View Full Version : Honda CRX / EF Civic (1988 - 1991)
- can they put anymore tar on an SI?!?
- 89 DX Hatch w 88 Si CRX Wiring???
- d series crank help ??
- post your TURBO SETUPS here
- How to check for a bad brake booster?
- intake manifolf
- TOP of BOTTOM... which is the easyest way to remove the altenator?
- Sohc NON vtec si head on dx block.. HELP
- Best Cams for the $$$ for d16a6......help!!
- 92-95 SOHC VTEC <IM> ON D16A6!!!!!PROBLEMS..HELP
- Should I cut the bumpstops on my Tokico blues?
- WTB: EF Civic... under $1k
- how to remove dead pedal
- bench bleeding and brake booster check
- stock brake upgrade options
- Attention Nj/Ny/Pa-Need a hand..
- What wrong with my clutch ????
- Zex camshaft for a D16Z6 or a crower...
- 90,91 DX ps blue door panel
- (question) crx tranny gurus help.
- Best thing ever: Chilton's part #8256
- RSX swap into a Civic???
- 4 door Civic rear handles on CRX? Help
- Water temp. gauge?
- ZC Question?
- lx hood and front fender on a crx
- code 17,my rpms and speedometer dont work?
- **fuel filter question?**
- Wierd Idling Noise...HELP! asap
- bottom end worth it?
- Max tire width on 90-91 CRX Si wheels......
- What engine in my car?
- How to check codes with LS swap???
- Guys with GSR gauge cluster into CRX, need help fast???
- body ??'s for crx's
- How loud would the car be with out the muffler?
- 1st gen b16a to type r intake manifold upgrade: questions...
- Using msd rpm activator as my v-tec controller. Wiring Help needed.
- A/F gauge problem
- need a wiring diagram 4 a hack job by previous owner
- Engine is smoking after header install...HELP!!!
- Weird noises coming from front brakes, WTF?
- cancer
- MTF oil?
- Where do i Buy Ground wires?
- What intake manifold gasket to use???
- Mill 30 thou or 20 thou
- shooting cars behind you with the windshield wiper jets.......
- Header clearance with LS???
- EDM Cluster for my CRX
- A6 Rebuild question
- sticky throttle
- easiest way to remove axle
- weight of my hatch
- 1st gen. radiator on a 2nd gen crx
- I think i just bought a b16 tb??? HELP
- Si-R swap, what next?
- 86 CrxSi Question?
- Best Spring rates for 89-91 civic with B16
- need help with ecu code 7 and 13
- troubles with installing short shifters ? anyone ?
- new here
- Spring Rates
- Do you have a EF because you want one...
- V2 Coilovers Are they any Good?
- can i put a VTEC head on a HF....
- Need help from Admin. IM error
- i need stock HF doorpanels, only in AZ!!!!!!!!!
- Stock Airbox with K&N filter vs. AEM CAI
- Dyno tuning tomorrow *fingers crossed*
- integra seats
- 1987 crx si wheels?
- i need some help swapping an si motor into my dx
- Dpfi to Mpfi
- need quick help please??
- CEL 23.....KS not wired
- sohc, dohc, d series, b series, what to get.
- Has anyone here changed their Wimpy Horn?
- got the vss, but will my speedo be correct?? Cause of different tire sizes.
- GSR Brake Upgrade
- FS:90 si hybrid b16a3
- axles aren't going in! help
- Canadian Shops and build costs
- why the hell doesn't my horn work?
- Axle-back, will a Civic one fit a CRX?
- What upgraded rotors do you guys prefer?
- brake problems
- How to adjust the valves?
- Steering wheel Play?
- Idle Surging when depressing brake? SICK!
- Need help with B16 swap, I think I'm Retarded....
- WILL it fit
- 5 lug conversion?
- Homemadeturbo.com???
- Is it ok to use synthetic motor oil?
- Terrible idle on 1st Gen B16
- **crx hatch rattle?**
- whats this engine code
- a question how much should you retard your timing
- windshield
- Help me!!!
- question about European CRX/hatch trannies
- zombies sell b16a's?? what the..
- where are the front bumper bolts......
- Will an IACV from a SOHC EG work in my OBD0 EF?
- B20 swap was fine, now what!?!?!
- nitous oxide system help
- ZC Info Needed - OBD0 & OBD1 Differences
- 88 hatch won't start after being run
- Oy Vey! I fried my guage cluster!
- MTL problem
- EF sunroof
- plz help me, swap question
- 88-91 hatchback dash swap?
- Quick question: RE---> altenator on a B & Dseries motor
- B18A axle question
- Ignition signal output???(CEL15) gurus please help
- Throttle cable bracket ?
- Exhaust leak ?
- lift points on engine - where the #*!* are they?
- Compression turning over problem????
- Can someone please help me with wiring my B16 in my crx hf?
- OMG!!!! I'm drooling OVER this Mugen d16a6 engine Hot damn!!! *pic*
- computer readig
- I'm new here :) Introduction....
- how to test TPS?
- NEED help haveCEL 15
- VIS c/f "SiR style" hood... clears b-series swap?
- 96-00 EX swap into EX??? HELP!!!!!
- Would a barometer sensor cause this?????
- Sohc ZC
- honda history
- gsr master brake cylinder?
- how low can they go??
- Spring Rates On Street/Strip Modded EF Sedans??
- clicking noise when turning
- huge 1/8 by 2 inch gash in radiator!!!
- timing on b20b!!!
- i think i cooked my car....
- Dx + B16
- just got a crx
- Big problem when CRX sleeps
- how to change manual transmission oil??
- Falken Aziens or Toyo FZ4?????
- Small radiator leaks? Fix?
- B20A Main cam bearing cap torque spec?
- Is my Thermostat dying?
- D16Z6, a couple questions... dizzy and mounts?
- mugen d serries engine ?????
- B17 supercharger PROBLEMS!!!!!
- 90-91 teg Throttle body fixing
- WHAT DO I DO!?!?!?
- cf hood fitment?
- SI manifold on and HF
- Wheel bearing and tie rods? Are they hard to replace.
- Well the y8 intake swap is done *pics*
- LSD Tranny Question
- Dumb quick question (concerning Eibach Pro-Kits)
- How can I give a stock D16Y7 some power and torque?
- Thoroughly confused(tranny question)
- NorCal (bayarea) guys - need help!!
- sohc ZC output
- Tranny Question?
- integra intake in an EF
- Speeding up the lil SOHC
- ? D16y7 Question ?
- SOHC Vtec Swap
- Obd2 in a Obd0 Crx???? Help Please!
- B18c Block wiht B16 Head??
- MPFI question?
- HELP! My car won't start! Part II (I've made some progress!)
- O/T Help I Can't See Pics.
- Having strange problems with my D16A6
- crx handling?
- Help me build an All-motor Mini-Me!
- 2 1/2 inch collector + greddy sp exhaust
- coolant temp ?
- milling d16a6 head
- help with turbo
- neuspeed sport springs
- 87 Crx Body
- Clutch or Tranny?
- JDM honda parts orange dark orange crx, need the pic please
- Header install wooas
- NE1 using CRX SI rear swaybars on DX?
- Help With 91 CRX sway bar install
- need help w/ mini me swap in crx
- Dallas Shops
- h0ly ripoff batman
- Looking for a link off HT - exhaust
- I have a few short vids of my Civic....
- what suspension set up have you gone for?
- Dohc Zc swap!!! pics inside too!
- lexan windows for 88 crx or any other light materials for window
- skunk2 extended lug studs..
- Ignition Switch options.....
- vibration woes
- Stock vs. Modded
- help finding a carb dohc zc
- Hurst short shifter
- what could cause this??
- what is required to change from obd-0 to obd-1 for ls/vtec in crx
- What to get
- Whats the best engine for a crx
- need help installing shift light on 89 crx
- Turbo crx
- Exhaust back pressure! Opinions needed!
- gas smell
- Need pics for ef9 backseats!!!!please
- turbo questions
- decisions decisions...
- window fell of track
- rear quarter help....quick
- Momo Hub adapter....only one part # for 88-91?
- Please help!!!!! 88 Civic, B16, no power to ECU!!!
- Wiring troubles, wiring gurus help...
- EF Swap Techs Please look
- AEM CAI owners.. got a question....
- timing & alternator belts
- Finished swap then a Suburban crashes into me...Damage estimate please...(pics)
- EF w/ b16...anyone elses shifter rattle at high speeds?
- what kinda times can i expect with a SiR2 swap and bolt ons?
- RPM needle sticks and 0 then jumps up to normal, what the?
- HELP!!!my idle is at 4k and won't drop.....
- Smog techs or anyone else please help....
- Has anyone converted....
- ACT or Exedy clutch....
- Bisimoto header!
- my injector broke.. help!
- Integra dash in 88 crx
- OBD0 o2 sensors
- b16 into 89 dx civic....trust me i searched
- b18?
- sohc vtec motors
- Hasport mounts
- my civic is crunked
- P2E Ecu??????????/ From What?
- is my coil going out?
- What are your thoughts on Injen CAI's
- Huge Fat Tires!
- considering crx or ef. few questions.
- will the rear disks off of a del sol fit on my rex?
- yo check out this SiR on ebay
- purchased some parts today!
- oil around spark plug wires
- what to use for my home depot lip on crx??
- OBD-1/0 Problems
- jdm siR front brake assembly
- Tornado sucker thing?
- help out please
