- ZC Vtec swap problems.
- Rear hatch key hole
- Swapped out my B18a1 for a B18B. Problems...........
- b16 obd0 IAT
- Help my brakes are acting up please help...
- wat size battery ?
- b18 engine swap helppppppp
- New swap
- Few Questions About Engine Removal. . Need Advice
- Help please. Brakelight and turn signal
- BATTERY LIGHT ON
- shiftyjm's 1991 EF STD Project
- Question 91 dx
- crx rear windshield ?
- Code 20 ELD (Electric load detector)
- i think i have a timing problem please help
- Can anybody show me pics of em1 center console in ef
- TPS install. help!!
- b16,b18 help
- apexi vafc2 question
- gsr intake manifold in ef
- My Ef sedan
- b18a crx major bog!!! help
- are ef8 crx doors the same as ef9 civic hatch
- Can't get secondary gear onto shaft
- Help removing rear wiper inside cover
- Need HELP with Suspension on a EF!! Please thanks
- D16A6 rough running after HG change
- Crx doesnt go fast enough..
- map sensor?
- D15b1 injectors??
- DOHC zc engines
- Transmission problem/noise
- ef sedan jdm fenders
- Sluggish Acceleration & Bad MPG
- Is this the horn wire?
- back up light, need help
- what this seem like?
- help!!! need advice on engines!
- Doing a B18A1 LS Swap
- 91 Civic DX 2-Dr Hatchback, 1.5L SOHC Engine Rough Idle Probs - PLEASE HELP !
- getting a higher compression ratio (b18a1)
- Clutch disc question??
- b18a1 swap
- *Pic request
- ?s about 89 wagovan rear diff RT-4wd
- 02 civic intake on a dpfi
- Paint LS mesh
- b18 axles really confusing help
- sohc shift linkage simularities?
- need help with the rex
- 91 dpfi crx
- A couple of ?'s about my 88 sedan/Please
- CRX idles weird then dies sometimes
- difference in 88-89 and 90-91 sedan interior?
- difference in 88-89 and 90-91 interior?
- crx fog lights
- HIGH IDLE!!!!!!!!
- honda crx B-series swap help
- D16 Webber Manifold conversion
- stock oem fan won't fit because of o2 sensor
- ecu code 7 problems
- DA aluminum radiator into ef?
- b16a boost build Questions
- b16a built to b16b specs?
- my FREE 88 hf build. (complete build)
- b18 motor mount question
- What all am i needing to put rear disc brakes on my ef?
- Gauge cluster has a mind of it's own??
- honda hx wheels
- Are all d16 clutch & flywheels the same?
- UK/JDM H22A7 CRX Track Rebuild
- Performance Options - 91 Civic DX Hatch, 1.5L SOHC
- Fuel or Ignition Problem?
- 91 CRX dies randomly
- Window issues..Need help before the rain!!!
- Need EF Help
- NRG Lock?
- ls swap question (not a repeated one trust me)
- Greetings from Costa Rica
- 1" to 15/16 adaptor-master cylinder problem
- Which would you choose
- Gas smell
- need helppp!!
- 1991 civic d15b2
- BB/MC Replacement help
- ► ► for sale / would like to buy 88-91 crx/civic parts only ► ►
- Intermittent sputter/hesitation
- need help about headlights and map sensor!
- EF9 MIDWING??
- headlight adjustment 1991 civic hb
- Need help
- Engine wont stay running
- EF inner/outer tie rod help
- Question about Loose Wire
- KSport LCAs, how are you guys mounting your sway bar?
- Help with B16 CEL
- Steering Wheel Shake
- obd1 B16 CRX Issues
- Steering Wheel Removal
- 1991 si parts in a 89 hf Compatability
- Using OBD1 Intake Manifold w/ OBD0
- People running Skunk2 FRONT camber kit.
- Real deal JDM CR-X Si (ZC) spec's
- EF civic sedan auto to manual conversion.
- OBD1 D15B VTEC into 91 EF OBD0
- converting obd0 distribuitor to obd1
- 91 crx. help me out need some advice
- My 88 Sedan Build
- what is this ad why does it cost as much as my car?
- 88 Sedan/ Need to find intake for it
- 1991 EF SI Interior ?
- crx suspension
- CARBON
- A couple questions about the fuel pump.
- Circuit Hero: Shift Lever Extender
- Crower Cam w/ Stock valves and springs?
- isn't it illegals to have tires from japan /china??
- B-series Swap Wiring?
- 5 speed tranny problems
- ef turbo z6 runing rough
- any one ever have issues w password jdm front bar w da brakes
- Function form type 1 wont go low on my 90 hatch?
- Need Help for a CLutch problem
- d16a6
- Help I Made a mistake. PICs
- Fpr gauge install
- D16A6.. TIMING
- Dx/Std harness questions
- need help on samping my wifes 1990 automatic civic sedan
- what you think about turbo cam?
- EF Civic Sedan light mod
- does anyone know of?
- I need help on this problem i got with my distributer
- crx rear interior panels question
- should i use them?
- SHES ALIVE!!!!!
- Mount bracket tearing off of Frame: Common?
- please help.. b16a problems
- dpfi obd0 - d16z6 ecu pin issues
- da axles in an ef
- EF D15B2 Swap Help
- 88-91 CRX rear hatch window removal?
- Glass top vs. Sunroof top vs Metal top weights
- just got a new clutch but I think its wrong!!
- 90 crx keeps cutting out
- '89 RT 4WD Wagaon operates in RWD only
- 6 SHOCK's on a ef ???!!!!
- Clock testing?
- Header clearance?
- 1990 Honda Civic EX Sedan popping noise from drivers side
- quick question about ecu's
- Vin trouble. Need help
- rear auto and manual cross member.
- EF/DA parts interchangeable?
- brake upgrade integra to civic
- Racing harness in 91 CRX DX?
- Hey guys really need your help my ef sedans running like crap!!!!
- oem part numbers?
- Codes 1 and 7... Limp mode :(((
- Gana take out a/c box question!
- Need electrical help: Battery dies
- All Motor D16.
- Unknown plug behind dash
- Cruise Control!!
- Help - DRL and Gauge Lights not working
- need some help...
- braking problem help?
- My ef project
- 89' SI rotor button Screw, HELP I LOST IT!
- Ecu chipping question
- what might be decent with skunk2 shocks?
- Trade Question
- Do ef hatch backseats fit sedan bckseats
- extended top hats?
- EF Acting up
- HELP WITH GSR BRAKE SWAP ON MY EF***
- My new to me real EF9
- just got a alignment done
- which motor should i go with?
- Bad Ecu???
- Battery cluster light- related to no start
- How the hell do you adjust the IACV without stripping the bolt?
- HELP!!! Vibration Under Acceleration
- wiring harness
- Rescue Mission: Parts and optional equipment at the wrecker's
- LS in ef probs. need help
- Removing CRX Radiator
- d series turbo setup with fullsize alum. radiator?
- Function and Form Type 1's
- ETD radiator or full race radiator
- hi
- NOOBIE Question!
- How to remove Climate control cables?
- indicator light for engine fan...????
- ARRGGGG!!! CRX broken into twice in 3 weeks!!!
- OBD1 Injectors with DPFI-->MPFI Swap
- Wheel Hub Size
- JDM is the new RICE!
- GSR mount question
- Where can i find OEM tail lights?
- spark + fuel + timing but still wont start
- Saving The Sedan!
- D16a6 hesitates/misses after adding bolt-ons (NOT DIZZY)
- swap questions f22 into 88 hatch
- Joining the club
- EF swap
- Dizzy Question
- ef j syap possible yes!!!
- rsx seats fitment
- Fog lights?
- D15B2 heating problem. HELP!
- how much power??
- What's up?
- ignition is stuck
- fuel problems !!!!!! help
- which axle to use
- Strange D-Series Combo Question
- HELP HELP 88 crx with an 87 integra d16a1 swap what mount do i use on the driver side
- 91 civic si window molding removal??
- My new 90' civic DD
- has anyone?
- OBD1 B16 CRX Alternator Belt Question
- non oem sunroof on sedan leaks!!!!help!asap
- ELD
- D16Z6 in CRX HF Help,
- my crx clutch pedal
- Light issues
- spark plugs!!!!!!!!!!! help
- whats the difference between a short ram intake or a cold air?
- need shift linkage length stock d series.
- Requesting Window Visors From Weathertech.com
- ODB1 pinout D1 important?
- d16z6 eng and trans in a ef hatch
- center console help
- EF swap to B18B obd0
- Older CRX's
- What color is factory '88 trans fluid?
- No start crx b16 i got fuel and spark.....
- ef8 jdm fog light install
- Electrical Issue with Brake Lights
- If i have a D15B1 block does that mean...
- Why TPS set at.73volts?
- i think my main relay is dead not sure help!
- i need help with my 91 si cluster!
- 87 crx si wont start...
- Electrical prblem....now car won't Start
- mutli port conversion issues code 4????
- bosch 02 sensor wiring
