View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Oil light on after a port and polished rebuilt head install!!!
- PIC REQUEST: Your A6 dizzy on Z6 head. How is your dizzy positioned?
- Any Jersey people??
- Scratchy noise sounds like its coming from the speedo...
- Junkyard suggestions?
- Help! Will a 92-95 Civic armrest/console fit in my 89 CRX?
- how to hook up speedo after b series hydro install????
- CRX Rear Strut bar--a specific one that fits without cutting plastic?
- whats up guys just got my Std ef hatchback tranny noise diagnois needed
- Will 90-91 Crx tail lights fit the 88-89 without any mods?
- Swapping Clutch tommorow, any specialty tools I need???
- A n00b with a question!
- what seats fit??
- b16 o2 Si harness question
- K20ef pics
- i need a crx si tranny with n grinds does anyone have one i can buy
- HELP WANTED: MPFI conversion in san diego. get $$$ ASAP
- NEED HELP FAST ASAP RIGHT AWAY!!!!!!!
- osakajdmmotors.com
- Turbo charge side routing
- Fitting an LS/VTEC under a stock hood.
- EF jdm carbon fiber hood where to buy?
- My valentine
- 3 or 4point mount system?
- Need help with rear motor mount
- Need a B16A
- I think I just found a slight problem.................YS1 tranny/clutch related
- OBD0 STD TO OBD2a Help!!!
- noise after replacing clutch
- Any LOUISIANA people in here?
- d16a6 replacement help in Maine needed.
- Do I need a BOV
- Converting to OBD1
- Rewiring a 88-89 Civc hatch to use a 90-91 dash cluster?
- junk yard location bay area
- obd-0 to obd-1 Those who know!
- 1990 civic crx Suspension: Some question about it.
- what are differences between 92-95 and 96-2000 map sensors for a B series
- anyone try.....
- Anyone know the OHM's of the stock CRX/Civic fuel gauge sender?
- 93 delsol engine/tranny mounts on an 88 crx?
- pm9 head egr port plugging?....
- Brake Upgrade
- Brake rotor...2 screws removal tips?
- HELP: 86 crx hf hesitating.
- help with a d16a6 motor..
- How should I be idling?
- Brake master cyclinder question?
- Cams in DOHC ZC
- Helms manual for 88
- SPC camber kits, what do you think?
- wanted: crx fenders , anyone?
- Rear disc conversion?
- Stereo Installation Help
- What's your favorite clutch?
- where can I get Traliling arm bushing for an 88 CRX Si
- What is the difference between these crx engine harnesses?
- Fourthgen accord front suspension on an EF?
- CRX Si rear stablizer bar question
- What years civic and integra's Shocks fit 88-91 civic hatches
- Anyone seen this yet?
- yO are the 88-89 crx seat brackets and 88-89 Civic Hatch brackets the same
- JDM d15b vtec...who has one???
- speedo
- fuel and timing maps on mugen pr3?
- 91 civic ?!!!
- need to find shaoter spindals
- good idea?
- woot woot kinda itr related
- EF SPOON LSD? or DC2?
- my new, kinda ricey, but i like it, crx
- b16a obd1 fuel line problems
- Accord lip on a factory CRX bumper?
- getting a EF hatchback STD model..couple questions
- OBD1 conversion problems need smart help?
- ef nightmares please help
- How many splines on input shaft of 89-91 Si transmission?
- 89 PM6 Si ecu's chipable?
- Need help with ECU problem please!
- which swap
- help...headlight removal
- Rolling Blackouts!
- What windshield parts to buy?
- Kinda OT: Port and Polish b16a
- door molding for 90 civic hatch!
- clutch or cable?
- Who is running an Exedy clutch?
- How Many Ef Guys Actually Race?
- thoughts on turbo'ing stock d16a6 w/178k on it....
- WTB: CRX Si 90-91 703 VIRGINIA AREA
- Parts list for Auto to manual 1991 CRX DX
- Rear JDM SiR Disc Brakes.....any US replacement calipers?
- injector order......?
- stock gsr motor mount
- Anyone have pics of the D15b2 rods VS D16a6 rods?
- ls swap in to a 91 hatch!
- 91 Civic - PLEASE help!!!
- Does your 88-91 civic/crx surge at freeway speeds under light throttle?
- B18c1 CRX owners ?
- OBX Type-R catback for Civic/CRX pic request
- Weird problem...gotta be ground....Right? (searched)
- Just installed cold air intake....a few questions though
- B Series Vs D Series: The Epic Adventure(ADD stay away)
- Big ZC Problem! HELP!
- Where to buy a Center force stage2 clutch
- D Series Tranny Questions
- What motor is this on the crx?? is it a honda motor??
- What goes in this hole? (86 1.5 Carb'd)
- rear defroster problems!
- Front motor mount bolt size? Is mine right?
- dx to si conversion using a y8 intake mani?
- How much shuold I ask for my Si tranny? Need Cash!
- can i turn my d16 by the crankshaft to adjust valves???
- ver stripped the bolt on the camshaft to turn engine
- this tranny is giving me ulcers, please help
- Places to get JDM d16 v-tec motors?
- '89 JDM CRX SiR front clip
- best deal ..... ever.... period
- wheres the eacv on a 91 crx si...
- I need help! Tell me why no one will buy this car of mine! (Not an ad, just looking for help!)
- B16A1 ... More HP?
- raspy exhausts solutiuons
- Will a A6 crank fit in a Y7 block?
- OK....installed a new short shifter
- 88 Crx Si CF or Fiberglass Fenders?
- How much Hp can a d16a6 hold
- JDM SIR spoiler CRX mounting questions. PICS of inside hatch bolt locations
- SOHC motor build up
- What OEM swaybar options for EF9 Civic or CRX , (E.G other models)
- would 92+ dohc ZC fit in my ef??
- J's Racing Lip
- zc box
- Are CIVIC VTI EE9 clusters plug and play for USDM civics??
- Double Cat?
- Will a hx 1998 V-TECH-E intake mani work on my y8 head?
- 94 gauge cluster on a 93?
- ANYONE have the link to the guy that was selling bateries?
- Honda parts manufacturer
- What clutch to use for a ZC?
- what timing belt do I use?
- Need Help: How To Remove a cable Tranny from '88 civic HB
- PM6 ECU's
- PIC REQUEST:Nice Looking..NOT flashy..CRX Front ends.
- Necessary parts needed for JDM EF front conversion
- Rear Lower Control arms bent!?
- Integra Type R rear lower tie bar
- OT Anyone else live in Colorado?
- Tech Help
- '88 Civic brake swap
- fake carb approval sticker
- 88 Dx Emission problems
- price on hf
- Intake Question
- Cali legal swap owners: BAR sticker is for 1995 Honda 1.8L (B18C1) and I need to replace the head
- Dumb brake question
- obd0-obd1 conversion
- what mounts do i need? swaping a cx motor into crx
- body kit ...appearence i kno but
- Does anybody have pic of that car from mtv:i am street racer crx kids name is greg post them up plea
- gutted my 89 4 doh last weekend. (pics)
- Code 19 on PM7
- K20 mount kit for EF???
- Electrical PROBLEM!!! BAH!!!
- VTEC Solenoid Oil Pressure Switch... do I have to use it? (Mini Me)
- How do I put 95si seats in my HF?
- A6/Y8 technical Q.
- pics of my new rollcage.
- 1/4 mile ET guess with this set up?
- problems with zc swap?
- how do i swap a 1.5 to a 1.6 si on a hf or dx 91crx????
- Got a couple of questions
- Rear Lower tie bars
- Strange clunk coming from the left side suspension.... What is it???
- Cusco lower tie bar?
- How much would you pay for custom IC piping???
- I'm parting out my 89 CRX si
- are all crx's the same size inside??
- Do i need extra pins for si to sir conv?
- WHY!
- spoon
- intake question---ALREADY SEARCHED
- How often do main relays go bad in '95 civics?
- ef7/ef8/ef9?
- Turbo options
- any1 running front integra(DA) sway bar on their efs???
- swap 90-91 crx gauge cluster on 88-89 crx
- Wings West body kit Question
- EF/B18 info?
- Need help...need affordable person to do swaps,
- ECU not blinking??????
- thicker head gasket?
- Cold Air Intake on CRX (90) SI fit on DX model ?
- Can I Swap Suspension?
- brakes problems..
- 1st gen civic
- DIY Clear sunroof plug
- EF9 jdm cluster door lights
- strut bar questions please help???
- RSR cat back...who carries them?
- Anyone running a Z6 with A/C? 4g or 5g compressor?
- why should i get cam gears??
- rear crossmember help!
- s2000 (15400-PCX-004) oil filter
- Carbon Fiber Sunroof.. anyone tired it yet?
- motor question: type-r or gs-r on my 1990 crxdx?
- Oil on spark plugs
- Those with Ground Control coilovers, how long is your spring? Is it 200?
- Slight delay when starting up my car
- I've made my decision... about to purchase B16A
- JimFab crossmember with a 92-95 civic radiator
- SOHC ZC into 1990 Civic Wagovan (D15B2)
- Why did Tokico leave out the EF's?
- oil consumption?
- anyone ever fit a js racing lip on an USDM EF
- HOW DO YOU INSTALL A FIELDS VTEC CONTROLLER ON A 89 HATCH WITH A B16A
- Where to start with a B16A?
- Which Helms manual do I get for my motor?
- ZC tranny swap question.
- idle adjustment
- What's the best shocks to buy?
- Need 2 Fenders
- Front Lips for 91 crx.
- TEIN NA
- k20 swap on civic....
- fixn to start crx need some info!
- Speed bleeder size/part number for 88 CRX DX?
- gauge clusters
- looking for odb1 jumper.
- You pick my setup
- measurements of crx
- Front Tower Strut Bar
- grounding wires???
- Changing my cluster...what will fit?
- vtec controller worth it on your EF?
- Civic differences
- pic of an jdm itr header in a rex,.. anyone!!!!!
- Transmission oil
- Pondering...All motor D15
- 91 civic dash
- 91 civic si motor
- 91 cibvic si hood for sale
- Difference in 88-89 and 90-91 caliper mounting places?
- anyone got any Si wheelsw/tires for sale(CHEAP)
- DSM Injectors for a honda all motor build
- when wiring the vtec from a mini me...
- These Ground control coilovers say: 45194b gc200.64.44 limited edition, what's it mean?
- Wheel offset? +44mm on a civic?
- wiring harness for 90 hb b16 swap
- found a 91 integra with a b18, will it fit my 88 hatch?
- I need some fenders..Will si fit?
