- crx meet
- JDM CRX Power Folding Mirrors Question
- runnin a z6 with itb's...head gasket?
- Strange Problem with CEL
- need help utilizing stock mounts and brackets
- racing seats
- i need obd0-1 conversion pinouts.
- OEM Single Cam questions
- engine swap in a 91 civic
- JDM taken too far
- Integra suspension on 90 Hatch: NEW question!
- Ethanol emission test fail. Nox through the roof!
- code 6, ect wiring problem
- is the crx and hatchback rear locks the same?
- need help!!! removed the ignition cyclinder lock and car still does same thing!!!
- Hatch Vs. Sedan Molding
- Where to buy OEM style replacement carpet for my ef?:
- Monster intake does it fits CRX?
- Crx exhaust problem
- obd1 ef code 9
- service connector?
- Spindle hub question
- Del Sol Engine/Tranny for CRX
- tps sensor?
- engine mounts
- any nice floor mats out there anymore
- Wiring problems...
- crx sputtering!!
- anyone rocking tein SS on their ef
- Getting a GSR swap for x-mas!
- gsr swap in ef
- How to remove my trunk latch.
- d16a1 head on d15b
- DA dash into EF hatch?
- hks exhaust ITR motor
- diy wire tuck harness.
- sohc vision cam gear, memory fab seat rails
- Do 1989 Civic LX's have airbags?
- Help with Rear LCA
- AVID or HASPORT
- converting dohc zc obd1**
- Head Change!!!
- wiring diagram of service connector?
- Bore size
- need help with a dizzy
- upper and lower rad hoses?
- I need the nut size for the rack and pinion inner rods
- 91'civic vs 00'celica who would win see details
- Need to ask something about my SKUNK2 Lowing spring and the struts.
- d16a1 tegs
- dc2 rear seats fit in an ef hatch perfectly
- EF COILOVERS AND LCA'S COMPATIBLE WITH DC REAR TRAILING ARM??
- CRX D16
- code 9 came up nd now my rex takes awhile @ start
- crx exhaust on my 1990 hatch
- Koni yellow fitment question.
- ecu diagram needed for obd1 p30
- Need help, positive battery terminal wire, which one?
- 88 civic lx sedan will not get spark
- EF WIT A 94 D16Z6..IDLE PROBLEM
- Check eng. with KOEO and gas floored?
- 90 Crx Si w/b18c Swap Map Sensor Question.
- ef9 front bumper
- Question for fellow ef owners...
- What ef spoiler is this?:
- HVAC vent selection buttons
- NEED HELP WITH 1990 CRX - hasnt ran in 3 years!
- Help JDM B16 Y1 Tranny Seal Help ????
- omni-power test pipe length?
- crx hf bottom end
- CRX was STOLEN.. Chicago.. please help.
- Knock sensor cel code 23
- [help] HKS Exhaust
- Coilovers for CRX
- wheel squeaking
- z6 motor and zc trans clutch and axle question help?!
- Need help with Transmission FLush !?!?
- traction bar on a ef
- Won't crank with key....but starts with remote start!
- electrical problems
- vtec killer cams?
- top dead sensor?
- zc troque specs
- 89 CRX HF engine quit suddenly, won't restart.
- d16y8...anyone running obd2?
- crx wiring problem. HELP needed pls
- some obd0 ----> obd1 questions
- A/c Help *searched*
- Front end help (1990 CRX si)
- Civic and Crx windows the same?
- Heated Seats?
- Anyone know of a good DIY for EF RHD swaps? *already searched*
- engine swap.. now no start
- diagnostics help
- kk problems with a swap
- how to remove vin # from dash
- Battery drain on my 90 HB civic dx
- car problems
- cruise control
- optional cente console peice
- 4 wire O2 in a 1 wire OBD0 car?
- need ???? answered about a b16a swap
- Restoring interior plastics......Scratched up rear :(
- I need some help with my 91 honda crx DX
- d16a in crx?
- Question about a head swap
- WHO DID KEYLESS ENTRY ON THIER CRX/CIVIC HB?????
- STD problem
- Another Mugen MR5 MR-5 center cap question!
- Car needs oil to start???
- dry summit h swap
- Bouncy Rex
- Loud sound, then something fell off. Need help identifying part
- zc and a6 differences
- new to obd
- Need Help Fast 1991 honda crx
- clutch cable bracket?
- tranny
- d15b2 problems
- 2 questions here code 7?
- Del sol vtec to crx si D16z6 PLEASE HELPP
- Quick year/engine question..
- drivability problems(help please)
- Help: How to install sway bars
- Bad distributor?
- looking for new fuel pump, what lph should I get?
- reading codes on obd1 ef
- tansmission question CRX
- Swapping B16b into my 88 crx si and need some pointers!!!
- b16 speed plug
- car studers when reving up
- best mounts for h22 crx?
- Need help with my JDM B18CR swap
- Vote ban on VTECROAR96typeR
- what year vtec selenoids fits 94-01 b18c gsr?
- Unsettling vibration - unbalanced tire or something else?
- NSX cluster ????
- YS1 Transmission
- crx hf rebuild question
- wierd driving problem
- does anyone make the carbon fiber J's racing lip anymore?
- D series skunk2 intake manifold QUESTIONS anyone know????
- obd0 soh zc intake manifold on 99 y8 head?
- B16a 1800 rpm idle CRX
- Theory - How would you build a '10 second' CRX or EF?
- awd 400hp ef
- 91 crx and 91 hatch door panels?
- Are all crx interior parts interchangeable?
- Will 97 Civic HX axles fit Si cable trans
- Need help on finding a part
- advice..
- 1991 honda civic se hatch back
- D15b1 mini me??
- Pic Request: ----> Blue Interior on a "EF" Hatch or 4 door <----
- Low idle when light are turned on? Alternator? Battery?
- Oil/grease burning off exhaust after engine swap
- need help asap please hurry
- random question??
- 90 civic front end question
- Parents SNAFUd my car!!! Someone Please Help!!!
- NEED HELP PLEASE! CRX dies out while driving.
- trouble with my swap on fuel injectors
- crx bog problem
- Silly question before I buy a new O2 sensor.
- good axle or bad axle
- pic request--DA dash in EF
- map problem?
- PLEASE HELP 88' to 00' swap ?!?!?!
- Need new engine: Which VTEC engine should i get?
- Will a 90-93 Integra LS transmission fit a 91' base model?
- BIG PROBLOM NEED HELP ASAP
- 88-91 civic/crx highbeam wired into lowbeam?:
- need to find some one to make me a dpfi-mpfi for wagovan(first time posting)
- new to the forum
- Changed 02 sensor can't get rid of code 1...
- 90 civic dx
- CRX wont start?
- seat problem question
- crx billit motor mounts vibiration
- b16 into crx hf wiring
- New motor prob
- How and what do I need to swap a b16a sir into my 91 civic hatch (not SI)
- coolant bypass
- brakes starts clamping after drivng for awhile
- JDM Front end Problem
- Sorry Rywire
- o2 problems
- all ef
- 1990 honda crx ?
- CRX JUST STOLEN PLZ READ
- Replacing Coolant Hoses: Engine -> Intake; Heater Core -> Heater Core Valve -- A Hopefully Hel
- ECU test
- Question on aftermarket steering wheel
- Speaker Grill Removal
- Mutha[freak](a)s scoping my car tonight.
- CEL Code 8?
- Automatic Seatbelt Problem
- 90 civic dx how do i go from dpfi to mpfi? minnie me swap help!!! wiring in vtec!! please help!!!!
- JDM parts????
- my main relay wont click over !!!!
- what is all needed to swap a b18c1 into a 88-91 ef 2 door and 4 door? Usa da mounts? what about shif
- '91 crx front bumper support help
- HELP!! No steering return cant figure this out
- ARP Head Studs... what is the right way to torque them?
- what driveshaft do i need?
- Obd1 Code issue...
- Pro Arms LCA's
- code 8?
- Multi function switch q w pix
- obd0 to obd1
- how do you remove the crankshaft pully
- crvtec hood clearance
- axles for engine swaps??
- rebuilding a D15 head
- New to Obd0
- seats
- california laws questions
- What brake pads do you run?
- High idling and car does start when hot
- ETD traction bar Failure!
- Brake Problem
- need help asap
- d15b vtec dual carburater swap
- so im having trouble with my hatch
- Alternator/electrical help for 88 crx hf
- Need help with wiring!
- 89 STD 4spd to SI 5spd swap question.
- Automatic trans questions
- Vtec _E in a 89 4dr EF what do i do with the distributor?
- What type of oil to use?
- Trans issues...Help me....
- Rear speakers
- ecu codes
- CRX B16a help! please! i would appreciate anything!
- excessive oil leak
- i need help with my idle???
- JDM DOHC ZC MOTOR. information needed.
- 4 Speakers in Civic DX Hatch? - Rear Speakers Available?
- No Fuel getting to the motor.
- Calibrating TPS??
- edm lhd power window switches...
- Need Help Finding magazine about CRX (Project Car Tuning #7)
- ZC Headgasket write up?
- crank shaft pulley issues!!!
- ZC rear coolant pipe question.
- 91 Civic Stalling in mid-flight .. HELP!!!
- Dangit, did I ruin my piston?
- interior hybrid
- B16 in crx OBD0 ecu questions
- Spiratic IDOLING????
