View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Bizarre Stumble 88-DX 1.5L
- need starting help bad
- spark plugs, which do you use?
- Charcoal canister hose ?
- ef2 suspension problem...!!!
- My quality shot!!
- Help: Valve Cover Bolts
- My Valves Are Knocking
- ecu fuse keeps popping...wtf!!
- Anyone ever race an LS1 Camaro
- Really bad sputter, then spark!
- PW0 on d15?
- RPM/MPH discrepancy question
- door /dash leak
- Mount bolts in block stripped
- need a pic of braided brake lines on ef
- RMF drag header in an EF
- Post Pics of your 88-91 EF Sedan!
- 6 speed Question
- Exhaust for a b18 ef?
- need info about this car?????
- starting problems
- 88 crx with stuck hub/driveaxle nut(middle of the caliper)
- Need wiring help with gsr swap in ef wagon
- my car wouldn't start until...
- felpro gaskets
- ntb help plz need this soon
- just multi port swapped now very poor gas mileage
- eg dash into ef?
- supercharger in an ef with a bseries motor (big MC also) fitment?
- 89 CRX Si Instrument Lights not working(dash board)
- Si trans rpm and speed
- sounds like the engine moving when shifting!
- What is the best among Honda CRX, EG8 and EK3?
- 89 hatch b16a problems
- Hatch won't hold a charge
- odd mini me question
- possible stupid ?, lol
- Adding A/C to 1990 Civic hatchback
- BUYING A K24A2
- obd0 to obd1 project
- Stereo help with 91 ef quick qestion
- d15b2 with zc sohc head
- Where should I start to tune my crx
- ef sedan transmission problem
- CRX SI CLUSTER
- Anyone have a part number for...
- engine harness HELP!!!
- d16a6 - d16y8?
- s2000/RSX calipers on SI knuckles with 11.1" VW Rotor
- Looking at 90 EF
- ITR in my CRX???
- CRX CR wheels
- Buying a CRX that has some problems
- swaps for a 88 crx
- D16 Hatch Need Mount info ..
- Got a Zc Need SOme INfo New To Site ..
- ls/vtec not starting sometimes....
- can i use this from a sedan to hold my hb front bumper?
- sedan trailer arm on hatch?
- CRX seats into 94 del sol ??
- ls swap wont crank
- my car died this morning, need help
- ignition wire color codes
- Fuel pump failures
- Help needed with a D16A6 regrind cam...
- b18a with b16a intake manifold (searched)
- K24 ITB Build
- jdm d15b interchangable parts
- Ef9 rear bumper set?
- Pr7 ecu?
- spring loaded tensioner
- 1991 Honda Civic Wagon
- 88-89 door panels on 91.
- clifford alarm problem or bad ignition?
- help with fuel pump 91 civic
- valve adjustment gone wrong!
- my ef bogs.
- Mostly Stock 88 CRX Si with Roaming Idle and ECM Code6
- Need help my Crx is effin up!
- EF Sedan Tribute. Callin all sedans...callin all sedans
- suspension prob
- 91 honda crx transmission fluid
- D.i.y.
- EG rear toe and camber on EFs
- is this my speedo cable?
- Looseness in Steering Rack...what's loose?
- code 16 (fuel injectors) HELP!
- got an auto ls motor, what to do for egr?
- green/black wire
- crx with b18c1/b16a tranny
- Obd1 integra harness Obd1 b18a1 Obd0 90 civic (DX)
- car wont start 2 out of 10 times .
- Have you had your EF today?
- an akward build thread
- Slim Fan?
- done throwing parts at a code 4 need help
- Glasspack exhaust
- D16A6 Piston Decision
- i desire sportmaxx on my sir
- HELP ME OUT WITH MY CAR!!!
- speedo and cool temp gauge stopped working
- Help 91 hb won't start!
- ? about swap, is it worth it?
- need jdm crx power window wiring diagram
- how to tell if r12 or r134
- Why is the B16 OBD0 PW0 looked down on..?
- simple ecu question
- Bumper Lights
- jdm crx door panels
- american crx to jdm power windows
- Brake drag after axle replacement
- anyone using a y8 distributor/minime
- 88 91 honda civic / crx dual point question
- New Dude and First Honda. little guidance needed.
- weird no start issue
- Fuel and spark problem
- Dashpot/Purge Solenoid Help!!!
- What you think about my new ef work in progress.....???
- Fuel pump not working and no spark
- no injector pulse?
- dash swap question CRX into Civic
- shorter alt. belt??
- Rear Lip Wing For 91 Sedan?
- fuel pump problem wont kick on
- Ac wire harness question
- Popping noise front right
- OEM vs. Aftermarket Body Parts
- AXLES??
- How to install fuel Pump in 91 EF
- No Start -code 16
- hullo all
- 1990 civic 4dr with obd1 conversion.. need b series swap help(b18)
- 1990 civic 4dr interior swap ...need info please look
- they stole my car
- plastic covering replacement??
- My EF9
- (help) ignitor wiring
- Cant pass emissions... High HC @ idle, tips?
- 91 CRX Si radiator
- Wolf Steel Body Panels
- Accord/CRX VSS
- 91 Ef My new car chek it out I need some help.....
- Gettin new car looking for info I cant find.
- H4H HID bulbs?
- clutch promblem.... gsr in 90 ef... feels rough ....help
- Will a 99 Civic rear Disc brake be able to convert onto a 91 crx
- DA knuckle swap to my EF hatch.
- Omnipower vs Koni/GCs
- obd2 dizzy into obd1 harness?
- Looking at a CRX....
- corner lights wiring
- can your honda do this?? lol
- Coolant leak
- ECU control of Alternator
- y1 lsd tranny
- NEED HELP no spark
- could an 89 civic hb fender fit on a 91 civic hb?
- i know its probably been asked alot but...
- when does the fan turn on?
- obd1 wiring
- b to d series trans adapter??
- Headlight question
- SLIM FAN NOT COOLING ENOUGH?
- crank angle sensor.HELP
- Are parts readily available?
- Buying a CRX tomorrow
- civic si (ef) axle dampener???
- My new Car and (my other love)
- Fuel Injectors 2 to 4 have no pulse
- Cylinder One Not Responding. What can it be...
- ne one?
- is this the reason why my passenger...
- Trailing arm bushing problem
- can someone plz help me.
- cable tranny vs fluid tranny... HELP!!!!!!
- PCV Valve
- Sedan and CRX headlights
- Sometimes: Lean under 4k rpm, gets better after
- loop mode mpfi swap
- LS/V wont start after work shift ended!
- Obd1 Wiring
- BEFORE AND AFTER,do we have one of these threads?
- Projector Headlights?
- I need Head Bolts for a JDM SOHC VTEC?
- Rootbeer Mugen B20 vtec
- What kind of ECU for D15B2
- engine dies after warm up won't start again
- COOLING FAN HELP!!!!ASAP!
- EE9/EF9 UKDM/EDM rear foglights and rear bumper
- caliper bracket ???
- ac back into my crx
- crx white exhaust smoke
- Axle and linkage help...
- need suspension help
- God do I despise wiring. previously swapped obd0->obd1 help
- HELP, NEED TO FIND A PERFORMANCE SHOP IN ORLANDO QUICK
- need little help before sir front goes on my rex
- last minute help before SiR conversion
- RUST!!!
- steering column
- easy question need quick answer
- valve cover
- which crx door panel is this??
- ok... now what???
- C Pillar Bar Question
- code 19 and no spark
- How Low Can You Go!?
- 91 crx a/c question..( did search )
- will 88-89 civic hoods fits 88-89 crx!!
- Koni/GC Noise Issue
- have u heard about the infamous g23 motor
- want to see pictures ef's with sprint hart cp's
- what do u think about the B?
- Question on trans's
- b18a std swap coolant hoses?
- willing to buy
- Whats swaps in?
- Ridiculous non starting
- d15b7/d15b vtec
- For people that have a CRX SI 90-91
- B16A into EF Vacuum Diagram
- New ride 90 4dr EX! Need help!
- Gas gauge not working properly
- d16a6 block-d15b7 head will it work??
- 88 civic dx with jdm d15b non v-tec need coolant and vacuum hose help
- vtec?
- question on a 4wheel drive ef
- help
- z6 question???
- speedo and cool temp gauge doesn't work...
- speedo and gas gauge not working with swap?
- losing patience pplease help
- d15 block with d16 head
- which pistons?
- engine swap, axles
- crx si se
- skunk2 lcas and koni yellow shock
- 89 crx si engine and trans removal question
- BIG EF MEET IB GRIFFITH PARK
- honda crx goes into gear but wont move
- WHY THE **** DO MY BRAKES STILL DRAG
- Stereo fuse?
- Ef8 crx sir question?
- what do you do to stay cool when it's hot and no ac
- 1989 civic si hatchback.. b16a project. dizzy connections are diffrent
- all the pistons working?
- When Changing your Final Drive...
- cluster question
- wire harness problems ?????????
