View Full Version : Honda CRX / EF Civic (1988 - 1991)
- help i can't find something
- DIZZY ?? PORQUE ??
- PW0 on CR-VTec
- New pics of J-Mags and DA brake swap....Opinons?
- After adjusting valves
- HeadLights problem HElp ME.!!
- Whats up with the EF squad?
- b16 swap cranking but not turning over
- b16 swap
- Info on an EX EG coupe D16Y8 swap anyone?
- Replacing speedometer cable clip to tranny
- pcv valve question.
- valve cover ???
- Which water pump?
- 88 89-90 91 tail lights......
- Should I buy this EF for my Daily Driver?? Need Opinions.
- Question about B16
- please help 94 b18b swap in to a 91 crx that is converting to obd0 to obd1
- keep moldings white, or paint them black??? (pics inside)
- check engine light while cranking
- b16 and ls tranny
- all motor ls
- What is the number on the relay
- Scratching noise at specific RPM?!?
- Air conditioning system for integra into crx? possible?
- LS/vtec ignition and cam timing
- Failed Emissions testing (running rich) What should I do now?
- auto to manual pedal swap help? (SEARCHED)
- Pic request of catch cans on EF's
- Removing heatsheild , any cons?
- b series swap mounts urethane insert
- Please help with "Charge System Warning Light".
- Wiring help**
- d16 from an Si into an HF
- Nitrous vs. turbo
- my ef sedan
- Swap Censor help
- Small Oil Leak in Header
- Black tinted tails
- DPFI-MPFI
- PIC REQUEST Megan Racing Cat-Back on CRX
- shuting off
- Check out these pics: Std. vs. SOHC ZC wiring...
- Front end... welded??
- TPS
- Looking for body clips...
- BODY PROBLEMS, IDEAS??????
- b18 or b20?
- tach problem
- H22 crx Vs. B20 Vtec crx Vs. GSR hatch...which one to buy?
- a ZC question
- b16 swap help....
- B16 bogging and hesitation issue
- EF CRX stainley side marker install
- Problem Turbo CRX
- 91 CRX SI, ZC Motor. Black Widow Project
- EF coilovers....will they fit onto a ITR?
- how hard is it to remove a dash from a hatch
- No dash light and no tail lights
- Worth $100?
- ITR shocks on 91 cx
- 83 1500s Civic, Need a 1.6 Vtec to fit
- SOHC Revving Help Please!!
- PL3 A100...SI or HF tranny?
- touch-up paint....where to buy, only honda?
- prelude seats in a CRX
- Turb'n my d16a6
- Running lean
- What air compressor and accessories to paint my CRX DIYer...help!
- iacv help
- hesitation problem please help
- TURBO WITH AC IS IT POSSIBLE WITH A HOMEMADETURBO KIT ON A D SERIES ?
- do i have to convert....
- resetting the tps
- Carbbed Sohc?
- HELP HELP I GOT A QUESTION!!! 89 CIVIC HB!!!
- VAFC Install
- D16A6 Block Question
- Got a question on b16 in ef. Dizzy wires from ecu?
- SOHC ZC dizzy plug not matching Std. harness's dizzy plug!
- My new rex project MPG
- Civic Si Seat Recline handle missing?
- need parts someone help make some money
- ZC Swap O2 Sensor
- Transmission Swap D15B1 4spd to D15B2 5spd
- bought my first honda today:)
- Ryan Basseri gets into Honda Tuning
- !!Help!! 91 CRX w/b16a obd0 Bogs out on highway
- light / running light / corner light problem
- pissed hood
- Heat Shield for 1st Gen B16 exhaust Manifold
- snapped rear lca bolt -- what to do?
- does any one know were i can get a v-tec wiring diagram
- Got in a accident . . pics
- RS-R Exhaust with wing west body kit on crx
- b16 swap with problem **code 8**
- 84 - 86,87 CIVIC Compatabilities?
- NHRA (94 civic coupe)
- timing odd!!! do u know??
- need windshield wiper help
- Looking for RHD conversion
- Looking for a RHD conversion for EF hatchback
- Clutch question
- Official 4x114 conversion list
- Cooling fan ? Which ones +?
- 91 civic si hatchback
- I need a good reference on parts...
- What type of Main/Rod bearings should i use for LS-V ??
- ignition switch how do get it off the steering column????
- any one got a wiring diagram for v-tec on a b16
- 92 civic ex knuckles/spindles on 88hf... whats the truth?
- CRX w/ B20 Swap; Which ECU do I use?
- new to forum....here is my CRX!!
- which brake lines for 89 crx rear disc brake conversion?
- crx engine swap D16
- Project AWD-T by red civic standard and redzcstandardhatch
- D15 idling weird?
- hmm...weird thing...should i try this on my trannies?
- Will these Audi wheels fit?
- $400 Used T3/T4 Kit - Worth It?
- Stock CRX bogs and dies - not coil or main relay
- UK CLUSTER INSTALL???
- Warm Weather = funny idling while warming up.
- question about gas
- which is recommended? Y1,S1,or J1 tranny from hmo?
- 1989 si
- 87 Crx SI in south carolina 900.
- need help getting steering column out (plz help fast)
- axles
- WHAT AXLES FOR 1ST GEN JDM B16 INTO 90 CIVIC SI?
- Can someone give me the OBD0 diagram of a B16 on how to wire up V-tec
- EF driver door is popping/clicking when opening... so annoying!
- Brake Question help?
- HF front bumper support/beam fit on an Si?
- si interior question?
- Dx engine harness removal
- Stalling problem on 90 Civic LX
- 86 crx si....lots of problems
- Will password jdm power chamber fit with no mods
- distributor
- Dohc ZC camshafts replacement
- Lug Nut size...
- Can I use an Integra Brake booster & MC??
- What should I sell my black 90 si w/ rebuilt B16 for?
- EG sized radiator hose inlet/outlet question
- header question for ls/vtec
- header question
- CRX rear caliper replacement, same as DA integra?
- H22 in CRX.. front heavy O.o
- ls oil problem?
- s3 light blinking on auto rt4wd wagon
- so i got my hands on this nitrous system.....
- SOHC Vtec in 89 Std Revvin Help
- tps calibration???
- MiniMe or DOHC ZC setup for a 91 CRX Si?
- d17a2 motor??
- ??????? how do i know
- crx dx w/a mpfi harness conversion ? can we solder this ?
- problems, problems..and more problems...on fuel injection
- Over Heating Problem please read
- si tranny with dx diff.
- Axle Problem
- who is running nitrous on there single cams
- ajustable cam gears
- What to do with my Crx Hf?
- help with suspension and steering rebuild
- harness bars?.....harness questions
- taillights staying on as long as the battery is hooked up?? wtf??
- Negative battery terminal and wire: where does it go?
- b18c1 into 91 crx si... which ECU?
- d16 to d15 swap info?
- Thermo tach jumps up !!!!!!!! help!!!!!!!
- pics of installed tie bars?
- Coilovers installed...
- side moldings are fading!
- crx B16 swap
- steering vibration on highway
- My 91 Hf w/ 95 D16z6
- Can K20 Fit.
- WTB: 89 crx si complete door
- what to do with fused wires on battery relocation?
- Engine stuttering
- lil help please !!!!!!!!!
- Help with this damn ZC
- my civic
- D series non vtec build q's
- This may not be tech but i need some photoshop if anyone is willing.
- question about mini me searched got different answers!!!
- jdm b18c type-r 4 sale
- Need Help..cant get underdrive pully off!!! Any suggestions???
- AC tensor issues... MAD PHAT JDM PHOTOSHOP INSIDE!!11!!!
- Drivers side door hits fender... why???
- Torque specs with diff gasket!!!!
- Guide to putting a B16b into crx
- Vegas people heads up!!! Stolen hatch.
- d16z6 in an 89 crx dx
- map sensor problem
- No Spark?
- RMF narrow header in EF ?
- what are these corner lights for?
- z6 distributor in an 89 crx
- SI tranny into an STD.
- no vtec??? what the hell
- obd1 b16a to obd0 crx
- 90 CRX SI - buying today - need opinions
- GSR in a CRX WHAT?
- is there a JDM junk yard somewhere ???????????
- Well this sucks
- crx car insurance ?????
- 89 dx swapping b16 throttle cable and clutch cable problem ...........PLEASE HELP........
- swapping b16 into 89 dx front hubs question Please help
- looking 4 a bare right hand drive clip
- What does the series of block mean, like 5 milloin series
- ITR steering wheel in a ef???
- Budget Rear Swaybar upgrade for EF/CRX Si
- where did the DOHC ZC come from?
- accord rear lip on ef rear - anyone? pixx?? SeArChEd
- Halfshaft bearing info needed
- Whats the difference between rear 90+ integra rotors and crx si?
- car was broken into again
- Pistons Rings replacement
- fuel pressure regualtor questions
- CRX for sale
- just whenI thought I was out, they pull me back in!
- lights flicker when i turn car off..
- over heating !!!! help
- Resurrected Rex
- question...car wont start b/c of somthin stupid?
- picture test...
- rear disc brake problem
- b16 swap help HEEEELLLLPPP started it and I need the wiring pinouts I have a dx dualpoint
- headlight bulbs (9006)
- need to know what the wire colors stand for..NEED HELP ASAP PLEASE
- <---New EF honor...anyone familiar with this?
- HERE IS MY OLD PROJECT !!!!
- yet another fun evening
- Specs for ZC motor?
- b16 valve replacement
- 88 dx wiring ??????????? just an idea
- Handbrake light is always on???
- what lip should i get for my crx??
- My New EF Hatch....(let me know what you think)
- Hood Question
- 88-89 CRX dashboard into 90-91 CRX Si?
- seat belt saftey recall
- b16 auto swap?
- obd0 to obd1
- **Update** CRX LS swap
- expletive Theives
