91 civic si bogs down when shifting
OK here goes I have a d16z6 with si cable tranny new clutch carshifts fine when cold when warmed up the car loses pick up still shifts good tho. I've adjusted the clutch cable doesn't help. The car won't move when in neutral until it cools down then it's fine. When it's hot I can smell the clutch burn but not too bad. I have a spec flywheel with exedy clutch kit I've searched everywhere but I'm stumped any suggestions? I had the same problem before I changed the clutch thinking it was a faulty clutch but it wasn't. Same spec flywheel tho
