b18 swap and car doesn't have any power
i have a B18 gsr engine in my 99SIcoupe, what could be robbing my car of horsepower or what could i do to get out all that potential? it doesn't even spin in 1st gear.
could a bad O2 sensor be doing that?
Re: b18 swap and car doesn't have any power (1REDGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1REDGSR1 »</TD></TR><TR><TD CLASS="quote"> it doesn't even spin in 1st gear.</TD></TR></TABLE>
Weird way of gauging the power output. ::shrugs::
Is it possible the clutch is slipping?
1 Post
Re: b18 swap and car doesn't have any power (e jay one)
timing! check your ignition timing. My car ran like **** and had no power when i had just put the dizzy on and had not set the ignition timing.
Re: b18 swap and car doesn't have any power (underachiever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underachiever »</TD></TR><TR><TD CLASS="quote">Weird way of gauging the power output. ::shrugs::
Is it possible the clutch is slipping?</TD></TR></TABLE>
well a SI could spin in 1st..... and i put a new clutch in.
any car can spin em in 1st.. my old vw fox would roach em in 1st..
:shakes head:
dont consider it lose of power consider it as ur gettin good traction.....
:shakes head:
i have a gsr in mine and it never spun em in first until i put the skunk2 manifold on it, check the intake manifold for oil, when the company i bought mine from shipped it they tilted it and oil ran into the throttle bodie and intake
Yeah I would recommend checking the timing. It's pretty easy to do. When I changed a head gasket I started the car before getting the timing straight and it just sounded weak, although I never drove it like that.
Multi-paradigm
Re: (B16aDasher)
how can it not spin up your tires? Are you expecting your tires to spin when you floor it from a rolling start in 1st gear? your stock GSR in your coupe...let alone an SI coupe...won't spin your tires this way unless you have shitty tires.
do a compression check or do a dyno run. or both.
Re: (Screwtape:)
I didn't no a car had real power cause it can chirp tires... damn i shoulda keep my dx motor cause i could catch 2nd sometimes just a little am humor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1REDGSR1 »</TD></TR><TR><TD CLASS="quote">i have a B18 gsr engine in my 99SIcoupe, what could be robbing my car of horsepower or what could i do to get out all that potential? it doesn't even spin in 1st gear.
could a bad O2 sensor be doing that?</TD></TR></TABLE>
No comment
No comment
RsxType-Stitch
16
09-07-2005 07:52 PM
