View Full Version : Honda CRX / EF Civic (1988 - 1991)
- D16Y8-T into 89' LX Sedan, Wiring questions
- 91 vs 85 sliding roof parts
- D15b2 piston ring clearnance question.
- different kits, need some advice please !!
- tube seal leaking issue
- my wagon shakes at idle
- Oil leaking under acceleration
- 1989 Hatch Center Garnish fit on 90-91?
- Shakes/Vibrates 1st and 2nd
- Help weird idle issues and smell!
- hatch and wagon shock cover lids
- burnt exhaust valves
- 89 civic si air conditioning reinstall
- help me decide on which camshaft to buy?
- PSI of the fuel pressure regulator
- Hesitation during light throttle
- jacking with a traction bar?
- Exhaust Manifold Removal?
- EF Sedan motor swap & rebuild questions
- tranny drain plug leak
- 90 CRX- bogging, cutting out under load.
- D.I.Y. Resolving clutch pedal Squeak
- Missing Speedo clip cause CEL?
- Will Civic mirror interior panel work on CRX?
- 1991 CRX DX - Transmission Whining
- 235/60-15 M&h...
- 89 hatch rear bumper on 90 hatch
- bogging at WOT....
- Help with choosing best commuter civic for the price.
- 91 civic dx
- Rear Disc Conversion Cables
- 1990 civic 1.5L, randomly dies,
- 91 civic dx stalling and engine cutting out while driving
- 89 crx si no fuel pump prime/start
- DA Front Brakes
- 91 crx si sunroof cable
- Could this piece cause a relay to malfunction?
- B Swap Alternator Brackets in Place of Hammering the Frame Rail?
- Door and seatbelt light on, buzzer keeps going off
- New Honda CRX Facebook Page
- tps sensor going out!??!
- EF traction bar/radius rod modification for proper triangulation.
- Starter not engaging? Not solenoid, starter, battery, ground?
- Unplugged TPS and motor did nothing
- Tranny fill plug stripped
- Intake Gasket
- Hey New
- D series' DC sports header
- weird mpfi swap problem
- break lines
- Trouble in paradise...
- best way to mount integra seats in a wagon
- anyone install Preventor 1000 alarm?
- Re-skinning the roof. Anyone have experience with it?
- crx electrical maelstrom
- 0 rear camber pros/cons?
- Strange trouble codes at highway speeds (89 wagon d16a6)
- Having an issue with the temp and cel
- 4wire o2 wire in on 89 si with b18a1 obd1
- Big Brake Upgrade on DX EF front Knuckle
- DPFI to MPFI OBD0
- 1990 Honda CRX Si Restoration/Time Attack Build
- Tips to salvage this bumper filler
- Air leak between brake booster and master cylinder
- where can i buy new tires for cheap?
- anybody running 235/60-15 M+H on EF chassis?
- Cheetah's 91 CRX Si build - 2.6L K20 all motor Stroker
- 1990 civic hatch issues: starts evry time, but runs rough in 1st and sometimes 3rd
- EF Sedan Side skirts and rear lip
- 89 CRX Si obd1 B18a1 swap
- Sputter at high rpm and no power
- 91 Civic Keeps Running Without Key
- why does my car overheat?!?
- 18 Free Items No Purchase Necessary at Harbor Freight
- 88 CRX transmission/engine compatability questions.
- 89 Civic Hatch STD Build (from S2000 to EF Hatch)
- blakes turbo sedan Build
- 89 wagon steering wheel turning but not the wheel.
- overhaul or get a new engine for my civic
- LS swapped SI cold start issues
- Fresh D16Z6 install, first start up and purges
- Wagon swap problem indeed help
- Tilt column for CRX HF?
- 90 crx Gsr swap. Vtec doesn't seem to engage
- Z6 run without purge solenoid?
- Question squealing sound under hood
- Stay small or go big?
- Stripped 1 Rear lower tranny mount bolt
- civic si seat restoration
- '89 CRX si BLOWN TRANNY?? HELP
- Questions About the EF
- Yet another newbie MPFI swap issue. Please help
- Random small stuttering problem?
- 1988 STD/B16 VSS Issue
- DPFI to MPFI swap idle issues
- 40/40 Prop Question
- honda problems
- Map Sensor?
- Fuel mileage problems with ZC
- 93 integra brake/suspenion converion on 89 civic si hatchback
- crx gsr wiring help
- my cars timing messed up out of nowhere.
- d15b2???
- 89 Crx HF Main relay clicking, won't start.
- Can not locate part, Need Help!
- IACV hose location?
- Looking for a/c parts
- eBay Turbo Garbage?
- 1990 DX not starting (fuel starved)
- Clutch and Flywheel Warped?
- Intermittently getting Buzzing when Starting
- Will a 99-00 lip fit on an EF9?
- b20b with b18a1 head pcv breather box is not hooked up.
- IDLE Surging no CEL, Unplug IACV, No Surge w/CEL.
- 1990 std hatch stuck in 3rd gear
- D16Y8 HG on D15B7??
- Minimum space required between caliper and rim?
- Wiring reverse
- D16A6 Head Rebuild
- 89 Honda civic Si gauge cluster (rpms)
- Anyone know what model/gen Honda these seats came out of?
- where to buy JDM Engine?
- 91 crx wont start after swap. help
- 91 Civic engine immediately revs to 5,200 rpms
- L3 Main Input Bearing Check??
- My wrecked 1989 Civic Hatchback and 1991 CRX HF
- Fan Switch Manual Override
- Randomly won't start
- My Show N Go CRX Build
- My new red ef hatch
- Stripped lower driver motor mount d16z6
- 88 CRX SI D15B vtec swap wiring help??
- cable too tight?
- 89 dx to z6 swap again!!
- How do i replace the belts?
- b20b burning oil rebuilt with b18a1 head obdo need help
- what type of oil for ac?
- axles on b18a1 swapped hatch si
- D16Y8/D16A6 Adjustable Cam Gears Interchangeable?
- Where can i get this part
- What do you call this part?
- Crank pulley wobble
- 3500k
- EF steering problems
- Install AC - anyone done it? How difficult?
- difference in 'respray' and 'painted'
- K vs J swap in an EF
- about camber kits
- ECU Swap??
- project save a 88 CRX HF from the crusher
- '90 Crx Driver's window reg
- problem with b16a swap
- CRX SiR bumper any different from 90/91 USDM?
- Acceleration problem still not fixed
- coolant temp sensor problems.
- Stock 90 integra LS rims fit my 90 EF
- Throttle body
- Civic Ef brake booster compatibility
- Engine Help!
- Need quick response to Si camshaft
- Front Axle Replacemnt
- 12v Ignition source for power windows?
- obd-1 d16a6
- need ideas on ways to prevent tabs on 90si wheel centercaps from breaking?
- Should I convert to Hydro?
- My CRX build
- Changing Automatic shift cable on 91 DX
- Starter Swap??
- EF Dash Swap Issues
- 91 civic rear disc conversion question
- How should I approach this?
- Removing the rear quarter moulding permanently, any downsides??
- What is the name of this part?
- Condenser fan not turning on
- Increasing alternator voltage by sensing diode?
- need advice with air intake/battery mod
- 94 Sanden AC Compressor in CRX
- Idle problem
- Calif Swap Question??
- How did I find a PM9-5 head on a stock civic si...
- 1990 Honda CRX HF clutch(?) issues
- Tach doesn't work
- dohc zc distributor wiring
- best place to buy tie rod?
- Intake manifold gasket re-use with RTV, sound idea
- My 89 Civic hatch SI build :)
- 1991 SI Cluster Light Bulb
- Trailer hitch removal
- Rocker Assembly, does it just pop apart? a6
- 88 EF DX engine/trans swap
- engine swap questions
- 91 Civic EF, how you guys replace alternator??
- Cluster swap - tachometer reading high
- Undercarriage help
- 91 Hatchback Autocross Build
- Obd0-Obd1 ecu jumper/depin & repin
- 88 ef Auto to Manual complete swap.
- 91 CRX Vibration
- 1991 honda civic sedan b swap issue
- Fixing your new odometer to match your old one
- Car won't start
- No brake light or cluster lights!
- 90 civic dash cluster smoke?????
- YET ANOTHER 88 CIVIC FUEL ISSUE...
- 1990 Civic HB Seatbelt Beeping
- Favorites
- Do b series axles fit at all in the hub of std spindles?
- 1991 CRX Si brought back to Life
- Rear speaker mounting on HB without pods??
- First oil change
- What parts are worth keeping / selling?
- D16a6 consuming oil and running rich...related?
- 1990 STD DPFI Idle issue
- d15b2 to d16z6 swap
- 89 hatch si b18a1 no spark/no fuel prime
- Steering wheel
- 1990 dx no start no spark ecu not lighting up
- please help! cable cluster to p28 diagram needed
- Stereo wire mismatch
- hydro cable converison kit?
- tranny help 91 civic
- b18c hx35
- 1990 LX D16a6 Swap Smog Fail
- Coolant temp sending unit connector broke
- JDM D15B VTEC in Overheating Hell
- 91 Civic won' crank... Starter not powered..
- Where to buy clutch safety switch?
- can ef bumper cover be mounted without support?
- DIY Junkyard D16Y8 Head Build*Pics*
- 91 civic hatch
- AFR rich and clutch cable issue (B16A ED6)
- 89 civic- do i just need this bushing replaced?
- d16y8 block on a d15b2 head
- 90 rt4wd ls swap
- 89 VSS Problem
- D15B2 D16Z6 Swap?
- 91 CRX Si - Blowing ECU fuse (help)
- dpfi to mpfi code 4 issues
- ef9 on esm bbs rep 15x9 10 offset. will it fit?
- ZC transmission axle seal?
- Lubrication Points on CRX
- Civic EF, lookig to get near 200hp
- Fuel pump not priming.
- '89 DX Gear Ratio Woes
- 91 CRX alignment
