question before purchasing a car
- crx code one wont clear
- Z6 swap. Wiring question.
- rpm gauge wont move??? or speed gauge
- Heater core/AC fan
- obd0 to obd1 jumper harness
- 1990 crx hf not getting spark to #1 cylinder
- radiator fan plug? ecu reading **PICS/VIDEO**
- funky acceleration OBD0 B16
- B16A Headers to B18C
- 1991 civic hatchback oil pressure
- DOHC ZC rebuilding.
- F20b in an EF?
- Valve Adjustment b16head
- b18a1 throttle cable question
- b18a1 throttle cable?
- ZC install.
- How do I remove rear seats? Help please.
- Keep blowing parking light fuse.
- MPFI Parts Needed
- Would This Fit?
- d16a6 delta cams???
- b18 shift linkage
- b series swap sensor info
- creaking sound after swap
- electrical Problem
- wire harness/obd1 conversion confusion
- best block and head ...(dd/sat night beater)
- 88-89 90-91 civic rear mud flaps
- Can I make this work ?
- 99 civic gauage cluster
- injectors always running
- p28 tuning with crome
- pm6
- dizzy help
- RPMs bouncing in First Gear
- Dualpoint to Multi-port conversion
- Weird Axle Problem ... HELP
- b20 overheat
- turns, but won't fire
- fmic question
- will a crx long block fit a d16a1
- what are the symptoms if my main relay is going bad?
- K20/k24 EF an CRX thread
- 88 CRX Si seats INTO 89 HF ?
- Guides/Books
- Aeromotive fuel filter.
- are CRX and EF steering knuckles the same?
- Help b16 code 14 eacv
- Couple of issues with recent swap. FPR??
- cali smog questions?
- i need an ef!!!!!!!!!!!!!!!!!!!
- vavle spring hight
- Help with Cruise Control?
- HELP!!! SERIOUS NOOB QUESTION
- torque settings
- Oil leak help
- High idle on startup even when engine warm?
- mystery overheating issue
- Distributor help
- seats help!
- Starter Spinnin but not kicking. HELP!!
- Shift Linkage question
- Compression Test Results!!
- Low-Fuel Light
- axle question for a b16a swapped crx
- OBD0 Distributer Coil Wires
- pilot bearing
- APEX'i N1 vs. HKS Hi-Power vs Skunk2 Megapower
- JDM EF8 SiR exhaust
- Radiator question....
- FS: Mugen Ecu obd-0, LSD cable tranny
