View Full Version : Honda CRX / EF Civic (1988 - 1991)
- is there a difference between crx pulleys?
- B16 Bogg help.
- 90 hatch dash in 89 crx? please help me !!!!
- change blue int. to black w/ fabric paint
- Arm rest in a CRX?
- Quick console question.
- OBD1 conversion code question.
- Guage Cluster Swap
- B16 swap question
- 90 CIVIC SI seats in 90 CRX not working?!
- ? for EVERYONE??
- UKDM crx si speedo cluster 150mph!
- Need Help: Ppl with JDM/USDM or other Fog lights please look within.
- Tein V's Zeal
- Rear disc brakes....
- best CAI for a swapped b16 motor in ef?
- zc to si problem
- Which parts from which blocks are the best??
- Car wont start cause of a little piece of rubber?
- 89 4 door civic
- Any Bay Area Shop that does HID Retrofit???
- black trim or color-matched trim?
- Which wires to run?
- How To Fit Them Together?
- D16A6 ECU HELP!
- VTEC Controller?????????
- splitter on EF
- havn't seen this topic covered yet (searched too)
- well, im taking apart my head
- bouncy dammnn
- y7 to y8
- pw0 and pr3 ecu questions... need help
- THEY FOUND MY STOLEN CAR IN RICHMOND AND I HAVE A QUESTION
- hf ecu in a 90 civic hatch with mpfi
- 90 civic std. ac swich wiring
- fastest setup for 1500$$
- D16A6 vs. D16Z6
- what axels to use for 91 EF with J1 Tranny on B16A1 ??
- mounts?
- sputtering while driving
- D16Y8 Intake ??
- Quick question about an ig timing plug...
- Keep $3k 97 Civic Coupe for Si/SiR Conversion or buy 2000 Si
- 91 STD HB Interior
- CRX JDM SI-R Conversion kit?????
- Type R Suspension on a 1989 CRX Si
- si dizzy
- Anyone know a good place to buy lightweight 14" wheels and R compound tires?
- girgle girgle shift
- Del sol shifter in 88-91 crx...fitment ?'s...
- whats the best swap for???
- help with body part..
- d15b question
- knock sensor for a B16
- Walboro fuel pump install EF
- d15b vtec times?
- safty/dashboard
- For you guys with EF/Honda websites, or any websites...
- civic dash in crx?
- 91 crx si steering rack
- FS: B16 89 Civic Si..YES i posted in CLASSIFIEDS!
- What to adjust my cams too?
- fs: b16 motor in northern Virginia
- Anyone ever ordered from autofuzion.com before
- D-series hydro tranny install?
- SiR Sway Bars
- Converting to OBD1 from OBD0??
- b16 valve cover
- zc wont start; go figure..
- I need a tranny
- if your car is dropped look here
- best header?
- Potencial of a B16a all motor ....does it have any?
- I need a cam
- D16 into EG
- Tein RA's on an EF anybody got 'em?
- i just found crx/civic front lips in German on Ebay!!!
- looking for crx body kit
- ZC wiring complications...Where do these go?
- what starter for a 1st gen b16 w/ s1 tranny?
- camber kit / how much wear without one?
- Possible Car to buy, questions
- difficulty passing emissions with the b16a engine in my crx??
- What does everyone think?
- b16a1 hearder?
- Apexi on D14A8, type MB2 Civic
- kicked out of racetrack...92.3 decibals
- MSD blaster 2 coil setup
- automatic seatbelts+ aftermarket or other seats.
- what the story on this D series header?
- Kosei K-1 15x7 45mm rubbing lca???
- dissy question
- crx body kit install tips?
- ECU Codes
- Parting out 1989 Civic HB with 1995 D16Z6 SOHC VTEC
- What Exhaust?
- JDM CRX SiR Air Box Intake Assembly...
- Oil pump... has anyone rebuilded one???
- Race Fuel
- b16 exhaust question
- A few ???
- slow b18b
- holy s***, obd0-obd1 conversion woohs
- Is it worth it?
- borla exhaust
- What could be causing this???
- tires for my car
- Need Help!!
- Can Urethane Be Wet Sanded To Get Rid Orange Peel? ASAP
- does any one sell...
- Which exhaust for my 88 Civic?
- I dont know why it takes me so long to start my car..
- why does the car keep turning off on me........
- Is anyone using a DA master cylinder and brake booster in their rex?
- signs of bad fuel pump
- Need info on pulse from dizzy...
- Alright, I Got 84 CRX Si, I need Your help!
- jackson racing supercharger
- AEM FPR from 2K civic SI
- service connector loc.?
- strange noise
- CRX Corner lights? anyone have extra
- My window weatherstripping fell off, what can I do?
- Short shifter question
- b20/vtec
- Timing belt is off a tooth, how to fix?
- Drop tank to change fuel pump?
- how to hook up 91 si ecu to engine without under dash harsess?
- Battery relocation on EF..more ground wires?
- recalibrated the throttle cable
- jdm d15b vtec
- HOW TO GET HUB NUT OFF AXEL!? replacing ball joints...
- 89 civic hatch helm manual now available
- Stupid Civic Windows
- 90 CRX air Vents in to 91 CRX?
- Is my vtec solenoid out?
- Car went wack, need help quick!
- Rust spots?
- Possible Fuel Problem
- ZC distirbutor help!!
- can I use a CIVIX EX cluster on a 88 CRX Si?
- What shifters will fit?
- need help with msd activation
- vss question ( civic 88-91 94+ gsr cluster)
- question on bumpers
- 91 dx 4dr w/ d16z6, having mpfi problems
- does the Hatch hood fit the 4 door?
- Help me decide which path to take
- For those with b16's in their crx.
- D16z6 dizzy???
- single cam vtec d16z6 redline??
- second o2 sensor bung
- Cam Gears Question
- Code 14, last problem wtih swap, help please?
- ED9 Si guage cluster into an 88 ED8 DX?
- Messed something up good, need HELP...
- Civic DX ZC
- '91 si: how to get to 88hf weight?
- 89 civic si.... is it worth 500 bucks?
- How many gallons does a crx gas tank hold?
- b16 civic tuning
- best crx swap ???
- Cable to Hydrolic tranny swap.
- new member
- lets see some pics of ur momo/sparco seats in your EF's
- ef carbon fiber hood?
- ecu help
- bent valve symtoms
- Crx Factory Style Sideskirts
- door won't open
- 87 crx front clip
- Helm's CRX service manual
- A new CRX???
- new member.. Hi HOnda tech
- -----b16 CRX ,what fuel filter?-----
- d15 vtec
- BEST Suspension??? Need your input.
- Fuel Tank Swap '88 HF tank into '90 DX Hatch
- What do you guys think of the Honda Civic Ex?
- CRX New B16 Seems to be Running Hot
- CRX owners with type R swaps...
- High Flow Cat.
- Is the CRX Si and DX hatch front suspension the same?
- Hatch strut bars on a crx ??
- y8 mani on a zc (searched)
- b18c5 -> cooling problems?
- dash swap ?'s
- b16 w/ ITR IM, crx intake possible?
- CUSTOM CRX Plates!
- Flywheel weight?
- 89crx si d16a6 what ECU do i have?
- diameter of AEM cai?
- steering rack
- car dieing at idle
- WHAT THE FUCK? NO o2 SENSOR? PGM-FI
- z6 swap into Si=15.56@86.56
- b17 swap into 90 Std. Civic, weird sensor on back of block
- True or False: The oil pan is pressurized and can be tap for oil pressure?
- Drive Axle Help!!!
- Do they make replacement hubs for EF CRX's?
- CRX dash parts
- Interior Lights
- Springs,Coilovers and Ride Height i need some help with my 91 si rex.
- good springs that will give me a 1.5-1.75" drop in front??
- Suspension Problems
- Need help MPFI Vacuum hookups!!!!
- Tranny gear ratio question
- Differences between hatchbacks (Not CRX)
- B18A in 88 hatch
- which cv axel to use?
- what does the lock up solnoid do?
- Removing Tints...Again
- Help identifying parts for a Mini-me, ECU and Head.
- part # for input shaft bearing in 91 Si tranny.
- Why isn't my `86 Civic alternator working?
- fuel pump install help
- osaka email
- What spark plugs do you use for a ZC motor from a jdm 91 civic hatch si
- how to remove door pillar molding?
- differences ijn CRX and Hatch Si tranny
- anyone know if 5th gen shifters fit in 4th gens?
- Beater wont start sometimes - light flashes 16 times??????
- Car DEAD HEKP MEEEE!!!
- The Project is over. My EF and lots of stuff for it F/S
- Question on a Purchase - Comments Welcomed!
- 90-93 DA integra dash into a EF civic hatch?
- Exhaust Piping on B16A
- Wire diagram for Climate control
- b16a (SiR-II) or XSi?
- Bad CV Joint/ O2 Sensor
- TO ALL EF MEMBERS
- stereo codes
- Bisimoto D series Header Dyno
- Is this a sign of bad ball joints?
- Power Steering
- what brakes I use?
- What do I look for In a bodyshop??
- Battery problems....
- STD Gas Mileage?
- Will a D16y inlet gasket fit on a D16a6? Hondata heat shield???
- RS*R B16 Header
- 86 CRX SI swap question!! help!
- Tokico suspension kit?!?!
- zc ecu code problem
- ef vs. eg: Which is better for autocross?
- thank! whats the right plug gap for the b16a
- DA rear disc brake conversion?
- Wiring Question?
- JDM ITR non-SRS Steering wheel in EF: HOW????
- B16A FIRING ORDER PLEASE!!!!!!!!!!!!!!
