View Full Version : Honda CRX / EF Civic (1988 - 1991)
- my turbo 4d ef having some problems
- d series: thermostat housing is it threaded?
- WTB ex cluster
- Does anyone make.............
- e non a/c radiator ok?
- Swap ?'s
- zc head gasket help please
- 94+ ls seats in a 89 sedan. ?'s
- CRX problems
- crx wont start
- Removing impact Beam for Intercooler... Good Idea? PICS? How Do You Mount Bumper?
- B18 swap turbo manifold.. can i save my fullsize radiator?
- ust switchrear disc conversion
- A few pics of my Mugen EF9
- MRA4886's ef sedan build thread.
- EACV/IACV Problem...Can this be fixed?
- looking for: how to install JDM cluster w/ electic speedo into 91 civic. ***searched
- New starter. Still will not start. :(
- Heater/blower dont work.. HELP??
- I need help fixing up my seized rear dum brakes
- Crx swap question
- rack querry
- front bumper
- Intake manifold swap
- honda EF OEM/JDM foglight kit?
- b16a2 swap crx dx wont start..please help!!!!!
- got a few questions b16 and suspension related
- d16a6/d16y8/d16z6/d16a1
- yes i know ebay manifold= no good but this one looks decent.
- Exedy clutch actin a fool
- front fork question...
- ANYONE IN NORCAL DONE MULTI POINT SWAP???
- Please help...
- Wiring Diagrams and Harnesses
- My ECU taking a dive on me?
- in RoNeed to find a Good shop in Miami!
- turbo oil cooler on h22a pros and cons
- speedo questions
- anyone got one?
- e Any CRX's with 88-91 Civic center consoles?
- ckp cyp codes 4 and 9 CAR NOT STARING
- Auto 2 Man??????
- I have cruise control in my EF Civic!!!!!????
- Injector question, could be serious
- most common swap mistakes or problems?!?
- headgasket replacement
- HELP! B16a will turn over but won't start.
- Ebay $700-1000 turbo kits.
- black interior in 89 sedan
- Hood pins on EF9 hood
- Swapping B20b into 91 civic Wago
- questions bout turbo kits
- Supercharging a 1991 CRX Automatic?
- need help with turbo timer install, b16 head swap, and koni yellows/H&R springs, and Head Repair
- Need help deciding.... B20 Swap or JRSC Sohc vtec in my 90 Crx si
- o2 sensor question crx b16
- Ebay cats
- JDM Parts
- No throttle Response when GAS IS PUSHED DOWN HELP!!!!!!!
- b18 ecu in my rex
- rear bumper question
- Cutting side the markers
- Need Input: MNS Prototype CRX front lip ( 50% complete )
- Innovative Mounts issue.
- dohc zc tranny and 88 crx tranny the same??
- Need an opinion of price.
- need some wiwirng links quick!!!!!!
- lowering spring problem
- EF_SEDAN tuRBO (AUTOMATIC)
- What year mudflaps are these?
- Need help finding out part name or Number
- i cant deside which to buy
- what is Rocker Arm Ratio? where to apply it,
- Clear head light for ef lovers (just an example)
- car wont start
- how to check engine light??
- b16a1 dizzy rplacement? asap
- New member saying hello.....
- problem d16z6 sputtering and stalling
- Car already swapped. What do I have?
- mud flaps, standard or option?
- Side markers for EF hatch
- Ebay coilovers or not?
- EF9 front end conversion
- TOKICO illum. help
- sohc turbo question
- new to the crx, just bought one, got a few qusetions
- confused and wary
- oil on plugs
- Prelude Harness in civic for h22 swap?
- even worth the money?
- what rods to use?
- d15b7+auto tranny work w/ my 89'dx auto?
- (non techniacal) IS there any 88-91 civic coupe made?
- The E-break is moving up
- what size piping for exhaust?
- civic and crx dash.
- D15b non vtec wiring harness question
- hatch si swaybar questions?
- gas mileage???
- all gauges wont work
- 91 crx and civic hatchback dash?
- Seat belt problem
- Fuel problems
- my battery keeps dying!!
- Code 9 - Cylinder sensor @ Honda Crx OBD1
- Symptoms of a bad o2 sensor
- Code 9
- stock with custom piping
- Have a plan what do you guys think...?
- Do I need to change fuel pump?
- B18C5 Swap, Driveshaft Question
- Climate Control Fan Settings. 1 doesn't work, 2,3,4 do correctly. Hypothesis?
- Buddy Club Spec II Exhaust
- ENGINE FIND
- tranny and ecu
- car wont start
- Skunk 2 Intake mani
- wiring harness
- '88 wiring issues??
- code 2 problem
- how to pull code?
- searched couldn't find anything.
- anyone make a directi fit wiring harness for trailer lights?
- fuel millage problem, b18a swap
- cross member
- JDM Italy from German?
- b16 parts list?
- b20 w\ b16 tranny
- New CRX project..not what you think..
- Transmission part number
- need help
- EGR Valve replacement!!!!!!!
- crx problem
- crx question
- Paint me yello
- b16 and stock exhaust
- fan switch help asap
- someone give me input
- ignition module
- Intake and Exhaust Valve possible problem?
- d15b direct swap to 86 crx
- head
- pistons work w\ cams
- are ls plug wires sufficient for a b16?
- Pray to let it spray
- Very Weird Problem help please
- 90 civic speed sensor wire's
- piston swap
- ZC Smog question for Cali ef owners
- Need Help Temp!
- possible axles issue?
- 91 EF SOCH v-tec for sale
- Will a FPR increase my fuel comsumption?
- battery relocation. searched
- i need some help removing my seat belt.
- Stuck coolant hose removal
- Looking for midstate ny powder coating
- D16A6 Cylinder Head Parts Questions
- 88-89 Civic fit 88-89 CRX?
- Honda CRX: Significantly worse than average crash test rating
- teg cluster in a ef
- keypad starter kill problems
- ODB0 and ODB1?
- Engine.
- TURBO AUTOMATICS EF_SEDAN
- MPFI SWAP NO START!!! HELP
- smoke problem!!!
- Sir blinker
- Car starts but wont stay running??
- Ignition switch question (searched)
- Will the jdm ef8 SiR lip fit usdm ef8?
- anybody ever get the explicit racing D-series mounts?
- oem rsx cd player in 90 civic?
- NEED HELP PLEASE...
- stupid vtec question,,,
- A6 rebuild
- dizzy question
- Ef w/b16a Runs like crap after warm up please help
- ebay cluthch
- EASESHORT SHIFTER IS LOSE AND WONT CHANGE GEARS
- 91 ex.... b16 swap question...
- need help!!!
- 88-91 CRX Si engine harnesses all the same?
- password jdm si-r front lip
- Rywire STD to D15B/D16Z6
- In what order to install the a/c?
- b16 clicking sound from head?
- EF JDM FOG SWITCH?
- mpfi swap problem :-(
- oil leaking thru exhaust
- Looking for info on D16y8 Intake manifold on 92-95 D15 Vtec
- axle nuts on crx
- How do you put this trim piece back on?
- Cant Turn Key In Ignition
- IDLE ISSUES PLEASE HELP
- password lip
- help motor install!!?
- ne I need some help!!
- DOHC ZC parts
- Need some good ideas
- weight reduction
- WHY IS IT
- B16A swap help
- 1985 Carb Civic won't start
- transmission fit?
- throttle body
- vtec solenoid
- 90 CRX HF keys worn out
- ex dizzy = si dizzy correct?
- Harness Question
- A little help please
- water pump gone??
- gauge cluster question fuel gauge problem
- ZC transmission modification
- BseriesKllr's Project: 4 Doh's fo mo Ho's lol
- 90 CRX Si rear hub replacement
- Updates on my AWD turbo wagon!
- b16 boosted
- No cluster harness?
- b16 thermostat??
- car wont stay on...
- b16a crx runs weird...
- obd1 Dizzy leaking oil
- CRX feels like its gonna break, missing 2 bolts in chassis up front????
- i need to know stock b18a1 fuel pressure at fegulator
- full-race traction bars and radiator fitment??
- oil pan gasket
- tranny men!!!!!!!!
- B16a into 91 civic lx
- Help Please!! Mini Me rev/miss problem....
- Hood question
- tenzo r bolts
- HID--->HELP!!!!!!!!!!!!!
- crx seats
- need a d16 asap
- 90 CRX HF with 1.6 swap
- Some Opinions B or H?
- chipping pr4.....need someone to tune.
- HELP ASAP!!!
- girlfriends car wont start please help couldnt find in search
- Ls Axles in 89 Dx hatch...
- HELP ASAP!!
- my 88 4door build
- anyone order from x3racing.com before?
- will 90 si seats fit my 90 dx rails ?
- Noise when i turn.
- obd0 or obd1?
