View Full Version : Honda CRX / EF Civic (1988 - 1991)
- fuse blows. engine doesn't start
- Throwing CEL 7 (Throttle angle), help...
- New CRX owner here!!
- Hondamotorsonline.com (now Hmotorsonline) or Osakajdmmotors.com???
- EF swap help!!!!!!!!!!!!!!
- d16z6
- What ECU do I need?
- 90 Civic Si seats in a 90 CRX Si....why don't they fit!
- OREGON/WASHINGTON H-T meet check it out !!!
- crxsi/ p72 ecu wires to dash
- Fans aren't turning on...what to look for?
- ZC Head Gasket Selection
- sohc non vtec problem
- wtb stock 90 si steelies
- n1 dunk?
- what fuel pumps bolt right in?
- car wont stay at idle
- Help! Code 17 and 1
- FS: Crx 88-89 taillights. NEEDS TO GO TONIGHT!
- crx windows / greddy turbo in an EF
- fs or trade. 92-95 fiber glass gude bullfrog hood
- how hard to swap a B18C1 OBD2 in an 88 crx si?
- HELP ASAP!! Guage cluster wiring
- 215/40/16 tires on crx rubs?
- skunk2 springs for ef?
- place vs. hasport
- what is 1/4 time for si motor........
- Swap Time- What else do i need???
- B16 EF owners
- code 16 need HELP?
- quick question
- What code is a PM6 ECU
- my b16 swap
- WTB> Looking for side moldings for a 88-89 civic 3dr
- Si Seats
- Energy Suspension Master Bushing Kit on CRX? Anyone?
- Don't Post Comments In Pic Post!!
- no heat
- Shop says my LS will be in next week!
- Monkey Bars
- Very strange question? Gas door release? Dumb question! lol
- Coilover Question??
- oil in spark plug well, and on spark plug??
- Would you build your own engine?
- water in tire well
- What axle do i need??
- Are there any disadvantages to buying a Crx HF vs A crx Si??
- Air intakes debate
- failed emissions
- Ok another sohc ZC question. :)
- 5 lug type R w/ rotor etc. on a Crx ?? ( just some questions)
- whats the best clutch to hold 220 hp on a d series???
- Anyone From The Bay selling a Single Cam Vtec motor?
- need a6 to y8 swap websites
- Boring a b18c out to 2.0, does that make it a b20z? B18 vs. B16 in handling.
- What would u do without ur' mechanic...
- Rebuilding my race car motor.
- Dont laugh...how hard is this swap?
- Damn Rain Flooded Out My CRX!!!
- ZC SOHC info needed
- anybody has seen a D series pushing this???
- Throtle/Engine Coolant Sensor
- ATTN: Oregon / SW Washington people!
- Need Help! Car died on the freeway...Doesn't want to start
- timing question
- Needed.....Valve cover studs
- how to install clutch without alignment tool
- 1/4mile time d15 and turbo
- ecu pinouts
- damn obd0 crap screwing me again
- CRX EF-7 muffler can be used on EF-6?
- Transmission places in the San Francisco Bay Area?
- Bizzall Jizzoint
- D series website?
- Radiator Suds
- too much for b16?
- Code 17 VSS woes
- Help: Install dual gauge pillar pod and oil and water temp
- been asked before,sorry. What octane with b16?
- How hard was YOUR swap?
- ***Rare Canadian OEM Honda 83-87 CRX Rear Hatch Glass Spoiler*** (YES!!! this is posted in Classifie
- anybody got a carfax account?
- clutch problem...??
- need help asap
- Looking for some advice on converting to Hydro instead of cable??
- Looking for some local tracks in San Diego??
- i Need a ZC in NJ area....and also parts list for EF experts
- Clutch problems on my new b16a
- whats a code 9 on a 90 civic w/ z6 swap?
- 90 Si motor
- B16A1 owners with A/C
- B16 question...
- jdm crx center console in a hatch?
- which will fit best?..
- Questions about Changing Timing Belt, etc...
- Having weird problems w/ stalling, anyone know whats wrong?
- carbon fiber lip for ef ??
- b16 starts up weird in the morning
- Can I use a 1990-91 clutch setup in my 1989 ZC dohc motor and tranny???
- i can't find water leak? any tips?
- 91 Civic Si Valve Clearances????
- out of gear
- bad CV joint ???
- 90-93 Integra seats in 91 hatch
- door alignment
- why won;t my clutch pedal come back up?
- h22 or h23 injectors in B16a1
- Bay Area Meet, did it go down.....
- Need adjustable FPR: Will my friends B16A B&M fpr fit?
- 88-89 cluster to 90-91 setup???
- 7100 Rev Limiter on B16
- Head Help.............
- New to the site....
- EF amber corners
- Fuel Pressure Regulator.....
- Offset of wheels?
- Turbo Type R
- CRX Fuel problem
- need camber kit? what to get for the front and rear??
- 92-95 ground control coilovers fit 88-91?
- question
- Columbus, Ohio H-T Meet -Video
- Please Read!!!! Big Question!!!!
- Short shifter (bushing) where to buy one/EnergySuspension?
- GSR and Type R throttle-bodys are they the same???
- JDM CRX Differences
- NEWBIE to the CRX/EG Civic Forum! Questions? Radius Rods/ Deckplate/zdyne
- Factory Ground wires??
- What do you think I can get for it?
- tranny question
- gsr supenion on a hatchback
- Intake question... need quick answer
- Just got a CRX...basic upgrades?
- Changing Rod Bearings
- pivot vtec controller???
- 92 hatch side view mirros
- Need a pic please!
- quik ? on crx sliders on gsr seats..
- SiR axle help please
- dohc losing to a sohc???
- Street Tires
- sohc vtec head swap
- Civic Si motor into Civic Dx
- Brake Question?
- Si-R gauge cluster???
- Ka-BooM
- Motor's hesitating...
- 88 civic starter dead
- Turbo B Series
- GSR Hub/Spindle setup fit on EF's?
- Found a fix (temporary at least) for squeaking hatch
- my weekend. some great some bad (pics)
- CRX Head Change
- b16 help
- ITR intake manifold & TB HP gains
- Washing and cleaning engine
- block swapping questions
- Dipsh$t needs help with Dipstick
- im lookin for a CRX
- crx headlight with low beams on
- damnit...how did i do this
- Selling a CRX, need osme advice from owners..
- DX tranny against a Si one
- CRX head Replacement
- Help remocing knuckle off 88 si....
- HF bottom end with Si head ?
- please help...i dont know whats wrong with my car!!!!!!
- Newbie Ef owner
- b16 in and running great
- need to make my corners amber
- Yes or NO
- B18A what is the real displacement?
- Final Drive
- 88-89 CRX Dash ambering
- JDM CRX headlights
- ...axle clip-ring question..How important is it?
- ? about jdm one piece headlights
- ATTN!!!!so cal PEEPS!!!!! MUST READ!!!
- wtb: ef9 center console
- i need si seats do u have some?
- apexi 4-1 headers? will they fit?
- need help with dx to si
- b16 piston rings?
- short shifter.
- New project. Need direction.
- Really looking hard for intercooler
- how is everyone in the ef forum?
- clutch alignment tool
- b16 question.
- EF Squad where you at?!
- ls non vtec 1/4 mile times in a CRX
- Help me convince 89_Y_49RIP...
- B16 in first gen CRX
- anyone have a z10 crossmember on their crx?
- Adios Sunroofs!!!!
- rods
- what springs to use with b16a swap?
- 91 Civic 4door front and rear seats in a 90 hatch? (5spd tranny as well)
- How does ECU chipping works?
- Bad news
- need help with 88 civic dx hatch
- Just got a B17A swap!
- 90 4 Dr NO START , B16 Just installed!
- Seat Belt Lock-Up?
- vtec solenoid question
- results on mini me swaps?
- How Many gallons In a Civic????
- anybody use tein springs on there car?
- Is there a site that has the complete swap on it for a crx?
- water leak in back of block by the water pump!!!
- climate control busted!
- nor cal people help?
- turbo help......
- Just bought a B16A
- stunnas and liars
- stock b16 bore size??
- found a decent deal on JDM SiR EF9 parts!!
- engine balance?
- Reserve tank for coolant always empty..
- quick question bout t-belt
- fuel setup ?
- what links?
- 92 si seats in 90 civic?
- Car not warming up
- but how many qrts of oil for b16 oil change?
- Amber corner lights. . .
- New problems with zc again ;/
- b16a pwo ecu for 200 shipped....
- alignment specs after DA knuckle and rear trailing arms swap.
- Torque Specs for header?
- gsr cluster in 89 si
- could messed up relay causing no sparks?
- HX on SI
- zc swap?
- pr3 with mugen program??
- throttle body on B16A1
- does anyone have Apex Intergration N1 coilovers on their 88-91 civic/crx?
- help, radiator
- type r seats in a crx
- Major Emergency Need 1st gen Tranny Now!
- ZC engine and cold air intake
- just ordered an an-r header
- Axle Picture
- Hawaiian RWD H22 boosted civic..............
- DA (90-93 intega) shocks fit my 91 CRX?
- Announcement: Ghettodyne V1.02 released
- CRX motor HELP
- stock crossmember motor mount
- anyone here have pics of SS works CRX?
- Oil leak...any ideas from where?
