View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Engine Help!!!!---advice
- Need Help With EX Cluster!
- replaced whole distributor now it bogs..
- 95 civic EX into 89 crx DX
- 10% off anything from PasswordJDM.com
- what did it cost you to build a turbo ready motor top to bottom
- JDM S1 tranny...LS 5th gear.
- Import builders, reliable engine source?
- how good is this exhaust???
- blown headgasket help
- OBD0-->OBD1 ecu harness...
- Did search...anybody have Race springs on crx?
- should my 90 Std. hatch steering wheel height be adjustable?
- Steering Wheel Extender???
- greddy mx exhaust
- What should I do ?
- rear motor mount?
- bumper supports weigh a lot ...
- recaro srd's in a crx
- Z6 in an 89 CRX
- My car won't start ""HELP""
- questoin about single cam head swap
- Civic trunk leak -help please!
- Engine light just came on in the Rex - causes?
- How much do you guys think i could get for my crx?
- Need help with injectors
- Best Online Distributor?
- JDM/USDM Distributors for B16A SIR
- DX with multi port conversion better than Si?
- (Searched) Wasnt someone selling jdm corners???
- Need help identifying suspension part
- CRX curb weight
- Fusebox Diagram
- will '92-95 civic si rear disc brake work on my EF?
- Colorado CRX and Wagon Owners
- head milling specs? want to raise compression 1 point.
- odd electrical problem...
- crazy steering problem
- B16 clutch in crx
- need HELP bad!!!!!
- Gas needle is off, but by how much.
- ?? about jdm rhd ef
- went and weighed my 91 pig, i mean hatch!
- zex kit on dx motor
- hey guys, new place to shop for JDM parts, wholesale and retail
- 90 hatch gauge cluster
- testing the waters
- Question on eleltric for a 85 crx si
- How better off would i be?
- skunk manifold help needed
- posted again, can someone please repond this ttime
- stock 91 dx hatchback
- Will this clutch fit?
- 91 EX master cylinder
- Vaccum diagram!!!
- will DA mirrors fit on a EF
- Neuspeed Sports vs. Eibach Sportline
- K20A2 engine swap into a 90 civic hatchback...
- Need HELP in MI *$$$* in it for you
- I'm looking for videos of C1/C5?
- Faded moldings
- Brakes for a 1991 Si?
- oil light???
- I'm Beginning to Hate this Damn Car
- screw OBD0, i'm switching to OBDI
- b16a for ef for sale
- Energy Bushing question
- guage cluster for 90 DX? already searched
- new vss ? which to use? sohc vtec swap!?!?!?!
- Brake Dust Shields
- looking for info on 1G CRX's with the bulged DOHC hood
- Upgrading nonobd injector plugs for my EF
- Car keeps running
- Do the make clear (white) LED bulbs?
- two echc cars
- engine mounts for civic type-r
- How to tell if distributor is PM5/6
- ebay
- What Ecu??!!
- Wheres the iat sensor?
- crx tail lights 88-89, and 90-91 swap
- 2 gen Honda CRX 1.6i-16V DOHC gamgear settings? Any suggestions?
- anyway of putting this back on?
- F&%@ O2 sensor!!!!!!
- heli-coil good? bad? does it work
- Point me in the direction of Si-R Front/rear seats
- Which axles to use?
- euro front bumper lights
- Lower control arm broke loose an WHAM!!!.........
- help with code 22
- header skid plate
- anyone elses oil plug leak?
- want to get a header for 1st.gen b16,but what about the 2 o2 sensors?
- Went to the dyno today!!!
- Brakes for b16 hf
- **MY car leaks...inside!! help!!**
- auto to manual question
- B16 all motor c/r
- I'm looking for........
- Why was my post about the CRX with the 1996 NSX motor swap DELETED?
- Lookin for what seats bolt in
- My Goodbyes to all the good people here
- I'm looking for websites with tranny codes
- check out these insane prices!
- 8 flashes on the computer
- i have a cam ques
- Header for D series motors
- A chilled out 4th gen forum
- differences in EF ECUs
- fender
- rear brake problems
- D series engines and trannies
- Anyone want to help...?
- price check for this>> *pics inside*
- A how to page on Instaling a gen2 dash?
- if i get a zc ecu and vtec controller.......
- Pg7 issues...need a little help
- posting in other forums
- dx tp d16z6 wiring questions - part 2
- is there anyway to make 90-91 tailights fit on an 88-89 crx???
- are the spindles and trailing arms the same on the CRX Si and DX?
- reply to locked post
- the motor did not like one of the spark plugs?!?
- anyone that has removed there rear wiper on a crx please look
- what after market piston should i go with?
- Wings west RS Kit for sale
- Water Leak from hatch strut on my CRX
- Wireing on JDM tails
- B16 Hatch VS B16 Sedan
- WTB: Stock 1.6 head or motor !!!!!!
- AEM pulleys
- 1.5 Sohc Vtec
- please look and tell if this is true or not
- Need Help!?!
- Does this price sound right?
- Anybody that works at a Honda dealer please come here!!!
- My car dies when I hit bumps...
- Headlights get brighter as I rev???
- Engine Swap Question
- another Y1 tranny problem ......
- crx carpet??
- CD Player installation problems (not really car audio, didn't know where to go)
- wats the diffrence between a ef8 rad support and usdm rad support?
- does anyone know how to install a ef8 bumper to a crx???
- done with my valve cover now what?
- A little help here....car eatting oil? leak?
- Engine Swap
- Has anyone...
- quick question?
- Question
- '88 CRX Si
- $23 muffler robbing power?
- zc swap.....distributor wiring? plz help
- changing timming belt
- negative battery cable question
- paint job question
- which head to use
- Performance Parts
- is a d16a6 head from a 4wd civic the same head as from a crx?
- will DA front sway bar fit crx si? will it help?
- If you had a choice, what 2 autometer gauges would you get
- anyone have info on stroker kits?
- alternator test, confirming this is true....
- Axles? CRX/b18
- found a sweet deal but is it worth it
- road racing the ef!!
- b16
- need help is it a 88 or a 89 si motor
- clearing out headlights
- Smells like burning.....
- Strut Bar help - will DA's fit?
- b18bturbo or gsr
- DSM 450's
- !!!!!Please Help Me FIX my CIVIC!!!!!
- Gas Tank Size?
- looking for replacement engine asap
- will si distributor fit on DX?
- Will 90-93 integra echaust fit on crx si......did serach
- People with real experience with 15" Azenis?
- Head swap
- help my new brakes have a problem
- 89 civic lx cluster wire diagram
- brake swap parts list confirmation for '91 Civic Si
- Differences between 88 dx and 89 Si clusters for a rex.
- b16 trans?
- looking for pics of a ef black/gray interior
- 4-1 Header onto a b16 ? ? ? 2 o2 sensor's ? ?
- hey can some one help me out
- Distributor wires cut. What do I use????
- New 84-87 CRX Website
- It's Alive!!!
- i think this is what my b20 set up will look like
- half built ls/vtec OR b16?
- need info on putting a d15b2 into my 89 CRX DX
- si and jrsc
- Dashboard lights don't work on my 89 Civic...
- Transmission problems, why do clutches have to be such ....
- DX to d16z6 wiring questions
- cruise control.... possible?
- What to look for?
- how are 88-89 so much lighter
- wiring ? 91dx
- I hate AEM intake
- Buying a CRX
- 91 CRX DX Ecu
- cheapest place to get a b16 engine and trans?
- ASAP! 88 Crx DX: Swaybar Diameter?
- LS rods in a d16?
- Just want to verify...
- Intake manfiold swap
- Tein HA's in CRX
- axle question?
- A/C ?
- ZC or D15B
- What do I/can I mount the lap belts for my 4pt Harnesses on?
- Anybody have any pics of Neuspeed Sport and race springs
- 88 crx si !!!!!
- HELP: Need ECU map
- front transmision mount..... look!
- mini me distributor questoin
- help please!
- old, old gas...can b-12 chemtool get it out?
- someone please
- hood cable problems?
- jdm b20 in 91 crx
- Idle surge problem- your experiences
- Do 4g hatch Si's come with?
- rear bumper help
- what tire size for si wheels?
- will mounts from 89 crx fit a 90?
- electronic vss wiring
- woot! i've got an accord alarm system
- PG7 Ecu Code 19
- What am i Missing
- What make you buy EF??
- Losing power when cornering hard
- 90 civic ex Msd 6A install help
- cooling fan circuit help
- fuel pressure info???
- Valve Question????
- Anyone got pictures of how they mounted their Autopower Bolt in Roll Bars?
- b16 motor mounts
- i saw a cheap JDM EF SIR wing on ebay
- Stolen Side moldings =*(
- My time with basic bolt ons
- Hey trinity... Top this
- VERY high idle b16- 3-4k Help please!
- Code 4????
- Neuspeed Race springs FS
- Moving...
