View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Look what I got for 130 bucks!
- What is this for ?
- 2nd gen dohc zc motor into a crx
- weird sound coming from rear wheels
- how much for a new tranny?
- Idle Changes With Brakes Applied
- Its been over five years since ive had my CRX....
- Fuel Pressure Regulatar question...
- quick head swap question. first time need guidance.
- how much is my ef worth?
- 1.5 to 1.6
- dx with a sunroof
- Wire tuck map sensor question
- Is the Transmission for 92-00 the same as EF? Guide in FAQ is for 92-00...
- CTR pistons, which piston rings???
- dizzy help!!!
- clicking noise coming from dash
- parts for jdm dohc zc motor
- Dizzy help!!!
- car sputters need help
- Re wire help needed " CRX"
- INJECTOR SWAP. OBD0-OBD1 WIRE DIAGRAM
- Need help with Brakes ASAP
- Halfshaft problem, searched
- OBX LSD - where should I buy???
- B20B and CRX swap
- si trans code
- spark plugs
- Trying to finish the wiring of my P28
- My Experience with Rywire - EXCELLENT!
- B18a1 timing belt question
- Help me finish my DA brake conversion!!!
- Need help ASAP! Clutch pedal is broken
- wiring diagram for cd player
- 91 si map sensor
- JDM Climate control install?
- can someone rub me the right way? +32 offset on 15x6.5.
- 91 Project Hatch STD
- Problem with my blinkers
- ? about 4-door handle swap on crx, do i need to use differrent rods?
- Looking For a crx
- LOOK HERE WIRING GURUS. I need help finding out what these plugs are
- i KNOW THIS SHOULD BE.
- OEM Si center caps interchangable?
- My Mini Me results
- Help, best way to pull alternator out of EF hatch d-series
- Need more topend
- auto to manual swap on sedan - 99% done, got a linkage problem - TOO LONG
- Help with wiring
- j1 tranny
- mini me a6 z6 whos done it
- CLUTCH ISSUES..............
- PIC request
- fenders
- pics about crx tein or newspeed springs
- 89 crx si cluster wiring to a jdm sir cluster
- Ladder or wheelie bar info needed/
- Guesses?
- Buying CRX, need advice.
- Code 8 and my car wont start. HELP!!!
- Extremely low gearing
- exhaust in cali illegal or what
- need help
- window visors
- good sticky tires, not "meats"
- MSD DIGITAL 6 vs. msd BTM
- HID Ballast placement
- DIY Voltmeter and Cig. lighter relocation
- help
- Wrecked Crx
- sohc d15b7 swap to sohn zc
- Leak problem
- Which way does the fan spin ??
- what clutch for s1 tranny
- ZC in a crx..
- car takes a long time to start???
- Question
- windshield trim
- EF Squad Decals
- WHAT DO I NEED TO DO THIS SWAP?
- trade
- Wiring obd1 d16z6 dizzy in too obdo harness anyone know?
- b2 swap out to b7 intake manifold
- 99 Si Valve cover fit an obd-0 B-series????
- Can somone help me find my compression?
- 88 crx for sale orlanda fl...sohc vtec swap needs body work,seat carpet..red
- overflow tank bubbling???
- car not starting?
- OBD1 dizzy same bolt pattern as OBD2?
- Door handle install
- *searched* JDM bumper on my 91 SI.
- Will 90-91 CRX SI Rims fit 90-91 Civic EX front brakes
- Question about ECU
- Vacuum Line Replacement
- Heater Fan Motors & Intermitant Speedos
- Transmission Problem
- Dual O2 On a B16a????? WTF????
- Engine swap
- Ksport lca's?
- Another spring question
- D16A6 Assembly Question
- b18 swap
- b16 turbo parts (want to buy)
- removing motor and tranny; any way to move car afterwards
- will 99-2000 si front and rear disc conversion fit HELP!!!?????
- redline tv
- 15x7 wheel question
- tell me info about this engine and tranny #
- help on finding info
- 91 CRX HX tranny + B16 engine = Doable or NOT
- pcv valve
- Those JDM Engines of Ebay Questions
- hatch help
- CRX Si clutch in a 94 dx
- tachnometer
- Miata Cluster into 90-91 CRX
- lightz
- Head, dizzy, and compression help!
- new dizzy, car won't start
- Honda OEM center cap ?
- Black CRX picture request
- rear bumper support
- b16a1 swap question
- What tranny do i have?
- Is it possible for: 88 civic dx hatch w/ d15a2 to have 175whp... 0-60 time of 6.0sec
- Need helping finding clip that hold speedometer cable to tranny, i need to order online
- 90 Si hatch Oh-shit handles
- Temp Guage doesnt work when on..but works when off, but in on position???
- shift linkage needed?
- h22 motor mounts for a crx?
- Bronze Tint; i know, but I WANT to do it....
- OBD1 Conversion, Now Gay Idle...
- SOHC ZC Exhaust fitment?
- ????pics????
- EF Hatch as a parts hauler.... will a B-series motor fit in the back?
- LS Vtec?
- D16Y7 into '89Dx HB
- SearcHed.......Odd smoking on DoHc ZC
- need help removing door panels..
- sooo... is it possible?
- Hatch bumpers onto CRX?
- good sticky meats
- Idol Issues(need help)
- Fuel Injectors
- interchangeable?
- Help with wiring problem code 15 HELP PLZ
- Quick Question on B16 EF-Swap hubs on DX?
- JDM or USDM replacement?
- P2J-1 head???
- number on my rocker arms
- check engine light
- Axel Chart For EF Civics X Trans + Y knuckle = Z Axel
- anyone have a MEGAN N1 catback on there CRX?
- Installing 99-00 civic SiR Fuel Pump in My 1990 Crx with b16a1
- Finally!! first run at LACR Posting video soon!!!!
- home made b-series ITB???
- mini-me timing belt
- Two Brake related EF CRX Question (ABS, and Rear Disc Conv -> what happens to parking brake?)
- ABS brake set-up to non ABS
- Ball joint removal
- reinforcement from crx 88-91 is it ithe same as ...
- where to find
- Ef9P730
- Interesting problem...
- Help!!!
- Crx starting problem, help me if you can
- CRX fire. Opinions needed
- retarded tranny q 90 integra
- B16a Conversion diagram?
- mid engine crx
- What to do with the old, shitty engine...
- MINI ME VTEC
- ***HEEEELLLLPP!***Car Starting Whoes 91 SI LS SWAP.... DISTRIBUTOR PROBLEMS? Wireing?? hell i dont k
- fit a 99 b16
- my 3rd brake light is out. will ek work?
- ONE MORE PROBLEM
- converting lips
- 1st Gen intake or P30?
- idea what to put on instead of my sunroof ?
- Car stalls after Fast acceleration an coming to a stop
- ef's with a jdm gsr b18c or usdm b18c1 i have search already
- 87 civic 12 valve 1.5 timeing belt
- How do i fix my cluster
- help getting DOHC ZC passed emissions!!
- what size exhaust piping for jdm d15b?
- What durometer engine mounts to get?
- HOW the hell do i take off my headlights!!!!!!!
- Always excessive lash on a bent valve?
- 91 si hi i need help honda runnnin
- confused about HID for sedan (searched)
- rex or hatchie? help me
- Turbo List for my CRX b16 (am i forgettin anything?) and i have fuel management Q's
- 88 Civic Stalls when braking
- ef hatch pass mirror vs crx pass mirror
- z6 and a6 head studs same?
- 16 quicks flashes from ECU on std
- Will a stock hood work with EFB1 mounts???
- How To Install ???
- Any1 have or know about the Tanabe Super Hyper Medallion Racing Exhaust for a CRX
- DOHC ZC bearings
- minime setup/what arp head studs??????????????
- Finn rims??
- dizzy question
- Replacing taillight bulbs/gaskets
- New from the UK
- b series half shaft question
- Map Sensor Removal??
- d15b2 with y8 swap distributor questions?
- msd with out blaster coil
- main relay,why does it work only when i jump it?
- Simple Radio Mounting Question..
- Rod knocking??
- what time?
- Spherical Bearing Upper Arm Mounts
- b series questions!!!
- couple quick questions before starting (balljoints, alignment etc..)
- Going Going Gone
- D-series hydro to cable conversion.
- weird problem, code 43 fixed!
- larger and wider wheels to balance out the EF
- How can you tell if you have an Si tranny AND where to get it rebuilt?
- burning smell WTF??
- how much is a mpfi swap worht? (ecu, intake mani,wiring, guage cluster ect..)
- 92-00 spark plugs wires on si motor??
- good turbo setup for d16a6
- HElp!! Car smokes White n smells like Gas
- C-Pillar bar
- What cluster can i use for a 88 civic hatchback...base model.
- Fuel Lines are rusted through...?
- Total number of EFs sold in the US...???
- help with wiring please.
- HELP PLEASE!!!! JDM CLUSTER IN 88 CRX DX...
- d16yb
- 1986 CRX 1500 HF! Help!!!
- 1st gen CRX air intake
- CRX Owners Opinions
- What cluster can I use with electronic VSS?
- D.A. Cluster
- help car bogging,then dies
- oem si wheels?
- Which pin is the stock VSS cluster pin for 90-91 crx?
- need help... vtec is not kicking in....
- noob question about itr steering wheel...
- Turbocharged and stock rims... looking for input
- Lets See That Quarter Panel/Fender Rust
- oil pan gasket leak. do i need to remove the header?
- CV axle replacement
- REX HELP!!!
- OIL LIGHT JUST CAME ON!!!!
- iacv
