View Full Version : Honda CRX / EF Civic (1988 - 1991)
- EF Squad Stickers/ Decals?
- Strut Bars
- Need help choosing an exhaust system for my 91 XSi
- I need help finding the jumper wires to read ecu codes.
- pic request: b series hydro trans internals (searched)
- qestion on z6 parts
- omni power lca
- crx si seats into ef hatch
- 1987 civic, bseries swap
- Supercharger or Turbo
- ef/b18b egr setup ?
- Thank God for Clutchlocks.
- What size tires does a UKDM 1.6i-VT run on stock?
- Auto Trans Compatabilty
- Throw out, pilot, mainshaft, countershaft...
- short shifter for a B16A1?
- OBD1 - 4 Wire o2 Sensor to ECU
- what is an engine block made of?
- 2 CRX's keep em or sell?
- Swap question
- Has anybody ever put a jrsc on a d15b7?
- Which Clutch??
- B20A5 Tranny on a B16A... Opinions?
- Odd clicking sound Any advice appreciated
- Crx LEAking tranny, and bad alternator
- b20 vtec question...where to get bottom end kit
- Rear Disc Conversion
- 89 crx HF with a 91 si intake and a z6 long block
- How Much Did Your Swap Cost?
- Throw out bearing
- 88 si had spark put in a motor and now no spark
- ugh another ecu question :)
- vicor x manifold questions...yes i searched
- stoker kit
- how much boost?
- 90 Crx with b16 choking out
- hatch cover
- CEL (Dash) Rapidly Flicking - Fuel Pump SOMETIMES Primes - Car Wont Start - Motor Swap
- swap problem... no power
- i need help with my car problems
- how much 134a does a 91 honda civic 1.6 take?
- Tach in 91 hatch dohc zc
- 88 CRX SI Fuse Diagram
- Newbie question(difference between 1.5 and 1.6)
- plz help someone
- iacv or iac valve on a obd0 b16a swap in a crx?
- i think i firured out how to post pics......lets hope this works...lol
- Mugen style front bumper questions
- A couple ?'s about DPFI to MPFI and what head and dist. do i have?
- ZC in 91 Civic Hatch
- were is the eacv plug in harnes located???
- Car comes out of gear...
- D15A2 Honda CRX HF (Carbed)....
- found a car what do you guys think?
- Is there a gasket...
- 96 civic 4 door??
- What brackets do people use to mount racing seats in 89 civic?
- Where can I find adaptor for oil pressure
- Whats In Your EF?
- Stock EF8 lunging forward without foot on gas
- Air con harness
- Need help with injectors..
- B16a Clutch
- How to remove Headgasket needed
- eg half size radiator into civic
- 1991 Civic FRONT END CONVERSION!!
- Gauge Cluster..
- Project Mini-Me Catastrophe!!!! HELP ME
- Hiding my overflow tank.. Options?
- Help! Water leak on the rear hatch
- Forum policy and etiquette
- DOHC ZC Valves Questions?
- would i be able to swap an h23 into my 88rex?
- Question from a Crx Noob, I admit I haven't a clue.......
- fuel pressure regulaitors
- gasket
- d16y8 intake manifold help putting on
- What factory airbox works with b16a?
- 1990 Civic EX Sedan Help
- what knock sensor can i use for the b16?
- Which motor mount bracket is needed for b16a swap(one that is on the back of trans)
- D15B
- WHAT TO DO TO MY CIVIC ?!?!
- Need help with EDM LHD Power Window install
- rubber moldings. can i get plastic replacements?
- Problem with oil pressure gauge
- B18c swaps, what header are you running?
- jdm b18b or b20?
- 3g integra sway bar
- *Lets see Skunk2 and Invidia N1 Exhaust pics!*
- high idle
- b18a1 wont rev over a certain point 1800 to be egsact
- Cam Gear Issue
- old civic question
- crx b18a1 obd1 ?
- help 92-95 front end conversion
- Clutch Arm movement/ trouble shooting
- NEED help on this front spoiler
- z6 intake manifold on a 88 hf
- Fuse Keeps Blowing what's goin on?
- 1.7 liter swap
- Power steering/'91 hatch/B18
- ED clutch pedal assembly
- bad dizzy rotor?
- b20 swap in 88 EF hatch... AXLE SNAPPIN!!!!
- how shorter does my shiftlink need to be???
- Brake Issues
- OEM CRX Si lip fit Hatchback front end?
- What valve cover is this?
- block guard welding
- B18C-R EF9 VS EVO
- After a couple of hours checking my car i have some serious question.
- Shift linkage question
- Rough cold start / bogging / hesitation when cold
- Thick White Smoke..no contamination.
- why doesnt my heat work?? ive checked a bunch of stuff already
- Where to buy amber bumper lights?????
- clutch?
- seats? - and other parts.
- need crx exhaust advice please...thanks :)
- Searched but cat Find. Please help.
- EF9 JDM window visor install help / instructions
- Free HF seats.
- gauge cluster
- CRX B16A1 sawp+turbo+VAFC2=????
- obd2a dizzy adapter where can i find one?
- JDM ITR recaro's into EF CRX ??
- Looking for help with mini-me swap in CRX DX CA$H MONEY!!!
- Whats the worth??
- head gasket leak
- vtec problems
- ls vtec or gsr
- TRANNY CODE
- crx lips and hatch lips
- F-R Rad on Innovative Crossmember
- is this right?????????!!!!!!!!!!!!!!!!
- Greddy header from 00 civic?
- b16a swap, i think the iacv, iac valve (what ever its called)
- WHITE SMOKE
- Has anyone weighed the rear drums VS rear discs?...
- 1991 CRX HF with B16A swap for 200$
- Moroso Oil Pan (Alum) - How Much Oil? Dipstick Accurate?
- Found some cheap EF8 mirrors
- Is a 15.8 pretty good for a stock d16z6 swapped 91' dx?
- light soot in dpfi top throttle body
- ls-vtec cutting out
- engine swap update
- heater
- gauge mounting
- idle question
- OBD 0 B16 into '90 CRX
- oil leak problems. PLEASE HELP
- b16a2 obd2 has anyone tried to put this in a integra???
- eg parts on a ef?
- 91 Civic Project! NEED HELP WITH ENGINE SWAP!!
- new bearings
- Question about my build
- VTECH head on nonVTECH block
- need a part # guys..
- 4x114
- removing wheather stripping
- Original CR-X Mugen Kit Badges Wanted
- 94 civic ex
- b16 wont stay started unless foot on gas????
- b16 running rough,,,, I only used one o2 sensor, but not throwing any codes but code 4
- wagon WON'T STAY RUNNING!
- axle stuck in hub
- How do I post pics?
- Civic Wagon Suspension
- Quick Is this my VSS?
- surging then it wont start please help
- Question on wheels.
- Car over heats when at a stop...? NEED HELP
- help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!!
- EF FUEL PUMP FIT EG?
- EF QUESTION!
- alrite here's the deal...
- **HELP!! just put my d16a6 together, timing is right, still runs rough as hell!!!***
- apexi auto timer install ?
- double cluchers check in
- manual window diagram
- ? in regards to seats & rails
- LS to GSR swap
- DOHC ZC will not start! Problems starting.
- CRX HF was a 1.3L?
- ZC valve adjustment?
- Distributor question...help!!!
- CABLE TRANNY SEARCHED
- well guys it was fun .........
- EF Civic Dash Swap?
- Let's see your aftermarket seat
- 1991 Civic Si lsvtec project car
- 88 civic ef hatchback takign off dash help
- Timing Belt Install - Align To Single Crank Mark *NOT* The 3 Marks, Correct?
- b16a,PR3,obd0, CODE 4??????
- zc swap into 89 hatch question
- Knock sensor on the green plug it has two wires coming out of the plug???? tap into which one...
- B16a swap running, but check engine is on and it is throwing code 4 ???? I tried swaping around the
- how do i get rid off all of these hoses
- JDM EF8 Fog Lights
- Front LCA ???
- Should I sell my EF9 b20vtec??
- crx si stock intake
- Just bought a 91 crx
- a/c problem need advice!!!
- Painted my high beam side headlight yellow....
- problem with vtec
- 88 HF crx with B18a swap, got any ideas
- tein coilovers
- not geting any power???? help
- Some nice info
- how do i know what year my parts car is?
- USDM CRX window visors.....
- 00' SI front and rear brakes into a 89 Crx?
- D16Z6 head on 89 D15B2 block?
- converting to odb1
- comp #s need advice
- vacuum line problem?
- Power steering add
- Help VSS broke!
- EF Front Camber Kits
- I think my engine has a small oil leak. am i right ?
- Chip burning.
- 92-96 header for b16?
- cel help when changing ecu's
- B16a crx swap, clutch problem
- Knock Senser problem
- could use some help
- nitrous systems question
- need quick reply! will an 86 crx carbureted engien valve cover fit an d16a6?
- rear driver side triangle thing
- dipstick problem (weird one)
- lost C-clip on rear quarter window
- Can I use my VAFC II to help me save fuel?
- Intake Manifold gasket question?
- weird stuttering and idle problem.
- Who did some wire tucking and kept AC?
- '91 Si Hatch lip on a '91 Sedan
- Y1= YS1, S1, A1 can some parts enterchange
- B16a swapped CRX slower then Civic?!?!?
- carbon fiber cargo cover???
- quick question on starter
- need help with uberdata
- TIE ROD BUSHING QUESTION
- 1991 honda hatchback dx question
- clicking fuel injectors?
- zc downpipe fit si exhaust?
- Someone post a picture of your engine stamp that says "B16A1"
- Holler at your boy (noob)
- Need some help with O2 sensor and these plugs:B16 CRX
