View Full Version : Honda CRX / EF Civic (1988 - 1991)
- BODY KIT question
- b16a into 91 civic dx
- Not sure whether to buy an EF hatch nearby or not.. opinions wanted
- Caliper messed up?
- break pad install question
- found deal on 86 si hatch, sound good?
- Anti-Freeze draining, wheres the bolt?
- Will some civic obx headers fit on my stock hf?
- my distributor went out again today!!!!!!!!!!
- How do you install a fuel pressure gauge on a 91 CRX?
- 88 crx si can i use 89 crx si engine harness if not can i convert engine harness?
- Si head swap..
- Squeaking rear hatch/truck
- what is the diff between obd0 and obd1/2 dizzys?!!?
- Anyone know where to get cheap bushings?
- jdm climate control....
- b16a1 help
- Brown CRX interior on Ebay
- stainless steel or ceramic coated headers?
- brake booster??
- HELP!?!?!?!?! hook pos. cable on battery and starter kicks on??????
- p28 code 9/16 and safe mode?? help please.
- I want to turbo my d16a6, what would you do with $2k. fuel management, turbo, etc...
- Crx Online Manual pdf please
- Parting Out B16a1
- HELP seat beeper and light
- What kind of EF do you get for $400.00?....Well...see for yourself
- uh b17a1 in a 90 crx
- Ebay headers question...
- will a 91 Civic Si cat fit on an EM1? (00 Si)??
- York County, Pennsylvania Emissions Inspection or decal?
- d15b
- Help?
- tire size
- looking for two front shocks ASAP any brand
- Worth Replacing the mounts on D-Series Swap?
- *Sigh* Yet another camber kit topic. (Searched)
- Need info on swap
- Free! Online! Legal! Honda CRX Shop Manual
- Just replaced clutch....still having trouble...
- eliminating charcol canister and evap
- What color should i paint my car?
- my new car.... well new to me at least
- quick ecu code flash question
- Ground Control
- Suspension acting funny
- 87 crx bodykits
- Axle Popped half out, now wont come out of trans???? 6ft prybar..nothing help ASAP!!
- where could i get door keys made?
- WEIGHT QUESTION????
- Engine won't start! Help!!!
- sohc manifold to y8 manifold questions
- holes inside throttle body...
- IS THERE ANYONE THAT LIVES IN MICHIGAN??
- DAMNIT, NO HOT AIR!! AND "OVERHEATING"
- been Searchin but no luck please help!
- crx si seat fitment
- ls v-tech
- aftermarket radiator question
- Honda Civic / CRX SI and EX (using 40mm bearings only) ?????
- Crx tps
- Just a quick clutch question
- who has the omni power coil sleeves on a CRX?
- Emission Test tomorrow!!!
- Short Shifter Compatability, which to use b16a/90crx
- swap for integ brakes or aftermarket brakes?
- $50 for a CRX
- A rather large gift from the JDM gods!!
- help: DA suspension on CRX
- k series swap
- Just got B16A powered EF Hatch, what do you all think?
- GSR Leathers!!
- 3 inch Thermal on all motor car?
- Sound clip of Thermal R&D Exhaust
- will a d15 head and distributor work on a d16 block?
- vss ????
- what is this plug on the back of the blocK? b18a
- dizzy plugs?
- aem short ram whistle noise??
- Fuel Gauge Not Working *searched*
- electrical problem b16
- Simply curious about scissor doors
- Axle wont go in!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- what kind of oil and how much
- complete swap list for b18a
- About to pick up a crx... need ur opinions...
- clear bumper lights for CRX SiR front end?
- chassis black?
- PIC request backside of 90-91 CRX Si rims
- where to get a CRX JDM front end in Canada?
- PIC REQUEST: Clutch cable
- Setting timing on a 89 CRX w/ PR3 B16
- Electornic VSS
- quwstions about 88 crx
- TPS
- need full CEL trouble code for a ZC
- 88 dx hatch trowing codes.
- pully removal
- leaking fuel filter
- ran off the road and the car over heats wtf?
- DPFI to MPFU to OBDI in the future
- 2 questions
- mini-me radiator hose question
- Water leaking into car
- NO ONE IS GONNA BELIEVE THIS!!!!!
- boggs on acceleration
- i'm an idiot, help me out...
- ex knuckles?
- Need help ASAP, project is almost done
- TO TINT or not to tint :crook:
- What injectors to used for turbo t25 d16a6 obdO? DSM injectors? help
- need some help
- PAIN in my ASS!!! Please HELP!!
- Couple of STUPD newb questions.
- water pump issue
- my brakes are locked
- NO VTEC
- car is missing dont know why~!! cant fix
- What do you think I should do? Sotck or Not!!
- need help with guage cluster
- Hissing sound + Brakes are rock hard + car dies when come to stop
- do i have to use an obd1 dizzy for my obd0-obd1 conversion?
- My "new" front end.
- 90 Civic EX exhaust question
- BLOWN B18A, WHATS NEXT???????????
- Replacing a clutch cable
- lowering help
- Jumped the curb and bent the suspension. Is this repairable? Frame damage?
- engine bearings
- Fluidyne fitment question.
- ~** JDM D15B? **~
- 90 Crx "SiR" JDM Front End, USDM front bumper? *pics*
- ?problem?
- b18a affordability,help me clear this up
- ok quick its goin to happen tomarrow b16 or single with turbo
- 16 18 22 motor mounts used - How much they worth?
- ef car covers??
- Civic with 5zigen FN01R-C?
- HOW LONG?
- intercooler piping
- guage cluster need help
- Problem: My car sounds like sh!t after rain
- Mysterious Smoking Problem
- i can smell rich gas on my car...
- FS: 89 CRX SI with B16 Swap *Tucson, AZ*
- Help with ITR intake manifold on OBD0 b16a in CRX *searched*
- Parking Lights On
- prothane bushing kit for 91 hatch
- Is the factory oil cooler (ZC) worth retaining?
- Homecoming: My 3rd EF...first CRX...idle problem?
- quick simple question CRX cluster VSS --help
- Don't put the wrong trailing arms on your shit.
- How to take the fender off
- Need help on fixing dents
- name of the other ef site ?
- dpfi to mpfi
- 1/4 times on a d15 non vtec hatch
- tranny question
- Integra springs on EF?
- whos got nuespeed race springs?
- B16 (lsd tranny) into CRX - PROBLEM WITH LOW REV LIMIT
- Need help getting my car started
- Car died after hitting brake? SEARCHED
- crx check light is on
- Beware of Dynotuned in Madison Wisconsin!!! They are scammers!!! www.dynotuned.com
- AGX broken or OK?
- Swap 88 fuse box into 91???
- problem getting into gear
- EF JDM Amber Corner light
- EF Euro Complete interior (With front and rear headrests)
- my future set up
- how physically durable is the ECU?
- D16Z6 CRX SWAP(wiring harness)
- EF SUSPENSION?
- How much does a b16 swap go for when all is said and done..?
- *searched*mpfi
- How much can I get for this?
- Replacement For Upper Ball Joint?
- Anyone want to buy integra ls leathers grey (not gsr;s)
- front camber kit
- Brake master cylinder?
- May buy a $400 EF
- So will these disc brakes for the rear swap right in?
- shock question
- stupis rain
- 88-89 Taillights
- can someone help me
- Running Rich, Sputtering-bogging??
- I want a super quiet exhaust system...
- lip question
- whats the difference between 88 si tranny and 89 si tranny???
- 198,000 d16a6 turbo?
- Run with NO crossmember..?
- how can i tell what year gsr tb i have
- Big brake up-grade for CRX
- looking for crx leather seats red stiching
- where can i buy new dc header or greddy header from online for my d series motor
- EF9/EF9 question
- dual proportioning valve help!
- dpfi to mpfi?
- need rhd ef wiring , for climate control
- AEBS manifold throttle bracket
- B18C6 (c5) and obd1. which map ?
- 1990 CRX SI Body - Any Interest?
- smog????
- B16a Crx Swap Guide
- Any Rexers In East tennessee?
- Ive come to a decision
- gauge cluster swap
- Interior, tail and corner lights not working...
- Hazard flashers not working properly
- b16 or minime swap
- Over kill
- Spoon front strut bar on crx????
- what the best tranny to use
- need a new Crx Fuel pump
- hey all..
- *** JDM D16Z6 in a HF with a TD05 Turbo??***
- B16/STD1/4
- DPFI TO MPFI question
- zc obd0 to obd1 swap. what ecu? searched
- dohc zc turbo honda crx
- FOR SALE!! VIS carbon fiber hood!!!!!!!.'.'.'.'.'.'.'.'.'.'.'.'.
- 95 gsr cluster into ef
- VTEC?
- dead pedal? how to remove? HELP
- 91 to 88 dash question/problems
- ?D16Z6 swap into HF with TD05 turbo?
- Idle problem :(
- What parts needed for d16z6 upgrade?
- ZC crx
- ATTN: Mugen shift knob owners! How-to align logo inside!
- Boosted CRX for autocross/road racing how should i begin?
- mini me or upgrade d16a6 i already have i/h/e
- HOW-TO: DIY CRX cargo deck reinforcement
- crx invadia exhaust on hatchback
- WTB: knock sensor
- which mounts vibrate the LEAST?
- emissions n vafc
- Fuel pump voltage/problems
- B16a bogging down..
- Cable to hydro conversion questions?
- HOW TO: DIY Pop-up security box for CRX
- JACSONVILLE/ORANGEPARK EF SEDANS!!!!!!!
- remove air conditioning?
- Q about mugen shift knob
- aftermarket differences in b16 question
