View Full Version : Honda CRX / EF Civic (1988 - 1991)
- fuel injectors????
- High or Low impedance injectors??
- OBD0 OBD1 Conversion oxygen sensor?
- Who has the Fastest CRX in Europe
- 1990 honda std hp gain
- Price Check: AC system fix
- i was going to order a zc dohc swap for my crx 89 si will the si ecu work? and is there and thing el
- how much are h22 motor mounts for a 89 crx si
- Intake Manifold on B16a1
- FS: EF Motor mounts & Body kit
- For those that love the classics Honda's golden years
- i want to put a h22a in a crx need help
- seat swap and Low budget
- electrical problems with my ac. very frustrated
- help from the DFW area...(89 crx si)
- ecu?
- 00 b16a2 in 91 si....
- 1st time at the track
- ls swap problem?
- Cranking but not starting......gimme some hints
- SI tranny question
- obd1 d16z6 swap quick injector question
- crx itb?
- where do i find taillights
- CRX heater blower
- quarter mile time setup b16a1
- crx catback
- some problems that tp sensors cause?
- compression test with no power?
- a/c in a 91 hatchback with b16
- burnt wiring harness
- will 90 integ gs ecu work on a five speed 90 motor?
- Burning Oil, Comp test results and questions
- i know this gonna sound real crazy and prolly get flammed lol but an 2000 si dash ?
- NATURAL GAS PISTONS
- Bitch Pin?
- Bought a JDM Y1 tranny and I want a limited slip for it.
- installing cruise control
- HELP!!
- Blew my motor
- NEED HELP ASAP!!! about bleeder screw??!
- driver side window regulator HELP!!!!!!!!
- when are we getting the for sale section back
- Crx Bumper Light
- fuel gauge stopped working!!
- Fuel Pressure???????Help????????
- jdm
- replacement front upper control arms for camber adjust
- CRX Door
- what will work?
- Fuel Problem PLZ Help
- question abt a front lip from a 84-87 si ? and eg side skirt question
- Bad Compression = Bad Emissions Theory
- Housing that Gauge Cluster Sits in? What's it called?!
- Need Si underdash harness ASAP!!!
- Vtec through VAFC on Non Vtec ECU
- Cam Timing ?
- DPFI ---> MPFI conversion stupidity outcome..
- hard to shift in gears what can be the problem?
- How Does My FMIC look?
- any1 ever thought about this??
- type r on crx
- ef w/ ls ...running hot?
- zc brown top clutch on d-series???
- writeup on head gasket
- Does this sound like a good trade?
- Bizarre Skunk 2 side effect ????
- delsol or crx
- Need help with wiring for H22 crx
- clunking goes away when I hit the brakes
- what's the biggest engine for a 1990 civic wagon without losing real time 4wd ?
- sparco siena or torino with flat bracket mount and slider fit OK in 91 CRX HF?
- Car sparks between gears
- what is the biggest engine that can fit into a 1990 honda civic wagon for maximum performance ? sugg
- Buying a new ef
- cel does not go away.
- ZC Starter same as other OBD-0 D-series?
- Want to be a fellow hatch owner, hows this sound?
- NeEd HeLp!!!!!
- how many CRX owners need rockers and wheelwell arches?
- Are JDM CRX turn signals the same as JDM Civic HB turn signals?
- '91 CRX Si Sunroof into '89 CRX Si? (I did search)
- Thermostat?
- what is this thingy?
- Best CRX Catback Exhaust...Vote Now!!!
- 91 civic hatch dx
- My car got backed into :( *Pics*
- Good body shop on the treasure coast/central florida
- Replaced alternator belt car wont work
- d15z1 head on d15b2
- invader hood clearence
- Quaife gear set?
- Help trying to troubleshoot?
- ANYONE HAVE CERTI FIT FENDERS???
- Timing: From Dropping the Head to Setting Timing. I need it all. *HELP*
- ok, need help with Integra sway bar in Crx
- Water temp quest.
- wide body kits ?
- ?NeeD PARTs for 89-91 civic hatchback?
- old school hasport motor mount replacement
- Anyone see the new Honda Tunning?
- de-pinning
- exhaust help for CRX GSR swap
- Help CRX died, tach bounces - MPFI swap on auto DX
- jdm/spoon/mugen/OEM..
- stickers/decals
- Knocking rod in a crx
- well i got bored today...
- crx dash in a 88-91 civic hatch??
- gassy smell
- tryin to find an e.g
- Which ECU is best for a crx b20b swap?
- CV joint problems!
- rear gutted of crx
- ukdm power windows
- MY CRX is running shitty after a motor swap.
- starter relay replacement
- RUST!!! help please!
- D16Z6 into my EF 4dr sedan...What do i need??? HELP!!!
- what parts needed for d15z1 minime?
- Z6 swap OBD0 no fans and overflowing radiator
- Friends BLITZ bumper was stolen in middle of day at crowded mall... WTF?!?!
- YS1 tranny problems......
- installing lma's
- how to clean PR3 bare head?
- Engine Identification
- Rumors, Rumors. Thought I would share
- Weird starting problem!?
- enkei rims for 90 crx
- Anyone have a Suspension Techniques rear sway bar?
- A/C replacement
- Tranny Help!!!...
- Differences in ECU's
- valve guides or rings ??
- Wheel will not spin when Axle / Spindle nut is on too tight.
- 88-91 CRX Greddy SP2 Catback Exhaust Pics Wanted...
- Paint Type
- New Supersprint Muffler (pics)
- muffled pop type sound when trying to start 1990 civic Timing maybe??
- tranny from brown top zc
- positive camber problem - 2000 dx front spindles
- HELP!!!!
- Doing vtec d15b swap, motor came with automatic flex plate???
- ZC CRX Swap dilemna
- how do I cut my linkages for a b20 swap?? please help ASAP
- Replaced upper radiator hose but..
- straight pipe exhaust
- throwing crazy codes
- CRX REAR SEATS???
- DOHC ZC BUILD
- Ghetto Cruise Project
- cable to hydro swap- 91 crx si
- Headgasket Right?.
- WTB passenger seat
- Ever heard of "JG" Cam Gears?
- need help my crx wont start..
- Difference between Dx and Si brakes system??
- Good Lowering Springs for the money...help me decide plz
- tranny?
- WTB: 90 CRX Si SS cat-back w/FLAT muffler.
- are 89-91 lca's the only thing needed for conversion to use 89-91 shocks?
- Honda tech to the rescue!!!!!!!!!!!!!!!!!!!
- Gas Prices In San Diego vs Ethanol E10 or E85 prices
- Civic doors on a CRX
- what do you people think...
- Civic DX Muffler/Exhaust *Searched*
- 90' civic std weight?
- considering dpfi to mpfi........but odd questions
- Is my CRX worth this much??
- LCA Problems & GC Install Questions
- why is my timing belt tring to come off??????
- my ef civic (comments welcome)
- Fixing and painting an optional center console (56k beware)
- Monuts for b16 swap? A.S.A.P PLEASE!
- SOHC ZC Probs/Questions
- b16a1 swapped in ctr cams with gears...no a problem
- whats better for N/A ls motor safc or vafc
- Black on Black interior?
- Can I get the gearing ratios of a B16A1 Tranny?
- B18A1 into 91 civic hatch????
- Steering Wheel Removal. Aftermarket Hub Install. Guide Anywhere
- VSS Removal/Install. Guide? Pics? Info?
- 4 dr 88 civic
- Betcha never seen these wheels on a civic...
- help with rear brake swap
- Any one here ?
- skunk 2 timing marks?
- oil pressure gauge wierd readings
- How to replace alternator on 91CRX.
- choosing an ecu....YOUR INPUT PLZ
- 90 EF b16a axle help
- How about that POWER!
- d15z1 mini-me on d15b2 block?
- 90 crx cat converter
- ZC Back motor mount.....need help.
- Temperature Gauge Wiring on a Climate Control
- keep blowing horn/brake fuse underhood
- GOT ME A MOTOR YA!!!!!!!!!
- crx dash in a hatch?
- does this engine look good?
- please help me with my water pump...
- dpfi to mpfi
- ebay coilovers sleeves, with some good shocks= Decent ride?
- what's better/easier to go turbo on, OBD0 or OBD1-2 ???
- WTB jdm ef9 front end!!!!!!!!in dallas area
- hatch overheating after intake manifold install
- where to find ef9 carbon fiber spoiler for cheap?
- What happened now?
- Obd0-1 Distributor Wiring?
- 91 std brake conversion question
- Just converted to obd1 - idle problem
- seats
- ANYONE KNOW WHERE TO GET MOTOR FLUSHED ? OR HOW TO?
- O MAN ..........
- car dont start with relay - ls/vtec
- difference between dx and si dizzy?
- Radiator fan not working!!!
- D16A6 rebuild, what do i need?
- intake
- New member--questions on restoring a '91 CRX Si
- HELP!!! CARBON FIBER FENDERS FOR 03 CIVIC SI...AND TORINO 2 RACING SEATS...WEBSITES PLEASE
- something is draining my battery
- i just sold the crx boohoo
- what is a dizzy? is it the distributor?
- engine swap ?
- opinions on colors
- wiring ?'s
- b16 crank pulley
- Stroke the D15?
- how did they do this??? pic inside, 56k go away.
- LS-Turbo Electrical Assistance NEEDED!
- Harness needed
- GSR header problem
- Everyone with a b16 Chime in!! doing a swap in 2 days.
- Proportionning valve help
- holy crap...
- Z6 rev limiter at 3500
- Problems keeping the ZC running
- shifting
- i need serious help, no compression, again!
- d16y8 into 1987 crx HF ???
- Motor question...
- need help with my wiring
- Tranny just went out at work........
- 88 Crx B16 Swap wiring problems
- Civic and CRX all speedo cables the same?
- pr3 ecu do i tap into pin a8/b5
- what is code 2 and 21
- A screw is in my tire.
