View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what headgasket to use for a b16a1
- wtb: 90-91 Civic EX front knuckles
- 225/45 or 50/ 15 on a 2nd gen CRX
- Lower Rear Tie Bar?
- Rear Sway Bar for 90 DX...What parts needed?
- Injector resistor boxes?
- EF9 Wanted
- ZC top speed in DX
- Koni Yellow w/Ground Controls really bumpy in the rear
- Just Did B16 Swap, HELP ME
- Distributor Help
- tranny plug
- code 9 means? ?? ?pls help
- what clutch does a sohc zc trans need?
- Got board today. had some stuff delivered check em out JDM
- Place Racing B16 Mount ground Clearance
- Help!!!
- Sweet VTEC Sound!!!
- Mini-me timing belt
- Pics of my car
- How much n2o for b16 in ef?
- Got a couple of pics of my nu project.....91 Crx Si.
- How to build a d16 for turbo?
- Have a 1991 Civic 4DR I Want to know if i can put a hb hood on my sedan?
- resistor boxes for sale
- 89 crx DX dpfi to mpfi
- B16 Questions
- best flywheel to go with clutchmasters stage 3 for 90 crx si
- Conversion (bodywork guys respond)
- Turbo eclipse or gsx injectors possible on DPFI?
- converting to front brakes from 95 integra
- Does this flywheel look okay?
- what can i do with my 90 1.4 dual carb civic in order to get more "power"?
- Tokico or KYB??
- my ride in 99
- B16a Overheating
- WTB: D16Y8 Pistons
- mini me
- Which will fit the 88-91?!
- the rex got hit!!!
- Motor problems.. need help.
- integ short shift in EF?
- Can I get or make a turbo for a stock DX????
- smoke
- removal of tar soundproofing info and pics! and more!
- Idle problems.....HELP
- high rev's
- Does anyone have any CRX SI seats for sale??
- Wow loud!!!!!!!!!!!!
- B16a1 from hondamotorsonline.com ?????????
- what swap can I buy for 2400 cdn if I do all work by my self.??????
- need help B16a
- Non OBD to OBD1 question
- need help w/ project.. 89 civic dx w/ jdm d15b motor..
- exaust question!!! please help
- Tranny?
- idle problem, please help
- dx final drive in Si tranny......
- Help! Gear box problem
- 88 Si high perf. clutch?
- ODB1 b16 o2 sensors question
- cost of LS swap?
- ECU help
- Help: Tenzo Type R seats
- where to find these trannies?
- D16A6 + Boost? What cha'll think?
- Rollcages
- crx DX or Si?
- FS: B-series cam gears & JDM EF parts
- Spark plug gapping
- Link to classifieds for H&R sport springs
- found my timeslip
- From a Stop or From a Roll?
- just got wings west kit
- Look!!
- New Rotas Sub-Zeros
- Drag or Greddy
- hf tranny??
- Hazing the n00b
- All right fellas which is faster, a Type-R or H22 motor in a CRX.
- Where can I find this?
- CT-R swap in classifieds and on ebay
- B16A woes...
- Wanna see the ugliest CRX ever? Better have a strong stomach......
- Need help qick!
- b18a vs sohc turbo
- Tell me if this is CA-smog legal
- Anyone turbo charged a 2002 civic Type R yet ?
- what size socket for axle nut?
- Anyone know the limits of the D15B2 crank?
- Msd Modified Cap
- dangers of battery?
- sensor on top of intake manifold for OBD2 B18C1
- 2" or 2.25" cat or no cat??
- JDM Y1 Speed Gear
- Crx
- which clutch and flywheel to use with 89 JDM sir b16a
- alternator's
- SiR Shift Linkage??
- 2000 Civic Si Greddy Turbo on a crx
- Sway bar on HF??
- Osaki Sports muffler
- crx center console in hatch
- idle trouble with turbo zc(plz read)
- adjusting valves?
- ITR, CTR pistons and rods
- 89 CRX DX with a 95 B18B1, Wiring Problems
- JDM SiR cluster in my 90 CRX Si
- Who has Autosonic (Arcadia , CA) address?
- Hey got 3200 what should i do.........
- Power Window how to
- summertime engine work ?
- Are 1990 CRX SiR (EF8) front spindles the same as 90-94 Integra?
- so i need a little help here
- why cant i put a sir hood on a usdm?
- JG 301 cam
- DIY polish/paint valvecover
- OEM Rims
- Hub Assembly Question......
- JDM style hood on usdm EF..... Any modifications needed?
- Upgrading master cilinder
- automatic zc motor?
- turbo, radiator
- B16a Replacement water Pump
- props to crx's
- what rubber on stock rims?
- Your suspension
- Best USDM Carbon Fiber Hood
- 95 Sohc Vtec Head w/98 intake manifold on crx
- what would you do with ...
- I searched but could not find..
- ideas on mounting MSD box in crampped engine bay
- CRX si to ZC wiring (I need help)
- Need some help !
- used rims shops locations wanted
- My suspension feels hard as a rock......
- Cvs and lowering a h/b
- Tie rods
- Im spoiled, i want power steering on my 90 DX.
- anybody have pic of black EF hatch with SI's???
- ls distributor on a b16a HELP!
- open cam gears?
- need info-sway,strut tower,tie rod,lower arm BARS
- What color should I paint my vavle cover?
- B16 in 91 ef si hatch questions TPS, harness HELP!
- Which oil pan do I use for 1st gen JDM B16A???
- TPS question?
- 89 HB shaved side moldings
- Signs of a failing main relay????
- Aight Screw this!!! lol
- Almostttt there.....ok not really.
- Need your opinions on a 87 or 88 rex.
- Anyone with a Buddy Club exhaust on an EF?
- ex tranny in crxs1?
- 89 CRX Si engine swap?
- ZC gone bad...
- Wiring help on sohc zc...
- 1.5 to 1.6
- Steering wheel swappage
- lol...i just realized how much potential my zc has
- 1st gen safc vs 2nd gen safc
- DC Header, will it fit?
- What cat to use on B16crx?
- LS engine is throwing code 43? Help!
- Got rear ended and now running lights don't work, WHY!
- Anyone with a HAsport mount kit and a turbo kit? Curious if it fits?
- I want to go faster.
- Factory CRX (EF8-9) SIR Specs???
- what will a 90 crx si run in the 1/4 mile
- what is a lab sencer what does it do?
- Good Deal?
- good place to find used engines?
- Fender Fixing, SOHC VTECing, P/S converting....OH my!
- D Series piston project ... latest addition
- All motor options in 1st gen b16
- pic of my crix
- Houston H-T Meet
- si internals into ex
- CRX's in Wisconsin?
- hi i am new, with a few Q's?
- I may be trading the rex for a......
- From this to this
- crx weights?
- Anyone with this set up---> 5th Gen civic w/ JDM 2nd Gen B16A
- Turbocharging a ZC DOHC in an EF3 Civic
- lil help needed
- front bumper
- i'm gonna make a real rice mobile, what do you guys think?
- zc in dx?
- Fucking Theives
- pics of 16" white racing harts
- Radius arm bars
- My pos
- Am I dumb? What is this?
- SpeedTrialUSA Track Day @ GingerMan Raceway June 3
- a/c mount for ED with B16.
- Sway bars
- ricer
- Apex'i VAFC wiring on a Mini-Me
- darn axle broke
- could my ecu be doing this?
- GSR Knuckles, Will it work?
- Best price on a Neuspeed Rear Strut Bar...
- what series on 16'' rims? and other tire questions...
- can anyone tell me???
- I have a 90 crx si with powerwindows. Will 88 si doors fit in there?
- 88 CRX Si Seats in 88 Civic?
- West Michigan Honda Meet MAY 25th.
- How do you remove the back seat in an EF Civic?
- making "members rides".......
- Locked Thread
- Whast everybody running for exhaust...
- 01 PYR for sale !
- Gsr cluster in 88-91 crx??
- valve clearance
- crx with del sol front end
- Uh-Oh-Alignment?
- Just got my slipstreams and Falken Azenis....(sorry no pics)
- Hyper Blinkers
- The D16A1 motor
- Nopi at Maple Grove?
- D16A9 timing...........
- 88 hf wiring???
- clearence with a hasport mount kit a b16 and a 4-1 header
- new stock clutch usable with 16" new rubber??
- size of door speakers?
- no longer posting or viewing
- WTB: GReddy or similar exhaust for 89 CRX Si
- B16A valve tap
- any EE wagonEErs around here...?
- Modified Shift Linkage
- B16 prices with or without mounts
- wanna buy my car?
- Anyone own any 4th gen sedans?
- Another Dx to SI question
- Will this work?
- which timing belt
- Opinions on 2 different wheels(specific)
- member rides
- Can you use a 94+ Integra short shifer in a 91 CRX with a stock dash?
- Need Brake light help?
- ECU Wiring
- can I drive my car like this?(((((help))))))
- LS/Vtec Ecu
- right hand conersion?
- Does anyone have an extra D-series valve cover?
- Removing Crisco and Pam???
- Passing inspection at 1/4 mile?
- picture hosting change?
- how many members in louisiana???
