View Full Version : Honda CRX / EF Civic (1988 - 1991)
- clutch replacement???
- Starting over on wiring
- where can i find a ac block off plug for my ef hatch?
- thermosate houseing help?
- Fiberglass/Homemade armrest?
- help me out
- Engine harness
- any difference between 91 dx and si carpets?
- ls vtec
- NEED PICS OF YOUR CRX REAR VIEW MIRROR!!!!!
- why wont it fit the 91 std ?
- how do i take off my stock spoiler?
- Speedo Cable question
- CRX Motor Mount Question (Not Swap)
- turbo build on d-series ?
- drag dr-16 wheels?
- Aftermarket Exhaust questions..
- so i found a really good deal on a crx
- tranny question???HELP
- Compression specifications of D16A6
- got a problem with high beam. searched already.
- need to know once and for all
- 89 hatch wiring
- ?intercooler install question?
- Axle broke
- *sigh* another stolen crx
- Bye bye parts car!
- o2 sensor plugs?
- code 21
- Brake Problems... :(
- will these parts swap onto a 91 crx si
- Need Shorter Shift Boot
- gears wont go in
- Some simple EF sedan questons.
- TOV March Calendar Y-49 Calendar
- Seat harnesses
- white smoke
- steering wheel shakes
- What about my rims?
- jdm rear wing question
- Electrical - My Interior Dome Light is only ~5V, not the 12v+ (13.6?) it should be, why?
- 88' Hatch DX, with LS Throttle Cable (where to buy it)
- NEED A/C HELP IN CRX
- B16a Y1 Tranny Guru Needed, have a few questions after swap.
- traction bar turn issue
- Street/Slicks Tires!
- 88 tranny different?
- Boost a D15A2, bad idea?
- CRX VS. HATCH??? WHO WILL WIN
- any one want mugen floormats!!!!!
- This is what happens when you drink and drive. (56k go learn german)
- asr plate for Civic?
- speed sensor
- Will a 17 inch rim with 45mm offset rub???
- Crx exhaust fits Civic HB??
- oem parts
- civic / crx hood width
- how hard to fix? bodywork questions
- tdc sensor------->please help
- ODB0 to OBD1 conversion (wut else do i need?)
- my 1990 hatch... startin to transform her...
- function & form suspension
- Best Oil for SOHC ZC Swap?
- b16 dizzy
- Electronic VSS
- More b16 OBD-0 hesitation woes
- Please Help 1990 CRX will not start
- Will a b-series tb fit on this intake??? Help
- map sensor code 5
- How rare are OEM optional CRX floor mats.
- damn check this crx for sale on ebay... it got g35 tail lights and maximas headlights
- obd1 d16a6?
- where can i buy a tranny online
- EACV HELP... not understading
- Rubber trim on the bottom of the window
- ECU codes, code , explanation
- Turbo 16b questions and drag kit questions
- header problems
- getting code 14 b18a1
- Civic Hatch- resurrection?
- B18c vaccum hose locations.... pics anyone
- pennzoil
- "no Spark"
- How Easily to save money on gas?
- D16 Vtec Swap
- Replacement cv axles
- anyone squeeze 13 steelies on DA brakes
- >>>>NEED HELP: JDM EF8/EF9 FOG LIGHT INSTALL<<<<
- Hasport Mounts
- Total noob.
- Water with spare tire... How to track this? CRX 90
- anyone ever made....
- DPFI STRUT BAR?
- Part list for ZC swap: Is this complete?
- a crx died in my heart today
- Car died on highway please help
- 86 Civic Si Problem. Where do I begin??
- need help
- spoolin log manifold on an ef8
- d series shit
- Question about v-tec
- what kind of dizzy on my 91 sohc zc?
- integra taillights on crx
- Shifter Bushing Help Please
- 91 civic si keeps blowing fuse #14
- mpfi swap question
- Strange "Power Loss"...TPS????
- b16 obdo ->obd0 vtec wiring problems pw0
- oil leak, crankshaft seal.
- Rapid clicking form Main relay.
- gripforce clutchs?
- wire tuck question
- burning a quart of oil a day!
- civic tturbo kit for the zx with water to air intercooler
- can someone tell me more about this cylinder head???
- tranny fluid help
- Rough running CRX hf
- B16 Bolt/Mount Question
- Weird sound
- NEED HELP!!!!!!!!!!!!!
- HALF RAD IN 1990 CRX WITH B16A
- o2 sensor hookup help.
- crx ac problem
- help
- need help 91 dx check engine light on and off
- What parts do i need for a 88 EF to SiR front end conversion?
- JDM HONDA ACURA INTEGRA Sir-G
- confusin @$$ B16A wiring. . . . . . .
- rx8 is it a threat to a crx
- ITR Floormats in a CRX?
- short / slim hub for EF?
- Whats the best throttle body to use for my mini me swap???
- Will a 92-95 Civic z6 fuel rail work on my a6 maifold?
- Installing b16 into si, wire harness question
- How do I check the difference in B16 Trannies?
- Front Bumper removal??
- I NEED HELP...BAD!!
- what the hell is going on????
- gen1 CRX D16A3 Fan
- please help. main relay,runing rich,and which distributer...
- cool car insurance comparision site
- tranny swap
- cam cap torque spec? help
- Ridiculous POWER LOSS
- EF Hatch with Integra center console?
- Lowbeams + Daytime Running Lights help
- bogging engine
- 90 Si w/LSVTEC shakes real bad under load.
- 97 integra conversion
- Are these the right ITB's
- Car won't start..any one know?
- my ecu hates me
- Obd 1 vtec solenoid work on obd0 motor?
- 91 civic si distributor and spindle replacement PLEASE HELP
- Engine info
- Si rims
- Which timing belt for SOHC ZC?
- Lip for usdm civic
- Accelerator Reset - Pedal is slow/sluggish to return to home (how to lube?)
- No Codes...
- b16a in crx dx
- d16a6 wont start
- map sensor help
- Radiator bracket
- how to replace distributor
- What sensor is this?
- vin status, please read this vin
- NEED HELP WITH THROTTLE BODY
- 89 dx hatchback rear disc conversion ???????
- Calling all VAFC owners
- 88>90 CRX Dash/ Inst Panel Swap Question
- LS VTEC problems
- wiring sucks
- Anybody rewire the door buzzer?
- Questions about Innovative front crossmember...
- clutch cable snapped
- Dashbord problems/ NO LIGHTS!!!!!!!
- Shortest possible Alternator belt for b16
- Need help with internal wiring!!!!
- tech ?, std hatch back?
- I NEED HELP?
- Autozone Blazer fogs on CRX? Cant find post on it....
- need to know: difference in weatherstripiing/moldings/garnish between 88(JDM) and 91 US doors.
- Alternator...need more amps
- d16 in ef
- Are blue corner lights legal? (in NY)
- Electrical problems with 90 Crx Si
- EXTERIOR: Where the hell can i find this?
- Need help EF guys!
- Has anyone ever put a S2000 start button in the CRX?
- if u have a bad cylinder position sensor will your car start??
- PARKING LIGHT WIRE!!! Where and what color under dash?
- megan parts...are they good???
- 04-05 civic gauge cluster in crx?
- DX misses, help me track down the problem..
- does anyone have an airmass header?
- New Clutch question
- cold air intake that works for d series and b series
- b16a first gen with bc spec three cams bogging problems
- Brake Calipers
- seat swap
- Overheating problem
- rear brake line
- D15 w/ pm6 ECU?
- engine rebuilding
- Civic starting problems
- lower ball joint HELP
- My son's pinewood derby car.
- Car won't start
- jus a little help
- Skunk2 Coilover kits and the spring rates.
- main relay diffreneces in dx and all other mpfi car's
- Rywire diagrams labeling plugs on the side of b16a (did search)
- QUESTION ON HEADLIGHTS<<<<<<<<<<<<<
- Removing A/C Clutch Relay, and Condenser Fan Relay from engine bay... ???
- rubber sleeve for intake
- 16 valve head question
- how much should it be?
- Camber kits.
- How to bend this...?
- gsr swaped crx need help
- r2 cable
- I NEED ADVICE
- Manifold Pics Requested..
- tranny issues getting it off
- help!
- differnt ride height for one wheel
- Can someone post a pic of there wires on the main relay....
- Fuel Filter Missing - HELP
- quick question
- Roc n pinion
- FREE 91 CRX SI Motor and Tranny!
- hx wheels-$200-is this an ok deal?
- Radiator and a Turbo in a CRX, Here's how! Lots of pics
- ALARM Install - Need Some Help - Ignition Wire Colors/ Parking Light Color / Stock Door Pin Q
- Different type of motor swap question...
- post a6 in b2 cam results
- CRX b16a with DC 4-1 header problems????
- Where to buy coilover perch locks??? Progess Group doesn't give support for old product.
- is it pre-ingnition?? I need Help
- What would you do????
- battery question on EF with swap LS
- my dash lights shut off after hitting a pothole wtf
- What axel with hydro trans?
- indications of a bad ecu?
- pics of my crx project
- ecu or injector?????
- guess its my turn
- CD Player Wire Colours - Who knows the colours?
- help on zc and d15b
