View Full Version : Honda CRX / EF Civic (1988 - 1991)
- How much interest in BLACK ef squad shirts?
- Eibach spring rates, I need help fast!!
- please post you crx si pics
- Help: Intake manifold question
- GSR shifter fitment in crx
- 2-3 grand stumble on a ZC
- D16a6 block w/ d16z6 or d16y8 Head?
- B16 intake and H22 T/B problem
- Throttle body question (help)
- Engine Stats
- which is which on my b16 clutch woes?
- Rev guage problems help !
- what front mount when using hasports mounts can you use???
- Any resto catalogs for our cars?
- need crx pic bad
- ED9 to EE8 suspention swap. Running into troubles!!
- door mount seatbelt to other option... anyone try it?
- where to buy carpet for hatch?
- skunk 2 cams
- swapped the d15b2, but now wont start...any help?
- How much does an OBD 0 B16A ecu go for.
- Fuel Pressure reading for stock D16a6?
- what should i do?
- question about EF Civic seats brackets?
- just baught a 91 ef for 50 bucks with a blown motor..have some questions
- Smoking Problem............LONG Explanation
- CRX seat rails
- window problems
- Removing seats for Re-Upholstery....
- Hydro B-series ef's Please Help
- D16z6 vs. Mini Me
- Help with B16 shift linkage?????
- what will i need?????
- h22a4 in an 88-91 crx?
- how to check for spark... without anyone's help?
- camber kits?
- Online Parts Distributors Sources
- Which MC to use?
- Nissin caliper codes, a site? a list?
- 93 Civic DX stock/original 1.5L motors idles up, and down, up, down?!?!?!?
- AGX or Tokico?
- 88 civic hatch dash removal
- B18 CRX Throttle cable
- Niagara 9 ???
- Need help with HASport linkage...
- 4th gen engine mounts ??
- Hissing Gas Cap!
- b18c in 89crxhf
- CRX wipers suck! (keep hitting side of windshield)
- what do you all think should i trade my crx for 92 hatch???
- Head lights
- Friendly D16a6 VS ZC debate
- Available strut bars for EF/CRX's?
- Getting ready to order my ZC from hmotorsonline
- 1984 civic (swap)
- hood inclination between hatch and 4door
- difference in seating between 2nd gen crx and 5th gen HB
- What shocks to use with h&r's????
- fuel pump
- Need to settle a friendly argument about side view mirrors on 4th gens!
- What engine is a drop-in replacement of stock 91 CRX Si?
- code 43?
- just curious
- pic request: obd0-obd1 harness
- I need a hose if I remove my A/C?
- weight of the dohc zc?
- Question on tachometer...
- :\ Just a fast question...
- crx 1989 suspension swap
- Who from this forum is heading up to Hot Import Nights in PA on 3/15?
- zc info
- Real turbo kit for 88 crx /dohc zc
- Help on my back hatch
- 88/89 weights/hp/specs
- o2 sensor replacement...
- Taking A/C system out. Help plz.
- D16Z6 or ZC ?
- JDM Headlights with HID Conversion?
- Heat won't work anymore...
- NEED HELP ASAP!!!!!! b16a wont start.....
- Motor Mount installation
- what can stand alones do?
- Pics/Video of my 1991 Wagon Beater
- Putting a D16Z6 in my 91 crx si, Using a V-AFC to activate v-tec... quick help.
- Clutch to flywheel fitment issues, any help is a HUGE Help!
- part # timing belt b16a
- fuse question, thanks.
- JDM front end fit?
- 91 CRX: Will it effect performance to move o2 sensor from header to under the car on an aftermarket
- D17 crank into twincam ZC
- Rear engine/tranny mount
- getting pins out of black clips to ecu?
- do ef's seem more popular now?
- clutch trouble
- rotor size
- question about rear disc swap....
- stock shift linkage with b18a
- where do i mount temp sensor?
- Free AEM Intake
- The mugen sports meter kit
- b16 gas milage?
- Which header should i get? for Y8
- what is the diffrence???? hks exhaust question
- can someone post instructions on how to remove/swap steering knuckles?
- Can I get a VIN check on this CRX, purty please?
- Y8 intake mani install, but i have one problem *HELP*..... *pics*
- PR3 w/Z6 question
- Advice on adjusting coilovers
- my car cant warm up
- jdm front on a crx
- fuel pump problem?
- eibach pro-kits vs stock springs, how different?
- stuttering with the b16
- quick question. wiring vtec into crx
- tial wastegate hitting hood
- running intercooler piping can anyone post some of their pics to help
- you guys have to check this out!!
- Where do the ground wires go!!!????
- Cooling fan fiasco
- ZC vs. SI
- good deal for block?
- Ingalls camber kit instructions and info for future questions
- h22 crx
- how much can a d15b bottem end take?(RPM's and HP)
- B16 wiring question.
- whats a good price for a 90 crx si
- Anyone know where to find one of these??
- d16z6 block w/ d15b2 head
- what does an aftermarket TB really do?
- Injector impedence questions.....problems.....a little help please
- Just curious, what would happen if I didn't swap the steering knuckles on my HF...
- civic si knuckles for b series swap?
- Swaped cluster on my hatch put in GSR cluster now......................WTF!!!!!!!!!!!!!!!!!!!!!! !!!!
- Looking For: OE GloveBox Civic Si (black)
- who has the most mileage?
- questions on injectors.
- My "Hyperducktuning" opinion!
- is this my problem???
- crx weight reduction & factory weights
- 1997 Civic to 1990 Civic parts
- New ZC cams, European source ?
- B16A/EF Smoggability Question
- How can you convert a crx to 5 lug? and actually do it right?
- Bypass knock sensor.
- Searching
- Where is the PCV on a 89 Civic DX?
- Help Lowered Suspension Control Arms Hitting?
- Need help with clutch and throttle cables...
- Swap update...
- Looking for B16A JDM engine componets
- intake manifold
- low voltage :(
- nobody cares about the 88-91 hatches anymore
- idle screw?
- Axle Seal being a b&*ch...
- edelbrock intake manifold
- JG manifold in an EF ?
- Need OBD2 P72 96+ GSR ECU pinout wiring diagram!!!
- Trannies
- My car has a gremlin WTF??
- crx b16, need heater hose
- just lowered car now it rides like $h!t
- just learned my SI used to be an HF....
- 0.6 bar i will nedd to do any change on ecu ??
- any interest in mounting kit to put crx seats in a civic?
- zc gurus...question for ya
- Resistor box, a question concerning swap...
- need the divider for 88 crx
- Upgrades for B16a in 89' CRX SI
- b16a sucks
- Need center console for 88 crx blue, and door panels blue
- What is a better bore for running N/A???
- Why CRX/Hatch (4G)?
- couple of questions about my swap
- idle problems?
- how will kosei k-1 racing wheels fit
- 89 integra(PG7) ecu giving CEL 4
- b16a front clip
- Climate control doesnt light up, HELP!
- did i screw up my car by starting it with the crank pulley off?
- Need a fuel pump...
- euro type-r?????
- tranny and clutch Q's
- crx with h22 or 23
- Front LCA's
- want to buy 88-91 crx climate control
- Honda GURU's please read
- gsr in ef/ hood problems??
- Engine codes
- what kind of track times can I expect?
- 4th gen sedan exhaust ?'s
- adjusted valves to factory specs, and now my idle wants to die.
- I need help plz.........asap
- is it normal ...
- Sohc Vtec swap or b18b??
- 91 civiv dx w/b16 code 9 cel
- Fan not working.. help
- Searched w/ no results: What does the stock 91 crx si flywheel weigh?
- 95 civic coupe springs??
- Fiberglass hood
- Quick question about axles!! Please look.
- My stock track DX times
- D16z6 Swap Q's
- JDM J1 Tranny Gears into a 90 USDM LS Tranny?????
- Just got some Sir corner lights
- Is the vtp the green plug or white plug?vts?
- car keeps dieing
- crx ls how fast
- couple quick questions.
- Sorry..Can't Post In classified..tons of parts
- Will EK springs fit an EF
- what intake manifolds will fit on a DOHC ZC?
- Air Ride 4 92 Hatch
- Does the crx dx come with a 5-speed??
- Camshaft effect on compression?
- 89 Accord Struts on 88-91 CRX...
- Cleaned up head, now nosiy as hell, any ideas?
- this is my setup am i forgetting anything?
- pic page help
- Type R Injectors
- Lowering Springs
- CRX seats into Civic - How To
- difference in blocks (only blocks not head) d16a6 vs d16z6
- d15b v.s. b16a???
- Noob question
- fuel filter question?
- WTB, Civic 88-91, 90-91 SI prefered
- JDM EF9 Bumpers
- ECU Code 13 fix?
- 87 Crx Si engine swap
- Si to SiR speed sensor?
- fuel pump check???
- whats the difference between the d15b2 and d16a6 trannies?
- Burning oil, smoke only at idle, valve seals?? worth it to replace? help please!
- d16a turbo HP & 1/4 MILE TIMES?
- big problemo
- Sell my teg to fund a B16 swap??
- AWD or RWD Crx Can it be done with a b series motor?
- How much did you pay for your swap?!
- Crx exhaust Ideas ....89SI with 26mm sway bar in back need help!
- ? about aem fuel rail
- '87 crx si idle issues
- 30-1000 AEM EMS in crx/b16a
- D15 Questions
- checking pricing
- AC fan necessary?
- 2 quick questions i need answered in 30 minutes
- Comments on the HKS Sport Exhaust??
- how hard to get a NA d16a6 into the 14's with stock block?
- looking for itr seats?
