88 Civic Hatch Headlight and Cluster Light Problem
Old Jun 27, 2015 | 10:39 PM
Hectic937's Avatar
Default 88 Civic Hatch Headlight and Cluster Light Problem
Just got my b20Vtec in and running. Went to check over everything and noticed my headlights will not turn on nor will my cluster lights (won't light up cluster if headlights are turned to on position). The individual lights in the cluster like battery, door open, oil and all that come on but you can't see your speed, rpm and stuff in the dark. The brake lights work, turn signals work and even my high beams work. Tried checking fuses, grounds but cannot figure it out. It's like half my **** is working.
Old Jun 30, 2015 | 11:07 AM
Hectic937's Avatar
Default Re: 88 Civic Hatch Headlight and Cluster Light Problem
Bump. Going to try a new dimmer switch today. Checked fuse in engine bay and it was good. Checked fuses under dash and they seemed good too. Only thing i can think of is that dimmer switch or the stalk controller on the steering wheel that may be bad. What way to test if those are bad besides replacing?
Old Jun 30, 2015 | 11:19 AM
v4lu3s's Avatar
RTFM
you said brake lights and turn signals, but do your regular taillights work at all?
Old Jun 30, 2015 | 11:36 AM
Hectic937's Avatar
No my running lights in the back don't. But my brake lights, turn signals, hazards, and brights all work.
devin_hoang
Nov 22, 2008 03:24 PM
sublimnal
Oct 12, 2007 07:09 PM
lluks_844
Jun 1, 2007 05:01 PM
TheTealHatch
11
Dec 31, 2005 12:52 PM
InJ3cted
Jun 26, 2005 09:18 AM
